4 Replies Latest reply on Sep 30, 2012 12:53 PM by rubovia
    Dynamic Link Media Server error in PS CS6
    rubovia
      I've just installed PS CS6 Extended 32 and 64 bit versions 13.0.1 on a new PC running Windows 7.
      If I try to open a video I get an error message:
      When I click Continue I get this:
      And finally this ...
      Can anyone help me fix this please?
      Mike
        • 1. Re: Dynamic Link Media Server error in PS CS6
          sudarshan.t Level 6
          What do you mean - you installed 32 and 64bit versions?
          One of the two things:
          1. There is an incorrect application path specified by the installation to one of the application files
          2. Problematic video format - What format of video are you trying to import and how big is the video? Are you importing 1 or multiple videos? If multiple, can you try importing just 1?
          Lastly, can you try a reboot?
          • 2. Re: Dynamic Link Media Server error in PS CS6
            rubovia Level 1
            Thanks for your quick response.
            Your first question is a bit puzzling! The CS6 installation disk contains 32 and 64 bit versions of the program and I installed both. I believe this is the usual procedure ...
            As for your other questions:
            1. I didn't modify the default installation paths, although subsequently I moved the scratchfile location to another drive to overcome the directory protection bug in CS6.
            2. The videos are standard MOV format from my Canon digital camera. I only imported one at a time and they are relatively small (a few tens of MB).
            Yes, I tried rebooting but that didn't help.
            Since I posted my question I found that unchecking "Use Graphics Processor" in the Preferences dialog has stopped the error ocurring. Why should this be? My processor is an AMD A4-300 with Radeon HD6410D GPU.
            Mike
            • 3. Re: Dynamic Link Media Server error in PS CS6
              sudarshan.t Level 6
              You need not install both versions of it. It's only an installer for 32 or 64bit depending on your os..
              Your graphics processor - ensure you update to latest version of your video card driver. that should hopefully fix it.
              And yes don't update using windows updater, download the driver from manufacturer website please
              • 4. Re: Dynamic Link Media Server error in PS CS6
                rubovia Level 1
                OK Sudarshan, thanks for the advice.
                Mike
