3 Replies Latest reply on Oct 1, 2012 1:05 PM by sinious
    GPU Rendering and Stage
    soremite
      When I have things lined up perfectly on the stage and then test movie in ADL mobile, everything is fine.
      When I check GPU rendering, everything is way too high on the stage and only the bottom shows.
      I have Flash CS6.
      Any idea what is causing this?
        • 1. Re: GPU Rendering and Stage
          sinious Most Valuable Participant
          Have you tested on a device?
          • 2. Re: GPU Rendering and Stage
            soremite Level 1
            I had not since there was no point in continuing like that, but I have now.
            It lines up correctly, but renders very slow on my iPhone 4. I mean maybe a 1cm block per second rendering. Then it moves very slow too.
            I have a top of the line new MacBook Pro Retina so there should be no performance issue with the computer side.
            The app is just a test app with one screen of bubbles moving up the page. It's a tutorial I am working through. SO the problem seems to be mostly with testing the movie in the ADL
            • 3. Re: GPU Rendering and Stage
              On-device testing is a must. I develop from Windows and I can't see any video in a StageWebView or from the StageVideo class haha. I'm very used to testing being limited. You'll find that more and more as you go.
