0 Replies Latest reply on Sep 25, 2012 3:34 PM by code_away
    Compiling producing inconsistent SWF and causes errors with embedded PNGs/GIFs
    code_away Level 1
      I'm not sure if this question is better asked in this forum than here: http://forums.adobe.com/message/4685405
      In short, whenever I compile and run my Flex project, sometimes the SWF throws the following error or similar:
      Error:
      ReferenceError: Error #1065: Variable ItemDetails__embed_mxml_assets_printer_gif_1274103970 is not defined.
                at ItemDetails()
                at mx.managers::PopUpManagerImpl/createPopUp()
                at mx.managers::PopUpManager$/createPopUp()
                at MyProject/btnPrintClick()
                at MyProject/__btnPrint
      I thought is was related to the image but it's not and rather simply recompiling may cause it to work the next time. It seems sometimes images are left out and other times included. The error only shows for icons in my popup window and not the main app. I'm converted my Flex 3 app to Flex 4, so it uses the legacy MX tags. I compile to 4.5.1a. I'm using FB 4.6 on Mac OS.
      The closest I've found to an explanation is this: http://kachurovskiy.com/2010/storing-icons-in-external-zip-and-seamless-work-with-composit e-icons/
      Please advise.
      code_away
