6 Replies Latest reply on Sep 28, 2012 6:13 AM by steve_dayman
    Change license for active DAY instance
    steve_dayman Level 1
      Hello,
      I have created several instances of Day (CQ5.4, author and publish). Unfortunately I was provided a 'dev' downloadID and Customer Name.
      My instances of DAY are running inside an application server (JBOSS 5.1).  How can I correct the license these servers are using?
        • 1. Re: Change license for active DAY instance
          justin_at_adobe Adobe Employee
          You should just be able to edit the license.properties file and restart JBoss.
          • 2. Re: Change license for active DAY instance
            Where is this file?
            I've checked in crx home directory as well as in the jboss server file system.
            [root@wadp001cnc crx]# find ./ -name "*license*" -exec ls {} \;
            ./crx-quickstart/server/webapps/crx-explorer_crx/WEB-INF/lib/3rdparty_license.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/license_lgpl .txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/license_bsd. txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/edit_area/li cense_lgpl.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/edit_area/li cense_bsd.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/edit_area/li cense_apache.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/editarea/license_apac he.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/de/endorsed/extjs/license.txt
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/apps/crx-launchpad/crx_license_en try_box.png
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/apps/crx-launchpad/cq_license_ent ry_box.png
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/apps/crx-launchpad/crx_license_in fo_box.png
            ./crx-quickstart/server/webapps/crx-explorer_crx/docroot/apps/crx-launchpad/cq_license_inf o_box.png
            ./crx-quickstart/server/webapps/crx-explorer_crx/apps/crx-launchpad/license.jsp
            LicensePingParameters.class
            ./crx-quickstart/server/webapps/crx-launchpad/WEB-INF/lib/3rdparty_license.txt
            ./crx-quickstart/server/lib/3rdparty_license.txt
            [root@wadp001cnc crx]# find /opt/jboss/server/default/ -name "*license*" -exec ls {} \;
            /opt/jboss/server/default/tmp/a1t3d5t-luay1v-h7kqk0av-1-h7kql5ew-9o/ROOT.war/WEB-INF/lib/3 rdparty_license.txt
            /opt/jboss/server/default/deploy/crx.war/WEB-INF/lib/3rdparty_license.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/extjs/license.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/edit_area/license_lg pl.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/edit_area/license_bs d.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/edit_area/license_ap ache.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/license_lgpl.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/license_bsd.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/de/endorsed/editarea/license_apache.txt
            /opt/jboss/server/default/deploy/crx.war/docroot/apps/crx-launchpad/crx_license_info_box.p ng
            /opt/jboss/server/default/deploy/crx.war/docroot/apps/crx-launchpad/crx_license_entry_box. png
            /opt/jboss/server/default/deploy/crx.war/docroot/apps/crx-launchpad/cq_license_info_box.pn g
            /opt/jboss/server/default/deploy/crx.war/docroot/apps/crx-launchpad/cq_license_entry_box.p ng
            /opt/jboss/server/default/deploy/crx.war/apps/crx-launchpad/license.jsp
            • 3. Re: Change license for active DAY instance
              It should be in the parent directory of the crx-quickstart directory.
              • 4. Re: Change license for active DAY instance
                I have created the folder /home/crx. This folder contains crx-quickstart.
                There is no license.properties file located here. I entered the license information into crx/apps/crx-launchpad on first run.
                I've run a recursive egrep from /home/crx/ for the license key to see if its stored in a text file, it does not seem to be stored here...
                • 5. Re: Change license for active DAY instance
                  Sham HC Level 7
                  It should  be in the parent directory of the crx-quickstart directory , could you please also verify at bin directory of JBoss
                  • 6. Re: Change license for active DAY instance
                    Looks like it was in $JBOSS_HOME/bin. That's odd since i change all of the 'home' values in web.xml for both war files to /home/crx.
                    Either way, its fixed now
