10 Replies Latest reply on Sep 29, 2012 7:48 AM by sudarshan.t
    New page from CS5 template entirely editable
    riverwebs Level 1
      Very confusing - working in DW CS5 - I've created a new page from a template by chose New>Page from Template (select site and template) and named the file in the Save As dialog. All page code is editable, not jnust the section marked as an editable region on the dwt template. I tried this several times checking to make sure I selected the proper dwt file and save as file type and same result.  By applying the template to the htm file it creates the correct editable/non-editable regions but that is not the way it shiould work.  Even more confusing, when I open  new pages from  these templates in Contribute CS3, only the correct regions are editable. Some ideas please on how to troubleshoot this,
        • 1. Re: New page from CS5 template entirely editable
          Is the Template from which you're spawning the child pages located inside the Templates folder in your site folder?  Or did you inadvertently pick a template from another site?
          Nancy O.
          • 2. Re: New page from CS5 template entirely editable
            riverwebs Level 1
            Insite the templage folder of the correct site. BTW the correct path to the doc with the dwt code is nspaintshop.com/staging/dwt.pdf
            • 3. Re: New page from CS5 template entirely editable
              I don't see anything wrong with your Template code.
              Can we see code from a non-working Child Page?
              BTW: You can copy & paste code into the web forum (don't use email for this).
              Click on link to the Advanced Editor  >> Syntax Highlighting > Plain
              Nancy O.
              • 4. Re: New page from CS5 template entirely editable
                riverwebs Level 1
                I didn't see the Syntax Highlighting control but here is the code. As you can see there is no InstanceBeginTemplate in the file.
                <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN" "http://www.w3.org/TR/html4/loose.dtd">
                <html>
                <head>
                <meta http-equiv="Content-Type" content="text/html; charset=iso-8859-1">
                <title>Custom spray painting, cabinets, residential, commercial, trim, doors, north shore massachusetts, beverly, ipswich, salem, rockport</title>
                <script type="text/javascript" src="p7pmm/p7PMMscripts.js"></script>
                <script src="Scripts/swfobject_modified.js" type="text/javascript"></script>
                function MM_reloadPage(init) {  //reloads the window if Nav4 resized
                  if (init==true) with (navigator) {if ((appName=="Netscape")&&(parseInt(appVersion)==4)) {
                    document.MM_pgW=innerWidth; document.MM_pgH=innerHeight; onresize=MM_reloadPage; }}
                  else if (innerWidth!=document.MM_pgW || innerHeight!=document.MM_pgH) location.reload();
                MM_reloadPage(true);
                </script>
                <link href="style.css" rel="stylesheet" type="text/css">
                <link href="p7pmm/p7PMMh18.css" rel="stylesheet" type="text/css" media="all">
                </head>
                <body>
                <div id="wrapper">
                  <div id="header"> <img src="images/BOB-logo.gif" width="102" height="116" border="0" class="img_bob">
                    <p class="header_text"> Voted <br>
                      &quot;Best Interior Painter<br>
                      North of Boston&quot;<br>
                      by Boston Magazine<br>
                      <br>
                       <span class="call_text">Call (978) 744-SHOP (7467)</span></p>
                  </div>
                  <div id="nav">
                    <div id="p7PMM_1" class="p7PMMh18 p7PMMnoscript">
                      <ul class="p7PMM">
                        <li><a href="index.htm">HOME</a></li>
                        <li><a href="kitchens.htm">KITCHENS</a></li>
                        <li><a href="furniture.htm">FURNITURE</a></li>
                        <li><a href="interiors.htm">INTERIORS</a></li>
                        <li><a href="cabinetry.htm">CUSTOM CABINETRY & DESIGN</a></li>
                      </ul>
                      <div class="p7pmmclearfloat"> </div>
                      <!--[if lte IE 7]>
                <style>.p7PMMv18, .p7PMMv18 a, .p7PMMv18 ul {height:1%;}.p7PMMv18 li{float:left;clear:both;width:100%;}</style>
                <![endif]-->
                      <!--[if IE 5.500]>
                <style>.p7PMMv18 {position: relative; z-index: 9999999;}</style>
                <![endif]-->
                      <!--[if IE 5]>
                <style>.p7PMMv18 a, .p7PMMv18 ul {height: 1%; overflow: visible !important;}</style>
                <![endif]-->
                P7_PMMop('p7PMM_1',1,2,-5,-5,0,1,0,1,0,3,1,1,0,0,2);
                      </script>
                    </div>
                    <!--[if lte IE 7]>
                <![endif]-->
                    <!--[if IE 5.500]>
                <![endif]-->
                    <!--[if IE 5]>
                <![endif]-->
                    </script>
                    </div>
                  <div id="content">
                <p>Content area</p>
                </div>
                  <div id="footer">
                    <p style="color: #999"><a href="index.htm"><br>
                      Homepage</a>| <a href="kitchens.htm">Kitchens</a> | <a href="furniture.htm">Furniture</a> | <a href="interiors.htm">Interiors</a> | <a href="spraybooth.htm">Spray Booth</a> | <a href="cabinetry.htm">Cabinet Making & Design </a> | <a href="contact.htm">Contact Us </a><span class="footer"><br>
                  <a href="http://racingriverwebs.com" target="_blank" >
                    Website by Racing River Website Solutions </a></span><br>
                    </p>
                    <p align="center" class="footer"><br>
                      <br>
                  <script>
                                                        var time = new Date();
                                                        var year = time.getYear();
                                                        if (year < 1900) {
                                                            year = year + 1900;
                                                        document.write("&copy; Copyright The Paint Shop " + year);
                                                    </script></p>
                  </div>
                </div>
                swfobject.registerObject("FlashID");
                </script>
                </body>
                </html>
                • 5. Re: New page from CS5 template entirely editable
                  If Dreamweaver is acting erratically,  it's often a sign of a corrupt cache file. The first thing to try is deleting the file cache. If that doesn't work, delete your personal Configuration folder. Full instructions below:
                  http://forums.adobe.com/thread/494811
                  Nancy O.
                  • 6. Re: New page from CS5 template entirely editable
                    riverwebs Level 1
                    Hmm - I deleted the personal config folder but still have the issue.  Can you point me to the file cache are you referring to?
                    • 7. Re: New page from CS5 template entirely editable
                      On my system with CS6 installed, it's here:
                      C:\Users\Nancy\AppData\Roaming\Adobe\Dreamweaver CS6\en_US\Configuration\
                      Nancy O.
                      • 8. Re: New page from CS5 template entirely editable
                        Be sure to close DW before you delete the WinFileCache***.dat file.  When you re-open it, DW will create a new one.
                        Nancy O.
                        • 9. Re: New page from CS5 template entirely editable
                          riverwebs Level 1
                          That was the one I deleted.  Is there anything else I should do? What do you think about reinstalling DW as the next step?
                          • 10. Re: New page from CS5 template entirely editable
                            sudarshan.t Level 6
                            Is this happening only in this 1 template or all your templates?
                            Can you try recreating a new template to see if that works fine?
                            Another user had a similar issue and a new template creation solved his issue. http://forums.adobe.com/message/4711946
