1 Reply Latest reply on Sep 25, 2012 2:52 PM by conroy
    two adjustment layer in two different grups
    steenmikkelsen2 Level 1
      Hello
      I have a problem with my layers which I can not figure out how to solve.
      see picture:
      I have a group called: "Hele akvarier" " where I have used "Create new fill adjustment layer" - "Brightness / Contrast" to the layers which are under.
      (Layer 2, Original Copy, Original).
      Over is there are two layers named "Layer 3, Layer 1". These layers, I also need to  use the "Brightness / Contrast" to they're going to look right, but the top "adjustment layer" affects all the layers under.
      How do I get my layers divided into two groups, each with its "adjustment layer" to use each with its own settings?
        • 1. Re: two adjustment layer in two different grups
          conroy Level 5
          Put Layer 1, Layer 3 and the top Brightness/Contrast layer in a new Group. The Group will have a default blending mode of Passthrough which will still allow the Brightness/Contrast to affect the image below the Group. Change the Group's blending mode to Normal to limit the Brightness/Contrast effect to the lower layers inside the Group.
          Similarly, change the blending mode of "Hele akvarier" to Normal to limit its Brightness/Contrast to the lower layers inside the Group.
