7 Replies Latest reply on Sep 28, 2012 4:44 PM by Ned Murphy
    1152 Error
    Kendaric Imahso
      So I have a MC thats throwing me for a loop.  As stated its giving me the 1152 error code.
      Symbol 'Personal Gallery MC', Layer 'Actions', Frame 2, Line 81152: A conflict exists with inherited definition flash.display:DisplayObject.root in namespace public.
      and here is the line it refers to.
      var root:MovieClip = this;
      While I am sure this is exceedingly simple to fix I am stuck.  I know there are know smae named instances and that the stupid little check box is turned off in the AS section.
      Any thoughts?
        • 1. Re: 1152 Error
          Don't use "root" as a variable name.
          • 2. Re: 1152 Error
            Kendaric Imahso Level 1
            Ok.  make sense but then what should I use as the Var name?  This one thing is causeign my entire site to flip out.  which if this MC is trying to replace the root site makes good sense but if changed it doesnt work...
            • 3. Re: 1152 Error
              You'll need to show the context around which you are trying to implkement this line.  "root" is the reference to the main timeline of a file.  So what are you trying to do relative to the main timeline that has you wanting to create something else named that?
              • 4. Re: 1152 Error
                I dont need this MC to do anything to the main timeline,  It was coded and put together seperate from the main File... maybe thats the problem.  The MC is just a scrolling slide show that I am setting on the mainstage.  At anyrate Ill post up the whole code.. I just need to get this last thing working am im home free.
                // Preloader in AS frame 1
                stop();
                onEnterFrame = function () {
                    loading = Math.round(_root.getBytesLoaded().toString()/1024);
                    total = Math.round(_root.getBytesTotal().toString()/1024);
                    percentage = Math.round((loading/total)*100);
                    if (_root.getBytesLoaded().toString() == _root.getBytesTotal().toString()) {
                        gotoAndStop(2);
                        delete this.onEnterFrame;
                // Main AS in frame 2
                import flash.display.*;
                import flash.geom.*;
                import flash.filters.*;
                //Change these values below to customize the viewer fuctionality
                var myMO:Object;
                var myKO:Object;
                var loadedAll:Boolean;
                var distance:Number;
                var autoJump:Number = .15;
                var maxSlide:Number = 100;
                var deleteMinDistance:Number = 0;
                var deleteMaxDistance:Number = 900;
                var doubleClickRegister:Number = 500;
                var frontCDWidth:Number = 370;
                var frontCDHeight:Number = 370;
                var shelveCDHeight:Number = 320;
                var shelveCDWidth:Number = 280;
                var shelveCDSpacing:Number = 150;
                var centerDistance:Number = 50;
                var albumEase:Number = 4;
                var angle:Number = 8;
                var fadePoint:Number = Stage.width;
                var fadeDist:Number = 200;
                var current:Number = 1;
                var centerX:Number = Stage.width / 2;
                var centerY:Number = 200;
                var clickDelay:Number = 750;
                var scrollBarStart:Number = 0;
                var scrollerDelay:Number = 150;
                var scrollBarStop:Number = scrollBar.scroller._width + 49;
                var reflectionBackgroundColour:Number = d3dfd1;
                var reflectionBlurX:Number = 0;
                var reflectionBlurY:Number = 0;
                var reflectionQuality:Number = 3;
                var reflectionSpace:Number = 250;
                var reflectionAlpha:Number = 100;
                var reflectionRotation:Number = 90;
                var reflectionFocalPointRatio:Number = 0.3;
                var reflectionFillType:String = "linear";
                var reflectionSpreadMethod:String = "pad";
                var reflectionInterpolationMethod:String = "RGB";
                var unknownArtist:String = "Unknown Artist";
                var unknownAlbum:String = "Unknown Album";
                var infostruc:Array = [];
                var reflectionColors:Array = [0x000000, 0x000000];
                var reflectionAlphas:Array = [100, 10];
                var reflectionRatios:Array = [0, 255];
                var xmlData:XML = new XML();
                MovieClip.prototype.setSides = function(x1:Number, y1:Number, x2:Number, y2:Number, x3:Number, y3:Number, x4:Number, y4:Number):Void  {
                    this.px1 = x1;
                    this.py1 = y1;
                    this.px2 = x2;
                    this.py2 = y2;
                    this.px3 = x3;
                    this.py3 = y3;
                    this.px4 = x4;
                    this.py4 = y4;
                MovieClip.prototype.DistortImage = function(ptexture, vseg:Number, hseg:Number) {
                    if (ptexture instanceof BitmapData) {
                        this.texture = ptexture;
                    } else if (ptexture instanceof MovieClip) {
                        this.texture = new BitmapData(ptexture._width, ptexture._height);
                        this.texture.draw(ptexture);
                    this._w = this.texture.width;
                    this._h = this.texture.height;
                    this._aMcs = [];
                    this._p = [];
                    this._tri = [];
                    this.init();
                MovieClip.prototype.setTransform = function(x0:Number, y0:Number, x1:Number, y1:Number, x2:Number, y2:Number, x3:Number, y3:Number):Void  {
                    this.dx30 = x3 - x0;
                    this.dy30 = y3 - y0;
                    this.dx21 = x2 - x1;
                    this.dy21 = y2 - y1;
                    for (var l in this._p) {
                        this.point = this._p[l];
                        var gx = (this.point.x - this._xMin) / this._w;
                        var gy = (this.point.y - this._yMin) / this._h;
                        var bx = x0 + gy * (this.dx30);
                        var by = y0 + gy * (this.dy30);
                        this.point.sx = bx + gx * ((x1 + gy * (this.dx21)) - bx);
                        this.point.sy = by + gx * ((y1 + gy * (this.dy21)) - by);
                    this.render();
                MovieClip.prototype.init = function(Void):Void  {
                    this._p = [];
                    this._tri = [];
                    this.w2 = this._w / 2;
                    this.h2 = this._h / 2;
                    this._xMin = this._yMin = 0;
                    this._xMax = this._w;
                    this._yMax = this._h;
                    this._hsLen = this._w / 2;
                    this._vsLen = this._h / 2;
                    for (ix = 0; ix < 3; ix++) {
                        for (iy = 0; iy < 3; iy++) {
                            x = ix * this._hsLen;
                            y = iy * this._vsLen;
                            this._p.push({x:x, y:y, sx:x, sy:y});
                    for (ix = 0; ix < 2; ix++) {
                        for (iy = 0; iy < 2; iy++) {
                            this.p0 = this._p[iy + ix * 3];
                            this.p1 = this._p[iy + ix * 3 + 1];
                            this.p2 = this._p[iy + (ix + 1) * 3];
                            this.addTriangle(this.p0,this.p1,this.p2);
                            this.p0 = this._p[iy + (ix + 1) * 3 + 1];
                            this.p1 = this._p[iy + (ix + 1) * 3];
                            this.p2 = this._p[iy + ix * 3 + 1];
                    this.render();
                MovieClip.prototype.addTriangle = function(p0:Object, p1:Object, p2:Object):Void  {
                    this.tMat = {};
                    this.u0 = p0.x;
                    this.v0 = p0.y;
                    this.u1 = p1.x;
                    this.v1 = p1.y;
                    this.u2 = p2.x;
                    this.v2 = p2.y;
                    this.tMat.tx = -this.v0 * (this._w / (this.v1 - this.v0));
                    this.tMat.ty = -this.u0 * (this._h / (this.u2 - this.u0));
                    this.tMat.a = this.tMat.d = 0;
                    this.tMat.b = this._h / (this.u2 - this.u0);
                    this.tMat.c = this._w / (this.v1 - this.v0);
                    this._tri.push([p0, p1, p2, this.tMat]);
                MovieClip.prototype.render = function(Void):Void  {
                    this.clear();
                    this.ih = 1 / this._h;
                    this.iw = 1 / this._w;
                    this.tM = this.sM = {};
                    for (var l in this._tri) {
                        a = this._tri[l];
                        this.p0 = a[0];
                        this.p1 = a[1];
                        this.p2 = a[2];
                        this.tM = a[3];
                        this.sM.a = (this.p1.sx - (this.x0 = this.p0.sx)) * this.iw;
                        this.sM.b = (this.p1.sy - (this.y0 = this.p0.sy)) * this.iw;
                        this.sM.c = (this.p2.sx - this.x0) * this.ih;
                        this.sM.d = (this.p2.sy - this.y0) * this.ih;
                        this.sM.tx = this.x0;
                        this.sM.ty = this.y0;
                        this.sM = concat(this.sM, this.tM);
                        this.beginBitmapFill(this.texture,this.sM,false,false);
                        this.moveTo(this.x0,this.y0);
                        this.lineTo(this.p1.sx,this.p1.sy);
                        this.lineTo(this.p2.sx,this.p2.sy);
                        this.endFill();
                function init(Void):Void {
                    myMO = {};
                    myKO = {};
                    Mouse.addListener(myMO);
                    Key.addListener(myKO);
                    for (var i in infostruc) {
                        loader.clear();
                        loader.gradient_mc.removeMovieClip();
                        loader.attachMovie("default","art",1);
                        loader._width = frontCDWidth;
                        loader._height = frontCDHeight;
                        this["_bmd" + i] = new BitmapData(loader._width, loader._height);
                        this["_ref" + i] = new BitmapData(loader._width, loader._height);
                        this["_bmd" + i].draw(loader);
                        var mc:MovieClip = loader.createEmptyMovieClip("gradient_mc", loader.getNextHighestDepth());
                        matrix = new Matrix();
                        matrix.createGradientBox(loader._width,loader._height,reflectionRotation / 180 * Math.PI,0,0);
                        mc.beginGradientFill(reflectionFillType,reflectionColors,reflectionAlphas,reflectionRatio s,matrix,reflectionSpreadMethod,reflectionInterpolationMethod,reflectionFocalPointRatio);
                        mc.moveTo(0,0);
                        mc.lineTo(0,loader._height);
                        mc.lineTo(loader._width,loader._height);
                        mc.lineTo(loader._width,0);
                        mc.lineTo(0,0);
                        mc.endFill();
                        loader.art._alpha = reflectionAlpha;
                        loader.beginFill(reflectionBackgroundColour);
                        loader.moveTo(0,0);
                        loader.lineTo(0,loader._height);
                        loader.lineTo(loader._width,loader._height);
                        loader.lineTo(loader._width,0);
                        loader.lineTo(0,0);
                        loader.endFill();
                        this["_ref" + i].draw(loader);
                    for (var i:Number = count = 0; count < Stage.width - (centerDistance * 2); count += shelveCDSpacing, i++) {
                        var cArt:MovieClip = this.createEmptyMovieClip("art" + this.getNextHighestDepth(), this.getNextHighestDepth());
                        var rArt:MovieClip = this.createEmptyMovieClip("reflection" + (this.getNextHighestDepth() - 1), this.getNextHighestDepth());
                        rArt.id = cArt.id = rArt.cid = cArt.cid = Number(i) + 1;
                        cArt.DistortImage(this["_bmd" + cArt.id]);
                        controlTheObject(cArt);
                        rArt.DistortImage(this["_ref" + cArt.id]);
                        controlTheObject(rArt);
                        var tmpFilter:BlurFilter = new BlurFilter(reflectionBlurX, reflectionBlurY, reflectionQuality);
                        rArt.filterArray = [];
                        rArt.filterArray.push(tmpFilter);
                        rArt.filters = rArt.filterArray;
                    myMO.onMouseWheel = function(delta:Number):Void  {
                        if (delta > 0) {
                            next();
                        } else if (delta <= 0) {
                            previous();
                    myKO.onKeyDown = function():Void  {
                        if (Selection.getFocus() != "_level0.goto") {
                            if (Key.isDown(Key.RIGHT)) {
                                next();
                            } else if (Key.isDown(Key.LEFT)) {
                                previous();
                    scrollBar.scroller.onPress = function():Void  {
                        dist = this._parent._xmouse - this._x;
                        this.onMouseMove = function():Void  {
                            tmp = 1 + Math.ceil(((this._parent._xmouse - dist) - scrollBarStart) / (scrollBar._width - scrollBarStop) * (infostruc.length - 1));
                            if (tmp > infostruc.length) {
                                tmp = infostruc.length;
                            if (tmp < 1) {
                                tmp = 1;
                            current = tmp;
                            updateInfo();
                    scrollBar.scroller.onRelease = scrollBar.scroller.onReleaseOutside = function ():Void {
                        stopDrag();
                        delete this.onMouseMove;
                    scrollBar.left.onPress = function():Void  {
                        previous();
                        shifter = setInterval(previous, scrollerDelay);
                    scrollBar.right.onPress = function():Void  {
                        next();
                        shifter = setInterval(next, scrollerDelay);
                    scrollBar.onMouseUp = function():Void  {
                        clearInterval(shifter);
                    scrollBar.onMouseDown = function():Void  {
                        if (this.hitTest(_xmouse, _ymouse, true) && !this.left.hitTest(_xmouse, _ymouse, true) && !this.right.hitTest(_xmouse, _ymouse, true)) {
                            if (this._xmouse < this.scroller._x) {
                                previous();
                                shifter = setInterval(previous, clickDelay);
                            if (this._xmouse > this.scroller._x + this.scroller._width) {
                                next();
                                shifter = setInterval(next, clickDelay);
                    goto.onChanged = function():Void  {
                        if (!isNaN(Number(this.text) + 1)) {
                            this.text = Math.round(Number(this.text));
                            if (this.text > infostruc.length) {
                                this.text = infostruc.length;
                            if (this.text < 1) {
                                this.text = 1;
                            current = this.text;
                        } else {
                            this.text = current;
                        updateInfo();
                    distance = Number(i);
                    mask.removeMovieClip();
                    loader.removeMovieClip();
                    scrollBar.swapDepths(1101);
                    loadNext();
                    updateInfo();
                function concat(m1, m2):Object {
                    var mat:Object = {};
                    mat.a = m1.c * m2.b;
                    mat.b = m1.d * m2.b;
                    mat.c = m1.a * m2.c;
                    mat.d = m1.b * m2.c;
                    mat.tx = m1.a * m2.tx + m1.c * m2.ty + m1.tx;
                    mat.ty = m1.b * m2.tx + m1.d * m2.ty + m1.ty;
                    return mat;
                function updateInfo():Void {
                    goto.text = current;
                    img_info.author = infostruc[current - 1].auth;
                    img_info.album = infostruc[current - 1].album;
                    //New Addition
                    img_info.artistLink.enabled = true;
                    if (infostruc[current - 1].authLink == undefined) {
                        img_info.authLink.enabled = false;
                    } else {
                        if (infostruc[current - 1].authLink == "undefined") {
                        } else {
                            img_info.artistLink.onPress = function() {
                                getURL(infostruc[current - 1].authLink, "_blank");
                    img_info.albumLink.enabled = true;
                    if (infostruc[current - 1].albumLink == undefined) {
                        img_info.albumLink.enabled = false;
                    } else {
                        if (infostruc[current - 1].albumLink == "undefined") {
                        } else {
                            img_info.albumLink.onPress = function() {
                                getURL(infostruc[current - 1].albumLink, "_blank");
                    scrollBar.scroller._x = scrollBarStart + ((current - 1) / (infostruc.length - 1) * (scrollBar._width - scrollBarStop));
                function validateOk(target:MovieClip):Boolean {
                    return Math.abs(Math.min(Math.max((target._x - target.x) / albumEase, -maxSlide), maxSlide)) == maxSlide;
                function controlTheObject(mc):Void {
                    if (mc._name.indexOf("reflection") == -1) {
                        mc.onPress = function():Void  {
                            if (getTimer() - this.pressTime <= doubleClickRegister && this.pressTime) {
                            this.pressTime = getTimer();
                            current = this.cid + 1;
                            updateInfo();
                    mc.onEnterFrame = function():Void  {
                        if (Math.abs(this._x - this.x) > 1) {
                            if (this._name.indexOf("reflection") == -1) {
                                this._y = centerY;
                                if (this._x >= centerX + centerDistance) {
                                    this.swapDepths(Stage.width - this._x);
                                    this.setSides(-(shelveCDWidth / 2),-(shelveCDHeight / 2) + ((Math.sin(angle * Math.PI / 180) * frontCDWidth)),-(shelveCDWidth / 2) + shelveCDWidth,-(shelveCDHeight / 2),-(shelveCDWidth / 2) + shelveCDWidth,shelveCDHeight / 2,-(shelveCDWidth / 2),(shelveCDHeight / 2) - ((Math.sin(angle * Math.PI / 180) * frontCDWidth)));
                                } else if (this._x <= centerX - centerDistance) {
                                    this.swapDepths(this._x);
                                    this.setSides(-(shelveCDWidth / 2),-(shelveCDHeight / 2),-(shelveCDWidth / 2) + shelveCDWidth,-(shelveCDHeight / 2) + (Math.sin(angle * Math.PI / 180) * frontCDWidth),-(shelveCDWidth / 2) + shelveCDWidth,(shelveCDHeight / 2) - (Math.sin(angle * Math.PI / 180) * frontCDWidth),-(shelveCDWidth / 2),shelveCDHeight / 2);
                                } else if (this._x > centerX - centerDistance && Math.floor(this._x) < centerX && !validateOk(this) && angle - ((this._x - (centerX - centerDistance)) / centerDistance * angle) > autoJump) {
                                    this.swapDepths(1002);
                                    var sum:Number = shelveCDWidth + ((this._x - (centerX - centerDistance)) / centerDistance * (frontCDWidth - shelveCDWidth));
                                    var sum2:Number = angle - ((this._x - (centerX - centerDistance)) / centerDistance * angle);
                                    var sum3:Number = shelveCDHeight + ((this._x - (centerX - centerDistance)) / centerDistance * (frontCDHeight - shelveCDHeight));
                                    this.setSides(-(sum / 2),-(sum3 / 2),-(sum / 2) + sum,-(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2) + sum,(sum3 / 2) - ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2),sum3 / 2);
                                } else if (this._x < centerX + centerDistance && Math.ceil(this._x) > centerX && !validateOk(this) && angle - (((centerX + centerDistance) - this._x) / centerDistance * angle) > autoJump) {
                                    this.swapDepths(1003);
                                    var sum:Number = shelveCDWidth + (((centerX + centerDistance) - this._x) / centerDistance * (frontCDWidth - shelveCDWidth));
                                    var sum2:Number = angle - (((centerX + centerDistance) - this._x) / centerDistance * angle);
                                    var sum3:Number = shelveCDHeight + (((centerX + centerDistance) - this._x) / centerDistance * (frontCDHeight - shelveCDHeight));
                                    this.setSides(-(sum / 2),-(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2) + sum,-(sum3 / 2),-(sum / 2) + sum,sum3 / 2,-(sum / 2),(sum3 / 2) - ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)));
                                } else if (!validateOk(this)) {
                                    this.swapDepths(1004);
                                    this.setSides(-(frontCDWidth / 2),-(frontCDHeight / 2),-(frontCDWidth / 2) + frontCDWidth,-(frontCDHeight / 2),-(frontCDWidth / 2) + frontCDWidth,frontCDHeight / 2,-(frontCDWidth / 2),frontCDHeight / 2);
                            } else {
                                this._yscale = -100;
                                    this._y = centerY + shelveCDHeight + reflectionSpace;
                                    this.swapDepths((Stage.width - this._x) - 333);
                                    this.setSides(-(shelveCDWidth / 2),-(shelveCDHeight / 2) + (Math.sin(angle * Math.PI / 180) * frontCDWidth),-(shelveCDWidth / 2) + shelveCDWidth,-(shelveCDHeight / 2),-(shelveCDWidth / 2) + shelveCDWidth,shelveCDHeight / 2,-(shelveCDWidth / 2),(shelveCDHeight / 2) + ((Math.sin(angle * Math.PI / 180) * frontCDWidth)));
                                    this.swapDepths(this._x - 333);
                                    this.setSides(-(shelveCDWidth / 2),-(shelveCDHeight / 2),-(shelveCDWidth / 2) + shelveCDWidth,-(shelveCDHeight / 2) + ((Math.sin(angle * Math.PI / 180) * frontCDWidth)),-(shelveCDWidth / 2) + shelveCDWidth,(shelveCDHeight / 2) + (Math.sin(angle * Math.PI / 180) * frontCDWidth),-(shelveCDWidth / 2),shelveCDHeight / 2);
                                } else if (this._x > centerX - centerDistance && this._x < centerX && !validateOk(this)) {
                                    this.swapDepths(999);
                                    this._y = centerY + sum3 + reflectionSpace;
                                    this.setSides(-(sum / 2),-(sum3 / 2),-(sum / 2) + sum,-(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2) + sum,(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2),sum3 / 2);
                                } else if (this._x < centerX + centerDistance && this._x > centerX && !validateOk(this)) {
                                    this.swapDepths(998);
                                    this.setSides(-(sum / 2),-(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)),-(sum / 2) + sum,-(sum3 / 2),-(sum / 2) + sum,sum3 / 2,-(sum / 2),(sum3 / 2) + ((Math.sin(sum2 * Math.PI / 180) * frontCDWidth)));
                                    this.swapDepths(995);
                                    this._y = centerY + frontCDHeight + reflectionSpace;
                        if (infostruc[this.cid].loaded && !this.loadedImage) {
                            this.DistortImage(this._name.indexOf("reflection") > -1 ? this._parent["_ref" + this.cid] : this._parent["_bmd" + this.cid]);
                            this.loadedImage = true;
                        if (this._x < deleteMinDistance && this._parent["_ref" + (this.cid + distance)]) {
                            this.cid += distance;
                            this._x = deleteMaxDistance;
                            controlTheObject(this);
                            this.loadedImage = infostruc[this.cid].loaded;
                        if (this._x > deleteMaxDistance && this._parent["_ref" + (this.cid - distance)]) {
                            this.cid -= distance;
                            this._x = deleteMinDistance;
                        if (this.cid + 1 > current) {
                            this.x = (centerX + ((this.cid + 1 - current) * shelveCDSpacing)) + centerDistance;
                        } else if (this.cid + 1 < current) {
                            this.x = (centerX + ((this.cid + 1 - current) * shelveCDSpacing)) - centerDistance;
                        } else {
                            this.x = centerX + ((this.cid + 1 - current) * shelveCDSpacing);
                        this._x -= Math.min(Math.max((this._x - this.x) / albumEase, -maxSlide), maxSlide);
                        if (this._x < fadeDist) {
                            this._alpha = (this._x / fadeDist * 100);
                        } else if (this._x > fadePoint - fadeDist) {
                            this._alpha = ((fadePoint - this._x) / fadeDist * 100);
                        } else {
                            this._alpha = 100;
                        this.setTransform(this.px1,this.py1,this.px2,this.py2,this.px3,this.py3,this.px4,this.py4 );
                function next():Void {
                    if (current < infostruc.length) {
                        current += 1;
                    updateInfo();
                function previous():Void {
                    if (current > 1) {
                        current -= 1;
                    updateInfo();
                function displayAlternArt(art, width:Number, height:Number):Void {
                    artDisplay.attachBitmap(art,1);
                    artDisplay._width = width;
                    artDisplay._height = height;
                function loadNext():Void {
                    if (!loadedAll) {
                        var num:Number = current - 1;
                        if (infostruc[current - 1].loaded) {
                            var num:Number = current - Math.floor(distance / 2) - 1 >= 0 ? current - Math.floor(distance / 2) - 1 : 0;
                            while (infostruc[num].loaded && num < infostruc.length) {
                                num++;
                            if (num >= infostruc.length) {
                                while (infostruc[num].loaded && num > 0) {
                                    num--;
                                if (num <= 0) {
                                    loadedAll = true;
                        var newLoad:MovieClip = this.createEmptyMovieClip("artLoad" + num, this.getNextHighestDepth());
                        newLoad.createEmptyMovieClip("art",newLoad.getNextHighestDepth());
                        newLoad._alpha = 0;
                        var mc:Object = {};
                        mc.number = num;
                        var artLoader:MovieClipLoader = new MovieClipLoader();
                        artLoader.addListener(mc);
                        artLoader.loadClip("./" + infostruc[num].art,newLoad.art);
                        mc.onLoadError = function() {
                            infostruc[this.number].loaded = true;
                            loadNext();
                        mc.onLoadInit = function(target:MovieClip) {
                            target._parent._width = frontCDWidth;
                            target._parent._height = frontCDHeight;
                            root["_bmd" + this.number] = new BitmapData(target._width, target._height);
                            root["_ref" + this.number] = new BitmapData(target._width, target._height);
                            root["_bmd" + this.number].draw(target);
                            var mc:MovieClip = target._parent.createEmptyMovieClip("gradient_mc", target._parent.getNextHighestDepth());
                            matrix.createGradientBox(target._width,target._height,reflectionRotation / 180 * Math.PI,0,0);
                            mc.moveTo(0,0);
                            mc.lineTo(0,target._height);
                            mc.lineTo(target._width,target._height);
                            mc.lineTo(target._width,0);
                            mc.lineTo(0,0);
                            mc.endFill();
                            target._alpha = 50;
                            target._parent.beginFill(reflectionBackgroundColour);
                            target._parent.moveTo(0,0);
                            target._parent.lineTo(0,target._height);
                            target._parent.lineTo(target._width,target._height);
                            target._parent.lineTo(target._width,0);
                            target._parent.lineTo(0,0);
                            target._parent.endFill();
                            root["_ref" + this.number].draw(target._parent);
                            target._parent.removeMovieClip();
                            updateInfo();
                            loadNext();
                xmlData.onLoad = function(success:Boolean):Void  {
                    if (success) {
                        for (var i:Number = -1; this.childNodes[0].childNodes[++i]; ) {
                            var cNode:XMLNode = this.childNodes[0].childNodes[i].childNodes;
                            var val2:String = cNode[1].childNodes[0].nodeValue ? unescape(cNode[1].childNodes[0].nodeValue) : unknownArtist;
                            var val3:String = cNode[2].childNodes[0].nodeValue ? unescape(cNode[2].childNodes[0].nodeValue) : unknownAlbum;
                            var val4:String = cNode[3].childNodes[0].nodeValue ? unescape(cNode[3].childNodes[0].nodeValue) : noLink;
                            var val5:String = cNode[4].childNodes[0].nodeValue ? unescape(cNode[4].childNodes[0].nodeValue) : noLink;
                            infostruc.push({art:cNode[0].childNodes[0].nodeValue, info:val1, auth:val2, album:val3, authLink:val4, albumLink:val5, loaded:false});
                        loadStat = "";
                        init();
                    } else {
                        loadStat = "Unable to load XML Data";
                xmlData.ignoreWhite = true;
                xmlData.load("./albuminfo.xml");
                this.createEmptyMovieClip("loader",this.getNextHighestDepth());
                loader._visible = false;
                mask._alpha = 0;
                scrollBar.scroller._y = 0;
                img_info.swapDepths(2000);
                As I said it works fine on its own, which in case of root Var name makes sense, but I need it work work within a parent file, Hopping not to have to reconstruct this.
                • 5. Re: 1152 Error
                  The way you are using it and being that it is AS2 (where "root" is not a keyword, but "_root" is) you should be able to replace it with any variable name.
                  Being that this is all AS2 code, and you get a numbered error message, which is usually the case for an AS3 file, are you trying to add an AS2 movieclip to an AS3 file?  Try putting it into an AS2 main file and see if that cures your ills.
                  PS - too much code for anyone to want to read thru.  Try to keep things limited to what's relevant and explain how.
                  • 6. Re: 1152 Error
                    yeah i didnt expect anyone to read through it all.  was just frustrated,  and you are correct ad a feel like a fool... didnt pay attention that it was an old AS2 code... Ill have to reconstruct one in AS3.  Thank You Ned.
                    • 7. Re: 1152 Error
                      You're welcome
