6 Replies Latest reply on Sep 28, 2012 1:51 PM by geoff plunkett
    Resizing a Book
    geoff plunkett
      Brand new to Indesign & will probably use Indesign 6 (I have the original Indesign files).
      Had a book published years ago in B5: 250 mm x 176 mm - 800 pages.
      Am looking to republish using Lightning Source. The closest match in size (hardback) is 254 mm x178mm.
      Whats the best approach here to reformat in 254 mm x178mm.
      Many thanks
      __________________________________________________
      LS - Our products
      We offer a wide variety of trim sizes, bindings and print stocks, as well as choices for distribution and delivery.
      Hardback books
      Hardcover books are available in case laminate, cloth or jacketed with marks of craftsmanship such as stamping available upon request.
      Current sizes: 216x140mm, 229x152mm, 234x156mm, 254x178mm, 280x216mm
      Paperback books
      Trade paperback books, available with perfect binding, are our most popular offering.
      Current sizes: 203 x 127 mm, 198 x 129 mm, 203 x 133 mm, 216 x 140 mm, 210 x 148 mm, 229 x 152 mm, 234 x 156 mm, 244 x 170 mm, 246 x 189 mm, 235 x 191 mm, 254 x 178 mm, 254 x 203 mm, 280 x 210 mm, 280 x 216 mm, 297mmx210mm
      Colour books
      Colour books are available through our US manufacturing facility in saddle-stitch, hardcover and perfect bindings starting with a page count of only 4 pages.
      Current sizes: 216x140mm, 229 x 152 mm, 234 x 156 mm, 254x178mm, 254x203mm, 216x216mm, 280x216mm
        • 1. Re: Resizing a Book
          Michael Gianino Level 4
          Do you need to keep the page count the same? What about the font size or the sizes of the graphics?
          • 2. Re: Resizing a Book
            Nigel Chapman Level 1
            Since you're only dealing with a difference of a few millimetres, you would probably be best to take it up in the margins. All you need to do is ensure that layout adjustment is off (Enable Layout Adjustment is unticked in the Layout>Layout Adjustment dialogue), then reset the page size using File>Document Setup.
            If you want the text box to expand to make use of your extra mm, make sure that Layout Adjustment is on, and all the options are checked. If you do this and there are graphics and call-out boxes, you will need to resize or move those by hand.
            If you want to be super professional and adjust the margins and text box at the same time to maintain the proportions, leave Layout Adjustment on and make the necessary changes in both File>Document Setup and Layout>Margins and Columns.
            You may also need to move and resize any frames, such as running headers, on master pages.
            As far as I know, if you have a book file with chapters in separate documents, you need to make the changes to each document.
            On the subject of margins, note that LS require a generous 13mm safety margin all round. If  your book was originally printed conventionally, you may not have had to leave so much, and might have to do the margin adjustment for that reason.
            • 3. Re: Resizing a Book
              Note that in CS6 Layout Adjustment has been hidden away in favor of Liquid Layout. To find Layout Adjustment you must now go to Layout > Liquid Layout and then open the Liquid Layout panel menu to get to the Layout Adjustment dialog.
              • 4. Re: Resizing a Book
                My apologies, I don't have CS6.
                • 5. Re: Resizing a Book
                  No problem. Just trying to head off the "I can't find Layout Adjustment" problem before it happens.
                  • 6. Re: Resizing a Book
                    geoff plunkett Level 1
                    Many thanks -will go away and give this a go.
                    Want to keep it simple so will keep page count, font size and graphics all the same. Yes, each chapter is in a separate folder.
                    Will use Indesign 5 if that is easier?
                    Best
