11 Replies Latest reply on Dec 1, 2016 4:50 AM by franz josef gigler
    What's the ExtendScript command for updating a FrameMaker book?
    rlauriston Level 1
      I have some scripts adapted from the FM_Outputs_CondText.jsx sample in FM10, but I just noticed today that the book is not getting updated. Seems like I need something in between these two commands:
      FileSource = OpenBook(InputFile);
      SavePdf(FileSource,InputFile.replace(/\.book$/i,"") + OutPutFiles[output_no]);
        • 1. Re: What's the ExtendScript command for updating a FrameMaker book?
          FrameGurus
          rlauriston,
          You can use the following code snippet to update the book:
          int status = Book.UpdateBook(updateParams:PropVals , updateReturnParams:PropVals)
          Regards,
          FrameGurus
          • 2. Re: What's the ExtendScript command for updating a FrameMaker book?
            rlauriston Level 1
            That breaks the script, nothing happens at all.
            UpdateBook(FileSource) or UpdateAll() cause script processing to halt.
            • 3. Re: What's the ExtendScript command for updating a FrameMaker book?
              rlauriston Level 1
              I no longer have any conditions that are different between PDF and online help, so I no longer need such a complicated script. All I really need is:
              open book
              update book
              save as pdf
              close book
              • 4. Re: What's the ExtendScript command for updating a FrameMaker book?
                4everJang Level 3
                Have you tried it with all the chapter files in the book already open? If a file cannot be automatically opened because some error is blocking it, that might cause the UpdateBook to fail.
                • 5. Re: What's the ExtendScript command for updating a FrameMaker book?
                  rlauriston Level 1
                  Yes, actually I left out the command that opens the .fm files:
                  OpenBookFiles(FileSource)
                  CloseAll()
                  • 6. Re: What's the ExtendScript command for updating a FrameMaker book?
                    4everJang Level 3
                    Can you post the full text of the (relevant portion of) the script here ?
                    • 7. Re: What's the ExtendScript command for updating a FrameMaker book?
                      rlauriston Level 1
                      It's basically the FM_Outputs_CondText.jsx sample script. I noticed the other day that a new heading was missing from the TOC and realized the script was not updating the book.
                      /* ADOBE SYSTEMS INCORPORATED                                       */
                      /* Copyright 1986 - 2010 Adobe Systems Incorporated                 */
                      /* All Rights Reserved                                              */
                      /* NOTICE:  Adobe permits you to use, modify, and distribute this   */
                      /* file in accordance with the terms of the Adobe license agreement */
                      /* accompanying it.  If you have received this file from a source   */
                      /* other than Adobe, then your use, modification, or distribution   */
                      /* of it requires the prior written permission of Adobe.            */
                      * Program Name:
                      *    << FM_Outputs_Conditional_Text.jsx  >>
                      * General Description:
                      *    Book to Multiple PDF -> for generating Multiple PDF outputs on the basis of Conditional Text
                      InputFile="C:\\Books\\Bk8.book" /* Edit the FULL path of the Book here - this book should have conditional text with the names - Comment / Red / Blue / Green */
                      var ShowList = new Array()
                      var HideList = new Array()
                      /*  Output1: Show / Hide Conditions list here */
                      ShowList[0] = new Array("Comment", "Red");
                      HideList[0] = new Array("Blue", "Green");
                      /*  Output2: Show / Hide Conditions list here */
                      ShowList[1] = new Array("Blue", "Green");
                      HideList[1] = new Array("Red", "Comment");
                      /*  Define the list of Output file Names here. This would get appended to the original Book*/
                      var OutPutFiles = new Array("_Comment_Red.pdf", "_Blue_Green.pdf");
                      for (var output_no=0; output_no<OutPutFiles.length; output_no++)   /*  Optimize possible here - file needs to be opened once - the ShowHide needs to be shifted from OpenBookFiles */
                          /*  The Book on which Conditional Text  be applied before saving to PDF */
                          /*Apply Conditions to each document in OpenBookFiles function */
                          /*  The Output Book PDF on which Conditional Text  is applied before saving to PDF  */
                          SavePdf(FileSource,InputFile + OutPutFiles[output_no]);
                          /*  Close All Files */
                          CloseAll()
                      function ShowHide(FileId, CondName, showOrHide)
                           CondFmtId = FileId.GetNamedCondFmt (CondName)
                          if (showOrHide) /* If 1 then show else hide*/
                              CondFmtId.CondFmtIsShown = 1
                          else
                              CondFmtId.CondFmtIsShown = 0
                           FileId.ShowAll = 0  /* Setting it to ShowAll to apply the Condtional Text property*/
                      function OpenBook(filename)
                          openProp = GetOpenDefaultParams()
                          i=GetPropIndex(openProp,Constants.FS_FileIsOldVersion)
                          openProp[i].propVal.ival=Constants.FV_DoOK
                          i=GetPropIndex(openProp,Constants.FS_FontChangedMetric)
                          i=GetPropIndex(openProp,Constants.FS_FontNotFoundInCatalog)
                          i=GetPropIndex(openProp,Constants.FS_FontNotFoundInDoc)
                          i=GetPropIndex(openProp,Constants.FS_LanguageNotAvailable)
                          i=GetPropIndex(openProp,Constants.FS_LockCantBeReset)
                          i=GetPropIndex(openProp,Constants.FS_UpdateTextReferences)
                          openProp[i].propVal.ival=Constants.FV_DoNo
                          i=GetPropIndex(openProp,Constants.FS_UpdateXRefs)
                          i=GetPropIndex(openProp,Constants.FS_UseAutoSaveFile)
                          i=GetPropIndex(openProp,Constants.FS_UseRecoverFile)
                          i=GetPropIndex(openProp,Constants.FS_AlertUserAboutFailure)
                          openProp[i].propVal.ival=false
                          i=GetPropIndex(openProp,Constants.FS_BeefyDoc)
                          i=GetPropIndex(openProp,Constants.FS_FileIsInUse)
                          openProp[i].propVal.ival=Constants.FV_ResetLockAndContinue
                          i=GetPropIndex(openProp,Constants.FS_BookIsInUse)
                          i=GetPropIndex(openProp,Constants.FS_MakeVisible)
                          openProp[i].propVal.ival=true
                          i=GetPropIndex(openProp,Constants.FS_RefFileNotFound)
                          openProp[i].propVal.ival=Constants.FV_AllowAllRefFilesUnFindable
                          i=GetPropIndex(openProp,Constants.FS_FileIsStructured)
                          openProp[i].propVal.ival=Constants.FV_OpenViewOnly
                          i=GetPropIndex(openProp,Constants.FS_OpenFileNotWritable)
                          retParm = new PropVals()
                          docOpen=Open(filename,openProp,retParm);
                          //alert(docOpen);
                          return docOpen;
                      function OpenBookFiles(bname)
                      //Initialising Current Component
                      var bookComp=bname.FirstComponentInBook;
                      var compId = bookComp.id;
                      //Loop for traversing hierarchy of book
                      while(compId)
                          var nextId = 0;
                          var parentId = 0;
                          var compType=bookComp.ComponentType;
                          //Assigning next component - If current component  is Group or Folder(move downward in hierarchy)
                          if(Constants.FV_BK_FOLDER == compType || Constants.FV_BK_GROUP == compType)
                                  var nextComp=bookComp.FirstComponentInBookComponent;
                                  nextId = nextComp.id;
                          //Assigning next component - If current component is not a Group or Folder i.e. a file
                          if(nextId == 0)
                              var nextComp = bookComp.NextComponentInBook;
                          //Initialising parent component
                          var parentComp = bookComp;
                          parentId = parentComp.id;
                          //Moving upward in hierarchy if reached end of group or folder
                          while((nextId == 0) && (parentId != 0))
                                  parentComp = parentComp.BookComponentParent;
                                  nextComp = parentComp.NextComponentInBook;
                          //Opening the file
                          var fname = bookComp.Name;
                               fileId = openfile(fname) // Here openfile function is called
                          for (var i=0; i<ShowList[output_no].length; i++)   /*  Calling ShowHide function to Show */
                              ShowHide(fileId, ShowList[output_no][i], 1);
                          for (var i=0; i<HideList[output_no].length; i++)      /*  Calling ShowHide function to Hide */
                              ShowHide(fileId, HideList[output_no][i], 0);
                          //Iterating to next component
                          bookComp = nextComp ;
                      }//end of loop
                      function openfile(filename)
                          fileOpen=Open(filename,openProp,retParm);
                          return fileOpen;
                      function openxml(filename,appname)
                          i=GetPropIndex(openProp,Constants.FS_OpenAsType)
                          openProp[i].propVal.ival=Constants.FV_TYPE_XML
                          i=GetPropIndex(openProp,Constants.FS_StructuredOpenApplication)
                          openProp[i].propVal.sval=appname
                          openProp[i].propVal.ival=Constants.FV_DoCancel
                          fileOpen = Open(filename,openProp,retParm);
                          return fileOpen;
                      function SavePdf(file,pdfName)
                          var params = GetSaveDefaultParams()
                          var returnParamsp =new PropVals()
                          var i = GetPropIndex(params, Constants.FS_FileType)
                          params[i].propVal.ival =Constants.FV_SaveFmtPdf
                          file.Save(pdfName, params, returnParamsp)
                          return
                      function CloseAll()
                          doc=app.FirstOpenDoc
                          while(doc.id !=0)
                              doc2=doc.NextOpenDocInSession;
                              doc.Close(Constants.FF_CLOSE_MODIFIED);
                              doc = doc2;
                          book=app.FirstOpenBook
                          while(book.id !=0)
                              book2=book.NextOpenBookInSession;
                              book.Close(Constants.FF_CLOSE_MODIFIED);
                              book=book2
                      • 8. Re: What's the ExtendScript command for updating a FrameMaker book?
                        rlauriston Level 1
                        I have a sample project if anyone wants to look at it.
                        • 9. Re: What's the ExtendScript command for updating a FrameMaker book?
                          4everJang Level 3
                          If you can zip the sample project and script(s) and send them to jang at jang dot nl I can certainly have a look. It might not be immediately due to lots of paid work on my desk right now, but then it might turn out to be simpler than expected.
                          Ciao
                          Jang
                          • 10. Re: What's the ExtendScript command for updating a FrameMaker book?
                            4everJang Level 3
                            Robert,
                            What's happening? Did you solve the problem yet? If so, let us know what the solution was. If not, send me the files and I will take a look.
                            Ciao
                            Jang
                            • 11. Re: What's the ExtendScript command for updating a FrameMaker book?
                              franz josef gigler
                              Hm, maybe the following function snippet I've found elsewhere can close the gap.
                                  var book = bname;
                              . existing code in that function
                                  var props = GetUpdateBookDefaultParams();
                                  var index = GetPropIndex(props, Constants.FS_ShowBookErrorLog);
                                  props[index].propVal.ival = true;   // is usually false for scripts, but I like to see if there are erors
                                  var returnp = new PropVals();
                                  book.UpdateBook(props, returnp);
