4 Replies Latest reply on Oct 9, 2012 1:08 PM by peter minneapolis
    Can I change a cross reference display without having to recreate it?
    Gerben Wierda Level 1
      WHen cross references are to figures on the same page, I let the cross reference point to the paragraph number only ("see View 25"). When it is on another page, I use paragraph number and page ("See View 25 on page 34"). But when my text changes, sometimes text moves, sometimes images move and I need to change the cross reference. It is quite bothersome, I have to rmeove the old one and create a new one, hunting for the cross reference in a list of 150 or so.
      Is there a simpler way? E.g. put the insertion point in the cross reference and than some easy way to select a different appearance?
        • 1. Re: Can I change a cross reference display without having to recreate it?
          Steve Werner Adobe Community Professional & MVP
          There are Update Cross-Reference and Relink Cross-Reference choices on the Hyperlinks panel menu. Have you tried those? You can also change the formatting of a cross-reference in Cross Reference Options.
          • 2. Re: Can I change a cross reference display without having to recreate it?
            peter minneapolis Level 4
            I've just spent some time trying to do this in the commercial third-party Cross-References Pro plug-in for InDesign, from dtptools.com, using its intelligence that can display "on this page," "on previous page," "on opposite page," or "on next page." However, I can't make a single cross-reference format definition ignore the page number for the current page. You can try sending the question to their tech support - I may be missing something.
            HTH
            Regards,
            Peter
            _______________________
            Peter Gold
            KnowHow ProServices
            • 3. Re: Can I change a cross reference display without having to recreate it?
              Jan Macuch
              Hi, sorry for being a little late on this one. Here's a sample of the Cross-Reference PRO format you're looking for is:
              See Figure <paranum/> <pagenum usesectionname="true" forcearabic="true" usepage="true" pagetext="on page #" usethis="true" thistext=" " usenext="true" nexttext="on the next page" useprev="true" prevtext="on the previous page" useopposite="true" oppositetext="on the opposite page"/>
              The trick is that you include the words "on" and "on the" in the page wording definitions, but insert just emptu space for the This Page setting. There's a glitch that you end up with an extra space after the reference, but you can replace the normal space by a hair space (code ^| ) which makes it quite tolerable.
              Jan Macuch
              DTP Tools
              • 4. Re: Can I change a cross reference display without having to recreate it?
                Thanks for stepping in, Jan. I'm glad the smart page-reference building blocks in Cross-References Pro can actually do what I hoped it could, to solve this riddle for the original poster. I did a quick test, just to be sure it worked as I expected, and it does! It would be great for Adobe to license your technology and build this into InDesign, along with the rest of the extra-strength cross-reference abilities. (Disclaimer: I'm not connected to DTP Tools other than being a happy user.)
                As to the unwanted space, perhaps a character style in nested and/or GREP style could apply some kind of width adjustment that would reduce the displacement to an absolute minimum.
                Regards,
                Peter
                Peter Gold
                Jan Macuch
                DTP Tools
