3 Replies Latest reply: Sep 21, 2012 7:13 PM by RodWard RSS
    Captivate 6 functionality and flash version
    radrave Community Member
      Are there any features of captivate 6 that will not work or function properly when published to flash player 10 or 10.2? A client with a large worldwide workforce is loathe to upgrade just for the sake or L&D.
        • 1. Re: Captivate 6 functionality and flash version
          Anjaneai Srivastava Adobe Employee
          Hi!
          Captivate 6 output can be viewed on a web browser that is compatible with Flash Player 9 or higher.
          So, that should not be a problem, unless you have used any custom Widget, that is created specifically for Flash Player 10 or 11, you should be able to continue with this.
          Anjaneai
          • 2. Re: Captivate 6 functionality and flash version
            I have a developer that is claiming he experienced "playbar quirks" with a file published from captivate 6  that he was not experiencing with files produced from 5.5. He says that upgrading to the latest version solved these quirks. I'll try to get more detailed information from him, but you are telling me that there are no features  or bugs that are new in 6 that will not work properly if project is published out to Flash version 10 or 10.2?
            • 3. Re: Captivate 6 functionality and flash version
              RodWard CommunityMVP
              If these are projects created in a version earlier than Cp6 and then upgraded, there is a strong possibility that using components such as skins, playbars, preloaders, or widgets from earlier versions will cause issues.
              So tell your developer to remove the current skin and playbar he is using and replace it with one that came with Captivate 6.  See if that resolves the issue.
