4 Replies Latest reply on Mar 1, 2008 6:34 AM by GerryIsHere
    Using a variable value
    GerryIsHere Level 1
      Hi there!
      Please, first, promise not to laugh!
      In the script, I wrote:
      text_field.text = "yes";
      var a:String = text_field.text;
      At the beginning of a conditional logic statement I want to use the value of this variable.
      How should I write the condition?
      I tried:
      if (a == yes) {....
      if (a = yes) {....
      if (a == "yes") {....
      if (a.length = 3) {....
      Nothing works...
      Maybe I'm too tired and... confused!
      Please, put me back on the track.
      I thank you in advance.
      Best regards from Old Gerry
        • 1. Re: Using a variable value
          Level 7
          GerryIsHere,
          I'm with you so far.
          The a variable is typed as a string, so its value must be a string.
          > I tried:
          > if (a == yes) {....
          Because "yes" does not appear in quotes, Flash will interpret it as a
          variable. Since you haven't declared a yes variable anywhere, it's value
          will be undefined or null, so your first condition compares a with, say,
          undefined, which evaluates to false.
          > if (a = yes) {....
          This isn't a comparison at all, actually. The single equals sign is an
          active operator that *sets* the value of one thing to another. Here, you're
          setting the value of a to, again, undefined (or perhaps null).
          This should do it. When you say nothing works, how are you determining
          that?
          Again, the single equals sign is killing it. You're trying to set the
          String.length property to a number, but the length property is read-only.
          Is it possible that text_field isn't a correct reference to one of your
          text fields? One of your text fields would have to have the instance name
          "text_field" (minus quotes) in order to be referenceable by ActionScript.
          David Stiller
          Co-author, Foundation Flash CS3 for Designers
          http://tinyurl.com/2k29mj
          "Luck is the residue of good design."
          • 2. Re: Using a variable value
            GerryIsHere Level 1
            Hi David!
            Thanks for your reply and your... solidarity!
            I was so tired, confused and angry that I even tried solutions which I really knew they were wrong.
            I fully agree with your solutions and the related explanations.
            But it still doesn't work!!!
            (I used :
            and
            if (a.length == 3) {.... )
            Problem must be located somewhere else in the script...
            (but certainly not in the name of the TextField as I verified this point)
            Best regards
            Gerry
            • 3. Re: Using a variable value
              Level 7
              Gerry,
              Let's try this.
              trace(text_field);
              trace(text_field.text);
              trace(a);
              trace(typeof(a));
              Let me know what you see in the Output panel when you test your SWF.
              David Stiller
              Adobe Community Expert
              Dev blog, http://www.quip.net/blog/
              • 4. Using a variable value
                GerryIsHere Level 1
                Sorry for wasting your valuable time!
                I was very ttired and confused.
                Problem was in fact located in a misplaced if/else statement which made the script unable to reach the point where I was using the so called "faulty" variable comparison...
                Thank you all for your comprehensive help!
