11 Replies Latest reply on Sep 27, 2012 5:36 PM by BobLevine
    InDesign CS6 8.0.1 Fixes PDF, EPUB, Other Issues
    Steve Werner Adobe Community Professional & MVP
      Adobe updated InDesign CS6 to version 8.0.1, fixing many problems with EPUB and PDF export, as well as other problems.
      Recent postings in the user forums the past few months have complained about failure of some buttons to work when PDF was exported, and that is now reported to be working. There were several EPUB problems reported with fixes included in the update. Here’s a list of changes from the release notes:
      INDESIGN
      • Links in the exported IDML still reference to old link path after connect to DAM with different display name [3195038]
      • InDesign Shuts down when processing a book document with a cross reference to another book document [3189648]
      • Invalid PDF/X-4 Generated Due to References to .notdef Glyphs [3193833]
      • Umlaute are not displayed in form fields 3193827]
      • Buttons from Master Pages for PDFs Won’t Work in some cases. [3193832]
      • InDesign shuts down during during document recovery [3210940]
      • Debug Log.txt file not getting created with InDesign CS6 [3210945]
      • Previous versions of InDesign shut down when opening an IDML created from ID CS6 containing a psd file which has new Pantone Plus colors spot channels. [3210939]
      • Deleting characters before hyphenated words causes the application to shut down. [3125513]
      • Support Margin-top property in EPUB and HTML output [3197167]
      • Do not translate carriage return to nbsp in EPUB export [3197157]
      • Extra tag -epub-ruby-* in EPUb export CSS output [3197179]
      • Warning when validating an epub exported from an ID doc that has Spaces in its name [3198096]
      • Unable to select poster image using IMediaAttribute::enPosterTime [3210941]
      • CrashReporter is unable to collect info in Mac OS X 10.8 [3291250]
      • Memory leaks in AdobeCrashDaemon [3303518]
      • It is not possible to seek new playback positions in a EPUB because audio and video files are compressed. [3131562]
      • “adobe-page-layout-version” meta tag is missing from the metadata in EPUB3 format. [3220987 ]
      • Adobe Edge Preview package (.OAM) is not available in importable-files list [3288926]
      • Re-center policy not being honored on some exported layouts [3289996]
      • If you use Alternate Layouts, content is duplicated when you export to EPUB or HTML [3293896]
      • Automatic image conversion when exporting to HTML 5 selects JPEG instead of PNG, resulting in loss of transparency [3293906]
      • When you export to JPEG export, the output is at mixed, or low resolution, if you have low memory [3168711]
      • Updating image links in InDesign snippets results in corrupt or missing links [3178169]
      • InDesign quits unexpectedly if you fetching properties of grouped items using a script [3212753]
      • During EPUB Export the margin properties are not always set if they are overriden using a style [3217520]
      • InDesign quits unexpectedly if the product license is invalid [3286021]
      INCOPY
      • Unable to select text in InCopy opened document at first attempt [3156586]
      INDESIGN SERVER
      • InDesign CS6 Server shuts down when replacing Glyphs via JavaScript [3210946]
      • InDesign Server CS6 shuts down when trying to open enclosed bug file [3174087]
      Here's a link to the release notes:
      http://helpx.adobe.com/indesign/release-note/indesign-cs6-1-release-notes.html
