1. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 2:18 AM (in response to Niamh_Doyle)I wonder if it would be worth uninstalling and reinstalling the SVN plugin. Chances are that the RH10 update has disturbed something somewhere.
2. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 2:30 AM (in response to RoboColum(n))Hi there,
We don't use an SVN plug-in for our version control. All our version control is using Subversion outside of RoboHelp. This has worked fine in previous versions of RoboHelp - but now it seems to have a problem seeing the added files.
Thanks a lot,
Niamh
3. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 2:42 AM (in response to Niamh_Doyle)Try creating a new RH project, committing that to SVN and getting your colleague to do an SVN Update. Can she see the project's topics then?
4. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 2:44 AM (in response to RoboColum(n))Something else to try is to take a copy of the three added topics and then manually delete them from your local source repository. What happens if you then do an SVN Update. Do you see the same behaviour?
5. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 3:11 AM (in response to RoboColum(n))The same issue occurs if we create a new project which contains two topics. When my colleague updates and opens the project, she can see the two topics fine - but when she adds a new topic to the project and commits it, and I then update, I get the red X beside her new topic.
6. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 3:16 AM (in response to RoboColum(n))The same behaviour occurs in this case too I'm afraid
7. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 3:33 AM (in response to Niamh_Doyle)OK. At least the behaviour is consistent between users so we've established it is not an individual setup issue. Did you check the SVN icon on the three topics after you committed to ensure they were updated to the green tick. Also can you check the SVN repository to ensure three files are OK there. Open up each of the files in turn and check them.
Another hunch. Is the project's .cpd file included in the SVN repository? If so, it maybe worth doing an SVN Ignore on this and ensuring you have both deleted the .CPD file before opening the project.
8. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 3:38 AM (in response to RoboColum(n))Yes, the three topics are updated with green tick.
We already have the following files set to ignore:
cpd
hhp
pss
SSL folder and ssl files
eHlpDhtm.js
Ldb
$rhvariable$.htm
9. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 3:53 AM (in response to Niamh_Doyle)Thanks for confirming that Niamh. I just wanted to check all bases. I think the best course of action is for me to try exactly what you have done. I have access to RH10 here (home) but not SVN. I will however have access to both tomorrow. Can you give me until then and I will let you know how I get on.
In the meantime you can always import any added topics. It would also be worthwhile knowing if you get the same problem if you rename / delete topics and then commit.
10. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 3:57 AM (in response to RoboColum(n))Thanks for your help,
That would be great if you could check it out. We are actually getting the same problem with renaming topics but so far not with deleting topics.
11. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 4:07 AM (in response to Niamh_Doyle)Just to add - I created a new project on the network, outside of SVN (ie. I did not add or commit it to SVN) and we do not have the same problem. So it definitely relates to how RH 10 works with SVN.
12. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 4:08 AM (in response to Niamh_Doyle)No problem. I'll let you know how I get on tomorrow.
13. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 4:11 AM (in response to RoboColum(n))Whoa! You mentioned "network". Would you have all your RH source located on a network drive? If so, that could well be the issue. I know that RH10 says that you can now store your projects on a network drive but I would still strongly advise against that. If you have your source on a network drive, try moving it to a local drive and try again.
14. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 26, 2012 5:11 AM (in response to RoboColum(n))we pull the files from a server down to our local drives when we check the files out - I only saved a new project to the network to test it outside of SVN
15. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 26, 2012 5:21 AM (in response to Niamh_Doyle)Sorry. Just checking
16. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 27, 2012 1:56 AM (in response to RoboColum(n))Hi there,
Just to follow up - our tools department is convinced that this must be a problem with RH rather than SVN as SVN seems to be doing what it should. So we are really quite lost! Do you know if it's possible to reinstall RoboHelp 9? Could that be a solution?
The Import/Restore option doesn't work in the case where a team member creates a new file inside a new directory in the project manager. In this case, RoboHelp doesn't seem to be able to pick up the new directory after the SVN commit and update - and so it can't find the file at all. Restore and import do work, however, where a new file is added at root level or in an existing folder.
17. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 27, 2012 2:21 AM (in response to Niamh_Doyle)We have just discovered something - if we delete the cpd file before opening the project, this seems to resolve the issue. We each already have the cpd file set to ignore, but actually hitting the delete key before opening the project seems to correct the issue. (not an SVN > Delete operation, simply a keyboard delete).
Could this be the answer? Is there some way to tell RoboHelp to automatically delete the cpd file each time you open a project?
18. Re: RoboHelp 10 - SVN Issue
RoboColum(n) Sep 27, 2012 2:41 AM (in response to Niamh_Doyle)There sure is. Check out this post. It refers to RH8 but it still applies.
19. Re: RoboHelp 10 - SVN Issue
Niamh_Doyle Sep 27, 2012 2:44 AM (in response to RoboColum(n))then I think we have our answer. I might need a drink after all this thanks for your help!
20. Re: RoboHelp 10 - SVN Issue
Larisa D Jun 5, 2014 5:45 AM (in response to RoboColum(n))Wondering where this link went, since we are trying to iron out some SVN source control issues
