3 Replies Latest reply on Sep 26, 2012 12:48 PM by Kevin Parrott
    CS5 error ? Applescript corner effect
    JC6259 Level 1
      Hello to all
      I am using a CS2 applescript under CS5 using the compatibility feature version script preference 4.0. Indesign CS5 does not accept the following property when drawing a rectangle
      "corner effect: rounded corner"
      I got the syntax error : Expected “,” or “}” but found identifier.
      This script works fine when used under CS2.
      How is it possible to fix this problem?
      Jean-Claude
        • 1. Re: CS5 error ? Applescript corner effect
          Muppet Mark Level 5
          Corner effect is now a list {} in AppleScript as of CS5 it's possible to set each with differing properties…
          • 2. Re: CS5 error ? Applescript corner effect
            JC6259 Level 1
            Hello Muppet Mark
            Thank you for your answer, but changing in a list does not fix the problem, it seems that the word "effect" is not recognized.
            set propSS_rond to {corner effect:{rounded corner,rounded corner,rounded corner,rounded corner}, corner radius:5, geometric bounds:{}, fill color:FILL, fill tint:FILL_TINT, stroke weight:1, stroke color:STROKE, stroke tint:STROKE_TINT}
            If I used the CS5 applescript language as "bottom right corner option", this time it is not recognized as I am working in CS2 compatibility.
            Best regards
            Jean-Claude
            • 3. Re: CS5 error ? Applescript corner effect
              Kevin Parrott Level 2
              hi
              from memory this worked in cs5, and cs5.5
              tell application "Adobe InDesign CS6"
                  set myDocument to active document
                  tell myDocument
                      set myRectangle_1 to make rectangle with properties {geometric bounds:{0, 0, 45, 90}, label:"Window"}
                      set {w, x, y, z} to geometric bounds of myRectangle_1
                      move myRectangle_1 by {(w + 20), 55} -- Window Position --
                      set stroke weight of myRectangle_1 to 0.25
                      set the fill color of myRectangle_1 to swatch "None" of myDocument
                      tell myRectangle_1
                          convert shape given convert to rounded rectangle
                      end tell
                  end tell
              end tell
