2 Replies Latest reply on Sep 21, 2012 2:30 PM by LandonFriesen1444
    Premiere Pro Debug Event trackitemgroup
    LandonFriesen1444
      In Premiere Pro 5.5, I get a Premiere Pro Debug Event ending in "trackitemgroup.h-2" that crashes the program every time the project is opened.  Premiere will open other projects/create new projects, and importing the sequence and media into a new folder will bring up the same error, but won't always cause a crash.
      Thank you for any help
        • 1. Re: Premiere Pro Debug Event trackitemgroup
          the_wine_snob Level 9
          Do not recall reading of that particular error message.
          A couple of tests, to rule out a problem possibly with the Project itself, or with the Assets in that Project:
          1. Import that troublesome Project into a New Project, rather than use Open Project.
          2. Move the Assets (might be easy, or not, depending on your folder structure), and Open that Project. PrPro will/should ask, "Where is file ____ ?" Use the Finder dialog to locate the Assets (having them in smaller groups in separate folders might be helpful here) and re-link them. If the Project crashes on certain Assets, then you have narrowed things down greatly.
          Maybe others WILL recognize the error, and have other, more direct suggestions for you.
          • 2. Re: Premiere Pro Debug Event trackitemgroup
            LandonFriesen1444 Level 1
            Thanks for the quick reply.
            I basically did what you suggested, and didn't explain very clearly; created a new project file, imported the assets into that project, and then imported the original sequence. When I opened the original sequence (in the new project), all of the video showed up correctly, but I got the same error; the difference was, this time it didn't completely crash Premiere. I could just click OK and continue with the project (had to repeat that process a couple of times, but the project stayed open).
            More details: this was a day-turn local news package, video shot on a Sony NX5U, reporter voice track recorded as a .wav file. This is the same workflow we've used for 6 months, and I've never run into this issue. Like I said, new projects with the same workflow are fine. I guess I could try playing each file in the timeline one at a time and see if one of them is having issues, but in the course of trying a few, they seem to be fine.
