4 Replies Latest reply on Apr 8, 2013 6:04 PM by Karl Heinz Kremer
    No Internet Connection to Server
    wlxsf
      When I try to use a Template, I received the following message "No Internet Connection to Server"?
      But my internet works perfectly as I'm able to post here.
      Full message is:
      You must be connected to the internet to edit or view an online form.  Please check your internet connection and try again.
      Thanks for your help
        • 1. Re: No Internet Connection to Server
          rdolgov Adobe Employee
          Sorry you're having trouble.
          Do you still see the problem? I've tried just now and cannot reproduce the issue. If you still see the problem can tell me what template you are trying to use.
          Roman
          • 2. Re: No Internet Connection to Server
            Karl Heinz Kremer Adobe Community Professional
            Hi Roman,
            I am having the same problem: My Internet is working fine (I am typing this so it must be working ), but whenever I launch FormsCentral I get the same message - this is right when I start the application, before I can do anything. I can work locally, but clicking on the Retry button won't do anything.
            When I tried to launch the application this morning, it reported that an update was available, and it did install the update. The "no connection" problem did not go away however.
            Let me know if you need more information to debug this problem.
            Karl Heinz Kremer
            PDF Acrobatics Without a Net
            PDF Software Development, Training and More...
            http://www.khkonsulting.com
            • 3. Re: No Internet Connection to Server
              Hi Karl,
              I assume you are working with FormsCentral (standalone) application bundled with Acrobat (and not with online version accessed via https://formscentral.acrobat.com), right?
              Did you try to sign-in again once you in local mode? You can do it via menu in the top-right corner "Sign In", can you please try it and let me know the result.
              (I suspect that maybe something wrong with "remember me" token that is used to automatically sign-in on the application launch, so by manual Sign In this token should be updated, which may help).
              Roman
              • 4. Re: No Internet Connection to Server
                Hi Roman,
                you probably identified the problem correctly - I was not logged in, and
                when I tried to actually "distribute" the form, the desktop application
                prompted me for my password, and from that point on, I actually was able to
                see the uploaded form.
                Karl Heinz Kremer
                khk@khk.net
