2 Replies Latest reply on Sep 25, 2012 2:49 AM by loulou2003
    Unthread text frames indesign
    loulou2003
      hi
      i develop an indesign extension with CS extension builder 2 and flashbuilder 4.6.
      how to unthread text frames ? i don't find any method or property in textframe class...
      thanks
      Simon
        • 1. Re: Unthread text frames indesign
          emerasoft.srl Level 1
          The property you should have to look for is "nextTextFrame"; set it to "null".
          Best,
          Luca
          • 2. Re: Unthread text frames indesign
            loulou2003 Level 1
            hi
            thanks for your reply but it doesn't work because i want to keep the text in all textframe. I found a solution in 2 time duplic and remove :
            function unstory(qui:Document){
              for each(var stori in qui.stories){
               if(stori.textContainers.length>1){
              duplic(stori);
              remov(stori);
            function duplic(myStory){
                                          var myTextFrame;
                                          //Duplicate each text frame in the story.
                                          for(var myCounter = myStory.textContainers.length-1; myCounter >= 0; myCounter --){
                                                    myTextFrame = myStory.textContainers[myCounter];
                                                    myTextFrame.duplicate();
            function remov(myStory){
                                          //Remove each text frame in the story. Iterate backwards to avoid invalid references.
                                                    myStory.textContainers[myCounter].remove();
