1 Reply Latest reply on Sep 27, 2012 9:32 AM by Raghu Nagireddy
    authentication failed in rest service
    Ravi-Kant
      Hi All,
           I have created a small process in workbench, when i am trying to access it through url. It is asking me for the user name and password. So i entered my default user name and password  (administrator/password), but authentication is failed.
      So i am wondring which username and password i have to use.
      I am using workbench ES3
        • 1. Re: authentication failed in rest service
          Raghu Nagireddy Level 3
          Supply same login credentials what used to login to workbench/adminui, it should work. Also you can skip the authentication step by follwing the below steps on adminui after login: (These ateps on LiveCycle ES2)
          1. Browse to the service (Home > Services > Applications and Services > Service Management) and select the service/process
          2. Go the security TAB and select "NO" to "Require callers to authenticate:" also select "Run As:" to "System" then save.
          3. Try the url, it should skip the authentication step.
