2 Replies Latest reply on Oct 1, 2012 7:58 AM by John Hall
    Trouble with filterFunction
    John Hall Level 4
      I usually have no problem with an ArrayCollection filterfunction. I have one instance where the code is the following:
      itemsToDisplay = timeslotPM.timeslots;
      itemsToDisplay.filterFunction = filteredBySelected;
      itemsToDisplay.refresh();
      protected function filteredBySelected( item : Timeslot ) : Boolean {
                                              if ( currentState == "masterCalendar" && includeEmptyCheckbox.selected == false && item.isScheduled == false ) {
                 Logger.info("NO"); // traces no fine and when I debug the app it goes through this branch and shows false for about half the items
                 return false;
        Logger.info("YES");
        return true;
      Yet, the length of the ArrayCollection never changes, despite the filter function returning false on half the items. I've searched for other code across the application that might set a filterFunction to null, but no go.
      Any other suggestions on how to debug this problem?
        • 1. Re: Trouble with filterFunction
          jfb00 Level 3
          Try the next code, where you if statement (try debug) validates and keep the item in the arrayCollection.
          protected function filteredBySelected( item : Object) : Boolean {
               for each (var area:Object in item) {
                          return true;
                         break;
            Logger.info("YES");
            return false;
          I hope this help.
          Best,
          • 2. Re: Trouble with filterFunction
            John Hall Level 4
            Thanks for your input.
