In RH9, using Source Control 3.1.
Trying to bring in topics from several other projects. Somehow, we have managed to get all the files we want into the project as displayed in
RoboSource
Windows Explorer
But when each of us tries to open the project in RH9, none of us can see the topics we brought in from the other projects. Upon doing some research here in the forums, we opened a few fpj files in these folders and saw that they are scrambled.
There are dozens of these folders, we would prefer not to have to edit them manually.
So, long story long, is it safe to delete them - will they rebuild when the project is reopened?
Hi there
When you create a folder in RoboHelp, the FPJ is part of the XML structure used by RoboHelp to manage and track topics. I would think RoboHelp will become awfully confused and project corruption will ensue if you start deleting FPJ files.
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7, 8 or 9 within the day! |
Hi there
Cheers... Rick
yeah, I tested it anyway in a copy, and the destruction was wonton and wide-spread. So, I have been editing the fpj files manually - easy, but tedious in a very branch-y file structure. Too bad there isn't a reindexing utility that could just reinventory all the contents of a folder and reupdate the fpj files. But we are pressing on - one domino down, many more to go!
Like Rick said doing that would cause confusion.
Because RoboHelp maps references for each topic/htm file in FPJ file. So, assuming a Folder A has ten topics, FPJ inside A would have XML structure for all 10 topics, if FPJ is removed from A, in Robohelp Project manager, you would not see any any topic listed, even though it would be there at source.
Anjaneai
