2 Replies Latest reply on Sep 28, 2012 12:44 PM by gkaiseril
    need help creating a formula to calculate the number of days between two dates.
    antoniocarlosnogueiralima
        • 1. Re: need help creating a formula to calculate the number of days between two dates.
          George_Johnson MVP & Adobe Community Professional
          The two dates would be obtained from form field entries, correct? How will the date fields be formatted (e.g., mm/dd/yy, yyyy/mm/dd, or something else)?
          • 2. Re: need help creating a formula to calculate the number of days between two dates.
            You need to use the Custom JavaScript calculation and will need to know the form field names and formats of the dates.
            function Date2Num(cFormat, cDate) {
            /* convert the date string cDate to the numberof days
            from the JavaScript Epoch date.
            inputs: cFormat - format of the date string
            cDate - character string of the date value
            returns the number of days since the JS Epoch date
            // convert the date string to a JS date object
            var oDate = util.scand(cFormat, cDate);
            if(oDate != null) {
            // no conversion error
            // get the milliseonds from the date object
            var nMsecs = Number(oDate);
            // convert to days
            nDays = nMsecs / (1000 * 60 * 60 * 24);
            // truncate to whole days
            nDays = Math.floor(nDays);
            } else {
            // conversion error
            app.alert("Conversion error date: " + cDate + " with format string: " +cFormat);
            nDays = "";
            return nDays;
            } // end Date2Num function
            // field names and formats for the input dates
            // starting date
            var cStartDate = "StartingDate"; // name of field
            var cStartFormat = "dd-mmm-yyyy"; // date format of field
            // ending date
            var cEndDate = "StartingDate"; // name of field
            var cEndFormat = "dd-mmm-yyyy"; // date format of field
            // get the values from the fields
            var cStart = this.getField(cStartDate).valueAsString;
            var cEnd = this.getField(cEndDate).valueAsString;
            event.value = 0: // default value
            // process only if we have both dates
            if(cStart != "" && cEnd != "") {
            event.value = Date2Num(cEndFormat, cEnd) - Date2Num(cStartFormat, cStart);
            Change the field names and formats as necessary.
