3 Replies Latest reply on Feb 21, 2008 5:26 PM by ntsiii
    Functions
    jefflemon
      I want to call a service from within a function, but this doesnt seem to work:
      private function resultHandler(evt:ResultEvent):void
      myservice.getOperation('userloggedin').send();
      Also, is there anyway to call two methods from one myservice.getOperation('userloggedin').send();????
        • 1. Re: Functions
          Level 1
          Are you trying to pass the return value from "getOperation"??
          if so just add the var as a node in your service tag and bind it to the result
          then just do
          myservice.send();
          • 2. Re: Functions
            jefflemon Level 1
            No, I want to call two services at once, so atm I am calling one and in the result handler, trying to call the other.... how can i do this?
            • 3. Re: Functions
              ntsiii Level 3
              I think you are just not using the right syntax for the webservice operation.
              Calling a webservice operation form a function is a normal thing to do. The syntax depends on the wsdl.
              Tracy
