0 Replies Latest reply on Sep 21, 2012 11:15 AM by ScottB424
    ASDoc error - Type was not found or was not a compile-time constant: File
    ScottB424
      I am using Flash Builder 4.6 to export ASdoc files. It publishes correctly, but I am receiving errors for the following files while attempting to export ASDoc documentation:
      Error: Type was not found or was not a compile-time constant: File.
      Error: Type was not found or was not a compile-time constant: FileStream.
      I have checked Project -> Properties -> Actionscript Build Path and everything seems to be there.
      ${FLASHPRO_APPCONFIG}\ActionScript 3.0\libs
      applicationupdater_ui.swc - C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\frameworks\libs\air\applicationupdater_ui.swc
      framework.swc - C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\frameworks\libs\framework.swc
      textLayout.swc - C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\frameworks\libs\textLayout.swc
      framework_rb.swc - C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\frameworks\locale\en_US\framework_rb.swc
      Flex 4.6.0 - C:\Program Files (x86)\Adobe\Adobe Flash Builder 4.6\sdks\4.6.0\
      airglobal.swc - ${FLASHPRO_APPCONFIG}\ActionScript 3.0\AIR2.5\airglobal.swc
      These are the ASDoc arguments I am running in Flashbuilder:
      -source-path "C:\MSD\curriculum\activityTracker2.1\development"
      -doc-sources "com\connectionsEducation\activityTracker"
      -output Documentation
      -library-path+=activityTracker.swc
      -exclude-classes
      -define+=CONFIG::COMPILE_FOR_AIR,true
      -define+=CONFIG::COMPILE_FOR_BROWSERS,false
      -main-title "Activity Tracker - API Documentation"
      -window-title "Activity Tracker Documentation"
      -strict=false
      -exclude-dependencies=false
      Is this just a bug that occurs when exporting air documentation?
