0 Replies Latest reply on Sep 22, 2012 9:42 PM by prsolucoes
    Make the particle as same angle of object
    prsolucoes Level 1
      How to make the particle tail follow the ball rotation.
      In my example, here:
      http://www.prsolucoes.com/ioarena
      Whats the calc on update?
      I made it today in cannon class (particle is a object inside cannon):
      if (particles)
          particles.emitAngle = Util.radiansToDegrees(rotation);
      But doesnt works well as you see on link [up].
      After some tests, i discover that i dont need set the rotation/angle on every update, i need set it only one time when construct the particles.
      Example (change rotation instead of emitAngle):
      if (particles)
                particles.rotation = rotation; // second rotation property is from cannon
      Whats wrong? Is not the same rotation?
      My fire.pex file only for consult if need:
      <particleEmitterConfig>
        <texture name="fire.png"/>
        <sourcePosition x="0.00" y="0.00"/>
        <sourcePositionVariance x="0.00" y="0.00"/>
        <speed value="100.00"/>
        <speedVariance value="30.00"/>
        <particleLifeSpan value="1.96"/>
        <particleLifespanVariance value="1.9000"/>
        <angle value="0.00"/>
        <angleVariance value="0"/>
        <gravity x="0.00" y="0.00"/>
        <radialAcceleration value="0.00"/>
        <tangentialAcceleration value="0.00"/>
        <radialAccelVariance value="0.00"/>
        <tangentialAccelVariance value="0.00"/>
        <startColor red="1" green="1" blue="1" alpha="0.62"/>
        <startColorVariance red="0.00" green="0.00" blue="0.00" alpha="0.00"/>
        <finishColor red="1.00" green="0.31" blue="0.00" alpha="0.00"/>
        <finishColorVariance red="0.00" green="0.00" blue="0.00" alpha="0.00"/>
        <maxParticles value="100.00"/>
        <startParticleSize value="9.28"/>
        <startParticleSizeVariance value="49.53"/>
        <finishParticleSize value="10.00"/>
        <FinishParticleSizeVariance value="5.00"/>
        <duration value="-1.00"/>
        <emitterType value="0"/>
        <maxRadius value="100.00"/>
        <maxRadiusVariance value="0.00"/>
        <minRadius value="0.00"/>
        <rotatePerSecond value="0.00"/>
        <rotatePerSecondVariance value="0.00"/>
        <blendFuncSource value="770"/>
        <blendFuncDestination value="1"/>
        <rotationStart value="0.00"/>
        <rotationStartVariance value="0.00"/>
        <rotationEnd value="0.00"/>
        <rotationEndVariance value="0.00"/>
      </particleEmitterConfig>
      Thanks for any help
