What are error codes U44M1U5, U44M1P210 and U44M1U15?
My Adobe Application Manager was trying to install updates to my products this evening but failed, returning these codes in the Error Log.
Thanks.
-Ro
Download the updates manually from the Adobe site and install them. if that doesn't work, you will have to uninstall the products and reinstall everything from scratch.
Mylenium
The same thing happened during my update. I see a reply to your post that updates must be downloaded manually and/or the whole installation process repeated. That is unacceptable. I have an duly authorized product. Adobe should sort the issue out and provide us with a workable update process.
I have the same problem. Tried to update 10.1 to 10.4 but it said it couldn't do it as ProX components had changed and I should reinstall. Did that using AAM, ProX then booted again as 10.1 but said there was a configuration error, Error: 1. Tried to uninstall again but then AAM insists ProX is installed. No chance to reinstall!
And now Photoshop tells me 'files in Adobe App Support are missing, please reinstall'.
One thing I'm suspicious of is a line on the uninstall window which was checked, something about Suite - should I have unchecked it?
Can Time Machine help?
I'm seeing this as well on Mac OS X when using CS6 packaged with AAMEE. Updates were working earlier this month, but now seem to error out. I Spent 2 hours fighting with adobe's phone support system and got nowhere.... Uninstalling/reinstalling doesn't resolve this issue for me. I'm not looking forward to telling users they have to download the updates manually.
FlashTemp0.html:
Adobe Media Encoder CS6 6.0.2 Update
There was an error installing this update. Please quit and try again later. Error Code: U44M1U15
DPS Desktop Tools CS6 2.04.1 Update
Dreamweaver CS6 12.0.1 update to address critical issues
Adobe Extension Manager CS6 Update
Photoshop Camera Raw 7.1
Photoshop 13.0.1 update for Photoshop CS6 and Photoshop CS6 Extended
Adobe Bridge CS6 5.0.1 Update
Flash Pro CS6 update 2
There was an error installing this update. Please quit and try again later. Error Code: U44M1U41
Adobe CSXS InfrastructureCS6
Does this problem have anything to do with the latest adobe certificates hack?
Anyway, I also reinstalled WINDOWS from scratch and nothing helped!!!
WTF??? are they from Adobe sleeping or something?
I saw mention of an Adobe CS Cleaner Tool on a forum, downloaded, ran it after uninstalls and reinstalled everything, touch wood it seems to have sorted the problem out. I'm running 10.8.1 on a Mac mini.
OK, but this has nothing to do with it in my case -- I reinstalled Windows, and the errors persist!
If you are still continuing to experience difficulties then I would recommend reviewing the installation logs for the unapplied updates. You can find steps on how to accomplish this at Troubleshoot with install logs | CS5, CS5.5, CS6 - http://helpx.adobe.com/creative-suite/kb/troubleshoot-install-logs-cs5-cs5.html.
POSSIBLE WORKAROUND:
I had the same issue using the Adobe Application Manager with my Cloud account. I noticed that every time I would run an update, one thing would update and everything else gave the error. So, I ran it over and over and over and over till most everything was updated, one at a time. Not extremely efficient, but it worked for most everything.
The last 4 updates wouldn't install...
