1. Re: PDF/X-1a question
Dave Merchant Sep 28, 2012 12:26 AM (in response to Roy Marshall)PDF/X-1a:2001 is an 'old' standard but so are most RIPs in commercial print shops (and often they'll still be using Acrobat 6 for the same reason - if it ain't broke, don't fix it!)
There are later versions of PDF/X which support additional features but you certainly don't want to be sending mixed-space documents to a remote printing service unless you know they fully support the version of the standard you're sending - for example despite modern RIPs being able to convert RGB->CMYK they may not always abide by the embedded profiles, so the end results can be dramatically different. Some can't cope with transparency so the later 2003+ versions of PDF/X won't work.
The advantage of PDF/X-1a is that it's so restrictive it can't help but print properly. There are rare occasions where specialist documents may need LAB color or externally-referenced elements, hence why PDF/X-3 and /X-4 were written, but you shouldn't yet be using those versions for general purpose jobs. If in doubt use the lowest possible version of the standard which supports the file content.
