0 Replies Latest reply on Sep 25, 2012 10:28 AM by elPerea
    Problem with custom IncorrectEventHandlerNameRule
    elPerea Level 1
      Hello, I'm usin the eclipse-plugin, and I just have a problem with the IncorrectEventHandlerName
      I want that the name's function have this format:
      onXxxxxxHandler
      So, I created a custom ruleset and modified the IncorrectEventHandlerNameRule like this:
        <rule since="" class="com.adobe.ac.pmd.rules.naming.IncorrectEventHandlerNameRule" message="This event handler name ({0}) is not correct. You should use [{1}] as prefix and [{2}] as suffix">
          <description/>
          <priority>5</priority>
          <properties>
            <property name="prefix">
              <value>on</value>
            </property>
            <property name="suffix">
              <value>Handler</value>
            </property>
          </properties>
        </rule>
      But it seems that the rule doesn't use those properties when I run FlexPmd again the rule msg shows the default values (prefix="on" suffix="").
      Does anybody know what's wrong?
