1 Reply Latest reply on Sep 26, 2012 8:24 PM by Sham HC
    Problems while getting the Datasource from a Utill class
    chamila.fernando
      Hi all,
      I faced a problem when following below instructions.
      http://dev.day.com/content/kb/home/cq5/Development/HowToConfigureSlingDatasource.html
      It would not return from the getDataSource(dataSourceName); call. No exceptions.
      public DataSource getDataSource(String dataSourceName) {
              DataSource dataSource = null;
              try {
               log.info("Reaches here ! ");
                  dataSource = (DataSource) dataSourceService
                          .getDataSource(dataSourceName);
              log.info("Never Reaches here ! ");
              } catch (DataSourceNotFoundException e) {
                  log.error("Unable to find datasource {}.", dataSourceName, e);
              return dataSource;
      I can connect to db directly from post.POST.jsp so DB is correctly mapped.
      I had to remove below annotation since while compiling the bundle, it says that it is deprecated.
           @scr.component immediate="true" metatype="no"
      Log is as follows...
      com.day.cqwebsite.impl.DatasourceUtilImpl -------------------------------------------- Using DataSourcePool service lookup to get connection pool mynewdsname
      26.09.2012 17:49:30.197 *INFO* [0:0:0:0:0:0:0:1 [1348661970143] POST /content/mywebsite_cq/en/toolbar/login.html HTTP/1.1] com.day.cqwebsite.impl.DatasourceUtilImpl Reaches here !
      26.09.2012 17:50:17.770 *INFO* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.impl.AgentManagerImpl Processing job for agent publish
      26.09.2012 17:50:17.770 *INFO* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish Sending POST request to http://localhost:4503/bin/receive?sling:authRequestLogin=1
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish Error while sending request: java.net.ConnectException: Connection refused: connect
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish Replication (ACTIVATE) of /etc/designs/mywebsite/images not successful: java.net.ConnectException: Connection refused: connect Conversation follows
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish ------------------------------------------------
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish Sending message to localhost:4503
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish >> POST /bin/receive HTTP/1.0
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish >> Action: Activate
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish >> Path: /etc/designs/mywebsite/images
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish >> Handle: /etc/designs/mywebsite/images
      26.09.2012 17:50:18.983 *ERROR* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.Agent.publish >> ...spooling 744 bytes...
      26.09.2012 17:50:18.983 *INFO* [pool-6-thread-32-com/day/cq/replication/job/publish(com/day/cq/replication/job/publish)] com.day.cq.replication.impl.AgentManagerImpl Job for agent publish processed in 1213ms. Failed.
      Any help will be great !
      Tx
        • 1. Re: Problems while getting the Datasource from a Utill class
          Sham HC Level 7
          Could you please use [1], verify & confirm. If does not work let me know cq version & jdbc jar you are using.
          [1]
          import org.apache.felix.scr.annotations.Component;
          import org.apache.felix.scr.annotations.Properties;
          import org.apache.felix.scr.annotations.Property;
          import org.apache.felix.scr.annotations.Service;
          @Component(immediate = true)
          @Service(value = DatasourceUtil.class)
          @Properties({
                  @Property(name = "service.description", value = "Data Source lookup example"),
                  @Property(name = "service.vendor", value = "Day Management AG")
