1 2 Previous Next 40 Replies Latest reply on Oct 28, 2015 7:07 PM by CaptMytre
    Why won't Photoshop create new files or open old ones after awhile?
    CaptMytre
      So, I've had this issue for about a month now, and is really infuriating.
      I installed the CS6 Master Suit trial version and after a little bit, I'd notice that after awhile of using photoshop, it wouldn't:
      • Open old files
      • Create new ones
      • Would slow down and start bugging out if I had a file open when the "event" occured.
      • Would be unable to save.
      After searching google, I found many suggestions, such as the default printer being a network printer that was not connected or that the preferances had been corrupted. None of these worked. I did a clean reinstall of windows, but this did not fix my problem. Now, I think I remember that there was an issue that I had like this years ago, and it was a windows update that screwed up photoshop, one of the K9XXXXXX such updates. Other than that, I have no leads except the fact that it is either hardware based or somehow the problem lingers after reinstall of windows.
      I've tried support, but of course they require you to have purchased it to get any help. So all I have is this forum. Please help.
      PC specs:
      Windows 64bit
      i7 950
      HD6970
      Rampage Gene III mobo
      12GB ram
      All drivers up to date
        • 1. Re: Why won't Photoshop create new files or open old ones after awhile?
          conroy Level 5
          If you are working directly with files on a server then that may be causing a problem for Photoshop. If so, try working with a local drive.
          • 2. Re: Why won't Photoshop create new files or open old ones after awhile?
            CaptMytre Level 1
            I am working off the hard drives inside my PC. This is a home computer. 2 x 1TB HDD
            • 3. Re: Why won't Photoshop create new files or open old ones after awhile?
              sudarshan.t Level 6
              How many days do you have left in your trial? Based on your post, you've mentioned you've had the issue for about a month now. Trials are only 30 days.
              • 4. Re: Why won't Photoshop create new files or open old ones after awhile?
                Could be anything from graphics cards issues to issues with temporary disk space. Nobody can know. Watch your resource monitor or use even more detailed tracking tools like Sysinternals' System Monitor to find performance issues and resource bottlenecks. and not to state the obvious: Do systeme maintenance and restart your computer every now and then. Seems a bnad habit in certain parts of the world to let machines run forever because electricity must be dang cheap...
                Mylenium
                • 5. Re: Why won't Photoshop create new files or open old ones after awhile?
                  CaptMytre Level 1
                  @Sudarshan
                  Trial is 30 days, reinstalling windows means I can start the trial again. Currently 27 days left.
                  @Mylenium
                  Isn't my graphics card, I've tested it with another one and I get the same issue. I've runs tests for RAM and both HDD, they are fine. I take care of my PC, never runs for more than 10 hours max.
                  • 6. Re: Why won't Photoshop create new files or open old ones after awhile?
                    Noel Carboni Level 8
                    Just a bit of advice:  You might want to avoid publicly admitting you're using the trial version illegally on the site of a company with well paid lawyers.
                    If your problem has persisted across an OS install then you must have a hardware combination for which the drivers are somehow faulty, possibly with some kind of resource leak.  Did you make sure and update everything to the latest version after the reinstall?
                    It's possible to run Adobe software without rebooting Windows...  I only ever reboot when Windows Update demands it.  I've been doing TONS of Photoshop stuff, and my machine's been up something like 6 days now...
                    -Noel
                    • 7. Re: Why won't Photoshop create new files or open old ones after awhile?
                      sudarshan.t Level 6
                      Just asked out of curiousity. No offense please!
                      When it doesn't respond, does it crash? If it does, can you post your crash report/ error log for PS?
                      • 8. Re: Why won't Photoshop create new files or open old ones after awhile?
                        CaptMytre Level 1
                        @Noel
                        I am using the same account that I got the first trial on, would be incredbily easy for Adobe to make it once per account their side.
                        The thing with the hardware, is that it worked fine for ages beforehand, and now only recently has it started to act up. I only turn off my PC over night, as I'm not using it, but there have been times before this problem that it would run for a couple of days due to a download off Steam.
                        @Sudarshan
                        None taken, sorry if it sounded angry.
                        Photoshops does not crash, it appears to be working perfectly until you try and do something. Eg, such as make a new file, I can click on New File, but it won't appear, and open file, which takes you to the Open File browser, but won't open anything.
                        If I have a file open and I want to save it, it allows me to go all the way though the save process, but it does not actually save it. Brush strokes won't register etc.
                        Remember, it will work fine for awhile after rebooting, but then the bug will "happen" and all of the above occurs.
                        I'm going to uninstall all windows updates tomorrow if I can and see if that fixes the problem, as I remember one of them was causing an issue with an older version of CS.
                        • 9. Re: Why won't Photoshop create new files or open old ones after awhile?
                          sudarshan.t Level 6
                          Okay. Can you still post your System Info by going to Help > System Info? Lets see if we can figure out why this is happening.
                          • 10. Re: Why won't Photoshop create new files or open old ones after awhile?
                            CaptMytre Level 1
                            Operating System: Windows 7 Home Premium 64-bit (6.1, Build 7601) Service Pack 1 (7601.win7sp1_gdr.120503-2030)
                            Language: English (Regional Setting: English)
                            System Manufacturer: System manufacturer
                            System Model: System Product Name
                            BIOS: BIOS Date: 09/21/10 11:28:44 Ver: 08.00.15
                            Processor: Intel(R) Core(TM) i7 CPU         950  @ 3.07GHz (4 CPUs), ~3.1GHz
                            Memory: 12288MB RAM
                            Available OS Memory: 12280MB RAM
                            Page File: 4540MB used, 20016MB available
                            Via DxDiag
                            • 11. Re: Why won't Photoshop create new files or open old ones after awhile?
                              sudarshan.t Level 6
                              This is not the full report. It's been truncated. Can you please ensure you paste the full report here?
                              • 12. Re: Why won't Photoshop create new files or open old ones after awhile?
                                CaptMytre Level 1
                                I highly doubt this will help with anything, but fine:
                                System Information
                                Time of this report: 9/29/2012, 23:52:52
                                       Machine name: CAPTMYTRE-PC
                                             Memory: 12288MB RAM
                                        Windows Dir: C:\Windows
                                    DirectX Version: DirectX 11
                                DX Setup Parameters: Not found
                                   User DPI Setting: Using System DPI
                                System DPI Setting: 96 DPI (100 percent)
                                    DWM DPI Scaling: Disabled
                                     DxDiag Version: 6.01.7601.17514 64bit Unicode
                                DxDiag Notes
                                      Display Tab 1: No problems found.
                                        Sound Tab 1: No problems found.
                                        Sound Tab 2: No problems found.
                                          Input Tab: No problems found.
                                DirectX Debug Levels
                                Direct3D:    0/4 (retail)
                                DirectDraw:  0/4 (retail)
                                DirectInput: 0/5 (retail)
                                DirectMusic: 0/5 (retail)
                                DirectPlay:  0/9 (retail)
                                DirectSound: 0/5 (retail)
                                DirectShow:  0/6 (retail)
                                Display Devices
                                          Card name: AMD Radeon HD 6900 Series
                                       Manufacturer: Advanced Micro Devices, Inc.
                                          Chip type: AMD Radeon Graphics Processor (0x6718)
                                           DAC type: Internal DAC(400MHz)
                                         Device Key: Enum\PCI\VEN_1002&DEV_6718&SUBSYS_0B001002&REV_00
                                     Display Memory: 3814 MB
                                   Dedicated Memory: 2026 MB
                                      Shared Memory: 1787 MB
                                       Current Mode: 1920 x 1080 (32 bit) (60Hz)
                                       Monitor Name: Dell S2309W(Digital)
                                      Monitor Model: DELL S2309W
                                         Monitor Id: DELA041
                                        Native Mode: 1920 x 1080(p) (60.000Hz)
                                        Output Type: DVI
                                        Driver Name: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
                                Driver File Version: 8.17.0010.1140 (English)
                                     Driver Version: 8.982.0.0
                                        DDI Version: 11
                                       Driver Model: WDDM 1.1
                                  Driver Attributes: Final Retail
                                   Driver Date/Size: 7/28/2012 12:13:56, 1100288 bytes
                                        WHQL Logo'd: Yes
                                    WHQL Date Stamp:
                                  Device Identifier: {D7B71EE2-2458-11CF-C677-0A2BBEC2C535}
                                          Vendor ID: 0x1002
                                          Device ID: 0x6718
                                          SubSys ID: 0x0B001002
                                        Revision ID: 0x0000
                                Driver Strong Name: oem4.inf:ATI.Mfg.NTamd64.6.1:ati2mtag_NICayman:8.982.0.0:pci\ven_1002&dev_6718
                                     Rank Of Driver: 00E62001
                                        Video Accel: ModeMPEG2_A ModeMPEG2_C
                                   Deinterlace Caps: {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YUY2,YUY2) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(UYVY,UYVY) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(YV12,0x32315659) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {3C5323C1-6FB7-44F5-9081-056BF2EE449D}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                     {552C0DAD-CCBC-420B-83C8-74943CF9F1A6}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,2) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                     {6E8329FF-B642-418B-BCF0-BCB6591E255F}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,1) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_PixelAdaptive
                                                     {335AA36E-7884-43A4-9C91-7F87FAF3E37E}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY DeinterlaceTech_BOBVerticalStretch
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(NV12,0x3231564e) Frames(Prev/Fwd/Back)=(0,0,0) Caps=VideoProcess_YUV2RGB VideoProcess_StretchX VideoProcess_StretchY
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC1,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC2,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC3,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(IMC4,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S340,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                                     {5A54A0C9-C7EC-4BD9-8EDE-F3C75DC4393B}: Format(In/Out)=(S342,UNKNOWN) Frames(Prev/Fwd/Back)=(0,0,0) Caps=
                                       D3D9 Overlay: Not Supported
                                            DXVA-HD: Not Supported
                                       DDraw Status: Enabled
                                         D3D Status: Enabled
                                         AGP Status: Enabled
                                Sound Devices
                                            Description: Speakers (VIA High Definition Audio)
                                Default Sound Playback: Yes
                                Default Voice Playback: Yes
                                            Hardware ID: HDAUDIO\FUNC_01&VEN_1106&DEV_0441&SUBSYS_1043846A&REV_1001
                                        Manufacturer ID: 1
                                             Product ID: 100
                                                   Type: WDM
                                            Driver Name: viahduaa.sys
                                         Driver Version: 6.00.0001.8500 (English)
                                            WHQL Logo'd: Yes
                                          Date and Size: 6/4/2010 04:40:34, 1335408 bytes
                                            Other Files:
                                        Driver Provider: VIA Technologies, Inc.
                                         HW Accel Level: Basic
                                              Cap Flags: 0xF1F
                                    Min/Max Sample Rate: 100, 200000
                                Static/Strm HW Mix Bufs: 1, 0
                                Static/Strm HW 3D Bufs: 0, 0
                                              HW Memory: 0
                                       Voice Management: No
                                EAX(tm) 2.0 Listen/Src: No, No
                                   I3DL2(tm) Listen/Src: No, No
                                Sensaura(tm) ZoomFX(tm): No
                                            Description: Headphone (VIA High Definition Audio)
                                Default Sound Playback: No
                                Default Voice Playback: No
                                        Manufacturer ID: 1
                                             Product ID: 100
                                                   Type: WDM
                                            WHQL Logo'd: Yes
                                            Other Files:
                                              Cap Flags: 0xF1F
                                              HW Memory: 0
                                Sound Capture Devices
                                            Description: Microphone (VIA High Definition Audio)
                                  Default Sound Capture: Yes
                                  Default Voice Capture: Yes
                                              Cap Flags: 0x1
                                           Format Flags: 0xFFFFF
                                            Description: Stereo Mix (VIA High Definition Audio)
                                  Default Sound Capture: No
                                  Default Voice Capture: No
                                              Cap Flags: 0x1
                                DirectInput Devices
                                      Device Name: Mouse
                                         Attached: 1
                                    Controller ID: n/a
                                Vendor/Product ID: n/a
                                        FF Driver: n/a
                                      Device Name: Keyboard
                                         Attached: 1
                                    Controller ID: n/a
                                        FF Driver: n/a
                                      Device Name: G19 Gaming Keyboard
                                         Attached: 1
                                    Controller ID: 0x0
                                Vendor/Product ID: 0x046D, 0xC228
                                        FF Driver: n/a
                                         Attached: 1
                                    Controller ID: 0x0
                                        FF Driver: n/a
                                      Device Name: G19 Gaming Keyboard (Macro interface)
                                         Attached: 1
                                    Controller ID: 0x0
                                Vendor/Product ID: 0x046D, 0xC229
                                        FF Driver: n/a
                                      Device Name: FootSwitchV1.1
                                         Attached: 1
                                    Controller ID: 0x0
                                Vendor/Product ID: 0x0C45, 0x7403
                                        FF Driver: n/a
                                      Device Name: G3
                                         Attached: 1
                                    Controller ID: 0x0
                                Vendor/Product ID: 0xE0FF, 0x0002
                                        FF Driver: n/a
                                      Device Name: G3
                                         Attached: 1
                                    Controller ID: 0x0
                                        FF Driver: n/a
                                Poll w/ Interrupt: No
                                USB Devices
                                + USB Root Hub
                                | Vendor/Product ID: 0x8086, 0x3A36
                                | Matching Device ID: usb\root_hub
                                | Service: usbhub
                                | Driver: usbhub.sys, 3/25/2011 13:29:26, 343040 bytes
                                | Driver: usbd.sys, 3/25/2011 13:28:59, 7936 bytes
                                Gameport Devices
                                PS/2 Devices
                                + HID Keyboard Device
                                | Matching Device ID: hid_device_system_keyboard
                                | Service: kbdhid
                                | Driver: kbdhid.sys, 11/21/2010 13:23:47, 33280 bytes
                                | Driver: kbdclass.sys, 7/14/2009 11:48:04, 50768 bytes
                                | Service: kbdhid
                                | Vendor/Product ID: 0x046D, 0xC232
                                | Service: kbdhid
                                | Service: kbdhid
                                | Service: kbdhid
                                + Terminal Server Keyboard Driver
                                | Matching Device ID: root\rdp_kbd
                                | Upper Filters: kbdclass
                                | Service: TermDD
                                | Driver: i8042prt.sys, 7/14/2009 09:19:57, 105472 bytes
                                + HID-compliant mouse
                                | Vendor/Product ID: 0x046D, 0xC231
                                | Matching Device ID: hid_device_system_mouse
                                | Service: mouhid
                                | Driver: mouhid.sys, 7/14/2009 10:00:20, 31232 bytes
                                | Driver: mouclass.sys, 7/14/2009 11:48:27, 49216 bytes
                                | Service: mouhid
                                | Service: mouhid
                                + Terminal Server Mouse Driver
                                | Matching Device ID: root\rdp_mou
                                | Upper Filters: mouclass
                                | Service: TermDD
                                | Driver: termdd.sys, 11/21/2010 13:23:47, 63360 bytes
                                | Driver: sermouse.sys, 7/14/2009 10:00:20, 26624 bytes
                                Disk & DVD/CD-ROM Drives
                                      Drive: C:
                                Free Space: 637.1 GB
                                Total Space: 953.8 GB
                                File System: NTFS
                                      Model: SAMSUNG HD103SJ ATA Device
                                      Drive: D:
                                Free Space: 504.3 GB
                                Total Space: 953.9 GB
                                File System: NTFS
                                      Drive: E:
                                      Model: HL-DT-ST BD-RE  BH10LS30 ATA Device
                                     Driver: c:\windows\system32\drivers\cdrom.sys, 6.01.7601.17514 (English), 11/21/2010 13:23:47, 147456 bytes
                                System Devices
                                     Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3A
                                Device ID: PCI\VEN_8086&DEV_3A3A&SUBSYS_82D41043&REV_00\3&11583659&0&EF
                                   Driver: C:\Windows\system32\drivers\usbehci.sys, 6.01.7601.17586 (English), 3/25/2011 13:29:04, 52736 bytes
                                   Driver: C:\Windows\system32\drivers\usbport.sys, 6.01.7601.17586 (English), 3/25/2011 13:29:14, 325120 bytes
                                   Driver: C:\Windows\system32\drivers\usbhub.sys, 6.01.7601.17586 (English), 3/25/2011 13:29:26, 343040 bytes
                                     Name: Standard Dual Channel PCI IDE Controller
                                Device ID: PCI\VEN_8086&DEV_3A26&SUBSYS_82D41043&REV_00\3&11583659&0&FD
                                   Driver: C:\Windows\system32\DRIVERS\pciide.sys, 6.01.7600.16385 (English), 7/14/2009 11:45:45, 12352 bytes
                                   Driver: C:\Windows\system32\DRIVERS\pciidex.sys, 6.01.7600.16385 (English), 7/14/2009 11:45:46, 48720 bytes
                                   Driver: C:\Windows\system32\DRIVERS\atapi.sys, 6.01.7600.16385 (English), 7/14/2009 11:52:21, 24128 bytes
                                   Driver: C:\Windows\system32\DRIVERS\ataport.sys, 6.01.7601.17514 (English), 11/21/2010 13:23:47, 155520 bytes
                                     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 3 - 340A
                                Device ID: PCI\VEN_8086&DEV_340A&SUBSYS_836B1043&REV_13\3&11583659&0&18
                                   Driver: C:\Windows\system32\DRIVERS\pci.sys, 6.01.7601.17514 (English), 11/21/2010 13:23:47, 184704 bytes
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A39
                                Device ID: PCI\VEN_8086&DEV_3A39&SUBSYS_82D41043&REV_00\3&11583659&0&D2
                                   Driver: C:\Windows\system32\drivers\usbuhci.sys, 6.01.7601.17586 (English), 3/25/2011 13:29:03, 30720 bytes
                                Device ID: PCI\VEN_8086&DEV_3A20&SUBSYS_82D41043&REV_00\3&11583659&0&FA
                                     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 2 - 3409
                                Device ID: PCI\VEN_8086&DEV_3409&SUBSYS_836B1043&REV_13\3&11583659&0&10
                                     Name: Universal Serial Bus (USB) Controller
                                Device ID: PCI\VEN_1033&DEV_0194&SUBSYS_84131043&REV_03\4&CF85AA7&0&0010
                                   Driver: n/a
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A38
                                Device ID: PCI\VEN_8086&DEV_3A38&SUBSYS_82D41043&REV_00\3&11583659&0&D1
                                     Name: Intel(R) ICH10R LPC Interface Controller - 3A16
                                Device ID: PCI\VEN_8086&DEV_3A16&SUBSYS_82D41043&REV_00\3&11583659&0&F8
                                   Driver: C:\Windows\system32\DRIVERS\msisadrv.sys, 6.01.7600.16385 (English), 7/14/2009 11:48:27, 15424 bytes
                                     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 1 - 3408
                                Device ID: PCI\VEN_8086&DEV_3408&SUBSYS_836B1043&REV_13\3&11583659&0&08
                                     Name: High Definition Audio Controller
                                Device ID: PCI\VEN_1002&DEV_AA80&SUBSYS_AA801002&REV_00\4&2F1C4782&0&0118
                                   Driver: C:\Windows\system32\DRIVERS\hdaudbus.sys, 6.01.7601.17514 (English), 11/21/2010 13:23:47, 122368 bytes
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A37
                                Device ID: PCI\VEN_8086&DEV_3A37&SUBSYS_82D41043&REV_00\3&11583659&0&D0
                                     Name: Intel(R) 5520/5500/X58 I/O Hub Throttle Registers - 3438
                                Device ID: PCI\VEN_8086&DEV_3438&SUBSYS_00000000&REV_13\3&11583659&0&A3
                                   Driver: n/a
                                     Name: Intel(R) 5520/5500/X58 I/O Hub to ESI Port - 3405
                                Device ID: PCI\VEN_8086&DEV_3405&SUBSYS_836B1043&REV_13\3&11583659&0&00
                                   Driver: n/a
                                     Name: AMD Radeon HD 6900 Series
                                Device ID: PCI\VEN_1002&DEV_6718&SUBSYS_0B001002&REV_00\4&2F1C4782&0&0018
                                   Driver: C:\Windows\system32\DRIVERS\atikmdag.sys, 8.01.0001.1253 (English), 7/28/2012 14:07:44, 10278912 bytes
                                   Driver: C:\Windows\system32\DRIVERS\ati2erec.dll, 1.00.0000.0024 (English), 7/28/2012 11:12:54, 53248 bytes
                                   Driver: C:\Windows\system32\DRIVERS\atikmpag.sys, 8.14.0001.6268 (English), 7/28/2012 11:14:46, 368640 bytes
                                   Driver: C:\Windows\system32\atiumd64.dll, 9.14.0010.0924 (English), 7/28/2012 11:25:52, 6676480 bytes
                                   Driver: C:\Windows\system32\atiumd6a.dll, 8.14.0010.0363 (English), 7/28/2012 11:41:32, 4266496 bytes
                                   Driver: C:\Windows\system32\atitmm64.dll, 6.14.0011.0023 (English), 7/28/2012 12:08:20, 120320 bytes
                                   Driver: C:\Windows\system32\atiicdxx.dat, 4/13/2012 05:30:10, 637743 bytes
                                   Driver: C:\Windows\system32\amdpcom64.dll, 8.14.0010.0023 (English), 7/28/2012 11:08:42, 56320 bytes
                                   Driver: C:\Windows\system32\atimpc64.dll, 8.14.0010.0023 (English), 7/28/2012 11:08:42, 56320 bytes
                                   Driver: C:\Windows\system32\atiadlxx.dll, 6.14.0010.1106 (English), 7/28/2012 11:15:32, 540160 bytes
                                   Driver: C:\Windows\system32\atiumd6a.cap, 7/28/2012 11:39:50, 3150560 bytes
                                   Driver: C:\Windows\system32\atimuixx.dll, 6.14.0010.1002 (English), 7/28/2012 12:08:04, 21504 bytes
                                   Driver: C:\Windows\system32\atiapfxx.exe, 6.14.0010.1001 (English), 7/28/2012 12:15:50, 163840 bytes
                                   Driver: C:\Windows\system32\ativvsva.dat, 7/28/2012 11:39:50, 157144 bytes
                                   Driver: C:\Windows\system32\ativvsvl.dat, 7/28/2012 11:39:50, 204952 bytes
                                   Driver: C:\Windows\system32\atiesrxx.exe, 6.14.0011.1126 (English), 7/28/2012 12:09:44, 239616 bytes
                                   Driver: C:\Windows\system32\atieclxx.exe, 6.14.0011.1126 (English), 7/28/2012 12:10:34, 534528 bytes
                                   Driver: C:\Windows\system32\atiedu64.dll, 6.14.0010.2514 (English), 7/28/2012 12:07:58, 59392 bytes
                                   Driver: C:\Windows\system32\ATIDEMGX.dll, 2.00.4591.38120 (English), 7/28/2012 12:10:40, 442368 bytes
                                   Driver: C:\Windows\system32\atio6axx.dll, 6.14.0010.11762 (English), 7/28/2012 13:19:34, 24935424 bytes
                                   Driver: C:\Windows\system32\aticaldd64.dll, 6.14.0010.1741 (English), 7/28/2012 11:34:48, 16034304 bytes
                                   Driver: C:\Windows\system32\aticalrt64.dll, 6.14.0010.1741 (English), 7/28/2012 11:35:10, 51200 bytes
                                   Driver: C:\Windows\system32\aticalcl64.dll, 6.14.0010.1741 (English), 7/28/2012 11:35:02, 44544 bytes
                                   Driver: C:\Windows\system32\atipblag.dat, 9/13/2011 08:06:16, 3917 bytes
                                   Driver: C:\Windows\system32\atiu9p64.dll, 8.14.0001.6268 (English), 7/28/2012 11:13:40, 103936 bytes
                                   Driver: C:\Windows\system32\atiuxp64.dll, 8.14.0001.6268 (English), 7/28/2012 11:13:54, 129536 bytes
                                   Driver: C:\Windows\system32\atig6pxx.dll, 8.14.0001.6268 (English), 7/28/2012 11:15:12, 17920 bytes
                                   Driver: C:\Windows\system32\atig6txx.dll, 8.14.0001.6268 (English), 7/28/2012 11:15:04, 41984 bytes
                                   Driver: C:\Windows\system32\atibtmon.exe, 2.00.0000.0000 (English), 5/11/2009 21:35:30, 118784 bytes
                                   Driver: C:\Windows\system32\atiapfxx.blb, 7/28/2012 12:17:00, 268728 bytes
                                   Driver: C:\Windows\system32\atidxx64.dll, 8.17.0010.0451 (English), 7/28/2012 11:51:12, 7052288 bytes
                                   Driver: C:\Windows\SysWOW64\atiumdag.dll, 9.14.0010.0924 (English), 7/28/2012 14:09:20, 5538984 bytes
                                   Driver: C:\Windows\SysWOW64\atiumdva.dll, 8.14.0010.0363 (English), 7/28/2012 11:32:32, 4751872 bytes
                                   Driver: C:\Windows\SysWOW64\amdpcom32.dll, 8.14.0010.0023 (English), 7/28/2012 11:08:36, 56832 bytes
                                   Driver: C:\Windows\SysWOW64\atimpc32.dll, 8.14.0010.0023 (English), 7/28/2012 11:08:36, 56832 bytes
                                   Driver: C:\Windows\SysWOW64\atiadlxy.dll, 6.14.0010.1106 (English), 7/28/2012 11:15:22, 368640 bytes
                                   Driver: C:\Windows\SysWOW64\atiumdva.cap, 7/28/2012 11:30:54, 3187136 bytes
                                   Driver: C:\Windows\SysWOW64\ativvsva.dat, 7/28/2012 11:39:50, 157144 bytes
                                   Driver: C:\Windows\SysWOW64\ativvsvl.dat, 7/28/2012 11:39:50, 204952 bytes
                                   Driver: C:\Windows\SysWOW64\ati2edxx.dll, 6.14.0010.2514 (English), 7/28/2012 12:07:52, 43520 bytes
                                   Driver: C:\Windows\SysWOW64\atioglxx.dll, 6.14.0010.11762 (English), 7/28/2012 12:50:10, 20546560 bytes
                                   Driver: C:\Windows\SysWOW64\atidxx32.dll, 8.17.0010.0451 (English), 7/28/2012 12:07:10, 6430208 bytes
                                   Driver: C:\Windows\SysWOW64\aticaldd.dll, 6.14.0010.1741 (English), 7/28/2012 11:30:10, 13605888 bytes
                                   Driver: C:\Windows\SysWOW64\aticalrt.dll, 6.14.0010.1741 (English), 7/28/2012 11:35:08, 46080 bytes
                                   Driver: C:\Windows\SysWOW64\aticalcl.dll, 6.14.0010.1741 (English), 7/28/2012 11:35:00, 44032 bytes
                                   Driver: C:\Windows\SysWOW64\atipblag.dat, 9/13/2011 08:06:16, 3917 bytes
                                   Driver: C:\Windows\SysWOW64\atiu9pag.dll, 8.14.0001.6268 (English), 7/28/2012 11:13:32, 83456 bytes
                                   Driver: C:\Windows\SysWOW64\atiuxpag.dll, 8.14.0001.6268 (English), 7/28/2012 11:13:48, 109568 bytes
                                   Driver: C:\Windows\SysWOW64\atigktxx.dll, 8.14.0001.6268 (English), 7/28/2012 11:14:56, 33280 bytes
                                   Driver: C:\Windows\SysWOW64\atiglpxx.dll, 8.14.0001.6268 (English), 7/28/2012 11:15:08, 14848 bytes
                                   Driver: C:\Windows\SysWOW64\atiapfxx.blb, 7/28/2012 12:17:00, 268728 bytes
                                   Driver: C:\Windows\atiogl.xml, 7/16/2012 19:33:18, 38557 bytes
                                   Driver: C:\Windows\system32\ATIODCLI.exe, 1.00.0000.0001 (English), 6/22/2009 15:34:36, 51200 bytes
                                   Driver: C:\Windows\system32\ATIODE.exe, 1.00.0000.0001 (English), 8/27/2010 18:33:08, 332800 bytes
                                   Driver: C:\Windows\system32\atiglpxx.dll, 8.14.0001.6268 (English), 7/28/2012 11:15:08, 14848 bytes
                                   Driver: C:\Windows\system32\aticfx64.dll, 8.17.0010.1140 (English), 7/28/2012 12:13:56, 1100288 bytes
                                   Driver: C:\Windows\SysWOW64\aticfx32.dll, 8.17.0010.1140 (English), 7/28/2012 12:15:42, 931328 bytes
                                   Driver: C:\Windows\system32\coinst_8.982.dll, 1.00.0004.0007 (English), 7/28/2012 13:43:12, 70144 bytes
                                     Name: Intel(R) ICH10 Family PCI Express Root Port 5 - 3A48
                                Device ID: PCI\VEN_8086&DEV_3A48&SUBSYS_82EA1043&REV_00\3&11583659&0&E4
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A36
                                Device ID: PCI\VEN_8086&DEV_3A36&SUBSYS_82D41043&REV_00\3&11583659&0&EA
                                     Name: Intel(R) 5520/5500/X58 I/O Hub System Management Registers - 342E
                                Device ID: PCI\VEN_8086&DEV_342E&SUBSYS_00000000&REV_13\3&11583659&0&A0
                                   Driver: n/a
                                     Name: Intel(R) 82801 PCI Bridge - 244E
                                Device ID: PCI\VEN_8086&DEV_244E&SUBSYS_82D41043&REV_90\3&11583659&0&F0
                                     Name: Intel(R) ICH10 Family PCI Express Root Port 1 - 3A40
                                Device ID: PCI\VEN_8086&DEV_3A40&SUBSYS_82EA1043&REV_00\3&11583659&0&E0
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A35
                                Device ID: PCI\VEN_8086&DEV_3A35&SUBSYS_82D41043&REV_00\3&11583659&0&E9
                                     Name: Intel(R) 5520/5500/X58 I/O Hub Control Status and RAS Registers - 3423
                                Device ID: PCI\VEN_8086&DEV_3423&SUBSYS_00000000&REV_13\3&11583659&0&A2
                                   Driver: n/a
                                     Name: Intel(R) 82567V-2 Gigabit Network Connection
                                Device ID: PCI\VEN_8086&DEV_10CE&SUBSYS_82D51043&REV_00\3&11583659&0&C8
                                   Driver: C:\Windows\system32\DRIVERS\e1y60x64.sys, 10.00.0002.0000 (English), 6/11/2009 06:35:02, 281088 bytes
                                Device ID: PCI\VEN_8086&DEV_3A3E&SUBSYS_82EA1043&REV_00\3&11583659&0&D8
                                     Name: Intel(R) ICH10 Family USB Universal Host Controller - 3A34
                                Device ID: PCI\VEN_8086&DEV_3A34&SUBSYS_82D41043&REV_00\3&11583659&0&E8
                                     Name: Intel(R) 5520/5500/X58 I/O Hub GPIO and Scratch Pad Registers - 3422
                                Device ID: PCI\VEN_8086&DEV_3422&SUBSYS_00000000&REV_13\3&11583659&0&A1
                                   Driver: n/a
                                Device ID: PCI\VEN_1B4B&DEV_91A3&SUBSYS_84001043&REV_11\4&37C265C7&0&0008
                                     Name: Intel(R) ICH10 Family USB Enhanced Host Controller - 3A3C
                                Device ID: PCI\VEN_8086&DEV_3A3C&SUBSYS_82D41043&REV_00\3&11583659&0&D7
                                     Name: Intel(R) ICH10 Family SMBus Controller - 3A30
                                Device ID: PCI\VEN_8086&DEV_3A30&SUBSYS_82D41043&REV_00\3&11583659&0&FB
                                   Driver: n/a
                                     Name: Intel(R) 5520/5500/X58 I/O Hub PCI Express Root Port 7 - 340E
                                Device ID: PCI\VEN_8086&DEV_340E&SUBSYS_836B1043&REV_13\3&11583659&0&38
                                     Name: VIA 1394 OHCI Compliant Host Controller
                                Device ID: PCI\VEN_1106&DEV_3403&SUBSYS_83841043&REV_00\4&28714A0B&0&00E4
                                   Driver: C:\Windows\system32\DRIVERS\1394ohci.sys, 6.01.7601.17514 (English), 11/21/2010 13:23:47, 229888 bytes
                                DirectShow Filters
                                DirectShow Filters:
                                WMAudio Decoder DMO,0x00800800,1,1,WMADMOD.DLL,6.01.7601.17514
                                WMAPro over S/PDIF DMO,0x00600800,1,1,WMADMOD.DLL,6.01.7601.17514
                                WMSpeech Decoder DMO,0x00600800,1,1,WMSPDMOD.DLL,6.01.7601.17514
                                MP3 Decoder DMO,0x00600800,1,1,mp3dmod.dll,6.01.7600.16385
                                Mpeg4s Decoder DMO,0x00800001,1,1,mp4sdecd.dll,6.01.7600.16385
                                WMV Screen decoder DMO,0x00600800,1,1,wmvsdecd.dll,6.01.7601.17514
                                WMVideo Decoder DMO,0x00800001,1,1,wmvdecod.dll,6.01.7601.17514
                                Mpeg43 Decoder DMO,0x00800001,1,1,mp43decd.dll,6.01.7600.16385
                                Mpeg4 Decoder DMO,0x00800001,1,1,mpg4decd.dll,6.01.7600.16385
                                DV Muxer,0x00400000,0,0,qdv.dll,6.06.7601.17514
                                Color Space Converter,0x00400001,1,1,quartz.dll,6.06.7601.17713
                                WM ASF Reader,0x00400000,0,0,qasf.dll,12.00.7601.17514
                                Screen Capture filter,0x00200000,0,1,wmpsrcwp.dll,12.00.7601.17514
                                AVI Splitter,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                VGA 16 Color Ditherer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                SBE2MediaTypeProfile,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                Microsoft DTV-DVD Video Decoder,0x005fffff,2,4,msmpeg2vdec.dll,6.01.7140.0000
                                AC3 Parser Filter,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                                StreamBufferSink,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                Microsoft TV Captions Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                                MJPEG Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                CBVA DMO wrapper filter,0x00200000,1,1,cbva.dll,6.01.7601.17514
                                MPEG-I Stream Splitter,0x00600000,1,2,quartz.dll,6.06.7601.17713
                                SAMI (CC) Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                VBI Codec,0x00600000,1,4,VBICodec.ax,6.06.7601.17514
                                MPEG-2 Splitter,0x005fffff,1,0,mpg2splt.ax,6.06.7601.17528
                                Closed Captions Analysis Filter,0x00200000,2,5,cca.dll,6.06.7601.17514
                                SBE2FileScan,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                Microsoft MPEG-2 Video Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                                Internal Script Command Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                                MPEG Audio Decoder,0x03680001,1,1,quartz.dll,6.06.7601.17713
                                DV Splitter,0x00600000,1,2,qdv.dll,6.06.7601.17514
                                Video Mixing Renderer 9,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                Microsoft MPEG-2 Encoder,0x00200000,2,1,msmpeg2enc.dll,6.01.7601.17514
                                ACM Wrapper,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                Video Renderer,0x00800001,1,0,quartz.dll,6.06.7601.17713
                                MPEG-2 Video Stream Analyzer,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                Line 21 Decoder,0x00600000,1,1,,
                                Video Port Manager,0x00600000,2,1,quartz.dll,6.06.7601.17713
                                Video Renderer,0x00400000,1,0,quartz.dll,6.06.7601.17713
                                VPS Decoder,0x00200000,0,0,WSTPager.ax,6.06.7601.17514
                                WM ASF Writer,0x00400000,0,0,qasf.dll,12.00.7601.17514
                                VBI Surface Allocator,0x00600000,1,1,vbisurf.ax,6.01.7601.17514
                                File writer,0x00200000,1,0,qcap.dll,6.06.7601.17514
                                iTV Data Sink,0x00600000,1,0,itvdata.dll,6.06.7601.17514
                                iTV Data Capture filter,0x00600000,1,1,itvdata.dll,6.06.7601.17514
                                DVD Navigator,0x00200000,0,3,qdvd.dll,6.06.7601.17835
                                Microsoft TV Subtitles Decoder,0x00200001,1,0,MSTVCapn.dll,6.01.7601.17715
                                Overlay Mixer2,0x00200000,1,1,,
                                RDP DShow Redirection Filter,0xffffffff,1,0,DShowRdpFilter.dll,
                                Microsoft MPEG-2 Audio Encoder,0x00200000,1,1,msmpeg2enc.dll,6.01.7601.17514
                                WST Pager,0x00200000,1,1,WSTPager.ax,6.06.7601.17514
                                MPEG-2 Demultiplexer,0x00600000,1,1,mpg2splt.ax,6.06.7601.17528
                                DV Video Decoder,0x00800000,1,1,qdv.dll,6.06.7601.17514
                                SampleGrabber,0x00200000,1,1,qedit.dll,6.06.7601.17514
                                Null Renderer,0x00200000,1,0,qedit.dll,6.06.7601.17514
                                MPEG-2 Sections and Tables,0x005fffff,1,0,Mpeg2Data.ax,6.06.7601.17514
                                Microsoft AC3 Encoder,0x00200000,1,1,msac3enc.dll,6.01.7601.17514
                                StreamBufferSource,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                Smart Tee,0x00200000,1,2,qcap.dll,6.06.7601.17514
                                Overlay Mixer,0x00200000,0,0,,
                                AVI Decompressor,0x00600000,1,1,quartz.dll,6.06.7601.17713
                                NetBridge,0x00200000,2,0,netbridge.dll,6.01.7601.17514
                                AVI/WAV File Source,0x00400000,0,2,quartz.dll,6.06.7601.17713
                                Wave Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                MIDI Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                Multi-file Parser,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                File stream renderer,0x00400000,1,1,quartz.dll,6.06.7601.17713
                                Microsoft DTV-DVD Audio Decoder,0x005fffff,1,1,msmpeg2adec.dll,6.01.7140.0000
                                StreamBufferSink2,0x00200000,0,0,sbe.dll,6.06.7601.17528
                                AVI Mux,0x00200000,1,0,qcap.dll,6.06.7601.17514
                                Line 21 Decoder 2,0x00600002,1,1,quartz.dll,6.06.7601.17713
                                File Source (Async.),0x00400000,0,1,quartz.dll,6.06.7601.17713
                                File Source (URL),0x00400000,0,1,quartz.dll,6.06.7601.17713
                                Media Center Extender Encryption Filter,0x00200000,2,2,Mcx2Filter.dll,6.01.7601.17514
                                AudioRecorder WAV Dest,0x00200000,0,0,WavDest.dll,
                                AudioRecorder Wave Form,0x00200000,0,0,WavDest.dll,
                                SoundRecorder Null Renderer,0x00200000,0,0,WavDest.dll,
                                Infinite Pin Tee Filter,0x00200000,1,1,qcap.dll,6.06.7601.17514
                                Enhanced Video Renderer,0x00200000,1,0,evr.dll,6.01.7601.17514
                                BDA MPEG2 Transport Information Filter,0x00200000,2,0,psisrndr.ax,6.06.7601.17669
                                MPEG Video Decoder,0x40000001,1,1,quartz.dll,6.06.7601.17713
                                WDM Streaming Tee/Splitter Devices:
                                Tee/Sink-to-Sink Converter,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                Video Compressors:
                                WMVideo8 Encoder DMO,0x00600800,1,1,wmvxencd.dll,6.01.7600.16385
                                WMVideo9 Encoder DMO,0x00600800,1,1,wmvencod.dll,6.01.7600.16385
                                MSScreen 9 encoder DMO,0x00600800,1,1,wmvsencd.dll,6.01.7600.16385
                                DV Video Encoder,0x00200000,0,0,qdv.dll,6.06.7601.17514
                                MJPEG Compressor,0x00200000,0,0,quartz.dll,6.06.7601.17713
                                Audio Compressors:
                                WM Speech Encoder DMO,0x00600800,1,1,WMSPDMOE.DLL,6.01.7600.16385
                                WMAudio Encoder DMO,0x00600800,1,1,WMADMOE.DLL,6.01.7600.16385
                                IMA ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                Microsoft ADPCM,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                GSM 6.10,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                CCITT A-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                CCITT u-Law,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                MPEG Layer-3,0x00200000,1,1,quartz.dll,6.06.7601.17713
                                Audio Capture Sources:
                                Microphone (VIA High Definition,0x00200000,0,0,qcap.dll,6.06.7601.17514
                                Stereo Mix (VIA High Definition,0x00200000,0,0,qcap.dll,6.06.7601.17514
                                PBDA CP Filters:
                                PBDA DTFilter,0x00600000,1,1,CPFilters.dll,6.06.7601.17528
                                PBDA ETFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                                PBDA PTFilter,0x00200000,0,0,CPFilters.dll,6.06.7601.17528
                                Midi Renderers:
                                Default MidiOut Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                                Microsoft GS Wavetable Synth,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                WDM Streaming Capture Devices:
                                VIA HD Audio Line In,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                VIA HD Audio Microphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                VIA HD Audio Stereo Mixer,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                WDM Streaming Rendering Devices:
                                HD Audio digital out,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                VIA HD Audio Headphone,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                VIA HD Audio Output,0x00200000,1,1,ksproxy.ax,6.01.7601.17514
                                BDA Network Providers:
                                Microsoft ATSC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                Microsoft DVBC Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                Microsoft DVBS Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                Microsoft DVBT Network Provider,0x00200000,0,1,MSDvbNP.ax,6.06.7601.17514
                                Microsoft Network Provider,0x00200000,0,1,MSNP.ax,6.06.7601.17514
                                Multi-Instance Capable VBI Codecs:
                                BDA Transport Information Renderers:
                                BDA MPEG2 Transport Information Filter,0x00600000,2,0,psisrndr.ax,6.06.7601.17669
                                MPEG-2 Sections and Tables,0x00600000,1,0,Mpeg2Data.ax,6.06.7601.17514
                                BDA CP/CA Filters:
                                Decrypt/Tag,0x00600000,1,1,EncDec.dll,6.06.7601.17708
                                Encrypt/Tag,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                PTFilter,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                XDS Codec,0x00200000,0,0,EncDec.dll,6.06.7601.17708
                                WDM Streaming Communication Transforms:
                                Audio Renderers:
                                Speakers (VIA High Definition A,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                Default DirectSound Device,0x00800000,1,0,quartz.dll,6.06.7601.17713
                                Default WaveOut Device,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                DirectSound: Headphone (VIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                                DirectSound: Speakers (VIA High Definition Audio),0x00200000,1,0,quartz.dll,6.06.7601.17713
                                Headphone (VIA High Definition ,0x00200000,1,0,quartz.dll,6.06.7601.17713
                                EVR Power Information
                                Current Setting: {5C67A112-A4C9-483F-B4A7-1D473BECAFDC} (Quality)
                                  Quality Flags: 2576
                                    Enabled:
                                    Force throttling
                                    Allow half deinterlace
                                    Allow scaling
                                    Decode Power Usage: 100
                                  Balanced Flags: 1424
                                    Enabled:
                                    Force throttling
                                    Allow batching
                                    Force half deinterlace
                                    Force scaling
                                    Decode Power Usage: 50
                                  PowerFlags: 1424
                                    Enabled:
                                    Force throttling
                                    Allow batching
                                    Force scaling
                                    Decode Power Usage: 0
                                • 13. Re: Why won't Photoshop create new files or open old ones after awhile?
                                  sudarshan.t Level 6
                                  Just wanted to check if there was a failure on a component loader. Your report seems fine. That's ruled out.
                                  Have you installed any Photoshop plug-ins?
                                  • 15. Re: Why won't Photoshop create new files or open old ones after awhile?
                                    That's not the Help - System Info... report from Photoshop.
                                    -Noel
                                    • 16. Re: Why won't Photoshop create new files or open old ones after awhile?
                                      sudarshan.t Level 6
                                      Noel, thanks for pointing that out. My bad, I failed to notice the full info - I replied from my phone browser earlier!
                                      @CapMytre, this is the Windows sytem report, please post your PS system report! Sorry about the confusion.
                                      • 17. Re: Why won't Photoshop create new files or open old ones after awhile?
                                        CaptMytre Level 1
                                        Adobe Photoshop Version: 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00) x64
                                        Operating System: Windows 7 64-bit
                                        Version: 6.1 Service Pack 1
                                        System architecture: Intel CPU Family:6, Model:10, Stepping:5 with MMX, SSE Integer, SSE FP, SSE2, SSE3, SSE4.1, SSE4.2
                                        Physical processor count: 4
                                        Processor speed: 3070 MHz
                                        Built-in memory: 12279 MB
                                        Free memory: 10164 MB
                                        Memory available to Photoshop: 10999 MB
                                        Memory used by Photoshop: 70 %
                                        Image tile size: 128K
                                        Image cache levels: 4
                                        OpenGL Drawing: Enabled.
                                        OpenGL Drawing Mode: Advanced
                                        OpenGL Allow Normal Mode: True.
                                        OpenGL Allow Advanced Mode: True.
                                        OpenGL Allow Old GPUs: Not Detected.
                                        Video Card Vendor: ATI Technologies Inc.
                                        Video Card Renderer: AMD Radeon HD 6900 Series
                                        Display: 1
                                        Display Bounds:=  top: 0, left: 0, bottom: 1080, right: 1920
                                        Video Card Number: 1
                                        Video Card: AMD Radeon HD 6900 Series
                                        OpenCL Unavailable
                                        Driver Date: 20120727000000.000000-000
                                        Video Card Driver: aticfx64.dll,aticfx64.dll,aticfx64.dll,aticfx32,aticfx32,aticfx32,atiumd64.dll,atidxx64.d ll,atidxx64.dll,atiumdag,atidxx32,atidxx32,atiumdva,atiumd6a.cap,atitmm64.dll
                                        Video Mode: 1920 x 1080 x 4294967296 colors
                                        Video Card Caption: AMD Radeon HD 6900 Series
                                        Video Card Memory: 2048 MB
                                        Video Rect Texture Size: 16384
                                        Serial number: Tryout Version
                                        Application folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\
                                        Temporary file path: C:\Users\CAPT~1.MYT\AppData\Local\Temp\
                                        Photoshop scratch has async I/O enabled
                                        Scratch volume(s):
                                          Startup, 931.4G, 621.6G free
                                        Required Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Required\
                                        Primary Plug-ins folder: C:\Program Files\Adobe\Adobe Photoshop CS6 (64 Bit)\Plug-ins\
                                        Additional Plug-ins folder: not set
                                        Installed components:
                                           A3DLIBS.dll   A3DLIB Dynamic Link Library   9.2.0.112
                                           ACE.dll   ACE 2012/06/05-15:16:32   66.507768   66.507768
                                           adbeape.dll   Adobe APE 2012/01/25-10:04:55   66.1025012   66.1025012
                                           AdobeLinguistic.dll   Adobe Linguisitc Library   6.0.0
                                           AdobeOwl.dll   Adobe Owl 2012/06/26-12:17:19   4.0.95   66.510504
                                           AdobePDFL.dll   PDFL 2011/12/12-16:12:37   66.419471   66.419471
                                           AdobePIP.dll   Adobe Product Improvement Program   6.0.0.1654
                                           AdobeXMP.dll   Adobe XMP Core 2012/02/06-14:56:27   66.145661   66.145661
                                           AdobeXMPFiles.dll   Adobe XMP Files 2012/02/06-14:56:27   66.145661   66.145661
                                           AdobeXMPScript.dll   Adobe XMP Script 2012/02/06-14:56:27   66.145661   66.145661
                                           adobe_caps.dll   Adobe CAPS   6,0,29,0
                                           AGM.dll   AGM 2012/06/05-15:16:32   66.507768   66.507768
                                           ahclient.dll    AdobeHelp Dynamic Link Library   1,7,0,56
                                           aif_core.dll   AIF   3.0   62.490293
                                           aif_ocl.dll   AIF   3.0   62.490293
                                           aif_ogl.dll   AIF   3.0   62.490293
                                           amtlib.dll   AMTLib (64 Bit)   6.0.0.75 (BuildVersion: 6.0; BuildDate: Mon Jan 16 2012 18:00:00)   1.000000
                                           ARE.dll   ARE 2012/06/05-15:16:32   66.507768   66.507768
                                           AXE8SharedExpat.dll   AXE8SharedExpat 2011/12/16-15:10:49   66.26830   66.26830
                                           AXEDOMCore.dll   AXEDOMCore 2011/12/16-15:10:49   66.26830   66.26830
                                           Bib.dll   BIB 2012/06/05-15:16:32   66.507768   66.507768
                                           BIBUtils.dll   BIBUtils 2012/06/05-15:16:32   66.507768   66.507768
                                           boost_date_time.dll   DVA Product   6.0.0
                                           boost_signals.dll   DVA Product   6.0.0
                                           boost_system.dll   DVA Product   6.0.0
                                           boost_threads.dll   DVA Product   6.0.0
                                           cg.dll   NVIDIA Cg Runtime   3.0.00007
                                           cgGL.dll   NVIDIA Cg Runtime   3.0.00007
                                           CIT.dll   Adobe CIT   2.0.5.19287   2.0.5.19287
                                           CoolType.dll   CoolType 2012/06/05-15:16:32   66.507768   66.507768
                                           data_flow.dll   AIF   3.0   62.490293
                                           dvaaudiodevice.dll   DVA Product   6.0.0
                                           dvacore.dll   DVA Product   6.0.0
                                           dvamarshal.dll   DVA Product   6.0.0
                                           dvamediatypes.dll   DVA Product   6.0.0
                                           dvaplayer.dll   DVA Product   6.0.0
                                           dvatransport.dll   DVA Product   6.0.0
                                           dvaunittesting.dll   DVA Product   6.0.0
                                           dynamiclink.dll   DVA Product   6.0.0
                                           ExtendScript.dll   ExtendScript 2011/12/14-15:08:46   66.490082   66.490082
                                           FileInfo.dll   Adobe XMP FileInfo 2012/01/17-15:11:19   66.145433   66.145433
                                           filter_graph.dll   AIF   3.0   62.490293
                                           hydra_filters.dll   AIF   3.0   62.490293
                                           icucnv40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                                           icudt40.dll   International Components for Unicode 2011/11/15-16:30:22    Build gtlib_3.0.16615
                                           image_compiler.dll   AIF   3.0   62.490293
                                           image_flow.dll   AIF   3.0   62.490293
                                           image_runtime.dll   AIF   3.0   62.490293
                                           JP2KLib.dll   JP2KLib 2011/12/12-16:12:37   66.236923   66.236923
                                           libifcoremd.dll   Intel(r) Visual Fortran Compiler   10.0 (Update A)
                                           libmmd.dll   Intel(r) C Compiler, Intel(r) C++ Compiler, Intel(r) Fortran Compiler   10.0
                                           LogSession.dll   LogSession   2.1.2.1640
                                           mediacoreif.dll   DVA Product   6.0.0
                                           MPS.dll   MPS 2012/02/03-10:33:13   66.495174   66.495174
                                           msvcm80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                                           msvcm90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                           msvcp100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                                           msvcp80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                                           msvcp90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                           msvcr100.dll   Microsoft® Visual Studio® 2010   10.00.40219.1
                                           msvcr80.dll   Microsoft® Visual Studio® 2005   8.00.50727.6195
                                           msvcr90.dll   Microsoft® Visual Studio® 2008   9.00.30729.1
                                           pdfsettings.dll   Adobe PDFSettings   1.04
                                           Photoshop.dll   Adobe Photoshop CS6   CS6
                                           Plugin.dll   Adobe Photoshop CS6   CS6
                                           PlugPlug.dll   Adobe(R) CSXS PlugPlug Standard Dll (64 bit)   3.0.0.383
                                           PSArt.dll   Adobe Photoshop CS6   CS6
                                           PSViews.dll   Adobe Photoshop CS6   CS6
                                           SCCore.dll   ScCore 2011/12/14-15:08:46   66.490082   66.490082
                                           ScriptUIFlex.dll   ScriptUIFlex 2011/12/14-15:08:46   66.490082   66.490082
                                           tbb.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                                           tbbmalloc.dll   Intel(R) Threading Building Blocks for Windows   3, 0, 2010, 0406
                                           TfFontMgr.dll   FontMgr   9.3.0.113
                                           TfKernel.dll   Kernel   9.3.0.113
                                           TFKGEOM.dll   Kernel Geom   9.3.0.113
                                           TFUGEOM.dll   Adobe, UGeom©   9.3.0.113
                                           updaternotifications.dll   Adobe Updater Notifications Library   6.0.0.24 (BuildVersion: 1.0; BuildDate: BUILDDATETIME)   6.0.0.24
                                           WRServices.dll   WRServices Friday January 27 2012 13:22:12   Build 0.17112   0.17112
                                           wu3d.dll   U3D Writer   9.3.0.113
                                        Required plug-ins:
                                           3D Studio 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Accented Edges 13.0
                                           Adaptive Wide Angle 13.0
                                           ADM 3.11x01
                                           Angled Strokes 13.0
                                           Average 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Bas Relief 13.0
                                           BMP 13.0
                                           Camera Raw 7.1
                                           Chalk & Charcoal 13.0
                                           Charcoal 13.0
                                           Chrome 13.0
                                           Cineon 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Collada 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Color Halftone 13.0
                                           Colored Pencil 13.0
                                           CompuServe GIF 13.0
                                           Conté Crayon 13.0
                                           Craquelure 13.0
                                           Crop and Straighten Photos 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Crop and Straighten Photos Filter 13.0
                                           Crosshatch 13.0
                                           Crystallize 13.0
                                           Cutout 13.0
                                           Dark Strokes 13.0
                                           De-Interlace 13.0
                                           Dicom 13.0
                                           Difference Clouds 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Diffuse Glow 13.0
                                           Displace 13.0
                                           Dry Brush 13.0
                                           Eazel Acquire 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Embed Watermark 4.0
                                           Entropy 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Extrude 13.0
                                           FastCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Fibers 13.0
                                           Film Grain 13.0
                                           Filter Gallery 13.0
                                           Flash 3D 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Fresco 13.0
                                           Glass 13.0
                                           Glowing Edges 13.0
                                           Google Earth 4 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Grain 13.0
                                           Graphic Pen 13.0
                                           Halftone Pattern 13.0
                                           HDRMergeUI 13.0
                                           IFF Format 13.0
                                           Ink Outlines 13.0
                                           JPEG 2000 13.0
                                           Kurtosis 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Lens Blur 13.0
                                           Lens Correction 13.0
                                           Lens Flare 13.0
                                           Liquify 13.0
                                           Matlab Operation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Maximum 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Mean 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Measurement Core 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Median 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Mezzotint 13.0
                                           Minimum 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           MMXCore Routines 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Mosaic Tiles 13.0
                                           Multiprocessor Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Neon Glow 13.0
                                           Note Paper 13.0
                                           NTSC Colors 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Ocean Ripple 13.0
                                           Oil Paint 13.0
                                           OpenEXR 13.0
                                           Paint Daubs 13.0
                                           Palette Knife 13.0
                                           Patchwork 13.0
                                           Paths to Illustrator 13.0
                                           PCX 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Photocopy 13.0
                                           Photoshop 3D Engine 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Picture Package Filter 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Pinch 13.0
                                           Pixar 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Plaster 13.0
                                           Plastic Wrap 13.0
                                           PNG 13.0
                                           Pointillize 13.0
                                           Polar Coordinates 13.0
                                           Portable Bit Map 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Poster Edges 13.0
                                           Radial Blur 13.0
                                           Radiance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Range 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Read Watermark 4.0
                                           Reticulation 13.0
                                           Ripple 13.0
                                           Rough Pastels 13.0
                                           Save for Web 13.0
                                           ScriptingSupport 13.0.1
                                           Shear 13.0
                                           Skewness 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Smart Blur 13.0
                                           Smudge Stick 13.0
                                           Solarize 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Spatter 13.0
                                           Spherize 13.0
                                           Sponge 13.0
                                           Sprayed Strokes 13.0
                                           Stained Glass 13.0
                                           Stamp 13.0
                                           Standard Deviation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Sumi-e 13.0
                                           Summation 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Targa 13.0
                                           Texturizer 13.0
                                           Tiles 13.0
                                           Torn Edges 13.0
                                           Twirl 13.0
                                           U3D 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Underpainting 13.0
                                           Vanishing Point 13.0
                                           Variance 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Variations 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Water Paper 13.0
                                           Watercolor 13.0
                                           Wave 13.0
                                           Wavefront|OBJ 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           WIA Support 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           Wind 13.0
                                           Wireless Bitmap 13.0.1 (13.0.1 20120808.r.519 2012/08/08:21:00:00)
                                           ZigZag 13.0
                                        Optional and third party plug-ins: NONE
                                        Plug-ins that failed to load: NONE
                                        Flash:
                                           Mini Bridge
                                           Kuler
                                        Installed TWAIN devices: NONE
                                        • 18. Re: Why won't Photoshop create new files or open old ones after awhile?
                                          sudarshan.t Level 6
                                          Nothing seems to be wrong with your PS report as well.
                                          You said you had this issue even when you re-installed Windows earlier. Can you try re-downloading just Photoshop CS6 from the Adobe website as a trial and install it to see if that fixes it? Maybe a faulty/ corrupt download or installation?
                                          • 19. Re: Why won't Photoshop create new files or open old ones after awhile?
                                            CaptMytre Level 1
                                            I'll give it a try, but I am not able to just yet. This problem originally occured with CS5 btw.
                                            • 20. Re: Why won't Photoshop create new files or open old ones after awhile?
                                              CaptMytre Level 1
                                              Ok, think I found the fix. It was a windows update, not sure which one, just rolled back to stock install. Will post back here if it isn't.
                                              • 21. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                CaptMytre Level 1
                                                Ok, that didn't fix it... beyond annoying. Only thing I can think of now is that it is either a hardware or driver conflict.
                                                • 22. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                  CaptMytre Level 1
                                                  Revilation, making a new account allows me to use photoshop, while my old account still won't be able to use it. Don't know where that points the issue at.
                                                  • 23. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                    Level 7
                                                    Some system preference or registry setting is off on the old account.  But I don't know what it might be...
                                                    • 24. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                      CaptMytre Level 1
                                                      Another thing that I've noticed, I opened up 64 images in photoshop to see if it was a RAM issue, hitting 2.4GB ram useage by photoshop. I closed all the images, and photoshops ram usage has not dropped...
                                                      In terms of the accounts, I've yet to use photoshop long enough for the problem to occur, but when the bug occurs on my primary account, I can then change accounts and it works on the secondary account.
                                                      Honestly, it is looking like I either have to buy a laptop or replace components in my PC until it works.
                                                      • 25. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                        Perfectly normal and expected.  Photoshop will actually free that memory up if it senses the system struggling to scrape up memory for something else.
                                                        We have debated whether this the best approach here a number of times, and it's really come down to being impossible to define "best" in a way that both Adobe engineering and users would always agree on.  Adobe feels optimizing its memory use for its own application's performance is best, and a user might feel that freeing up the memory for other things is best, and both would be right under certain circumstances.
                                                        -Noel
                                                        • 26. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                          CaptMytre Level 1
                                                          K, thanks. Thought that might have been the issue to do with the issue, but I suppose that clears that one up.
                                                          • 27. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                            Photofixerupper
                                                            I've had the same problem my copy of Photoshop but now I got mine working again.
                                                            The basic problem seems to be coming from Adobe Service Manager.
                                                            If you run Task Manager, you'll see (Under Processes section) a process named CS5ServiceManager.exe (or depending on your version the name should be something equivalent).
                                                            Click on that process then click End Process in Task Manager.
                                                            Quickly go to Photoshop then try to open or create a new document before that process respawns.
                                                            If Photoshop works as expected, then you've found the root of your problem!
                                                            -- 1). Easy way to fix this is click Start->Run, then type in "msconfig"
                                                            -- 2). Under the Startup section, make sure CS5ServiceManager.exe is unchecked.
                                                            -- 3). Reboot, and now you shouldn't have problems with Photoshop!
                                                            I hope that was helpful.
                                                            - Cheers!
                                                            • 28. Re: Why won't Photoshop create new files or open old ones after awhile?
                                                              dwc81
                                                              I had same problem on CS5, then CS6 on two different machines (very different machines): Possible fix - works for me!
                                                              Type into start menu %TEMP% press enter.
                                                              Delete everything
                                                              Reboot
                                                              Seems to be ok for now.... fingers crossed.
                                                              • 29. Re: Why won't Photoshop create new files or open old ones after awhile?
        dwc81 Level 1
        My fix above does not work (well it did for a day or so!)
        • 30. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre Level 1
        I've tried both of the above fixes, but it hasn't fixed my issue. Quite annoyed to be honest.
        • 31. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre, in what - a year and a half - no one has come along and solved your problem for you.  That may say the problem is indeed with your system.
        While Photoshop is not bug-free, it certainly doesn't do what you've described for everyone.  That you've seen it persist through even OS reinstallations DOES say that you have something specific about your system that's broken.
        I'm on my 10th day of my current bootup (I don't shut my systems off), and I use Photoshop quite heavily.  It *never* fails to open or save files - and never has.  That says to me that there's not an inherent, systemic problem with Photoshop, but rather there must be a problem with something in the system environment of a particular system on which these problems are seen.
        So let's try to diagnose it a bit further, what do you say?
        Please go into Photoshop and choose Help - System Info, copy the results, and paste them into a post here.  Also, scour your WIndows event logs for information logged at the time you are seeing failures.  With this info we can try again to diagnose what's wrong with your system.
        I'm reminded of a time quite a few years ago when I first upgraded to Windows Vista.  My experience was horrible - a whole bunch of things were going wrong.  I finally got fed up enough to buy a new video card, throwing out a (very expensive) nVidia workstation card I was trying to use.  Lo and behold everything got better.  I had tried all the different drivers nVidia had released, and tweaked everything you could imagine, but it took REPLACING a faulty part before things settled down.
        -Noel
        • 32. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre Level 1
        Yeah, as I originally suggested, I feel it's a hardware issue. Interestingly enought a friend of mine has the same issue, I'll see if we share any specific features in terms of hardware.
        It should also be mentioned that I've purchased an actual licence for CS6 now, which works fine on my laptop but still is bugged on my desktop.
        As for the System Info:
        Adobe Photoshop Version: 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00) x64
        Version: 6.1
        Free memory: 8794 MB
        Memory available to Photoshop: 10961 MB
        Memory used by Photoshop: 68 %
        Display: 2
        Display Bounds:=  top: 0, left: -1680, bottom: 1050, right: 0
        Display: 1
        OpenCL Unavailable
        Driver Version: 13.250.18.0
        Driver Date: 20131029000000.000000-000
        Serial number: 92298170854478279439
        Scratch volume(s):
        C:\, 931.4G, 56.9G free
        ACE.dll   ACE 2012/01/18-15:07:40   66.492997   66.492997
        AdobeOwl.dll   Adobe Owl 2012/02/09-16:00:02   4.0.93   66.496052
        AGM.dll   AGM 2012/01/18-15:07:40   66.492997   66.492997
        ARE.dll   ARE 2012/01/18-15:07:40   66.492997   66.492997
        Bib.dll   BIB 2012/01/18-15:07:40   66.492997   66.492997
        BIBUtils.dll   BIBUtils 2012/01/18-15:07:40   66.492997   66.492997
        CoolType.dll   CoolType 2012/01/18-15:07:40   66.492997   66.492997
        Required plug-ins:
        3D Studio 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Accented Edges 13.0
        ADM 3.11x01
        Angled Strokes 13.0
        Average 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Bas Relief 13.0
        BMP 13.0
        Camera Raw 8.2
        Camera Raw Filter 8.2
        Charcoal 13.0
        Chrome 13.0
        Cineon 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Collada 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Color Halftone 13.0
        Colored Pencil 13.0
        CompuServe GIF 13.0
        Conté Crayon 13.0
        Craquelure 13.0
        Crop and Straighten Photos 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Crosshatch 13.0
        Crystallize 13.0
        Cutout 13.0
        Dark Strokes 13.0
        De-Interlace 13.0
        Dicom 13.0
        Difference Clouds 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Diffuse Glow 13.0
        Displace 13.0
        Dry Brush 13.0
        Eazel Acquire 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Embed Watermark 4.0
        Entropy 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Extrude 13.0
        FastCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Fibers 13.0
        Film Grain 13.0
        Filter Gallery 13.0
        Flash 3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Fresco 13.0
        Glass 13.0
        Glowing Edges 13.0
        Google Earth 4 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Grain 13.0
        Graphic Pen 13.0
        HDRMergeUI 13.0
        IFF Format 13.0
        Ink Outlines 13.0
        JPEG 2000 13.0
        Kurtosis 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Lens Blur 13.0
        Lens Flare 13.0
        Liquify 13.0
        Matlab Operation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Maximum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Mean 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Measurement Core 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Median 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Mezzotint 13.0
        Minimum 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        MMXCore Routines 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Mosaic Tiles 13.0
        Multiprocessor Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Neon Glow 13.0
        Note Paper 13.0
        NTSC Colors 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Ocean Ripple 13.0
        Oil Paint 13.0
        OpenEXR 13.0
        Paint Daubs 13.0
        Palette Knife 13.0
        Patchwork 13.0
        PCX 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Photocopy 13.0
        Photoshop 3D Engine 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Picture Package Filter 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Pinch 13.0
        Pixar 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Plaster 13.0
        Plastic Wrap 13.0
        PNG 13.0
        Pointillize 13.0
        Portable Bit Map 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Poster Edges 13.0
        Radial Blur 13.0
        Radiance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Range 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Read Watermark 4.0
        Reticulation 13.0
        Ripple 13.0
        Rough Pastels 13.0
        Save for Web 13.0
        Shear 13.0
        Skewness 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Smart Blur 13.0
        Smudge Stick 13.0
        Solarize 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Spatter 13.0
        Spherize 13.0
        Sponge 13.0
        Stained Glass 13.0
        Stamp 13.0
        Standard Deviation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Sumi-e 13.0
        Summation 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Targa 13.0
        Texturizer 13.0
        Tiles 13.0
        Torn Edges 13.0
        Twirl 13.0
        U3D 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Underpainting 13.0
        Variance 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Variations 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Water Paper 13.0
        Watercolor 13.0
        Wave 13.0
        Wavefront|OBJ 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        WIA Support 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        Wind 13.0
        Wireless Bitmap 13.0 (13.0 20120315.r.428 2012/03/15:21:00:00)
        ZigZag 13.0
        Flash:
        Mini Bridge
        Kuler
        • 33. Re: Why won't Photoshop create new files or open old ones after awhile?
        Level 7
        First, go install the CS6 updates.  You haven't installed any of the updates.
        • 34. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre Level 1
        I just checked if there were any updates, said there wasn't any for photoshop. I actually have the issue right now, so that could be why. I'll check the error log.
        • 35. Re: Why won't Photoshop create new files or open old ones after awhile?
        Level 7
        There are updates, but you have not installed them for some reason.
        • 36. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre Level 1
        Is there a way to force check that everything is correct? Checking for updates via photoshop didn't bring up anything. It did have updates for other products I have though.
        • 37. Re: Why won't Photoshop create new files or open old ones after awhile?
        dwc81 Level 1
        I've posted a few times over the years about this - had the same issue on various machines, various versions of photoshop, various OS. No one at Adobe seems to admit it's a problem and just say its your systems fault. I must just be really unlucky if that's the case.
        The PC im using now had the problem on CS6 & CS4 (had them both installed). Last week by buying a new GFX card (upgraded a Quadro 4000 to a K4000) the problem has gone but I fully exepct it to come back at some point. It's does not seem to be a logical problem so is so hard to trouble shoot.
        Good luck CaptMytre. I feel for you!
        • 38. Re: Why won't Photoshop create new files or open old ones after awhile?
        PECourtejoie Adobe Community Professional
        Hello, CaptMytre.
        Did you search online for "Photoshop Update?"
        You would have found this page: http://www.adobe.com/support/downloads/product.jsp?product=39&platform=Windows
        Now, on your machine, something prevents Photoshop to connect to its update server. Did you change your hosts configurations, use a proxy, etc?
        • 39. Re: Why won't Photoshop create new files or open old ones after awhile?
        CaptMytre Level 1
        Yeah, I updated it manually to 13.0.1.3. Unlikely to be the fix for this issue, but I'll have to see.
        1 2 Previous Next
