5 Replies Latest reply on Oct 2, 2012 8:38 PM by Dov Isaacs
    Xerox7500DN - Odd RIP issues
    Creephead Level 1
      We've been getting odd boxes when printing from ID CS5 to our new 7500.
      A PSD file with a transparent background is sitting on top of another PSD file that does have a background. The resulting proof has the transparent background of the top image as lighter (almost like there's a 5% white in there).
      Also, text boxes (again, with a transparent background) that have a drop shadow will also have a slight white tint.
      We are getting the same problem when printing from the X-1a files, but I thought I'd start here before I contact Xerox tech support. BTW - We're using the latest drivers.
      TIA
        • 1. Re: Xerox7500DN - Odd RIP issues
          Normally I woudl send you to InDesignSecrets » Blog Archive » Eliminating YDB (Yucky Discolored Box) Syndrome, but in this case I think it may simply be that you are using the wrong transparency blend space.
          • 2. Re: Xerox7500DN - Odd RIP issues
            Dov Isaacs Adobe Employee
            Assuming that you not using PCL5C personality of the Phaser 7500 (which you really should effectively disable), the driver is effectively irrelevant to this situation since for PostScript printers, all PostScript is generated for InDesign, Illustrator, and Acrobat internally, not by system PostScript drivers.
            Some thoughts on what to look at:
            (1)     What transparency blend space are you using? Specifying RGB for printing could be problematic.
            (2)     Do you get similar results if you export PDF from InDesign as PDF/X-4 and print from Acrobat Pro?
            (3)     There are some transparency effects that don't transfer well from Photoshop to InDesign via PSD. You might want to try saving as PDF from Photoshop and placing the resultant PDF in InDesign.
                      - Dov
            • 3. Re: Xerox7500DN - Odd RIP issues
              Creephead Level 1
              Thanks for all the replies. The InDesignSecrets was really helpful. I solved the issue by turning on "Simulate Overprint" in the Output dialog box. Haven't done extensive testing yet but so far, so good.
              YDB: Never heard that one before.
              Dov: Regarding the disabling of the PCL5C personality ... how would I go about that?
              • 4. Re: Xerox7500DN - Odd RIP issues
                That should just be a matter of installing the printer withthe Postscript driver and not using an instance installed with the PCL driver if you have one.
                • 5. Re: Xerox7500DN - Odd RIP issues
                  Obviously, as Peter indicated, never install any PCL drivers. But also, from the control panel or more likely from the printer's website (yes, all Phaser printers actually have their own web server built in such that you can set some of the more obscure communications and paper-handling options), simply enable all the i/o ports that you use for PostScript only.
                            - Dov
