hello,
I work with Robohelp for Word, version 9.
I can't generate PDF because the button is grayed :
I try to re-install Robohelp for word, result is the same, I desinstall PDFCreator, the same. In word, the options "Acrobat PDFMaker Office COM Addin" and "Robohelp word COM addin" are checked
I have Adobe reader version 10.1.4
I have no more idea ...
Someone to give me the solution ?
Thank You
Marie-Noëlle
Remove all flavours of Acrobat & reinstall. Running the Reader & Distiller is not recommended.
Thank you Jeff for your answer, I reinstall Acrobat in simplified mode but it's always the same ...
Hi Marie,
I guess there is some issue with the installation, as you already re-installed the Acrobat and Robohelp for word and problem still persist. For testing, please launch Robohelp HTML and create a blank project and see if you can see the PDF generation option grayed out or highted, if not then you need to completely uninstall Robohelp 9 and reinstall it once again and need to make sure that Acrobat Add should be checked.
Please let me know if that helps.
Priyank
Hi Priyank,
thank you for your help.
I Launch Robohelp HTML and after create a blank project, option PDF is enabled and I can generate PDF without any problem !
And Acrobat Add is checked when I install robohelp for word ...
I work on an other PC where the button generate is enabled, but i would like to work with mine ...
Marie-Noelle
