5 Replies Latest reply on Mar 20, 2013 3:09 AM by Ketki17
    Fail to access CRX with JcrUtils.getRepository
      I just started with CQ5/CRX/JCR, so I beg your pardon if asking silly questions.
      I'm running a CQ5 Standalone Server (CQ_5_5_Quickstart.jar) on my Windows 7 and am fine with accessing it with my browser and the URL "http://localhost:4502".
      Now I try to access it via a Java-client using the JcrUtils.getRepository-method, as described in http://dev.day.com/docs/en/crx/current/developing/accessing_the_crx.html.
      But this fails with message:
      javax.jcr.RepositoryException: Unable to access a repository with the following settings:
          org.apache.jackrabbit.repository.uri: http://localhost:4502/crx/server
      The following RepositoryFactory classes were consulted:
          org.apache.jackrabbit.commons.JndiRepositoryFactory: declined
      Perhaps the repository you are trying to access is not available at the moment.
      at org.apache.jackrabbit.commons.JcrUtils.getRepository(JcrUtils.java:199)
      at org.apache.jackrabbit.commons.JcrUtils.getRepository(JcrUtils.java:239)
      at AccessJCR.connectJcrUtils2(AccessJCR.java:32)
      at AccessJCR.main(AccessJCR.java:16)
      I'm not sure about the used URL; I just took it from cited webpage. There is said: "The default server's endpoint URL is http://host:port/crx/server. Make sure you adapt the client-side connection URL in case of customized server installation.".
      I didn't customize anything so this should be ok. I will attach the complete Code, hopefully you can give some hints.
      import java.util.*;
      import javax.jcr.*;
      public class AccessJCR {
            public AccessJCR() {}
            public static void main(String[] args) {
                 AccessJCR ajcr = new AccessJCR();
                 try {
                 catch (Exception ce) {
            private void connect() throws Exception {
                 //Create a connection to the Day CQ repository running on local host
                 Repository repository = org.apache.jackrabbit.commons.JcrUtils.getRepository("http://localhost:4502/crx/server");
