15 Replies Latest reply on Oct 1, 2012 12:34 PM by mikefasnyc
    Photoshop CS6 crashes, won't reload
    mikefasnyc Level 1
      My Photoshop continually crashes and won't restart. Hangs on Measuring Memory. I'm forced to restart my computer each time. The crashes appear to be random. The application stops responding and i'm forced to force quit. Won't reload unless I restart my computer. Is it time to reinstall? Or toss computer out a window?
        • 1. Re: Photoshop CS6 crashes, won't reload
          sudarshan.t Level 6
          Can you please post your crash report here?
          • 2. Re: Photoshop CS6 crashes, won't reload
            mikefasnyc Level 1
            forgive me Sudarshan, can you tell me how to retrieve the crash reports? the app typically hangs so i'm forced to force quit at which point apple asks for me to report. is that the information i should pull? i really should know this!
            • 3. Re: Photoshop CS6 crashes, won't reload
              sudarshan.t Level 6
              You could post that - although I'm unsure if we'll find what we need in it.
              However, could you go to Apple logo on top left of your screen, About this mac > More Info > Hardware (from left) > Memory
              On the right, see if Mac OS reports one or more memory modules as 'Faulty' or something else other than 'OK'.
              Also, verify that if you have multiple RAM modules, they're all of same spec - clock speed, type & preferably even the size. Sometimes an incorrect memory module could cause Photoshop to hang while its checking for memory.
              Another thing you could do (although I'm unsure if this will totally solve your issue), is to clear your Photoshop Preferences. Follow the instructions in this thread: http://forums.adobe.com/thread/375776
              • 4. Re: Photoshop CS6 crashes, won't reload
                Level 7
                Which OS version are you using?
                On MacOS, you should always get a crash report dialog (at least Apple's, and usually Adobe's) where you can click a button to get the full crash report details (several pages worth).
                We need to see the detailed crash report to know why and where it is crashing.
                But the need to restart the computer is a bit disturbing - that means that there is something wrong outside of Photoshop itself, that persists with the OS state.
                • 5. Re: Photoshop CS6 crashes, won't reload
                  mikefasnyc Level 1
                  Here's my memory report:
                  Memory Slots:
                    ECC:          Enabled
                  DIMM 1:
                    Type:          DDR3 ECC
                    Speed:          1066 MHz
                    Status:          OK
                    Manufacturer:          0x80CE
                    Part Number:          0x4D33393342314B37304348302D4348392020
                    Serial Number:          0x828E0D04
                  DIMM 2:
                    Type:          DDR3 ECC
                    Speed:          1066 MHz
                    Status:          OK
                    Serial Number:          0x828E0CF3
                  DIMM 3:
                    Type:          DDR3 ECC
                    Speed:          1066 MHz
                    Status:          OK
                    Serial Number:          0x424DCFA4
                  DIMM 4:
                    Type:          DDR3 ECC
                    Speed:          1066 MHz
                    Status:          OK
                    Serial Number:          0x424DCFC0
                  • 6. Re: Photoshop CS6 crashes, won't reload
                    Level 7
                    No, we need the CRASH report - from the dialog that opens right after you crash.
                    Or get the last report from ~/Library/Logs/CrashReporter/...
                    • 7. Re: Photoshop CS6 crashes, won't reload
                      mikefasnyc Level 1
                      I should have mentioned one other pretty major piece of info. Not only do I need to restart. I need to shut down first. If I attempt to just restart, the computer goes solid gray and sits there indefinetly. I've run the apple diagnostics, checking hardisk and permissions. all checks out okay. i'll work on getting the crash reports. although, I don't get adobe reports, just the apple ones.
                      • 8. Re: Photoshop CS6 crashes, won't reload
                        mikefasnyc Level 1
                        I found 2, but none from this morning. As I said, the program hangs, so I just force quit. Is a crash report generated at that point? the most recent photoshop 6 crash is below. thanks for taking the time to review!
                        Process:         Adobe Photoshop CS6 [1715]
                        Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                        Identifier:      com.adobe.Photoshop
                        Version:         13.0.1 (13.0.1.519)
                        Code Type:       X86-64 (Native)
                        Parent Process:  launchd [205]
                        User ID:         501
                        Date/Time:       2012-09-25 18:10:51.580 -0400
                        OS Version:      Mac OS X 10.8.2 (12C54)
                        Report Version:  10
                        Crashed Thread:  0  Main Thread  Dispatch queue: com.apple.main-thread
                        Exception Type:  EXC_CRASH (SIGABRT)
                        Exception Codes: 0x0000000000000000, 0x0000000000000000
                        Application Specific Information:
                        *** error for object 0x1a5d892d6: pointer being freed was not allocated
                        Thread 0 Crashed:: Main Thread  Dispatch queue: com.apple.main-thread
                        0   libsystem_kernel.dylib                  0x00007fff85a25212 __pthread_kill + 10
                        1   libsystem_c.dylib                       0x00007fff8e61eaf4 pthread_kill + 90
                        2   libsystem_c.dylib                       0x00007fff8e662dce abort + 143
                        3   libsystem_c.dylib                       0x00007fff8e636959 free + 392
                        4   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f395c PSIR_FileWriter::InternalRsrcInfo::~InternalRsrcInfo() + 70
                        5   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f3981 std::_Rb_tree<unsigned short, std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo>, std::_Select1st<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> >, std::less<unsigned short>, std::allocator<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> > >::destroy_node(std::_Rb_tree_node<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> >*) + 21
                        6   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f39c2 std::_Rb_tree<unsigned short, std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo>, std::_Select1st<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> >, std::less<unsigned short>, std::allocator<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> > >::_M_erase(std::_Rb_tree_node<std::pair<unsigned short const, PSIR_FileWriter::InternalRsrcInfo> >*) + 50
                        7   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f27b1 PSIR_FileWriter::DeleteExistingInfo() + 77
                        8   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f29cb PSIR_FileWriter::ParseMemoryResources(void const*, unsigned int, bool) + 39
                        9   com.extensis.AutoActivationPlugin.PS13          0x000000011f8f3222 PSIR_FileWriter::UpdateMemoryResources(void**) + 640
                        10  com.extensis.AutoActivationPlugin.PS13          0x000000011f8d4254 JPEG_MetaHandler::WriteFile(void*, std::string const&) + 1466
                        11  com.extensis.AutoActivationPlugin.PS13          0x000000011f8d4950 JPEG_MetaHandler::UpdateFile(bool) + 506
                        12  com.extensis.AutoActivationPlugin.PS13          0x000000011f8cab3f XMPFiles::CloseFile(unsigned int) + 225
                        13  com.extensis.AutoActivationPlugin.PS13          0x000000011f8c7bf8 WXMPFiles_CloseFile_1 + 69
                        14  com.extensis.AutoActivationPlugin.PS13          0x000000011f833ae1 TXMPFiles<std::string>::CloseFile(unsigned int) + 29
                        15  com.extensis.AutoActivationPlugin.PS13          0x000000011f836b5d WriteXMPFontSenseSlugToFile(std::string const&, __CFArray const*) + 426
                        16  com.extensis.AutoActivationPlugin.PS13          0x000000011f8069a5 UpdateFontSenseSlugsForDocument() + 121
                        17  com.adobe.Photoshop                     0x00000001007c2e03 boost::system::system_error::what() const + 2073859
                        18  com.adobe.Photoshop                     0x00000001005b7abc 0x100000000 + 5995196
                        19  com.adobe.Photoshop                     0x00000001005ad63e 0x100000000 + 5953086
                        20  com.adobe.Photoshop                     0x000000010001f312 0x100000000 + 127762
                        21  com.adobe.Photoshop                     0x00000001019218a4 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17608452
                        22  com.apple.Foundation                    0x00007fff85afc513 __NSFireTimer + 96
                        23  com.apple.CoreFoundation                0x00007fff8d795da4 __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20
                        24  com.apple.CoreFoundation                0x00007fff8d7958bd __CFRunLoopDoTimer + 557
                        25  com.apple.CoreFoundation                0x00007fff8d77b099 __CFRunLoopRun + 1513
                        26  com.apple.CoreFoundation                0x00007fff8d77a6b2 CFRunLoopRunSpecific + 290
                        27  com.apple.HIToolbox                     0x00007fff8eb2e0a4 RunCurrentEventLoopInMode + 209
                        28  com.apple.HIToolbox                     0x00007fff8eb2dd84 ReceiveNextEventCommon + 166
                        29  com.apple.HIToolbox                     0x00007fff8eb2dcd3 BlockUntilNextEventMatchingListInMode + 62
                        30  com.apple.AppKit                        0x00007fff8c5cf613 _DPSNextEvent + 685
                        31  com.apple.AppKit                        0x00007fff8c5ceed2 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128
                        32  com.apple.AppKit                        0x00007fff8c5c6283 -[NSApplication run] + 517
                        33  com.adobe.Photoshop                     0x00000001019219d2 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17608754
                        34  com.adobe.Photoshop                     0x0000000101923c3e AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17617566
                        35  com.adobe.Photoshop                     0x00000001005ae50c 0x100000000 + 5956876
                        36  com.adobe.Photoshop                     0x00000001007b0f8f boost::system::system_error::what() const + 2000527
                        37  com.adobe.Photoshop                     0x00000001007b11d9 boost::system::system_error::what() const + 2001113
                        38  com.adobe.Photoshop                     0x000000010054b4dc 0x100000000 + 5551324
                        Thread 1:: Dispatch queue: com.apple.libdispatch-manager
                        0   libsystem_kernel.dylib                  0x00007fff85a25d16 kevent + 10
                        1   libdispatch.dylib                       0x00007fff88babdea _dispatch_mgr_invoke + 883
                        2   libdispatch.dylib                       0x00007fff88bab9ee _dispatch_mgr_thread + 54
                        Thread 2:
                        0   libsystem_kernel.dylib                  0x00007fff85a250fa __psynch_cvwait + 10
                        1   libsystem_c.dylib                       0x00007fff8e621f89 _pthread_cond_wait + 869
                        2   MultiProcessor Support                  0x0000000110ef90f3 main + 8403
                        3   MultiProcessor Support                  0x0000000110ef91b0 main + 8592
                        4   MultiProcessor Support                  0x0000000110f15f50 main + 126768
                        5   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        6   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 3:
                        Thread 4:
                        Thread 5:
                        Thread 6:
                        Thread 7:
                        Thread 8:
                        Thread 9:
                        2   com.apple.CoreServices.CarbonCore          0x00007fff8af1b214 TSWaitOnCondition + 108
                        3   com.apple.CoreServices.CarbonCore          0x00007fff8af1b3eb TSWaitOnConditionTimedRelative + 132
                        4   com.apple.CoreServices.CarbonCore          0x00007fff8ae7db24 MPWaitOnQueue + 252
                        5   com.adobe.dvacore.framework             0x0000000118ca31e1 dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 193
                        6   com.adobe.dvacore.framework             0x0000000118c8a8b3 boost::function0<void>::operator()() const + 51
                        7   com.adobe.dvacore.framework             0x0000000118c992f3 dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()> const&, boost::function<void ()> const&) + 99
                        8   com.adobe.boost_threads.framework          0x00000001132acf25 thread_proxy + 133
                        9   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        10  libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 10:
                        Thread 11:
                        1   com.adobe.dvatransport.framework          0x00000001190ae5b3 boost::asio::detail::kqueue_reactor::run(bool, boost::asio::detail::op_queue<boost::asio::detail::task_io_service_operation>&) + 243
                        2   com.adobe.dvatransport.framework          0x00000001190ba27b boost::asio::detail::task_io_service::run(boost::system::error_code&) + 555
                        3   com.adobe.dvatransport.framework          0x00000001190a2ab5 SkyConnectionEnv::MainLoop() + 117
                        4   com.adobe.dvatransport.framework          0x00000001190a2b19 SkyConnectionEnv::StaticThreadFunc(SkyConnectionEnv*) + 9
                        5   com.adobe.boost_threads.framework          0x00000001132acf25 thread_proxy + 133
                        6   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        7   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 12:
                        2   com.adobe.dvatransport.framework          0x00000001190ba4df boost::asio::detail::task_io_service::run(boost::system::error_code&) + 1167
                        3   com.adobe.dvatransport.framework          0x00000001190baacd boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service_base::work_ io_service_runner>::run() + 61
                        4   com.adobe.dvatransport.framework          0x00000001190acd99 boost_asio_detail_posix_thread_function + 25
                        Thread 13:
                        Thread 14:
                        Thread 15:
                        Thread 16:
                        Thread 17:
                        5   com.adobe.ACE                           0x00000001051722c9 0x105139000 + 234185
                        6   com.adobe.ACE                           0x00000001051715da 0x105139000 + 230874
                        7   com.apple.CoreServices.CarbonCore          0x00007fff8aef27e4 PrivateMPEntryPoint + 58
                        8   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        9   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 18:
                        Thread 19:
                        Thread 20:
                        Thread 21:
                        Thread 22:
                        Thread 23:
                        Thread 24:: com.apple.CFSocket.private
                        0   libsystem_kernel.dylib                  0x00007fff85a25322 __select + 10
                        1   com.apple.CoreFoundation                0x00007fff8d7ba4e6 __CFSocketManager + 1302
                        2   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        3   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 25:: IPCClient rcvr: FMClient.501.1715.140735146471808.1
                        1   com.extensis.cpp-core-framework          0x000000013bcb4d5d GIPCReceiver::OSWaitForData() + 2369
                        2   com.extensis.cpp-core-framework          0x000000013bca9a6e GIPCClient::ReceiverThreadProc(GThread*) + 798
                        3   com.extensis.cpp-core-framework          0x000000013bd260a3 GThread::PthreadInternal(void*) + 223
                        4   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        5   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 26:: Agent IF Message Handler
                        2   com.extensis.cpp-core-framework          0x000000013bce6f9a GSemaphore::TimedWait(unsigned int) + 76
                        3   com.extensis.cpp-core-framework          0x000000013bcae327 GIPCClient::GIPCMTDataAccumulator::WaitForData(unsigned int, std::vector<char, std::allocator<char> >&, bool) + 37
                        4   com.extensis.ExtensisFontManagement.sdk          0x000000013d3245f7 GAgentIFMessageHandlerThread::RunMessageHandlerThread() + 445
                        5   com.extensis.ExtensisFontManagement.sdk          0x000000013d324d14 GAgentIFMessageHandlerThread::AgentIFMessageHandlerThreadFunc(GThread*) + 42
                        6   com.extensis.cpp-core-framework          0x000000013bd260a3 GThread::PthreadInternal(void*) + 223
                        7   libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        8   libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 27:
                        0   libsystem_kernel.dylib                  0x00007fff85a25386 __semwait_signal + 10
                        1   libsystem_c.dylib                       0x00007fff8e6a7800 nanosleep + 163
                        2   com.adobe.PSAutomate                    0x000000013d7b19cb ScObjects::Thread::sleep(unsigned int) + 59
                        3   com.adobe.PSAutomate                    0x000000013d7977c9 ScObjects::BridgeTalkThread::run() + 169
                        4   com.adobe.PSAutomate                    0x000000013d7b1d36 ScObjects::Thread::go(void*) + 166
                        Thread 28:
                        2   com.adobe.ape.engine                    0x000000014d956c0d APXGetHostAPI + 2516093
                        3   com.adobe.ape.engine                    0x000000014d704ec1 APXGetHostAPI + 83761
                        4   com.adobe.ape.engine                    0x000000014d956cd1 APXGetHostAPI + 2516289
                        5   com.adobe.ape.engine                    0x000000014d956d4a APXGetHostAPI + 2516410
                        6   com.adobe.ape.engine                    0x000000014d956e79 APXGetHostAPI + 2516713
                        Thread 29:
                        Thread 30:
                        Thread 31:
                        Thread 32:
                        0   libsystem_kernel.dylib                  0x00007fff85a23686 mach_msg_trap + 10
                        1   libsystem_kernel.dylib                  0x00007fff85a22c42 mach_msg + 70
                        2   com.apple.CoreFoundation                0x00007fff8d775803 __CFRunLoopServiceMachPort + 195
                        3   com.apple.CoreFoundation                0x00007fff8d77aee6 __CFRunLoopRun + 1078
                        4   com.apple.CoreFoundation                0x00007fff8d77a6b2 CFRunLoopRunSpecific + 290
                        5   com.apple.CoreMediaIO                   0x00007fff896dd6f8 CMIO::DAL::RunLoop::OwnThread(void*) + 146
                        6   com.apple.CoreMediaIO                   0x00007fff896d52de CAPThread::Entry(CAPThread*) + 156
                        Thread 33:
                        1   libsystem_c.dylib                       0x00007fff8e621fc3 _pthread_cond_wait + 927
                        2   com.adobe.ape.engine                    0x000000014d956bd0 APXGetHostAPI + 2516032
                        3   com.adobe.ape.engine                    0x000000014d96eddb APXGetHostAPI + 2614859
                        Thread 34:
                        3   com.adobe.ape.engine                    0x000000014dae92c3 APXGetHostAPI + 4164403
                        Thread 35:
                        0   libsystem_kernel.dylib                  0x00007fff85a252aa __recvfrom + 10
                        1   ServiceManager-Launcher.dylib           0x0000000140ec45ec Invoke + 45721
                        2   ServiceManager-Launcher.dylib           0x0000000140ec3813 Invoke + 42176
                        3   ServiceManager-Launcher.dylib           0x0000000140ec2be0 Invoke + 39053
                        4   ServiceManager-Launcher.dylib           0x0000000140ec2c66 Invoke + 39187
                        5   ServiceManager-Launcher.dylib           0x0000000140ebe30f Invoke + 20412
                        6   ServiceManager-Launcher.dylib           0x0000000140ebe616 Invoke + 21187
                        7   ServiceManager-Launcher.dylib           0x0000000140ebecd7 Invoke + 22916
                        8   ServiceManager-Launcher.dylib           0x0000000140ebef41 Invoke + 23534
                        9   ServiceManager-Launcher.dylib           0x0000000140ec161d Invoke + 33482
                        10  ServiceManager-Launcher.dylib           0x0000000140ec1775 Invoke + 33826
                        11  ServiceManager-Launcher.dylib           0x0000000140ec1fb2 Invoke + 35935
                        12  ServiceManager-Launcher.dylib           0x0000000140ec20ad Invoke + 36186
                        13  ServiceManager-Launcher.dylib           0x0000000140eb4d6b Login + 480
                        14  ServiceManager-Launcher.dylib           0x0000000140eb87ad Login + 15394
                        15  ServiceManager-Launcher.dylib           0x0000000140ec2412 Invoke + 37055
                        16  ServiceManager-Launcher.dylib           0x0000000140ec4253 Invoke + 44800
                        17  libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        18  libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 36:
                        0   com.adobe.Photoshop                     0x0000000100414143 0x100000000 + 4276547
                        1   com.adobe.Photoshop                     0x00000001004145d7 0x100000000 + 4277719
                        2   com.adobe.Photoshop                     0x000000010040f624 0x100000000 + 4257316
                        3   com.adobe.Photoshop                     0x00000001022f104d AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 27895469
                        4   com.adobe.Photoshop                     0x0000000100412ceb 0x100000000 + 4271339
                        5   com.adobe.Photoshop                     0x000000010041dec2 0x100000000 + 4316866
                        6   com.adobe.Photoshop                     0x0000000100af0aeb AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 2728267
                        7   com.adobe.Photoshop                     0x0000000100aa758a AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 2427882
                        8   com.adobe.Photoshop                     0x0000000100a707d7 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 2203191
                        9   com.adobe.Photoshop                     0x00000001005c3792 0x100000000 + 6043538
                        10  com.adobe.Photoshop                     0x00000001012abb98 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 10834424
                        11  com.adobe.Photoshop                     0x00000001019d45b3 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 18340883
                        12  com.adobe.Photoshop                     0x0000000101959730 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17837456
                        13  libsystem_c.dylib                       0x00007fff8e61d742 _pthread_start + 327
                        14  libsystem_c.dylib                       0x00007fff8e60a181 thread_start + 13
                        Thread 37:
                        5   com.adobe.CameraRaw                     0x000000023b51ef69 0x23b2c2000 + 2477929
                        6   com.adobe.CameraRaw                     0x000000023b51e1c0 0x23b2c2000 + 2474432
                        Thread 38:
                        Thread 39:
                        Thread 40:
                        Thread 41:
                        Thread 42:
                        Thread 43:
                        Thread 44:: cr_scratch
                        2   com.adobe.CameraRaw                     0x000000023b325873 0x23b2c2000 + 407667
                        3   com.adobe.CameraRaw                     0x000000023b6ad114 EntryFM + 976436
                        4   com.adobe.CameraRaw                     0x000000023b3f3338 0x23b2c2000 + 1250104
                        Thread 45:
                        2   libtbb.dylib                            0x00000001039f8010 tbb::internal::rml::private_worker::thread_routine(void*) + 416
                        Thread 46:
                        Thread 47:
                        Thread 48:
                        Thread 49:
                        Thread 50:
                        Thread 51:
                        Thread 52:
                        0   libsystem_kernel.dylib                  0x00007fff85a256d6 __workq_kernreturn + 10
                        1   libsystem_c.dylib                       0x00007fff8e61feec _pthread_workq_return + 25
                        2   libsystem_c.dylib                       0x00007fff8e61fcb3 _pthread_wqthread + 412
                        3   libsystem_c.dylib                       0x00007fff8e60a171 start_wqthread + 13
                        Thread 53:
                        Thread 54:
                        Thread 55:
                        Thread 56:
                        Thread 57:
                        Thread 58:
                        Thread 59:
                        Thread 0 crashed with X86 Thread State (64-bit):
                          rax: 0x0000000000000000  rbx: 0x0000000000000006  rcx: 0x00007fff5fbddc88  rdx: 0x0000000000000000
                          rdi: 0x0000000000000c07  rsi: 0x0000000000000006  rbp: 0x00007fff5fbddcb0  rsp: 0x00007fff5fbddc88
                           r8: 0x00007fff7469a278   r9: 0x0000000000000000  r10: 0x0000000020000000  r11: 0x0000000000000206
                          r12: 0x0000000108611600  r13: 0x0000000106c03000  r14: 0x00007fff7469b180  r15: 0x0000000000000007
                          rip: 0x00007fff85a25212  rfl: 0x0000000000000206  cr2: 0x00007fff74693fe8
                        Logical CPU: 0
                        Binary Images:
                               0x100000000 -        0x10333ffff +com.adobe.Photoshop (13.0.1 - 13.0.1.519) <A2A39B8C-869D-C4D3-3E38-9B1147C8B6ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                               0x1039e9000 -        0x103a15ff7 +libtbb.dylib (0) <57655978-A378-BE1E-7905-7D7F951AD6F7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbb.dylib
                               0x103a2c000 -        0x103a3aff3 +libtbbmalloc.dylib (0) <CB038B96-2999-5EB1-E26A-7720A7A8F8CD> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/libtbbmalloc.dylib
                               0x103a4e000 -        0x103a55fff  org.twain.dsm (1.9.4 - 1.9.4) <80EC0952-6137-3CA6-813F-D753856A13CE> /System/Library/Frameworks/TWAIN.framework/Versions/A/TWAIN
                               0x103a5d000 -        0x103a77ff7 +com.adobe.ahclientframework (1.7.0.56 - 1.7.0.56) <C1C5DE5C-39AB-0871-49A6-FA3449D39B8A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
                               0x103a80000 -        0x103a85fff  com.apple.agl (3.2.1 - AGL-3.2.1) <82AA78D1-159F-3B27-8CA5-1C227C956AC9> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
                               0x103a8c000 -        0x103c9bfe7 +com.adobe.owl (AdobeOwl version 4.0.95 - 4.0.95) <BA323D28-CBAE-90A6-E3C7-4A9FB244C74C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
                               0x103cdc000 -        0x104122ff7 +com.adobe.MPS (AdobeMPS 5.8.0.19463 - 5.8.0.19463) <8A4BA3B2-6F6A-3958-ABDE-C3E8F21373B0> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeMPS.framework/Versions/A/AdobeMPS
                               0x10419e000 -        0x1044f7ff7 +com.adobe.AGM (AdobeAGM 4.26.20.20743 - 4.26.20.20743) <27080135-E835-75EF-FF42-15299479FDA1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
                               0x104560000 -        0x1048c1fef +com.adobe.CoolType (AdobeCoolType 5.10.33.20743 - 5.10.33.20743) <758DF893-C0F4-5769-53C5-7C80FC9111FB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
                               0x10490e000 -        0x104936ff7 +com.adobe.BIBUtils (AdobeBIBUtils 1.1.01 - 1.1.01) <BFA061BE-7598-275D-D3F7-5842674E367E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
                               0x10493d000 -        0x104969fff +com.adobe.AXE8SharedExpat (AdobeAXE8SharedExpat 3.7.101.18636 - 3.7.101.18636) <488DF1F7-A643-5168-706A-498A0322A87E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8SharedExpa t
                               0x10498c000 -        0x104ad9ff7 +com.winsoft.wrservices (WRServices 5.0.0 - 5.0.0) <FFA48E0A-A17C-A04F-AE20-6815EB944DEA> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
                               0x104b4d000 -        0x104bbcfef +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <E0DD6CD7-DCBB-25A8-CF4F-E3AFE102DF8C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
                               0x104be3000 -        0x104c3cff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <EDB207A5-DC7C-C653-4E35-A002378D7CDC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/data_flow.framework/Versions/A/data_flow
                               0x104cdc000 -        0x104d63ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <2205BA2C-B886-3701-936C-20B072EBD1AF> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_flow.framework/Versions/A/image_flow
                               0x104dc8000 -        0x104de3ff7 +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <7E59820F-0DB4-B768-837A-66D289F00165> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
                               0x104dfd000 -        0x10503afff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <3F98C7A6-07AB-1522-5A28-84566D32F0A7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
                               0x105139000 -        0x1052b2fff +com.adobe.ACE (AdobeACE 2.19.18.20743 - 2.19.18.20743) <744F14EE-D2A2-E610-ADD9-960896F05D26> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
                               0x1052c5000 -        0x1052e4fff +com.adobe.BIB (AdobeBIB 1.2.02.20743 - 1.2.02.20743) <15E9C88F-1DB1-C4F3-610F-9246F7C4D75D> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
                               0x1052eb000 -        0x1053cffe7 +com.adobe.amtlib (amtlib 6.0.0.75 - 6.0.0.75) <07A3E1E1-55C3-BA5B-A0B0-60250809ED61> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
                               0x1053e0000 -        0x1054a5fff +com.adobe.JP2K (2.0.0 - 2.0.0.18562) <B14B096C-AA23-BA8F-E3AE-8DB102F9D161> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
                               0x1054f2000 -        0x1054f6ff7 +com.adobe.ape.shim (3.3.8.19346 - 3.3.8.19346) <13D5CEF7-6090-CD66-8DA0-190771950F76> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
                               0x1054fc000 -        0x10557afff +com.adobe.FileInfo.framework (Adobe XMP FileInfo 5 . 3 . 0 . 0 -i 3 - 66.145433) <5C63613F-6BDE-1C29-D3FD-9D292F9ADB12> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
                               0x10558b000 -        0x1055ebff7 +com.adobe.AdobeXMPCore (Adobe XMP Core 5.3 -c 11 - 66.145661) <B475CD07-1024-560D-5BFE-2A6FCE63925C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
                               0x1055f5000 -        0x105b4dfef +com.nvidia.cg (2.2.0006 - 0) /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/Cg.framework/Cg
                               0x1061aa000 -        0x106218fef +com.adobe.headlights.LogSessionFramework (2.1.2.1652) <25E6F475-1522-419C-2169-547FCF2FD97F> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
                               0x10626c000 -        0x106291ffe +adobepdfsettings (1) <56E7F033-6032-2EC2-250E-43F1EBD123B1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobepdfsettings.framework/Versions/A/adobepdfsettings
                               0x1062cc000 -        0x1062d0ff7 +com.adobe.AdobeCrashReporter (6.0 - 6.0.20120720) <A6B1F3BD-5DB0-FEE5-708A-B54E5CA80481> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReporter
                               0x1062d6000 -        0x106486fef +com.adobe.PlugPlug (3.0.0.383 - 3.0.0.383) <908DBB12-D2AC-1844-BD2A-F1C483424917> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/PlugPlug.framework/Versions/A/PlugPlug
                               0x10653d000 -        0x10655dfff +com.adobe.AIF (AdobeAIF 3.0.00 - 3.0.00) <C00C0A15-15ED-EF76-8C95-F270F8D6EC8D> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/aif_ocl.framework/Versions/A/aif_ocl
                               0x106577000 -        0x106634fff +com.adobe.AdobeExtendScript (ExtendScript 4.2.12 - 4.2.12.18602) <0957DFA6-0593-CE4B-8638-00F32113B07B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
                               0x10667e000 -        0x10672cfef +com.adobe.AdobeScCore (ScCore 4.2.12 - 4.2.12.18602) <9CEE95E5-2FC6-5E58-02A4-138EA6F8D894> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
                               0x106769000 -        0x106863fe7 +com.adobe.AXEDOMCore (AdobeAXEDOMCore 3.7.101.18636 - 3.7.101.18636) <C7652AF2-56D7-8AF8-A207-0BDEDDFF0BEC> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeAXEDOMCore.framework/Versions/A/AdobeAXEDOMCore
                               0x106907000 -        0x106b50fe7 +com.adobe.linguistic.LinguisticManager (6.0.0 - 17206) <301AAE8E-BA78-230E-9500-FCCA204B49CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeLinguistic.framework/Versions/3/AdobeLinguistic
                               0x106cf3000 -        0x106cf5ff7  com.apple.textencoding.unicode (2.5 - 2.5) <0518078E-C652-3CFC-A3FB-903C600CE831> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
                               0x106f5c000 -        0x106f5cff1 +cl_kernels (???) <3D56B3B6-A5E2-41E3-AA53-FD2AA5C171B9> cl_kernels
                               0x106fcb000 -        0x106fccff7  ATSHI.dylib (341.1) <3328D0EC-BD75-3041-A458-05FFE934C019> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/ATSHI.dylib
                               0x106fea000 -        0x106febff2 +cl_kernels (???) <4C81D52C-4D72-47BC-B2A0-049A4F8F5990> cl_kernels
                               0x107b1e000 -        0x107b1fff3 +cl_kernels (???) <A9159A33-D763-4EA2-A697-F1A72A06E7D6> cl_kernels
                               0x107b57000 -        0x107b57ff3 +cl_kernels (???) <77542505-A895-4A52-90F9-7E74D4FBEB0F> cl_kernels
                               0x107bf9000 -        0x107bfaff7  libCyrillicConverter.dylib (61) <D06971D7-9F16-3FE6-81E8-33E0FE4D6586> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
                               0x109708000 -        0x109709ff3 +cl_kernels (???) <2AF14112-1656-4091-8D17-1829458F1A3E> cl_kernels
                               0x1097cf000 -        0x1097ebff7  libJapaneseConverter.dylib (61) <D0F762C2-5372-3AA2-BBA4-066B8E4B1F8E> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
                               0x10caa7000 -        0x10cac8fff  libKoreanConverter.dylib (61) <7A601BB8-19DF-3DDC-9C50-3A798290F377> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
                               0x10cacc000 -        0x10cadbff7  libSimplifiedChineseConverter.dylib (61) <A2B475FF-667F-3B7B-A6E9-8768347F2BD6> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
                               0x10cadf000 -        0x10caf1ff7  libTraditionalChineseConverter.dylib (61) <DDAFF75C-0714-34F4-818F-8B439AC7BBCA> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
                               0x10cb8c000 -        0x10cb93fff  com.apple.URLMount.AFPPlugin (5.0 - 5.0) <EA14B6F5-BF15-390A-B963-0E4BEF101FDC> /System/Library/Filesystems/NetFSPlugins/afp.bundle/Contents/MacOS/afp
                               0x10cba8000 -        0x10cbadff7  libgermantok.dylib (7) <B98522FA-23D1-351E-9F25-5AAF58FD862D> /usr/lib/libgermantok.dylib
                               0x10cbc7000 -        0x10cbc7fff +Enable Async IO (???) <D11C9A94-50D0-9AC5-3841-5F9E6A1201FB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/Enable Async IO.plugin/Contents/MacOS/Enable Async IO
                               0x10cbcb000 -        0x10cbcefff +FastCore (???) <17609B2F-FA65-1FF2-EC5F-080869FE24BF> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/FastCore.plugin/Contents/MacOS/FastCore
                               0x10cc5b000 -        0x10cc5bff1 +cl_kernels (???) <E0250A45-3C4F-4033-9F76-EDD453EA5AB1> cl_kernels
                               0x10cd26000 -        0x10cd26ffb +cl_kernels (???) <68AED368-BFF4-4FB2-A0B6-AC9E77383786> cl_kernels
                               0x10e3fa000 -        0x10e3fbfff +com.adobe.boost_system.framework (6.0.0 - 6.0.0.0) <73C56088-5AD7-50F8-ED29-34BA73D1D47A> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
                               0x10ec1e000 -        0x10ec28ff7  com.apple.AppleSRP (5.0 - 1) <16B1431A-295A-386B-9159-A396877D6FE3> /System/Library/PrivateFrameworks/AppleSRP.framework/Versions/A/AppleSRP
                               0x10ec72000 -        0x10ecb8fe7 +com.adobe.pip (6.0.0.1654) <3576D8F9-E2F9-6EB8-6684-C2FE6B0A3731> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
                               0x10ece6000 -        0x10ece9ff7  libCoreFSCache.dylib (24.4) <C375CAA0-F91F-3D9F-AF90-DB951BD86983> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreFSCache.dylib
                               0x10ed37000 -        0x10ed4aff7 +MeasurementCore (???) <96AAD898-70F6-B809-EA52-7162AA8300FB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Measurements/MeasurementCore.plugin/Contents/MacOS/Mea surementCore
                               0x10ed56000 -        0x10ed61fff +com.extensis.fontplugins (3.0.10.9 - 3.0.10.9) <4CC67C3B-87D3-FA66-ABE3-036E315F6AC3> /Applications/Suitcase Fusion 4.app/Contents/Resources/PluginFiles/ExtensisPlugins.framework/ExtensisPlugins
                               0x110dc1000 -        0x110e2dfff +MMXCore (???) <B9B6C7FB-CE56-8F6F-664E-DFCBBC5E3ADE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MMXCore.plugin/Contents/MacOS/MMXCore
                               0x110eb4000 -        0x110f39fff +MultiProcessor Support (???) <F332405A-5896-7EF2-F0CE-21D604012833> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                               0x110fe6000 -        0x110ff4ff7  libGPUSupport.dylib (8.6.1) <C8A361A5-8A82-375D-B50E-E520662F76B1> /System/Library/PrivateFrameworks/GPUSupport.framework/Versions/A/Libraries/libGPUSupport .dylib
                               0x11325e000 -        0x11326aff7 +com.adobe.boost_signals.framework (6.0.0 - 6.0.0.0) <3CE5622D-3A6D-B9A5-56FD-C2FA1204C4E7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
                               0x113283000 -        0x11328bfff +com.adobe.boost_date_time.framework (6.0.0 - 6.0.0.0) <03173F0B-F30F-0663-4A5E-6D768518EDAE> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
                               0x1132aa000 -        0x1132b6fff +com.adobe.boost_threads.framework (6.0.0 - 6.0.0.0) <AD10EB96-8922-BFE3-4D86-8493013A31B7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
                               0x1132de000 -        0x1132e7fe7  libcldcpuengine.dylib (2.1.19) <50800DA2-7233-32E5-9553-A02171B68399> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/libcldcpuengine.dylib
                               0x118809000 -        0x118994ff7 +com.adobe.mediacoreif.framework (6.0.0 - 6.0.0.0) <1595E0AB-595C-A798-DF15-3D89E004B2C2> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/mediacoreif.framework/mediacoreif
                               0x118bbc000 -        0x118d8ffff +com.adobe.dvacore.framework (6.0.0 - 6.0.0.0) <C4F86849-F994-F1C8-B00D-D919771FB6E4> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
                               0x11901e000 -        0x11904bff7 +com.adobe.dvamediatypes.framework (6.0.0 - 6.0.0.0) <0627F3F0-2C4C-76F9-99EA-9275F1601B4E> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
                               0x119086000 -        0x1190e6fff +com.adobe.dvatransport.framework (6.0.0 - 6.0.0.0) <7BA6A1FC-A262-753E-BED1-2F11A697A6A5> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
                               0x119168000 -        0x1191acfff +com.adobe.dvamarshal.framework (6.0.0 - 6.0.0.0) <A01CC64E-A455-F51B-17C4-3A8988097E08> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
                               0x11923c000 -        0x11947afff +com.adobe.dynamiclink.framework (6.0.0 - 6.0.0.0) <D2CBCB05-456D-CA01-029C-AB11C2B51AB2> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
                               0x119673000 -        0x11969bff7 +com.adobe.dvaunittesting.framework (6.0.0 - 6.0.0.0) <75ED5067-5362-8F49-AF8E-FD7705C33737> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaunittesting.framework/Versions/A/dvaunittesting
                               0x1196e6000 -        0x11978bff7 +com.adobe.dvaaudiodevice.framework (6.0.0 - 6.0.0.0) <46DC2919-E6C1-525A-9612-32829CC08B4B> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaaudiodevice.framework/Versions/A/dvaaudiodevice
                               0x119868000 -        0x119951ff7 +com.adobe.dvaplayer.framework (6.0.0 - 6.0.0.0) <906557A2-9648-D93E-4187-ACAFED5FDB10> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/dvaplayer.framework/Versions/A/dvaplayer
                               0x11a666000 -        0x11a71fff7  ColorSyncDeprecated.dylib (400) <7CE58F6E-D2C8-39FB-8EE0-28CC6EC6D04F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/Resources/ColorSyncDeprecated.dylib
                               0x11a830000 -        0x11a854ff7  com.apple.security.csparser (3.0 - 55179.1) <E3D8D12B-84F7-3746-A019-F1AB5B150DF8> /System/Library/Frameworks/Security.framework/PlugIns/csparser.bundle/Contents/MacOS/cspa rser
                               0x11a8ae000 -        0x11a8dbfff  GLRendererFloat (8.6.1) <B598274C-3C23-3EBB-A7C5-13C131FAC651> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
                               0x11f000000 -        0x11f05dfef +com.extensis.Mercury (15.0.3 - 494) <91BB8A33-39B8-F106-301D-C6FB0B5A157F> /Applications/Suitcase Fusion 4.app/Contents/Frameworks/Mercury.framework/Mercury
                               0x11f083000 -        0x11f23afff  GLEngine (8.6.1) <94C4C4C0-E96C-30B2-8CD7-DE8D82CA74F1> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
                               0x11f271000 -        0x11f3b3fff  libGLProgrammability.dylib (8.6.1) <FC866EA6-6263-3F51-BF7C-EA1A9A4162B4> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
                               0x11f500000 -        0x11f798fe7  com.apple.ATIRadeonX2000GLDriver (8.0.61 - 8.0.0) <1FB8519B-5AE7-39FE-964F-6FB2CED5A227> /System/Library/Extensions/ATIRadeonX2000GLDriver.bundle/Contents/MacOS/ATIRadeonX2000GLD river
                               0x11f7ec000 -        0x11f9bdff7 +com.extensis.AutoActivationPlugin.PS13 (3.0.10.9 - 3.0.10.9) <8CC292AF-F60B-F5C2-03BC-9A40D39AB442> /Applications/Adobe Photoshop CS6/*/ExtensisFontManagementPSCS6.plugin/Contents/MacOS/ExtensisFontManagementPSCS6
                               0x11fa9e000 -        0x11fb10fff +com.extensis.FontManagement.plugin-interface (15.0.3 - 494) <3ED87EB9-EAF5-9D64-A718-8859F8F54C23> /Applications/Suitcase Fusion 4.app/Contents/Resources/ExtensisPluginInterface.framework/ExtensisPluginInterface
                               0x11fbbe000 -        0x11fc38fef +com.adobe.adobe_caps (adobe_caps 6.0.29.0 - 6.0.29.0) <C0AD101D-E452-4B4B-5B31-F467133EC20C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/adobe_caps.framework/adobe_caps
                               0x13bc5b000 -        0x13be8fff7 +com.extensis.cpp-core-framework (1.0) <F3D03C89-B332-C1CD-1061-D609E14A38DA> /Applications/Suitcase Fusion 4.app/Contents/Frameworks/cpp-core.framework/Versions/A/cpp-core
                               0x13bf95000 -        0x13bfbbff7 +com.adobe.ape (3.3.8.19346 - 3.3.8.19346) <79E11A18-8AF4-2515-59F7-4CBE161BF020> /Library/Application Support/Adobe/*/adbeapecore.framework/adbeapecore
                               0x13d000000 -        0x13d514fe7 +com.extensis.ExtensisFontManagement.sdk (15.0.3 - 494) <ACD2A65C-F220-5CAF-9ADA-4613B79CAD01> /Applications/Suitcase Fusion 4.app/Contents/Frameworks/ExtensisFontManagement.framework/Versions/A/ExtensisFontManagem ent
                               0x13d66d000 -        0x13d8c8ff7 +com.adobe.PSAutomate (13.0 - 13.0) <F3217910-C8BC-875B-7015-4756AF38B8CB> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/ScriptingSupport.plugin/Contents/MacOS/Scri ptingSupport
                               0x13d9da000 -        0x13dacbfff +com.adobe.AdbeScriptUIFlex (ScriptUIFlex 6.2.29 - 6.2.29.18602) <2BD3388F-976E-0B1C-55DB-B97A5AF95724> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdbeScriptUIFlex.framework/Versions/A/AdbeScriptUIFlex
                               0x13e2bc000 -        0x13e329ff7 +libicudata.40.0.dylib (40) <1FC741E8-F498-4185-7677-42701BF39611> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ICUData.framework/Versions/4.0/libicudata.40.0.dylib
                               0x13e36c000 -        0x13e3b4fff  com.apple.AppleShareClientCore (3.0 - 3.0) <E943C021-08EF-3A44-B2A8-20BC01BD5ABA> /System/Library/Frameworks/AppleShareClientCore.framework/Versions/A/AppleShareClientCore
                               0x13fa15000 -        0x13fac5fe7 + (???) <3DC0B893-3983-14AD-9701-295239CCFAA5>
                               0x13fddb000 -        0x13fde0fff  com.apple.audio.AppleHDAHALPlugIn (2.3.1 - 2.3.1f2) <E807EE74-4241-36B2-87A6-92AFAE41D68F> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
                               0x14041c000 -        0x140444ff7  com.apple.cmio.DAL.VDC_4 (301.0 - 4147) <52F61616-1034-3699-BD49-7860000A2671> /System/Library/Frameworks/CoreMediaIO.framework/Resources/VDC.plugin/Contents/MacOS/VDC
                               0x1404a3000 -        0x14057cff7  libcrypto.0.9.7.dylib (106) <3E1B14DE-342B-318C-8F22-7B9CD88EE760> /usr/lib/libcrypto.0.9.7.dylib
                               0x140e4f000 -        0x140e95fff +com.adobe.AAM.AdobeUpdaterNotificationFramework (UpdaterNotifications 6.0.0.24 - 6.0.0.24) <58C40EB9-2F38-2479-E710-344CAB0CEFB7> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/updaternotifications.framework/Versions/A/UpdaterNotification s
                               0x140eaf000 -        0x140edafff +ServiceManager-Launcher.dylib (389) <7AE35754-3413-206D-4B92-579AAA25B4F8> /Library/Application Support/Adobe/*/ServiceManager-Launcher.dylib
                               0x141e13000 -        0x141eaeff7  unorm8_bgra.dylib (2.1.19) <904EA51D-225A-38AF-B66C-84493C55C065> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_bgra .dylib
                               0x142904000 -        0x1429aefe7 +libicucnv.40.0.dylib (40) <768D99C5-46B9-B849-2834-B5BF541856D1> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/ICUConverter.framework/Versions/4.0/libicucnv.40.0.dylib
                               0x145d28000 -        0x145dc2fff  unorm8_argb.dylib (2.1.19) <1D561074-BC2D-31A1-97A2-12913DD005AE> /System/Library/Frameworks/OpenCL.framework/Versions/A/Libraries/ImageFormats/unorm8_argb .dylib
                               0x147000000 -        0x147e96fef +com.adobe.adobehunspellplugin2 (1.0) <0E601609-3F1F-B573-2CD0-D22B695AF7ED> /Library/Application Support/Adobe/*/AdobeHunspellPlugin.bundle/Contents/MacOS/AdobeHunspellPlugin
                               0x14d6bc000 -        0x14e641fd7 +com.adobe.ape.engine (3.3.8.19346 - 3.3.8.19346) <5E188E32-37F7-4E0B-0674-E8D16B60074F> /Library/Application Support/Adobe/*/adbeapecore.framework/Libraries/adbeapeengine.bundle/Contents/MacOS/adbea peengine
                               0x1c347e000 -        0x1c3c51ff7 +com.adobe.PDFL (PROD_MAJOR.PROD_MINOR.PROD_STEP - 10.0.1.18562) <8DC49EE4-5700-97A1-EBFE-68024AE1980C> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
                               0x1cae00000 -        0x1cb195fe7 +com.adobe.standard.multiplugin (13.0 - 13.0) <B323572C-A35D-F2D4-9D04-A454469889B8> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Filters/Standard Multiplugin.plugin/Contents/MacOS/Standard Multiplugin
                               0x1cb5c2000 -        0x1cbbabff7 +com.adobe.S4W (13.0 - 13.0) <5432C0D2-083C-4E43-5940-73304501E9F5> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Import-Export/Save for Web.plugin/Contents/MacOS/Save for Web
                               0x23b2c2000 -        0x23c50afff +com.adobe.CameraRaw (7.1 [354] - 7.1.0f354) <EB045CAE-E67B-5112-F194-B63B683B9A71> /Library/Application Support/Adobe/*/Camera Raw.plugin/Contents/MacOS/Camera Raw
                            0x7fff6f0a9000 -     0x7fff6f0dd93f  dyld (210.2.3) <A40597AA-5529-3337-8C09-D8A014EB1578> /usr/lib/dyld
                            0x7fff82fa7000 -     0x7fff8312dfff  libBLAS.dylib (1073.4) <C102C0F6-8CB6-3B49-BA6B-2EB61F0B2784> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
                            0x7fff8319e000 -     0x7fff831a8fff  com.apple.DisplayServicesFW (2.6.1 - 353) <0505CB8A-47D9-3539-9A0D-24F09D99E9D8> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
                            0x7fff831a9000 -     0x7fff831f5ff7  libauto.dylib (185.1) <73CDC482-16E3-3FC7-9BB4-FBA2DA44DBC2> /usr/lib/libauto.dylib
                            0x7fff831f6000 -     0x7fff832a7fff  com.apple.LaunchServices (539.7 - 539.7) <DA7C602E-5E01-31B8-925D-B45360CA089F> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
                            0x7fff832a8000 -     0x7fff832d3fff  com.apple.datadetectors (4.0 - 199.0) <4FE34A35-8DE1-3A43-8586-4B2ED03F2D84> /System/Library/PrivateFrameworks/DataDetectors.framework/Versions/A/DataDetectors
                            0x7fff832d4000 -     0x7fff833d6fff  libcrypto.0.9.8.dylib (47) <74F165AD-4572-3B26-B0E2-A97477FE59D0> /usr/lib/libcrypto.0.9.8.dylib
                            0x7fff83460000 -     0x7fff83475fff  com.apple.ImageCapture (8.0 - 8.0) <17A45CE6-7DA3-36A5-B7EF-72BC136981AE> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
                            0x7fff83476000 -     0x7fff834c1ff7  com.apple.CoreMedia (1.0 - 926.62) <CFBD094F-DA9C-3498-9D50-BC754B56F00A> /System/Library/Frameworks/CoreMedia.framework/Versions/A/CoreMedia
                            0x7fff83517000 -     0x7fff83539ff7  libxpc.dylib (140.41) <FAC04D8B-680E-325F-8F0C-DD69859D0E01> /usr/lib/system/libxpc.dylib
                            0x7fff835b5000 -     0x7fff835b5fff  com.apple.AOSMigrate (1.0 - 1) <585B1483-490E-32DD-97DC-B9279E9D3490> /System/Library/PrivateFrameworks/AOSMigrate.framework/Versions/A/AOSMigrate
                            0x7fff835b6000 -     0x7fff835c3ff7  com.apple.NetAuth (4.0 - 4.0) <F5BC7D7D-AF28-3C83-A674-DADA48FF7810> /System/Library/PrivateFrameworks/NetAuth.framework/Versions/A/NetAuth
                            0x7fff835c4000 -     0x7fff835c8ff7  com.apple.CommonPanels (1.2.5 - 94) <AAC003DE-2D6E-38B7-B66B-1F3DA91E7245> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
                            0x7fff835c9000 -     0x7fff83649ff7  com.apple.ApplicationServices.ATS (332 - 341.1) <BD83B039-AB25-3E3E-9975-A67DAE66988B> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
                            0x7fff83650000 -     0x7fff8369aff7  libGLU.dylib (8.6.1) <DF45C1E3-3884-3991-B84F-F39B482E8BF8> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
                            0x7fff8369b000 -     0x7fff8379dfff  libJP2.dylib (845) <405CAF25-0AA5-3C6B-A4A6-94471A1EDD2F> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJP2.dylib
                            0x7fff837dc000 -     0x7fff8380afff  com.apple.CoreServicesInternal (154.2 - 154.2) <3E6196E6-F3B4-316F-9E1F-13B6B9694C7E> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                            0x7fff8380b000 -     0x7fff83908ff7  libxml2.2.dylib (22.3) <47B09CB2-C636-3024-8B55-6040F7829B4C> /usr/lib/libxml2.2.dylib
                            0x7fff83909000 -     0x7fff840b1fff  com.apple.CoreAUC (6.16.00 - 6.16.00) <B0B4B5B8-6F8F-3221-9128-313E3B8C695D> /System/Library/PrivateFrameworks/CoreAUC.framework/Versions/A/CoreAUC
                            0x7fff840c3000 -     0x7fff840e2ff7  libresolv.9.dylib (51) <0882DC2D-A892-31FF-AD8C-0BB518C48B23> /usr/lib/libresolv.9.dylib
                            0x7fff840e3000 -     0x7fff84150fff  com.apple.datadetectorscore (4.0 - 269.1) <C94C372B-3821-3A46-A8C2-091AB1CFF7F4> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
                            0x7fff8415e000 -     0x7fff8416aff7  com.apple.DirectoryService.Framework (10.8 - 151.10) <DA05EF06-8EBD-3759-B5D3-E6FC86C5D850> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
                            0x7fff8416b000 -     0x7fff841baff7  libcorecrypto.dylib (106.2) <CE0C29A3-C420-339B-ADAA-52F4683233CC> /usr/lib/system/libcorecrypto.dylib
                            0x7fff841bb000 -     0x7fff841faff7  com.apple.QD (3.42 - 285) <8DF36FCA-C06B-30F4-A631-7BE2FF7E56D1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
                            0x7fff841fb000 -     0x7fff84637fff  com.apple.VideoToolbox (1.0 - 926.62) <7D749558-08B6-3F86-A20E-05ECDACE6F17> /System/Library/Frameworks/VideoToolbox.framework/Versions/A/VideoToolbox
                            0x7fff84752000 -     0x7fff847ecfff  com.apple.CoreSymbolication (3.0 - 87) <75F2C0DD-549A-36F6-BD9E-FB40A924344F> /System/Library/PrivateFrameworks/CoreSymbolication.framework/Versions/A/CoreSymbolicatio n
                            0x7fff847ed000 -     0x7fff84847fff  com.apple.print.framework.PrintCore (8.1 - 387.1) <1FA17B75-33E6-35BD-9198-35F92E37B248> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
                            0x7fff84848000 -     0x7fff848b0ff7  libc++.1.dylib (65.1) <20E31B90-19B9-3C2A-A9EB-474E08F9FE05> /usr/lib/libc++.1.dylib
                            0x7fff848b1000 -     0x7fff848bcfff  com.apple.CommonAuth (3.0 - 2.0) <74A86DDD-57D0-3178-AB74-E1F31DBFFC39> /System/Library/PrivateFrameworks/CommonAuth.framework/Versions/A/CommonAuth
                            0x7fff848bd000 -     0x7fff848dfff7  com.apple.Kerberos (2.0 - 1) <C49B8820-34ED-39D7-A407-A3E854153556> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
                            0x7fff848e0000 -     0x7fff84962fff  com.apple.Heimdal (3.0 - 2.0) <660A6C64-4912-32C8-A332-B64164032A2D> /System/Library/PrivateFrameworks/Heimdal.framework/Versions/A/Heimdal
                            0x7fff84963000 -     0x7fff849baff7  com.apple.ScalableUserInterface (1.0 - 1) <F1D43DFB-1796-361B-AD4B-39F1EED3BE19> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/ScalableUserInterfa ce.framework/Versions/A/ScalableUserInterface
                            0x7fff849bb000 -     0x7fff84aabff7  com.apple.DiskImagesFramework (10.8 - 344) <AC72B2EF-7307-3B20-B561-5ECF30E83627> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                            0x7fff84b4d000 -     0x7fff84b4eff7  libsystem_sandbox.dylib (220) <3C3B03CF-C525-3CB3-8557-62E91B93AC95> /usr/lib/system/libsystem_sandbox.dylib
                            0x7fff84b4f000 -     0x7fff84f46fff  libLAPACK.dylib (1073.4) <D632EC8B-2BA0-3853-800A-20DA00A1091C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
                            0x7fff84f4c000 -     0x7fff84f54ff7  libsystem_dnssd.dylib (379.32.1) <62AA0B84-188A-348B-8F9E-3E2DB08DB93C> /usr/lib/system/libsystem_dnssd.dylib
                            0x7fff84f55000 -     0x7fff84f69fff  com.apple.speech.synthesis.framework (4.1.12 - 4.1.12) <94EDF2AB-809C-3D15-BED5-7AD45B2A7C16> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
                            0x7fff84f8d000 -     0x7fff84ffdfff  com.apple.ISSupport (1.9.8 - 56) <23ED7650-2705-355A-9F11-409A9981AC53> /System/Library/PrivateFrameworks/ISSupport.framework/Versions/A/ISSupport
                            0x7fff84ffe000 -     0x7fff85029fff  com.apple.framework.Apple80211 (8.0.1 - 801.17) <05786C8E-8C6F-31AF-80B5-9C98175757B4> /System/Library/PrivateFrameworks/Apple80211.framework/Versions/A/Apple80211
                            0x7fff8502a000 -     0x7fff85080ff7  com.apple.opencl (2.1.20 - 2.1.20) <AF142CA4-EA1D-31B0-A48F-AA2B75D4309E> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
                            0x7fff85081000 -     0x7fff8509bfff  com.apple.CoreMediaAuthoring (2.1 - 914) <CFA664F9-D5A7-3281-A12F-3ED8A98FD8C1> /System/Library/PrivateFrameworks/CoreMediaAuthoring.framework/Versions/A/CoreMediaAuthor ing
                            0x7fff850c5000 -     0x7fff850c7ff7  com.apple.print.framework.Print (8.0 - 258) <34666CC2-B86D-3313-B3B6-A9977AD593DA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
                            0x7fff850dd000 -     0x7fff850fafff  com.apple.openscripting (1.3.6 - 148.2) <33B87CFB-CACC-3EBC-893D-38AECB94FB8A> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
                            0x7fff850fb000 -     0x7fff85108fff  com.apple.AppleFSCompression (49 - 1.0) <5508344A-2A7E-3122-9562-6F363910A80E> /System/Library/PrivateFrameworks/AppleFSCompression.framework/Versions/A/AppleFSCompress ion
                            0x7fff8510e000 -     0x7fff8530efff  libicucore.A.dylib (491.11.1) <CC318A27-878A-38CE-9292-1B98353FA9C7> /usr/lib/libicucore.A.dylib
                            0x7fff8530f000 -     0x7fff85429fff  com.apple.coreavchd (5.6.0 - 5600.4.16) <0CF2ABE5-B088-3B5D-9C04-47AE708ADAE3> /System/Library/PrivateFrameworks/CoreAVCHD.framework/Versions/A/CoreAVCHD
                            0x7fff8542a000 -     0x7fff85438fff  com.apple.Librarian (1.1 - 1) <1635162F-239A-341E-83C7-710C55E254AF> /System/Library/PrivateFrameworks/Librarian.framework/Versions/A/Librarian
                            0x7fff85439000 -     0x7fff8566eff7  com.apple.CoreData (106.1 - 407.7) <24E0A6B4-9ECA-3D12-B26A-72B9DCF09768> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
                            0x7fff856b7000 -     0x7fff856bcfff  com.apple.OpenDirectory (10.8 - 151.10) <CF44120B-9B01-32DD-852E-C9C0E1243FC0> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
                            0x7fff856bd000 -     0x7fff856befff  liblangid.dylib (116) <864C409D-D56B-383E-9B44-A435A47F2346> /usr/lib/liblangid.dylib
                            0x7fff856bf000 -     0x7fff856c0ff7  libdnsinfo.dylib (453.18) <E7595861-ECF9-336E-9901-BED2620FAA80> /usr/lib/system/libdnsinfo.dylib
                            0x7fff856f7000 -     0x7fff85718fff  com.apple.Ubiquity (1.2 - 243.10) <F97D3A33-2C8B-3CFF-AF75-A74866D42853> /System/Library/PrivateFrameworks/Ubiquity.framework/Versions/A/Ubiquity
                            0x7fff85719000 -     0x7fff85719fff  com.apple.Accelerate.vecLib (3.8 - vecLib 3.8) <B5A18EE8-DF81-38DD-ACAF-7076B2A26225> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
                            0x7fff8571a000 -     0x7fff8573fff7  libc++abi.dylib (24.4) <E7BD9363-1D25-3551-A68A-2E2FF6ABECD7> /usr/lib/libc++abi.dylib
                            0x7fff85794000 -     0x7fff857b4fff  libPng.dylib (845) <C3CDD2B4-3CB0-3F6D-8411-DAAF267E952B> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libPng.dylib
                            0x7fff857b5000 -     0x7fff857fdfff  libcurl.4.dylib (69.2) <EBDBF42D-E4A6-3D05-A76B-2817D79D59E2> /usr/lib/libcurl.4.dylib
                            0x7fff85928000 -     0x7fff85929ff7  libremovefile.dylib (23.1) <DBBFAF35-AC78-3856-92F6-6E4FD9DF14A2> /usr/lib/system/libremovefile.dylib
                            0x7fff8592a000 -     0x7fff8593dff7  libbsm.0.dylib (32) <F497D3CE-40D9-3551-84B4-3D5E39600737> /usr/lib/libbsm.0.dylib
                            0x7fff8593e000 -     0x7fff85a10ff7  com.apple.CoreText (260.0 - 275.16) <5BFC1D67-6A6F-38BC-9D90-9C712684EDAC> /System/Library/Frameworks/CoreText.framework/Versions/A/CoreText
                            0x7fff85a13000 -     0x7fff85a2eff7  libsystem_kernel.dylib (2050.18.24) <C0535565-35D1-31A7-A744-63D9F10F12A4> /usr/lib/system/libsystem_kernel.dylib
                            0x7fff85a2f000 -     0x7fff85a88fff  com.apple.ImageCaptureCore (5.0.1 - 5.0.1) <2CC27836-1E1E-3633-B15C-A3BA1734D092> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
                            0x7fff85a89000 -     0x7fff85de5fff  com.apple.Foundation (6.8 - 945.11) <A5D41956-A354-3ACC-9355-BE200072223B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                            0x7fff85de6000 -     0x7fff85e29ff7  com.apple.bom (12.0 - 192) <0BF1F2D2-3648-36B7-BE4B-551A0173209B> /System/Library/PrivateFrameworks/Bom.framework/Versions/A/Bom
                            0x7fff85e2a000 -     0x7fff85fb4fff  com.apple.WebKit (8536 - 8536.26.14) <7C4D5DE6-7153-3E54-8D4F-BB2E9AE74878> /System/Library/Frameworks/WebKit.framework/Versions/A/WebKit
                            0x7fff85fb5000 -     0x7fff85fb6fff  libsystem_blocks.dylib (59) <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
                            0x7fff85fb7000 -     0x7fff85fc4fff  com.apple.KerberosHelper (4.0 - 1.0) <6815439D-1A03-3251-99FE-CC24CF4C93C5> /System/Library/PrivateFrameworks/KerberosHelper.framework/Versions/A/KerberosHelper
                            0x7fff85fc5000 -     0x7fff86008fff  com.apple.RemoteViewServices (2.0 - 80.5) <F3A897C9-A277-3B56-8FB3-2BC2C10C33BF> /System/Library/PrivateFrameworks/RemoteViewServices.framework/Versions/A/RemoteViewServi ces
                            0x7fff86009000 -     0x7fff8600dff7  com.apple.TCC (1.0 - 1) <F2F3B753-FC73-3543-8BBE-859FDBB4D6A6> /System/Library/PrivateFrameworks/TCC.framework/Versions/A/TCC
                            0x7fff8600e000 -     0x7fff86019ff7  com.apple.bsd.ServiceManagement (2.0 - 2.0) <C12962D5-85FB-349E-AA56-64F4F487F219> /System/Library/Frameworks/ServiceManagement.framework/Versions/A/ServiceManagement
                            0x7fff860a1000 -     0x7fff86174ff7  com.apple.DiscRecording (7.0 - 7000.2.4) <005BE6FF-38A1-3AEA-B24C-9D4F330EF6BE> /System/Library/Frameworks/DiscRecording.framework/Versions/A/DiscRecording
                            0x7fff861dd000 -     0x7fff86213fff  libsystem_info.dylib (406.17) <4FFCA242-7F04-365F-87A6-D4EFB89503C1> /usr/lib/system/libsystem_info.dylib
                            0x7fff86214000 -     0x7fff862eeff7  com.apple.backup.framework (1.4.1 - 1.4.1) <A3CFCA9E-717C-302D-821B-16FD35E6673F> /System/Library/PrivateFrameworks/Backup.framework/Versions/A/Backup
                            0x7fff86a32000 -     0x7fff86a33fff  libDiagnosticMessagesClient.dylib (8) <8548E0DC-0D2F-30B6-B045-FE8A038E76D8> /usr/lib/libDiagnosticMessagesClient.dylib
                            0x7fff86a34000 -     0x7fff86a7ffff  com.apple.framework.CoreWLAN (3.0.1 - 301.11) <8370178E-438C-375C-AA41-A8DEE60B8636> /System/Library/Frameworks/CoreWLAN.framework/Versions/A/CoreWLAN
                            0x7fff86a80000 -     0x7fff86a87fff  libcopyfile.dylib (89) <876573D0-E907-3566-A108-577EAD1B6182> /usr/lib/system/libcopyfile.dylib
                            0x7fff86a8a000 -     0x7fff86a8afff  libOpenScriptingUtil.dylib (148.2) <B8061D13-C1B2-38D5-A723-9A98D64E67AC> /usr/lib/libOpenScriptingUtil.dylib
                            0x7fff86a8b000 -     0x7fff86b89fff  com.apple.QuickLookUIFramework (4.0 - 555.4) <58EC2F30-0959-3586-A1DD-BDCAF589D2D3> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
                            0x7fff86b8a000 -     0x7fff87b43fff  com.apple.WebCore (8536 - 8536.26.14) <60029E1A-C1DB-3A1F-8528-4970058D8B3D> /System/Library/Frameworks/WebKit.framework/Versions/A/Frameworks/WebCore.framework/Versi ons/A/WebCore
                            0x7fff87b58000 -     0x7fff884e8c67  com.apple.CoreGraphics (1.600.0 - 324.6) <DCC70C6E-AB6D-3457-A823-7569CB29B107> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                            0x7fff8852e000 -     0x7fff8853dff7  com.apple.opengl (1.8.6 - 1.8.6) <720CC06C-0D01-37AE-BB3D-D7F0242B262A> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
                            0x7fff88541000 -     0x7fff886b2ff7  com.apple.QTKit (7.7.1 - 2599.13) <5B24A892-ED69-3C01-8B00-DF3AD81A20D4> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
                            0x7fff886b3000 -     0x7fff886c2ff7  libxar.1.dylib (105) <370ED355-E516-311E-BAFD-D80633A84BE1> /usr/lib/libxar.1.dylib
                            0x7fff886c3000 -     0x7fff8872cfff  libstdc++.6.dylib (56) <EAA2B53E-EADE-39CF-A0EF-FB9D4940672A> /usr/lib/libstdc++.6.dylib
                            0x7fff88731000 -     0x7fff8875bff7  com.apple.CoreVideo (1.8 - 99.3) <C424838A-889C-39E5-8108-FD05C93D26A0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                            0x7fff88761000 -     0x7fff887f2fff  com.apple.CorePDF (2.0 - 2) <EB5660B1-0D79-34F3-B242-B559AE0A5B4A> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
                            0x7fff888b5000 -     0x7fff888c3fff  libcommonCrypto.dylib (60026) <2D6537F5-1B5E-305C-A1CF-D1FA80CA3939> /usr/lib/system/libcommonCrypto.dylib
                            0x7fff888c4000 -     0x7fff8891afff  com.apple.HIServices (1.20 - 417) <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                            0x7fff8891b000 -     0x7fff88947ff7  libRIP.A.dylib (324.6) <5A7EB5C2-BA60-36D7-BF41-9853F37837AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                            0x7fff88948000 -     0x7fff8897cfff  com.apple.securityinterface (6.0 - 55024.4) <614C9B8E-2056-3A41-9A01-DAF74C97CC43> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
                            0x7fff889ba000 -     0x7fff889befff  libpam.2.dylib (20) <C8F45864-5B58-3237-87E1-2C258A1D73B8> /usr/lib/libpam.2.dylib
                            0x7fff889bf000 -     0x7fff88b6dfff  com.apple.QuartzCore (1.8 - 304.0) <BDC66714-F60C-386D-A773-F897D1E87AB6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                            0x7fff88ba7000 -     0x7fff88bbcff7  libdispatch.dylib (228.23) <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                            0x7fff89472000 -     0x7fff894ffff7  com.apple.SearchKit (1.4.0 - 1.4.0) <C7F43889-F8BF-3CB9-AD66-11AEFCBCEDE7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
                            0x7fff89500000 -     0x7fff89517fff  com.apple.CFOpenDirectory (10.8 - 151.10) <FFBBA538-00B5-334E-BA5B-C8AD6CDCDA14> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
                            0x7fff896d3000 -     0x7fff89720fff  com.apple.CoreMediaIO (301.0 - 4147) <61E348A5-1F9E-3390-9613-3EACE40DBD8C> /System/Library/Frameworks/CoreMediaIO.framework/Versions/A/CoreMediaIO
                            0x7fff897f0000 -     0x7fff89871fff  com.apple.Metadata (10.7.0 - 707.3) <A45D75C1-B311-39F0-AF4A-63FCCC098C1D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
                            0x7fff89872000 -     0x7fff89893ff7  libCRFSuite.dylib (33) <736ABE58-8DED-3289-A042-C25AF7AE5B23> /usr/lib/libCRFSuite.dylib
                            0x7fff89894000 -     0x7fff89897fff  com.apple.AppleSystemInfo (2.0 - 2) <BC221376-361F-3F85-B284-DC251D3BB442> /System/Library/PrivateFrameworks/AppleSystemInfo.framework/Versions/A/AppleSystemInfo
                            0x7fff898a9000 -     0x7fff898a9fff  com.apple.quartzframework (1.5 - 1.5) <6403C982-0D45-37EE-A0F0-0EF8BCFEF440> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
                            0x7fff898aa000 -     0x7fff898b6fff  com.apple.CrashReporterSupport (10.8.2 - 414.3) <B1A904D2-1944-39AD-9F43-F589CEE3FCC3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                            0x7fff898bd000 -     0x7fff89a0efff  com.apple.audio.toolbox.AudioToolbox (1.8 - 1.8) <833DA682-A3C1-39E7-AEC3-9EDC734DE2A9> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
                            0x7fff89a0f000 -     0x7fff89a6cfff  com.apple.audio.CoreAudio (4.1.0 - 4.1.0) <B3198BD6-EA1D-3E5E-ADD4-37D8E6B72678> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                            0x7fff89a6d000 -     0x7fff89cc8ff7  com.apple.QuartzComposer (5.1 - 284) <D9CDC9ED-9F03-30F0-80DF-BA189A054AC9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
                            0x7fff89cc9000 -     0x7fff8a0c2ff7  com.apple.MediaToolbox (1.0 - 926.62) <83BBE53E-29FE-3874-9991-B6D009EADCC5> /System/Library/Frameworks/MediaToolbox.framework/Versions/A/MediaToolbox
                            0x7fff8a0c3000 -     0x7fff8a10bfff  com.apple.framework.CoreWiFi (1.0 - 100.10) <0E863B4A-1094-3F8D-BEDE-D99537E9C588> /System/Library/Frameworks/CoreWiFi.framework/Versions/A/CoreWiFi
                            0x7fff8a10c000 -     0x7fff8a10ffff  com.apple.help (1.3.2 - 42) <343904FE-3022-3573-97D6-5FE17F8643BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
                            0x7fff8a110000 -     0x7fff8a16cfff  com.apple.QuickLookFramework (4.0 - 555.4) <B34DB61C-15F0-3CF8-98A4-152C2F54DF8D> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
                            0x7fff8a16d000 -     0x7fff8a17bff7  libkxld.dylib (2050.18.24) <7027CE49-007D-3553-8FFA-3E3B428B2316> /usr/lib/system/libkxld.dylib
                            0x7fff8a504000 -     0x7fff8a7d4fff  com.apple.security (7.0 - 55179.1) <639641EF-8156-3190-890C-1053658E044A> /System/Library/Frameworks/Security.framework/Versions/A/Security
                            0x7fff8a830000 -     0x7fff8a949ff7  com.apple.ImageIO.framework (3.2.0 - 845) <553B9828-A7D9-3AE4-A214-1C33417545FD> /System/Library/Frameworks/ImageIO.framework/Versions/A/ImageIO
                            0x7fff8a94a000 -     0x7fff8a951fff  com.apple.NetFS (5.0 - 4.0) <82E24B9A-7742-3DA3-9E99-ED267D98C05E> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
                            0x7fff8a952000 -     0x7fff8a964ff7  libz.1.dylib (43) <2A1551E8-A272-3DE5-B692-955974FE1416> /usr/lib/libz.1.dylib
                            0x7fff8a965000 -     0x7fff8a978ff7  com.apple.LangAnalysis (1.7.0 - 1.7.0) <2F2694E9-A7BC-33C7-B4CF-8EC907DF0FEB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
                            0x7fff8a979000 -     0x7fff8ad04ff7  com.apple.FinderKit (1.1.1 - 1.1.1) <1A5F536A-E48E-362D-92D4-5BC834D79FBF> /System/Library/PrivateFrameworks/FinderKit.framework/Versions/A/FinderKit
                            0x7fff8ad05000 -     0x7fff8ad11fff  libCSync.A.dylib (324.6) <2033247A-CABC-3E20-8498-7367A8F44A08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                            0x7fff8ad12000 -     0x7fff8ad63ff7  com.apple.SystemConfiguration (1.12.2 - 1.12.2) <E095637C-457F-3D8F-AE32-A032F9D5A46C> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
                            0x7fff8ad64000 -     0x7fff8ad64fff  com.apple.Carbon (154 - 155) <372716D2-6FA1-3611-8501-3DD1D4A6E8C8> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
                            0x7fff8ad65000 -     0x7fff8ad69fff  libCoreVMClient.dylib (24.4) <55F71158-ADEE-3863-92E9-4772DCEA8E31> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
                            0x7fff8ad6a000 -     0x7fff8adbfff7  libTIFF.dylib (845) <ADCB4683-69EB-318B-8BE7-5FDF38BCADAF> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libTIFF.dylib
                            0x7fff8adc0000 -     0x7fff8ade8fff  libJPEG.dylib (845) <A32618D7-FB91-3EE2-A105-5407B2F3F8D8> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libJPEG.dylib
                            0x7fff8adeb000 -     0x7fff8adebfff  com.apple.vecLib (3.8 - vecLib 3.8) <794317C7-4E38-338A-A874-5E18001C8503> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
                            0x7fff8adec000 -     0x7fff8ae59ff7  com.apple.framework.IOKit (2.0 - 755.18.10) <142E19DD-1C8D-3D61-ABC8-83994A73279F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                            0x7fff8ae6e000 -     0x7fff8b185ff7  com.apple.CoreServices.CarbonCore (1037.3 - 1037.3) <DF7CABCA-F2CB-345B-8EFF-F0F4E937B7FF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                            0x7fff8b187000 -     0x7fff8b5a4fff  FaceCoreLight (2.4.1) <A34C9575-C4C1-31B1-809B-7751070B4E8B> /System/Library/PrivateFrameworks/FaceCoreLight.framework/Versions/A/FaceCoreLight
                            0x7fff8b5a5000 -     0x7fff8b5e5fff  com.apple.MediaKit (13 - 659) <0C56D7FF-0430-3199-9952-CF8577519449> /System/Library/PrivateFrameworks/MediaKit.framework/Versions/A/MediaKit
                            0x7fff8b5ff000 -     0x7fff8b5fffff  libkeymgr.dylib (25) <CC9E3394-BE16-397F-926B-E579B60EE429> /usr/lib/system/libkeymgr.dylib
                            0x7fff8b694000 -     0x7fff8b69fff7  com.apple.aps.framework (3.0 - 3.0) <11E1A5D1-F5E5-3228-8B6F-77EB36B5C248> /System/Library/PrivateFrameworks/ApplePushService.framework/Versions/A/ApplePushService
                            0x7fff8b6a0000 -     0x7fff8b7b892f  libobjc.A.dylib (532.2) <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
                            0x7fff8b7be000 -     0x7fff8b7c8fff  com.apple.speech.recognition.framework (4.1.5 - 4.1.5) <D803919C-3102-3515-A178-61E9C86C46A1> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
                            0x7fff8b7c9000 -     0x7fff8b86fff7  com.apple.CoreServices.OSServices (557.4 - 557.4) <841878A8-6F3E-300D-8F01-444B3CC1F41D> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
                            0x7fff8b8f3000 -     0x7fff8b8f4ff7  libSystem.B.dylib (169.3) <132FE02E-3865-3F1F-B78D-C93D65930A67> /usr/lib/libSystem.B.dylib
                            0x7fff8b8f5000 -     0x7fff8b8fbff7  libunwind.dylib (35.1) <21703D36-2DAB-3D8B-8442-EAAB23C060D3> /usr/lib/system/libunwind.dylib
                            0x7fff8b8fc000 -     0x7fff8b936fff  com.apple.GSS (3.0 - 2.0) <0BDF8090-5EF4-3759-94DE-8521D74188AA> /System/Library/Frameworks/GSS.framework/Versions/A/GSS
                            0x7fff8b937000 -     0x7fff8bbdbfff  com.apple.CoreImage (8.2.2 - 1.0.1) <930B0B23-DD84-3B0C-B5A9-C09B7068A6F0> /System/Library/Frameworks/QuartzCore.framework/Versions/A/Frameworks/CoreImage.framework /Versions/A/CoreImage
                            0x7fff8bbdc000 -     0x7fff8bbdcfff  com.apple.ApplicationServices (45 - 45) <A3ABF20B-ED3A-32B5-830E-B37831A45A80> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
                            0x7fff8bbdd000 -     0x7fff8bbebff7  libsystem_network.dylib (77.10) <0D99F24E-56FE-380F-B81B-4A4C630EE587> /usr/lib/system/libsystem_network.dylib
                            0x7fff8bbec000 -     0x7fff8bc17fff  libxslt.1.dylib (11.3) <441776B8-9130-3893-956F-39C85FFA644F> /usr/lib/libxslt.1.dylib
                            0x7fff8bc18000 -     0x7fff8bc53fff  com.apple.LDAPFramework (2.4.28 - 194.5) <0190B746-F684-3F43-B4D0-148EFE386CA4> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
                            0x7fff8bc54000 -     0x7fff8bc8bff7  libssl.0.9.8.dylib (47) <923945E6-C489-3406-903B-A362410753F8> /usr/lib/libssl.0.9.8.dylib
                            0x7fff8bcf4000 -     0x7fff8bd5cfff  libvDSP.dylib (380.6) <CD4C5EEB-9E63-30C4-8103-7A5EAEA0BE60> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
                            0x7fff8bd65000 -     0x7fff8bd65fff  com.apple.Accelerate (1.8 - Accelerate 1.8) <6AD48543-0864-3D40-80CE-01F184F24B45> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
                            0x7fff8be03000 -     0x7fff8be40fe7  libGLImage.dylib (8.6.1) <7F31DD61-3110-3541-A9BB-035CD1262E50> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
                            0x7fff8be41000 -     0x7fff8c0c1ff7  com.apple.AOSKit (1.05 - 151) <A34E8584-797C-318F-9E25-937A710C68AB> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
                            0x7fff8c0c2000 -     0x7fff8c206fef  com.apple.MediaControlSender (1.4.5 - 145.3) <3A308EA3-21F7-3213-9157-D3421EB43715> /System/Library/PrivateFrameworks/MediaControlSender.framework/Versions/A/MediaControlSen der
                            0x7fff8c222000 -     0x7fff8c22ffff  libbz2.1.0.dylib (29) <CE9785E8-B535-3504-B392-82F0064D9AF2> /usr/lib/libbz2.1.0.dylib
                            0x7fff8c26b000 -     0x7fff8c282fff  com.apple.GenerationalStorage (1.1 - 132.2) <3F5C87BD-D866-3732-8CB9-D23ED9784D6E> /System/Library/PrivateFrameworks/GenerationalStorage.framework/Versions/A/GenerationalSt orage
                            0x7fff8c283000 -     0x7fff8c2bdfff  com.apple.framework.internetaccounts (2.1 - 210) <0AB62FFA-42C8-3433-9C23-7D1AB411348F> /System/Library/PrivateFrameworks/InternetAccounts.framework/Versions/A/InternetAccounts
                            0x7fff8c2cd000 -     0x7fff8c2cdfff  com.apple.Cocoa (6.7 - 19) <1F77945C-F37A-3171-B22E-F7AB0FCBB4D4> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
                            0x7fff8c2ce000 -     0x7fff8c34cff7  com.apple.securityfoundation (6.0 - 55115.4) <137E156C-B29C-3B84-95B3-669BC7C1BA7A> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
                            0x7fff8c34d000 -     0x7fff8c46dfff  com.apple.desktopservices (1.7.2 - 1.7.2) <CDE8C2C2-C505-31B0-8C61-E40E4EA364A5> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                            0x7fff8c46e000 -     0x7fff8c472fff  libGIF.dylib (845) <2690CE83-E934-3EF8-A30A-996EDADCE3E4> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libGIF.dylib
                            0x7fff8c473000 -     0x7fff8c479fff  libGFXShared.dylib (8.6.1) <CF55E720-1B9E-3E24-A1DA-7FA8B261CD8E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
                            0x7fff8c47a000 -     0x7fff8d0a7ff7  com.apple.AppKit (6.8 - 1187.34) <1FF64844-EB62-3F96-AED7-6525B7CCEC23> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                            0x7fff8d0a8000 -     0x7fff8d0aefff  libmacho.dylib (829) <BF332AD9-E89F-387E-92A4-6E1AB74BD4D9> /usr/lib/system/libmacho.dylib
                            0x7fff8d13a000 -     0x7fff8d1f7ff7  com.apple.ColorSync (4.8.0 - 4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                            0x7fff8d338000 -     0x7fff8d5fbff7  com.apple.AddressBook.framework (7.1 - 1167) <92EF9CE4-A42B-3D30-8CA2-79C0A66BB4CE> /System/Library/Frameworks/AddressBook.framework/Versions/A/AddressBook
                            0x7fff8d5fc000 -     0x7fff8d60dff7  libsasl2.2.dylib (166) <649CAE0E-8FFE-3C60-A849-BE6300E4B726> /usr/lib/libsasl2.2.dylib
                            0x7fff8d60e000 -     0x7fff8d6acff7  com.apple.ink.framework (10.8.2 - 150) <84B9825C-3822-375F-BE58-A753444FBDE2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
                            0x7fff8d6b7000 -     0x7fff8d6e5ff7  libsystem_m.dylib (3022.6) <B434BE5C-25AB-3EBD-BAA7-5304B34E3441> /usr/lib/system/libsystem_m.dylib
                            0x7fff8d746000 -     0x7fff8d92ffff  com.apple.CoreFoundation (6.8 - 744.12) <EF002794-DAEF-31C6-866C-E3E3AC387A9F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                            0x7fff8d930000 -     0x7fff8d946fff  com.apple.MultitouchSupport.framework (235.28 - 235.28) <BD78B16E-9B5A-3E07-93B4-13AD1A538CAC> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
                            0x7fff8d949000 -     0x7fff8dabdfff  com.apple.CFNetwork (596.2.3 - 596.2.3) <6A16C2BD-1035-30F9-AE96-D9E3BB54A976> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                            0x7fff8dabe000 -     0x7fff8dac1ff7  libdyld.dylib (210.2.3) <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
                            0x7fff8dac2000 -     0x7fff8dac4ff7  libunc.dylib (25) <92805328-CD36-34FF-9436-571AB0485072> /usr/lib/system/libunc.dylib
                            0x7fff8dc1e000 -     0x7fff8dc62fff  libcups.2.dylib (327) <9B3F3321-D2BC-3195-BF20-4008FC52A390> /usr/lib/libcups.2.dylib
                            0x7fff8dc63000 -     0x7fff8dd58fff  libiconv.2.dylib (34) <FEE8B996-EB44-37FA-B96E-D379664DEFE1> /usr/lib/libiconv.2.dylib
                            0x7fff8dd6a000 -     0x7fff8dd6cfff  libquarantine.dylib (52) <4BE2E642-A14F-340A-B482-5BD2AEFD9C24> /usr/lib/system/libquarantine.dylib
                            0x7fff8dd6d000 -     0x7fff8dd6dffd  com.apple.audio.units.AudioUnit (1.8 - 1.8) <29E2C990-3617-3FA2-BDD7-DB7DF493E443> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
                            0x7fff8dd6e000 -     0x7fff8de79fff  libFontParser.dylib (84.5) <617A7D30-C7BC-39FC-A1FE-59367B4A5719> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
                            0x7fff8e08a000 -     0x7fff8e08cfff  com.apple.securityhi (4.0 - 55002) <8B2008A2-B6A2-3E69-9FA2-77B38C869DD6> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
                            0x7fff8e08d000 -     0x7fff8e0b9fff  com.apple.quartzfilters (1.8.0 - 1.7.0) <B8DE45D7-1827-3379-A478-1A574A1D11D9> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
                            0x7fff8e0ba000 -     0x7fff8e0bafff  com.apple.CoreServices (57 - 57) <9DD44CB0-C644-35C3-8F57-0B41B3EC147D> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
                            0x7fff8e0bb000 -     0x7fff8e0c2fff  com.apple.phonenumbers (1.1 - 47) <E6A01FEF-9C6D-3C18-B378-63F4134756E6> /System/Library/PrivateFrameworks/PhoneNumbers.framework/Versions/A/PhoneNumbers
                            0x7fff8e0c3000 -     0x7fff8e0c9fff  com.apple.DiskArbitration (2.5.1 - 2.5.1) <F7DAF7CC-5893-3F06-9168-3B0192B66D15> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
                            0x7fff8e0ca000 -     0x7fff8e164fff  libvMisc.dylib (380.6) <714336EA-1C0E-3735-B31C-19DFDAAF6221> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
                            0x7fff8e165000 -     0x7fff8e167fff  com.apple.TrustEvaluationAgent (2.0 - 23) <A97D348B-32BF-3E52-8DF2-59BFAD21E1A3> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
                            0x7fff8e168000 -     0x7fff8e16dfff  libcompiler_rt.dylib (30) <08F8731D-5961-39F1-AD00-4590321D24A9> /usr/lib/system/libcompiler_rt.dylib
                            0x7fff8e16e000 -     0x7fff8e17bff7  com.apple.HelpData (2.1.4 - 85) <EE68BDCC-AF2E-34D3-8E4F-87379E3A4D8E> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/HelpData
                            0x7fff8e17c000 -     0x7fff8e1b4fff  libtidy.A.dylib (15.10) <9009156B-84F5-3781-BFCB-B409B538CD18> /usr/lib/libtidy.A.dylib
                            0x7fff8e1b5000 -     0x7fff8e438fff  com.apple.RawCamera.bundle (4.00 - 658) <6786E9E0-3197-30A3-A0F4-22A6064B3EF2> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
                            0x7fff8e439000 -     0x7fff8e5d4fef  com.apple.vImage (6.0 - 6.0) <FAE13169-295A-33A5-8E6B-7C2CC1407FA7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
                            0x7fff8e5d5000 -     0x7fff8e5fcff7  com.apple.PerformanceAnalysis (1.16 - 16) <E4888388-F41B-313E-9CBB-5807D077BDA9> /System/Library/PrivateFrameworks/PerformanceAnalysis.framework/Versions/A/PerformanceAna lysis
                            0x7fff8e5fd000 -     0x7fff8e608fff  libsystem_notify.dylib (98.5) <C49275CC-835A-3207-AFBA-8C01374927B6> /usr/lib/system/libsystem_notify.dylib
                            0x7fff8e609000 -     0x7fff8e6d5fe7  libsystem_c.dylib (825.25) <8CBCF9B9-EBB7-365E-A3FF-2F3850763C6B> /usr/lib/system/libsystem_c.dylib
                            0x7fff8e6d6000 -     0x7fff8e6dbfff  libcache.dylib (57) <65187C6E-3FBF-3EB8-A1AA-389445E2984D> /usr/lib/system/libcache.dylib
                            0x7fff8e6dc000 -     0x7fff8e739ff7  com.apple.AE (645.3 - 645.3) <FF867ACA-8628-3E5A-8FA0-AF429B42C5D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
                            0x7fff8e84f000 -     0x7fff8e885fff  com.apple.DebugSymbols (98 - 98) <14E788B1-4EB2-3FD7-934B-849534DFC198> /System/Library/PrivateFrameworks/DebugSymbols.framework/Versions/A/DebugSymbols
                            0x7fff8eace000 -     0x7fff8edfeff7  com.apple.HIToolbox (2.0 - 625) <317F75F7-4B0F-35F5-89A7-F20BA60AC944> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                            0x7fff8edff000 -     0x7fff8ee13fff  libGL.dylib (8.6.1) <2E00615F-97F5-34EB-BE07-75A24F3C18D7> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
                            0x7fff8ee14000 -     0x7fff8ee1dfff  com.apple.CommerceCore (1.0 - 26) <997CD214-BC78-3C61-A1B8-813EA1CB9997> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
                            0x7fff8ee1e000 -     0x7fff8ee24fff  libCGXCoreImage.A.dylib (324.6) <45864BEA-B2EA-3F5F-9D04-F9832AB67A00> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXCoreImage.A.dylib
                            0x7fff8ee2f000 -     0x7fff8ee60ff7  com.apple.DictionaryServices (1.2 - 184.4) <054F2D6F-9CFF-3EF1-9778-25C551B616C1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
                            0x7fff8ee63000 -     0x7fff8ef60fff  libsqlite3.dylib (138.1) <ADE9CB98-D77D-300C-A32A-556B7440769F> /usr/lib/libsqlite3.dylib
                            0x7fff8ef61000 -     0x7fff8effeff7  com.apple.PDFKit (2.7.2 - 2.7.2) <DE5BE2EF-2570-3792-B1C3-AAD45765F533> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
                            0x7fff8f031000 -     0x7fff8f05ffff  com.apple.shortcut (2.2 - 2.2) <C573DB65-37FB-3DDC-AB19-525094346D9B> /System/Library/PrivateFrameworks/Shortcut.framework/Versions/A/Shortcut
                            0x7fff8f060000 -     0x7fff8f0b7ff7  com.apple.AppleVAFramework (5.0.18 - 5.0.18) <B75949DD-AC27-3848-8221-00D70D14C7E0> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
                            0x7fff8f0d3000 -     0x7fff8f12dfff  com.apple.Suggestions (2.0 - 102.1) <05D8D892-9A31-301A-BD24-D8A89B2AC905> /System/Library/PrivateFrameworks/Suggestions.framework/Versions/A/Suggestions
                            0x7fff8f12e000 -     0x7fff8f149ff7  com.apple.frameworks.preferencepanes (15.0 - 15.0) <45E922F9-E5F5-3026-90BA-C1F5F8451C9B> /System/Library/Frameworks/PreferencePanes.framework/Versions/A/PreferencePanes
                            0x7fff8f191000 -     0x7fff8f193fff  libCVMSPluginSupport.dylib (8.6.1) <7EFDA31E-E463-3897-A8DC-7FD266EB713E> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCVMSPluginSupport.dyl ib
                            0x7fff8f194000 -     0x7fff8f1bbfff  com.apple.framework.familycontrols (4.1 - 410) <AE49B2AB-7D2B-3D52-8E21-60EBEA1A38E6> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
                            0x7fff8f1bc000 -     0x7fff8f1bffff  libRadiance.dylib (845) <E8956A35-494E-3014-8B86-362D32576116> /System/Library/Frameworks/ImageIO.framework/Versions/A/Resources/libRadiance.dylib
                            0x7fff8f1c0000 -     0x7fff8f20fff7  libFontRegistry.dylib (100) <2E03D7DA-9B8F-31BB-8FB5-3D3B6272127F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
                            0x7fff8f210000 -     0x7fff8f218fff  liblaunch.dylib (442.26.2) <2F71CAF8-6524-329E-AC56-C506658B4C0C> /usr/lib/system/liblaunch.dylib
                            0x7fff8f219000 -     0x7fff8f21dfff  com.apple.IOSurface (86.0.3 - 86.0.3) <C121DE83-ED12-3DC1-BDB3-4FCB29AB0571> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
                            0x7fff8f21e000 -     0x7fff8f27aff7  com.apple.Symbolication (1.3 - 93) <66BAF8B0-26D5-38B6-A742-01031F1B4EC0> /System/Library/PrivateFrameworks/Symbolication.framework/Versions/A/Symbolication
                            0x7fff8f27b000 -     0x7fff8f515ff7  com.apple.JavaScriptCore (8536 - 8536.26.7) <ADAD1276-675A-3000-B746-560A2EB596A2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                            0x7fff8fa94000 -     0x7fff8fb59ff7  com.apple.coreui (2.0 - 181.1) <83D2C92D-6842-3C9D-9289-39D5B4554C3A> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
                            0x7fff8fb5a000 -     0x7fff8fb5efff  libCGXType.A.dylib (324.6) <2FC25246-A69F-3F81-9AC6-0A1753E1C6A8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
                            0x7fff8fb5f000 -     0x7fff8fb7eff7  com.apple.ChunkingLibrary (2.0 - 133.2) <D2A746DE-002A-3C6C-961E-BE94E71DB835> /System/Library/PrivateFrameworks/ChunkingLibrary.framework/Versions/A/ChunkingLibrary
                            0x7fff8fbd0000 -     0x7fff8fe7efff  com.apple.imageKit (2.2 - 667) <66A64289-6259-335E-9D8C-E3E02ECE7837> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
                        External Modification Summary:
                          Calls made by other processes targeting this process:
                            task_for_pid: 29
                            thread_create: 0
                            thread_set_state: 0
                          Calls made by this process:
                            task_for_pid: 0
                            thread_create: 0
                            thread_set_state: 0
                          Calls made by all processes on this machine:
                            task_for_pid: 7099
                            thread_create: 3
                            thread_set_state: 0
                        VM Region Summary:
                        ReadOnly portion of Libraries: Total=425.3M resident=327.7M(77%) swapped_out_or_unallocated=97.6M(23%)
                        Writable regions: Total=7.9G written=6.8G(86%) resident=7.1G(90%) swapped_out=0K(0%) unallocated=803.1M(10%)
                        REGION TYPE                      VIRTUAL
                        ATS (font support)                 32.1M
                        CG backing stores                  15.9M
                        CG image                           2036K
                        CG raster data                      116K
                        CG shared images                    320K
                        CoreAnimation                         4K
                        CoreImage                             8K
                        CoreServices                       2952K
                        IOKit                             132.6M
                        IOKit (reserved)                   2112K        reserved VM address space (unallocated)
                        MALLOC                            443.2M
                        MALLOC guard page                    48K
                        Memory tag=240                     32.0M
                        Memory tag=242                       12K
                        Memory tag=251                       12K
                        OpenCL                               68K
                        OpenGL GLSL                        1152K
                        STACK GUARD                        56.2M
                        Stack                              62.0M
                        VM_ALLOCATE                         7.2G
                        __DATA                             45.0M
                        __IMAGE                             528K
                        __LINKEDIT                         79.8M
                        __OBJC                                4K
                        __TEXT                            345.5M
                        __UNICODE                           544K
                        mapped file                        95.3M
                        shared memory                      71.6M
                        TOTAL                               8.6G
                        TOTAL, minus reserved VM space      8.6G
                        • 9. Re: Photoshop CS6 crashes, won't reload
                          mikefasnyc Level 1
                          found this under system diagnostic reports. looks like the issue we're discussing.
                          Date/Time:       2012-10-01 10:55:44 -0400
                          OS Version:      10.8.2 (Build 12C54)
                          Architecture:    x86_64
                          Report Version:  11
                          Command:         Photoshop
                          Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                          Version:         13.0.1 (13.0.1.519)
                          Parent:          launchd [204]
                          PID:             2748
                          Event:           hang
                          Duration:        4.04s
                          Steps:           41 (100ms sampling interval)
                          Hardware model:  MacPro4,1
                          Active cpus:     8
                          Free pages:      5759182 pages (+1456)
                          Pageins:         0 pages
                          Pageouts:        0 pages
                          Process:         Adobe Photoshop CS6 [2748]
                          UID:             501
                          Task size:       14858 pages
                            Thread 0x71d7c    DispatchQueue 1          priority 46
                            41 ??? (Adobe Photoshop CS6 + 5551324) [0x10054b4dc]
                              41 boost::system::system_error::what() const + 2001113 (Adobe Photoshop CS6) [0x1007b11d9]
                                41 boost::system::system_error::what() const + 1999771 (Adobe Photoshop CS6) [0x1007b0c9b]
                                  41 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 4178099 (Adobe Photoshop CS6) [0x100c52a53]
                                    41 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 3560277 (Adobe Photoshop CS6) [0x100bbbcf5]
                                      41 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 17774718 (Adobe Photoshop CS6) [0x10194a21e]
                                        41 AWS_CUI_GetVersionComments(OpaqueWindowPtr*, adobe::q::QDocument&, adobe::q::QString&, adobe::q::QAttributeList&, adobe::q::QDocument*, adobe::q::QProject*, long) + 8319872 (Adobe Photoshop CS6) [0x101045d20]
                                          41 ??? (Adobe Photoshop CS6 + 388636) [0x10005ee1c]
                                            41 ??? (Adobe Photoshop CS6 + 2336482) [0x10023a6e2]
                                              41 FSGetVolumeInfo + 29 (CarbonCore) [0x7fff9544dfee]
                                                41 _FSGetVolumeInfoWithFlags + 119 (CarbonCore) [0x7fff9544e06e]
                                                  41 FSMount::volumeattrs(unsigned int, FSVolAttributeInfo*, unsigned int, unsigned char*) + 174 (CarbonCore) [0x7fff9542e4a8]
                                                    41 FSMount::_volumeattrs(unsigned int, FSVolAttributeInfo*, unsigned int, unsigned char*) + 1068 (CarbonCore) [0x7fff9542e906]
                                                      41 GetVolFSAttributes(FSMount*, unsigned int, char const*, unsigned int, unsigned int, FSAttributeInfo*, unsigned int, unsigned int, FSVolAttributeInfo*, unsigned char*) + 649 (CarbonCore) [0x7fff95443721]
                                                        41 __getattrlist + 10 (libsystem_kernel.dylib) [0x7fff8ffd8bd2]
                                                         *41 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ced33]
                                                           *41 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e182a]
                                                             *41 getattrlist + 188 (mach_kernel) [0xffffff80002d9dfc]
                                                               *41 ??? (mach_kernel + 878504) [0xffffff80002d67a8]
        *41 vnode_getattr + 105 (mach_kernel) [0xffffff8000310669]
        *41 hfs_vnop_getattr + 548 (mach_kernel) [0xffffff8000512d64]
        *41 hfs_lock + 85 (mach_kernel) [0xffffff80004ef835]
        *41 lck_rw_lock_shared_gen + 128 (mach_kernel) [0xffffff80002b0c10]
        *41 thread_block_reason + 300 (mach_kernel) [0xffffff800022da0c]
        *41 ??? (mach_kernel + 190273) [0xffffff800022e741]
        *41 machine_switch_context + 366 (mach_kernel) [0xffffff80002b3d7e]
                            Thread 0x71d8b    DispatchQueue 2          priority 48
                            41 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9315f9ee]
                              41 kevent + 10 (libsystem_kernel.dylib) [0x7fff8ffd9d16]
                               *41 ??? (mach_kernel + 3471600) [0xffffff800054f8f0]
                            Thread 0x71de3    priority 46
                            41 thread_start + 13 (libsystem_c.dylib) [0x7fff98bbe181]
                              41 _pthread_start + 327 (libsystem_c.dylib) [0x7fff98bd1742]
                                41 main + 126768 (MultiProcessor Support) [0x111454f50]
                                  41 main + 8592 (MultiProcessor Support) [0x1114381b0]
                                    41 main + 8403 (MultiProcessor Support) [0x1114380f3]
                                      41 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8ffd90fa]
                                       *41 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5d30]
                            Thread 0x71de4    priority 46
                            Thread 0x71de5    priority 46
                            Thread 0x71de6    priority 46
                            Thread 0x71de7    priority 46
                            Thread 0x71de8    priority 46
                            Thread 0x71de9    priority 46
                            Binary Images:
                                   0x100000000 -        0x10333ffff  com.adobe.Photoshop 13.0.1 (13.0.1.519) <A2A39B8C-869D-C4D3-3E38-9B1147C8B6ED> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/MacOS/Adobe Photoshop CS6
                                   0x1113f3000 -        0x111478fff  MultiProcessor Support <F332405A-5896-7EF2-F0CE-21D604012833> /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Required/Plug-Ins/Extensions/MultiProcessor Support.plugin/Contents/MacOS/MultiProcessor Support
                                0x7fff8ffc7000 -     0x7fff8ffe2ff7  libsystem_kernel.dylib <C0535565-35D1-31A7-A744-63D9F10F12A4> /usr/lib/system/libsystem_kernel.dylib
                                0x7fff9315b000 -     0x7fff93170ff7  libdispatch.dylib <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                                0x7fff95422000 -     0x7fff95739ff7  com.apple.CoreServices.CarbonCore 1037.3 (1037.3) <DF7CABCA-F2CB-345B-8EFF-F0F4E937B7FF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                0x7fff98bbd000 -     0x7fff98c89fe7  libsystem_c.dylib <8CBCF9B9-EBB7-365E-A3FF-2F3850763C6B> /usr/lib/system/libsystem_c.dylib
                          *0xffffff8000200000 - 0xffffff800074033c  mach_kernel <69A5853F-375A-3EF4-9247-478FD0247333> /mach_kernel
                          Process:         accountsd [249]
                          Path:            /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                          UID:             501
                          Sudden Term:     Clean (allows idle exit)
                          Task size:       1204 pages
                            Thread 0x6ae      DispatchQueue 1          priority 31
                            41 start + 1 (libdyld.dylib) [0x7fff980747e1]
                              41 ??? (accountsd + 3048) [0x103745be8]
                                41 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff97d2e6b2]
                                  41 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                    41 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                      41 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                       *41 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                            Thread 0x6c7      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x103745000 -        0x103745fff  accountsd <0982A50A-159D-3E63-A2EC-6447F3706436> /System/Library/Frameworks/Accounts.framework/Versions/A/Support/accountsd
                                0x7fff97cfa000 -     0x7fff97ee3fff  com.apple.CoreFoundation 6.8 (744.12) <EF002794-DAEF-31C6-866C-E3E3AC387A9F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                0x7fff98072000 -     0x7fff98075ff7  libdyld.dylib <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
                          Process:         acwebsecagent [161]
                          Path:            /opt/cisco/*/acwebsecagent
                          Architecture:    i386
                          Parent:          vpnagentd [57]
                          UID:             0
                          Task size:       2140 pages (-12)
                          Process:         adb [431]
                          Path:            /Applications/Adobe InDesign CS6/*/adb
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       466 pages
                          Process:         Adobe Bridge CS6 [340]
                          Path:            UNKNOWN
                          Architecture:    unknown
                          Task size:       1 pages
                            Thread 0xb40      priority 31
                          *1 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ced33]
                             *1 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e182a]
                               *1 getattrlist + 188 (mach_kernel) [0xffffff80002d9dfc]
                                 *1 ??? (mach_kernel + 885205) [0xffffff80002d81d5]
                                   *1 vnode_getattr + 105 (mach_kernel) [0xffffff8000310669]
                                     *1 hfs_vnop_getattr + 548 (mach_kernel) [0xffffff8000512d64]
                                       *1 hfs_lock + 85 (mach_kernel) [0xffffff80004ef835]
                                         *1 lck_rw_lock_shared_gen + 128 (mach_kernel) [0xffffff80002b0c10]
                                           *1 thread_block_reason + 300 (mach_kernel) [0xffffff800022da0c]
                                             *1 ??? (mach_kernel + 190273) [0xffffff800022e741]
                                               *1 machine_switch_context + 366 (mach_kernel) [0xffffff80002b3d7e]
                            Binary Images:
                          Process:         Adobe Photoshop  [332]
                          Path:            UNKNOWN
                          Task size:       1 pages
                            Thread 0x70203    priority 31
                            Binary Images:
                          Process:         AdobeAcrobat [2694]
                          Path:            /Applications/Adobe Acrobat X Pro/Adobe Acrobat Pro.app/Contents/MacOS/AdobeAcrobat
                          Architecture:    i386
                          UID:             501
                          Task size:       18431 pages
                          CPU Time:        0.009s
                          Process:         AdobeCrashDaemon [365]
                          Path:            UNKNOWN
                          Parent:          Adobe Bridge CS6 [340]
                          Task size:       1 pages
                            Thread 0xd7a      priority 31
                          *1 return_from_trap + 156 (mach_kernel) [0xffffff80002ce4bc]
                             *1 i386_astintr + 35 (mach_kernel) [0xffffff80002b8163]
                               *1 ast_taken + 253 (mach_kernel) [0xffffff800021b70d]
                                 *1 act_execute_returnhandlers + 126 (mach_kernel) [0xffffff800023c63e]
                                   *1 special_handler + 168 (mach_kernel) [0xffffff800023c7c8]
                                     *1 thread_terminate_self + 297 (mach_kernel) [0xffffff8000239cc9]
                                       *1 proc_exit + 992 (mach_kernel) [0xffffff8000556b50]
                                         *1 fixjobc + 41 (mach_kernel) [0xffffff800055ef79]
                                           *1 proc_parent + 140 (mach_kernel) [0xffffff800055d9fc]
                                             *1 msleep + 116 (mach_kernel) [0xffffff800056a344]
                                               *1 ??? (mach_kernel + 3579734) [0xffffff8000569f56]
                                                 *1 lck_mtx_sleep + 78 (mach_kernel) [0xffffff80002265fe]
                            Binary Images:
                          Process:         AdobeCrashDaemon [371]
                          Path:            UNKNOWN
                          Parent:          Adobe Photoshop  [332]
                          Task size:       1 pages
                            Thread 0x1056     priority 31
                            Binary Images:
                          Process:         AdobeCrashDaemon [2750]
                          Path:            /Applications/Adobe Photoshop CS6/Adobe Photoshop CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app/Co ntents/MacOS/AdobeCrashDaemon
                          Parent:          Adobe Photoshop CS6 [2748]
                          UID:             501
                          Task size:       1047 pages
                          CPU Time:        0.003s
                          Process:         AdobeCrashDaemon [2758]
                          Path:            /Applications/Adobe Illustrator CS6/Adobe Illustrator.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemo n.app/Contents/MacOS/AdobeCrashDaemon
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1138 pages (+91)
                          CPU Time:        0.002s
                          Process:         AdobeCrashDaemon [2759]
                          Path:            /Applications/Adobe InDesign CS6/Adobe InDesign CS6.app/Contents/Frameworks/AdobeCrashReporter.framework/Required/AdobeCrashDaemon.app/Co ntents/MacOS/AdobeCrashDaemon
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1811 pages (+751)
                          CPU Time:        0.026s
                          Process:         AirPort Base Station Agent [291]
                          Path:            /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       360 pages
                            Thread 0x825      DispatchQueue 1          priority 31
                              41 ??? (AirPort Base Station Agent + 71957) [0x10d085915]
                                41 CFRunLoopRun + 97 (CoreFoundation) [0x7fff97d3d371]
                            Thread 0x82b      DispatchQueue 2          priority 33
                            Thread 0x832      priority 31
                                41 __select + 10 (libsystem_kernel.dylib) [0x7fff8ffd9322]
                                 *41 ??? (mach_kernel + 3581216) [0xffffff800056a520]
                            Binary Images:
                                   0x10d074000 -        0x10d08aff7  com.apple.AirPortBaseStationAgent 1.5.5 (155.7) <F3A0627B-7620-3A09-A390-3FEBA3DE9CCD> /System/Library/CoreServices/AirPort Base Station Agent.app/Contents/MacOS/AirPort Base Station Agent
                          Process:         appleeventsd [49]
                          Path:            /System/Library/CoreServices/appleeventsd
                          Parent:          launchd [1]
                          UID:             71
                          Sudden Term:     Dirty (allows idle exit)
                          Task size:       663 pages
                            Thread 0x25a      DispatchQueue 2          priority 33
                            Thread 0x25b      DispatchQueue 7          priority 31
                            41 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff9315cd85]
                              41 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8ffd9566]
                            Thread 0x723b3    priority 31
                            41 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              41 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                41 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *41 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x723b4    priority 31
                            Thread 0x723f6    priority 31
                            Thread 0x723f7    priority 31
                            Binary Images:
                                   0x104601000 -        0x104601fff  appleeventsd <4617FC4D-4C6C-3B62-9E64-08F9C99ABEEF> /System/Library/CoreServices/appleeventsd
                          Process:         AppleIDAuthAgent [233]
                          Path:            /System/Library/CoreServices/AppleIDAuthAgent
                          UID:             501
                          Task size:       1713 pages
                          CPU Time:        0.015s
                            Thread 0x66b      DispatchQueue 2          priority 33
                            Thread 0x66c      DispatchQueue 7          priority 31
                            Thread 0x88f      DispatchQueue 17         priority 31         cpu time   0.015s
                              41 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff98bd3cab]
                                41 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff9315e1c3]
                                  41 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff9315e2f1]
                                    41 _dispatch_queue_drain + 180 (libdispatch.dylib) [0x7fff9315e448]
                                      41 _dispatch_queue_invoke + 72 (libdispatch.dylib) [0x7fff9315e305]
                                        41 _dispatch_source_invoke + 691 (libdispatch.dylib) [0x7fff9315f29b]
                                          41 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff9315d0b6]
                                            41 _dispatch_after_timer_callback + 22 (libdispatch.dylib) [0x7fff9316196f]
                                                41 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff93160f01]
                                                  41 ??? (AppleIDAuthAgent + 9227) [0x10b1d240b]
                                                    41 semaphore_timedwait_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd76da]
                                                     *41 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000233ec0]
                            Thread 0x969      priority 63
                                41 __NSThread__main__ + 1345 (Foundation) [0x7fff900d2612]
                                  41 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff90074586]
                            Thread 0x96e      priority 31
                            Thread 0x6fa85    priority <multiple>
                            Thread 0x71ba9    priority <multiple>
                            Thread 0x72214    priority <multiple>
                            Binary Images:
                                   0x10b1d0000 -        0x10b200fff  AppleIDAuthAgent <83E1C2AC-BA88-304A-8CF5-E3FF228F77DB> /System/Library/CoreServices/AppleIDAuthAgent
                                0x7fff9003d000 -     0x7fff90399fff  com.apple.Foundation 6.8 (945.11) <A5D41956-A354-3ACC-9355-BE200072223B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                          Process:         AppleMobileDeviceHelper [334]
                          Path:            /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/Current/AppleMobileDevi ceHelper.app/Contents/MacOS/AppleMobileDeviceHelper
                          Parent:          iTunes [305]
                          UID:             501
                          Task size:       2391 pages
                            Thread 0xb02      DispatchQueue 1          priority 31
                            41 ??? (AppleMobileDeviceHelper + 5752) [0x100001678]
                              41 ??? (AppleMobileDeviceHelper + 9277) [0x10000243d]
                                41 ??? (AppleMobileDeviceHelper + 44976) [0x10000afb0]
                            Thread 0xb04      DispatchQueue 2          priority 33
                            Thread 0xb0e      priority 31
                            Binary Images:
                                   0x100000000 -        0x100017ff7  com.apple.SyncServices.AppleMobileDeviceHelper 5.0 (889) <7B6B311D-2C94-3368-BA3F-48E449EF6A1C> /System/Library/PrivateFrameworks/MobileDevice.framework/Versions/Current/AppleMobileDevi ceHelper.app/Contents/MacOS/AppleMobileDeviceHelper
                          Process:         AppleSpell [458]
                          Path:            /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       4039 pages
                            Thread 0x2bbf     DispatchQueue 1          priority 46
                              41 ??? (AppleSpell + 7271) [0x10025dc67]
                                41 -[NSSpellServer run] + 73 (Foundation) [0x7fff901bee36]
                            Thread 0x2bc9     DispatchQueue 2          priority 48
                            Binary Images:
                                   0x10025c000 -        0x100311ff7  com.apple.AppleSpell 1.9 (173.1) <6ED0981A-B081-3345-8EBB-E4AB821B077A> /System/Library/Services/AppleSpell.service/Contents/MacOS/AppleSpell
                          Process:         apsd [55]
                          Path:            /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       2345 pages (+3)
                            Thread 0x18f      DispatchQueue 1          priority 31
                              41 ??? (apsd + 21702) [0x1047664c6]
                                41 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff9007018a]
                                  41 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff900d789e]
                            Thread 0x37a      DispatchQueue 2          priority 33
                            Thread 0x6c8      priority 63
                            Thread 0x6d9      priority 31
                            Thread 0x724f8    priority 31
                            16 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              16 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                16 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *16 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x104761000 -        0x1047dfff7  apsd <955901BC-3EA7-3976-9473-FD16EE108102> /System/Library/PrivateFrameworks/ApplePushService.framework/apsd
                          Process:         ath [2147]
                          Path:            /System/Library/PrivateFrameworks/AirTrafficHost.framework/ath
                          UID:             501
                          Task size:       1073 pages
                            Thread 0x63df6    DispatchQueue 1          priority 31
                            41 ??? (ath + 7468) [0x100001d2c]
                              41 ??? (ath + 8186) [0x100001ffa]
                            Thread 0x63df9    DispatchQueue 2          priority 33
                            Thread 0x63dfb    priority 31
                                  41 ??? (ath + 9356) [0x10000248c]
                                    41 ATProcessLinkRunChild + 77 (AirTrafficHost) [0x1000f9347]
                            Thread 0x63dfc    priority 31
                            Binary Images:
                                   0x100000000 -        0x100007fff  ath <1289CE44-B010-3301-ADD4-CDA100C30F28> /System/Library/PrivateFrameworks/AirTrafficHost.framework/ath
                                   0x1000f6000 -        0x100277ff7  com.apple.AirTrafficHost 282 (282) <8BB16E44-91BB-3124-A1FA-040D4638B748> /System/Library/PrivateFrameworks/AirTrafficHost.framework/Versions/A/AirTrafficHost
                          Process:         autofsd [54]
                          Path:            /usr/libexec/autofsd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       362 pages
                            Thread 0x1ea      DispatchQueue 2          priority 33
                            Thread 0x2e6      DispatchQueue 7          priority 31
                            Binary Images:
                                   0x10a1ec000 -        0x10a1edfff  autofsd <84AA47F0-1486-37EE-9C69-12CB98C34F1C> /usr/libexec/autofsd
                          Process:         backburnerManager [168]
                          Path:            /usr/discreet/backburner/backburnerManager
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       631 pages
                          Process:         backburnerServer [194]
                          Path:            /usr/discreet/backburner/backburnerServer
                          Architecture:    i386
                          Parent:          sh [185]
                          UID:             0
                          Task size:       461 pages
                          Process:         backupd [674]
                          Path:            /System/Library/CoreServices/backupd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Dirty
                          Task size:       10529 pages
                          Note:            Self-throttled
                            Thread 0x8a24     DispatchQueue 1          priority 4
                              41 ??? (backupd + 66979) [0x1015fb5a3]
                            Thread 0x8a26     DispatchQueue 2          priority 4
                            Thread 0x8a27     DispatchQueue 10         priority 0
                                41 _dispatch_worker_thread2 + 304 (libdispatch.dylib) [0x7fff9315e1fa]
                                      41 ??? (backupd + 26401) [0x1015f1721]
                                        41 ??? (backupd + 27214) [0x1015f1a4e]
                                          41 ??? (backupd + 42284) [0x1015f552c]
                                            41 ??? (backupd + 70714) [0x1015fc43a]
                                              41 ??? (backupd + 78249) [0x1015fe1a9]
                                                41 ??? (backupd + 103504) [0x101604450]
                                                  41 ??? (backupd + 108832) [0x101605920]
                                                    41 _NodeOperation + 589 (DesktopServicesPriv) [0x7fff969711bf]
                                                      41 TFSCopyOperation::DoCopy(TCountedPtr<TCFURLInfo> const&) + 434 (DesktopServicesPriv) [0x7fff9697fc82]
                                                        41 TFSCopyOperation::CopyToTarget() + 650 (DesktopServicesPriv) [0x7fff969811a2]
                                                          41 TCopyReader::Read(TLOperationRecordPtr, TCountedPtr<TCFURLInfo> const&, TCountedPtr<TCFURLInfo> const&, unsigned int) + 336 (DesktopServicesPriv) [0x7fff969a1168]
                                                            41 TCopyReader::ReadDataFork() + 220 (DesktopServicesPriv) [0x7fff969a34e2]
                                                              41 TCopyQueue::GetBuffer() + 59 (DesktopServicesPriv) [0x7fff969a086f]
        41 MPWaitOnQueue + 252 (CarbonCore) [0x7fff95431b24]
        41 TSWaitOnConditionTimedRelative + 163 (CarbonCore) [0x7fff954cf40a]
                            Thread 0x8a25     DispatchQueue 57         priority 4
                                            41 _xpc_connection_wakeup + 145 (libxpc.dylib) [0x7fff8dad517c]
                                              41 _xpc_connection_wakeup2 + 1799 (libxpc.dylib) [0x7fff8dad58b4]
                                                41 _xpc_connection_wakeup_recv + 165 (libxpc.dylib) [0x7fff8dad716d]
                                                  41 _xpc_connection_recv_message + 699 (libxpc.dylib) [0x7fff8dad74a2]
                                                    41 ??? (backupd + 330584) [0x10163bb58]
                                                      41 ??? (backupd + 328415) [0x10163b2df]
                                                        41 ??? (backupd + 329911) [0x10163b8b7]
                                                          41 ??? (backupd + 328567) [0x10163b377]
                                                            41 ??? (backupd + 332511) [0x10163c2df]
                                                              41 semaphore_wait_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd76c2]
                            Thread 0x8a2e     priority 4
                            Thread 0xcd3a     priority 4
                                41 TCopyWriter::WriteTaskProc(void*) + 63 (DesktopServicesPriv) [0x7fff969a57ff]
                                  41 TCopyWriter::Write() + 187 (DesktopServicesPriv) [0x7fff969a5933]
                                    41 TCopyWriter::CreateItem() + 1228 (DesktopServicesPriv) [0x7fff969a67b8]
                                      41 TCopyWriter::CreateNewDestinationItem() + 433 (DesktopServicesPriv) [0x7fff969a88bd]
                                        41 TCFURLInfo::Open(unsigned int, __CFFileSecurity*, bool, bool) + 98 (DesktopServicesPriv) [0x7fff9698b838]
                                          41 TFileDescriptor::Open(char const*, unsigned int, __CFFileSecurity*, bool, bool, bool) + 281 (DesktopServicesPriv) [0x7fff969047eb]
                                            41 __open_extended + 10 (libsystem_kernel.dylib) [0x7fff8ffd9016]
                                                 *41 open_extended + 434 (mach_kernel) [0xffffff80002fc082]
                                                   *41 ??? (mach_kernel + 1030985) [0xffffff80002fbb49]
                                                     *41 vn_open_auth + 754 (mach_kernel) [0xffffff8000308e22]
                                                       *41 vn_create + 510 (mach_kernel) [0xffffff80002f426e]
                                                         *41 vnode_setattr_fallback + 623 (mach_kernel) [0xffffff800031148f]
                                                           *41 vn_setxattr + 328 (mach_kernel) [0xffffff800030a658]
                                                             *41 VNOP_SETXATTR + 61 (mach_kernel) [0xffffff800031382d]
                                                               *41 hfs_vnop_setxattr + 1267 (mach_kernel) [0xffffff800051a033]
        *41 hfs_setxattr_internal + 133 (mach_kernel) [0xffffff800051a135]
        *41 hfs_start_transaction + 163 (mach_kernel) [0xffffff80005105d3]
        *41 journal_start_transaction + 392 (mach_kernel) [0xffffff8000317888]
        *41 lck_mtx_lock + 653 (mach_kernel) [0xffffff80002acdcd]
        *41 lck_mtx_lock_wait_x86 + 391 (mach_kernel) [0xffffff80002b1917]
                            Thread 0x72418    priority 4
                            28 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              28 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                28 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *28 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x72419    priority 4
                            27 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              27 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                27 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *27 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x7250e    priority 4
                            13 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              13 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                13 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *13 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x7250f    priority 4
                            Binary Images:
                                   0x1015eb000 -        0x101679ff7  backupd <3D964111-58F4-3EF4-8197-A27BB2C31162> /System/Library/CoreServices/backupd
                                0x7fff8dacb000 -     0x7fff8daedff7  libxpc.dylib <FAC04D8B-680E-325F-8F0C-DD69859D0E01> /usr/lib/system/libxpc.dylib
                                0x7fff96901000 -     0x7fff96a21fff  com.apple.desktopservices 1.7.2 (1.7.2) <CDE8C2C2-C505-31B0-8C61-E40E4EA364A5> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
                          Process:         backupd-helper [665]
                          Path:            /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       394 pages
                            Thread 0x8889     DispatchQueue 1          priority 31
                              41 ??? (backupd-helper + 10387) [0x10d329893]
                                41 ??? (backupd-helper + 11909) [0x10d329e85]
                                  41 xpc_connection_send_message_with_reply_sync + 127 (libxpc.dylib) [0x7fff8dad6e1f]
                            Thread 0x888b     DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10d327000 -        0x10d334ff7  backupd-helper <3D607C65-6F0E-36E3-8E34-E78AA438EBF6> /System/Library/CoreServices/backupd.bundle/Contents/Resources/backupd-helper
                          Process:         bash [2539]
                          Path:            /bin/bash
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       239 pages
                            Thread 0x6f315    priority 31
                              41 ??? (bash + 10713) [0x1096b99d9]
                                41 ??? (bash + 117763) [0x1096d3c03]
                                  41 ??? (bash + 118794) [0x1096d400a]
                                    41 ??? (bash + 126665) [0x1096d5ec9]
                                        41 ??? (bash + 122871) [0x1096d4ff7]
                                          41 ??? (bash + 131135) [0x1096d703f]
                                            41 ??? (bash + 127095) [0x1096d6077]
                                                41 ??? (bash + 126740) [0x1096d5f14]
                                                  41 ??? (bash + 134896) [0x1096d7ef0]
                                                        41 ??? (bash + 123820) [0x1096d53ac]
                                                          41 ??? (bash + 156876) [0x1096dd4cc]
                                                            41 __wait4 + 10 (libsystem_kernel.dylib) [0x7fff8ffd969a]
                            Binary Images:
                                   0x1096b7000 -        0x10974dfff  bash <B3CE4882-ACE3-35E9-A5CC-6436AD7D504E> /bin/bash
                          Process:         blued [52]
                          Path:            /usr/sbin/blued
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       750 pages
                            Thread 0x18c      DispatchQueue 1          priority 31
                              41 ??? (blued + 166441) [0x105f69a29]
                            Thread 0x1a5      DispatchQueue 2          priority 33
                            Thread 0x305      priority 31
                            Binary Images:
                                   0x105f41000 -        0x105ff4fff  blued <058EC1F7-D1C8-3139-9D62-B7AE9E4087C7> /usr/sbin/blued
                          Process:         CalendarAgent [234]
                          Path:            /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                          UID:             501
                          Task size:       8626 pages (+3)
                            Thread 0x654      DispatchQueue 1          priority 31
                              41 ??? (CalendarAgent + 2739) [0x10208fab3]
                            Thread 0x6ba      DispatchQueue 2          priority 33
                            Thread 0x9b4      priority 63
                            Thread 0x9b7      priority 31
                            Thread 0xa08      priority 31
                                  41 -[CalAgentAPSConnectionManager _calAPSMain] + 731 (CalendarAgent) [0x1020a0274]
                            Thread 0x723b1    priority <multiple>
                          *33 ??? (mach_kernel + 3911792) [0xffffff80005bb070]
                                 *8  ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x72513    priority 31
                          *8 ??? (mach_kernel + 3911792) [0xffffff80005bb070]
                            Binary Images:
                                   0x10208f000 -        0x10208ffff  CalendarAgent <6CFDD227-73B3-3E19-9FE7-DD95699A3D15> /System/Library/PrivateFrameworks/CalendarAgent.framework/Executables/CalendarAgent
                                   0x10209b000 -        0x1020b0fff  com.apple.CalendarAgent 1.0 (55) <D8084316-7159-3552-BA5D-081F856A1550> /System/Library/PrivateFrameworks/CalendarAgent.framework/Versions/A/CalendarAgent
                          Process:         cfprefsd [60]
                          Path:            /usr/sbin/cfprefsd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       562 pages
                            Thread 0x1b5      DispatchQueue 2          priority 33
                            Thread 0x1b7      DispatchQueue 7          priority 31
                            Thread 0x722d0    priority 31
                            Thread 0x722d1    priority 31
                            Thread 0x722d2    priority 31
                            Binary Images:
                                   0x101c54000 -        0x101c54ff7  cfprefsd <01BC9748-9534-3638-A631-3FBAEFB5E37E> /usr/sbin/cfprefsd
                          Process:         cfprefsd [210]
                          UID:             501
                          Task size:       2051 pages (-14)
                            Thread 0x5ef      DispatchQueue 2          priority 33
                            Thread 0x5f1      DispatchQueue 7          priority 31
                            Thread 0x714a5    priority 31
                            Thread 0x7205d    priority 31
                            Thread 0x7237d    priority 31
                            Thread 0x7241b    priority 31
                            Thread 0x7241a    priority 31
                            26 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              26 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                26 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *26 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x10e2d5000 -        0x10e2d5ff7  cfprefsd <01BC9748-9534-3638-A631-3FBAEFB5E37E> /usr/sbin/cfprefsd
                          Process:         cfprefsd [248]
                          Parent:          launchd [245]
                          UID:             88
                          Task size:       234 pages
                            Thread 0x6af      DispatchQueue 2          priority 33
                            Thread 0x6b1      DispatchQueue 7          priority 31
                            Binary Images:
                                   0x10fdff000 -        0x10fdffff7  cfprefsd <01BC9748-9534-3638-A631-3FBAEFB5E37E> /usr/sbin/cfprefsd
                          Process:         cfprefsd [350]
                          Parent:          launchd [346]
                          UID:             89
                          Task size:       329 pages
                            Thread 0xb9c      DispatchQueue 2          priority 33
                            Thread 0xb9e      DispatchQueue 7          priority 31
                            Binary Images:
                                   0x1045e8000 -        0x1045e8ff7  cfprefsd <01BC9748-9534-3638-A631-3FBAEFB5E37E> /usr/sbin/cfprefsd
                          Process:         check_afp [682]
                          Path:            /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       303 pages
                            Thread 0x8a5d     DispatchQueue 1          priority 31
                              41 ??? (check_afp + 13493) [0x10825e4b5]
                                41 ??? (check_afp + 11124) [0x10825db74]
                                  41 ??? (check_afp + 10607) [0x10825d96f]
                            Thread 0x8a66     DispatchQueue 2          priority 33
                            Thread 0x8a64     priority 31
                                41 ??? (check_afp + 13385) [0x10825e449]
                                  41 mach_msg_server_once + 345 (libsystem_kernel.dylib) [0x7fff8ffd71f9]
                            Thread 0x8a68     priority 31
                            Binary Images:
                                   0x10825b000 -        0x10825ffff  com.apple.check_afp 3.0 (3.0) <A7958C11-9717-3853-A07F-A07C57139539> /System/Library/Filesystems/AppleShare/check_afp.app/Contents/MacOS/check_afp
                          Process:         ciscod [158]
                          Path:            /opt/cisco/*/ciscod
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       68 pages
                          Process:         CleanApp Daemon [56]
                          Path:            /Library/Application Support/CleanApp/CleanApp Daemon.app/Contents/MacOS/CleanApp Daemon
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       5327 pages
                          CPU Time:        0.028s
                          Process:         com.apple.audio.ComponentHelper [2784]
                          Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1203 pages
                            Thread 0x720df    DispatchQueue 7          priority 31
                            Thread 0x720e1    DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10b575000 -        0x10b577fff  com.apple.audio.ComponentHelper 1.0 (1) <092001EF-56E9-32D4-9B28-490D19476174> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.ComponentHe lper.xpc/Contents/MacOS/com.apple.audio.ComponentHelper
                          Process:         com.apple.audio.SandboxHelper [354]
                          Path:            /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                          Parent:          launchd [1]
                          UID:             202
                          Task size:       949 pages
                            Thread 0xc3f      DispatchQueue 7          priority 31
                            Thread 0xc41      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10b63e000 -        0x10b646fff  com.apple.audio.SandboxHelper 1.0 (1) <2023CAE6-2F01-3ACD-A2BB-A9FDC9C9A818> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                          Process:         com.apple.audio.SandboxHelper [2783]
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1125 pages
                            Thread 0x720da    DispatchQueue 7          priority 31
                            Thread 0x720dc    DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10123e000 -        0x101246fff  com.apple.audio.SandboxHelper 1.0 (1) <2023CAE6-2F01-3ACD-A2BB-A9FDC9C9A818> /System/Library/Frameworks/AudioToolbox.framework/XPCServices/com.apple.audio.SandboxHelp er.xpc/Contents/MacOS/com.apple.audio.SandboxHelper
                          Process:         com.apple.dock.extra [303]
                          Path:            /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       4419 pages
                            Thread 0x8dc      DispatchQueue 1          priority 46
                            41 ??? (com.apple.dock.extra + 5956) [0x1077a5744]
                              41 xpc_service_main + 433 (XPCService) [0x7fff96312d15]
                                41 NSApplicationMain + 869 (AppKit) [0x7fff96b1ecb6]
                                  41 -[NSApplication run] + 517 (AppKit) [0x7fff96b7a283]
                                    41 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff96b82ed2]
                                      41 _DPSNextEvent + 685 (AppKit) [0x7fff96b83613]
                                        41 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff990e1cd3]
                                          41 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff990e1e42]
                                            41 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff990e20a4]
                                                39 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                                  39 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                                    39 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                                     *39 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                                2  __CFRunLoopRun + 1775 (CoreFoundation) [0x7fff97d2f19f]
                                                  2  __CFRunLoopDoSource1 + 153 (CoreFoundation) [0x7fff97cfc019]
                                                    2  __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff97cfc2d9]
                                                      2  __CFMachPortPerform + 288 (CoreFoundation) [0x7fff97cfc410]
                                                        2  PullEventsFromWindowServerOnConnection(unsigned int, unsigned char) + 71 (HIToolbox) [0x7fff990e87d7]
                                                          2  CGEventCreateNextEvent + 31 (CoreGraphics) [0x7fff92170904]
                                                            2  CGSGetNextEventRecordInternal + 122 (CoreGraphics) [0x7fff921709c7]
                                                              2  snarf_events + 184 (CoreGraphics) [0x7fff92170b8b]
        2  _CGSGetPortStreamInline + 99 (CoreGraphics) [0x7fff92170d2e]
        2  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
        *2  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                            Thread 0x8e4      DispatchQueue 2          priority 48
                            Binary Images:
                                   0x1077a4000 -        0x1077a8fff  com.apple.dock.extra 1.0 (1) <BED692DE-9B6F-3D55-8A23-20014685C9CF> /System/Library/CoreServices/Dock.app/Contents/XPCServices/com.apple.dock.extra.xpc/Conte nts/MacOS/com.apple.dock.extra
                                0x7fff9210c000 -     0x7fff92a9cc67  com.apple.CoreGraphics 1.600.0 <DCC70C6E-AB6D-3457-A823-7569CB29B107> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                0x7fff96311000 -     0x7fff96318fff  com.apple.XPCService 2.0 (1) <97A25416-88DD-375B-8D08-14920C05804A> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                0x7fff96a2e000 -     0x7fff9765bff7  com.apple.AppKit 6.8 (1187.34) <1FF64844-EB62-3F96-AED7-6525B7CCEC23> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                0x7fff99082000 -     0x7fff993b2ff7  com.apple.HIToolbox 2.0 <317F75F7-4B0F-35F5-89A7-F20BA60AC944> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                          Process:         com.apple.iCloudHelper [2571]
                          Path:            /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1574 pages (-3)
                            Thread 0x6f3b8    DispatchQueue 1          priority 31
                              41 main + 176 (com.apple.iCloudHelper) [0x108df6e30]
                                41 xpc_main + 260 (libxpc.dylib) [0x7fff8dadd950]
                                  41 _xpc_main + 452 (XPCService) [0x7fff9631323b]
                            Thread 0x6f3b9    DispatchQueue 2          priority 33
                            Thread 0x6f3c0    priority 31
                                  41 -[AOSPushManager _AOSPushListener] + 271 (AOSKit) [0x7fff96411cfa]
                            Thread 0x7243a    priority 33
                            39 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              39 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                39 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *39 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x108df6000 -        0x108dfaff7  com.apple.iCloudHelper 1.05 (152) <F5AB8382-DFBB-3288-B70E-84D40933756E> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/XPCServices/com.apple.iClou dHelper.xpc/Contents/MacOS/com.apple.iCloudHelper
                                0x7fff963f5000 -     0x7fff96675ff7  com.apple.AOSKit 1.05 (151) <A34E8584-797C-318F-9E25-937A710C68AB> /System/Library/PrivateFrameworks/AOSKit.framework/Versions/A/AOSKit
                          Process:         com.apple.qtkitserver [2782]
                          Path:            /System/Library/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserve r
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1012 pages
                            Thread 0x720d3    priority 47
                            41 start + 1 (libdyld.dylib) [0x9898b725]
                              41 main + 158 (com.apple.qtkitserver) [0x33276]
                                41 xpc_service_main + 460 (XPCService) [0x6dd13]
                                  41 CFRunLoopRun + 129 (CoreFoundation) [0x94429061]
                                    41 CFRunLoopRunSpecific + 378 (CoreFoundation) [0x9441963a]
                                      41 __CFRunLoopRun + 1247 (CoreFoundation) [0x94419f7f]
                                        41 __CFRunLoopServiceMachPort + 185 (CoreFoundation) [0x94414599]
                                          41 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x947e87d2]
                            Thread 0x720d5    DispatchQueue 1701273966 priority 49
                            41 _dispatch_mgr_thread + 53 (libdispatch.dylib) [0x9a5da7a9]
                              41 kevent + 10 (libsystem_kernel.dylib) [0x947eb9ae]
                            Binary Images:
                                       0x26000 -            0x54ff8  com.apple.qtkitserver 1.0 (1) <A1CA5CC0-7648-39B9-8FD5-477DB86F90E2> /System/Library/XPCServices/com.apple.qtkitserver.xpc/Contents/MacOS/com.apple.qtkitserve r
                                       0x6c000 -            0x73fff  com.apple.XPCService 2.0 (1) <91BC7453-006F-30E0-AE08-8F82855CE5F8> /System/Library/PrivateFrameworks/XPCService.framework/Versions/A/XPCService
                                    0x943e2000 -         0x945caff3  com.apple.CoreFoundation 6.8 (744.12) <E939CEA0-493C-3233-9983-5070981BB350> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                    0x947d6000 -         0x947f0ffc  libsystem_kernel.dylib <C17D49D0-7961-3B67-B443-C788C6E5AA76> /usr/lib/system/libsystem_kernel.dylib
                                    0x98989000 -         0x9898bfff  libdyld.dylib <05D6FF2A-F09B-309D-95F7-7AF10259C707> /usr/lib/system/libdyld.dylib
                                    0x9a5d6000 -         0x9a5e8ff7  libdispatch.dylib <86EF7D45-2D97-3465-A449-95038AE5DABA> /usr/lib/system/libdispatch.dylib
                          Process:         configd [17]
                          Path:            /usr/libexec/configd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       1140 pages
                            Thread 0x164      DispatchQueue 1          priority 31
                              41 ??? (configd + 7263) [0x10b3b7c5f]
                                41 ??? (configd + 10127) [0x10b3b878f]
                            Thread 0x165      DispatchQueue 2          priority 33
                              41 __select_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8ffd9336]
                            Thread 0x167      priority 31
                                41 ??? (configd + 12444) [0x10b3b909c]
                            Thread 0x1ed      priority 31
                                41 ??? (configd + 54376) [0x10b3c3468]
                            Thread 0x1f3      priority 31
                            Thread 0x219      priority 31
                                41 pppcntl_run_thread + 2390 (PPPController) [0x10b7f3982]
                            Thread 0x7230d    priority 31
                            Thread 0x7238c    priority 31
                            Thread 0x7238f    priority 31
                            Binary Images:
                                   0x10b3b6000 -        0x10b3e4ff7  configd <DD25C0A9-EBBC-32EE-87B5-DDEC2F7B2BCE> /usr/libexec/configd
                                   0x10b7e8000 -        0x10b829ff7  com.apple.SystemConfiguration.PPPController 1.8 (1.8) <3E04BE0F-41A1-3BB3-A183-FE2FCB5291D0> /System/Library/SystemConfiguration/PPPController.bundle/Contents/MacOS/PPPController
                          Process:         cookied [2214]
                          Path:            /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       1446 pages
                            Thread 0x686b8    DispatchQueue 1          priority 31
                              41 _cookied_main + 1190 (CFNetwork) [0x7fff97ff8586]
                            Thread 0x686b9    DispatchQueue 2          priority 33
                            Thread 0x722bf    priority 31
                            Binary Images:
                                   0x1047a5000 -        0x1047a5fff  cookied <7C0D644D-10E1-3020-A6E9-9C8F6E264F1A> /System/Library/Frameworks/CFNetwork.framework/Versions/A/Support/cookied
                                0x7fff97efd000 -     0x7fff98071fff  com.apple.CFNetwork 596.2.3 (596.2.3) <6A16C2BD-1035-30F9-AE96-D9E3BB54A976> /System/Library/Frameworks/CFNetwork.framework/Versions/A/CFNetwork
                          Process:         coreaudiod [145]
                          Path:            /usr/sbin/coreaudiod
                          Parent:          launchd [1]
                          UID:             202
                          Sudden Term:     Dirty
                          Task size:       2554 pages (-2)
                          CPU Time:        0.046s
                            Thread 0x4ac      DispatchQueue 1          priority 63
                              41 ??? (coreaudiod + 393566) [0x102a0115e]
                            Thread 0x4b8      DispatchQueue 2          priority 33         cpu time   0.009s
                            Thread 0x50c      priority 61
                                41 ??? (coreaudiod + 435021) [0x102a0b34d]
                                  41 ??? (coreaudiod + 406379) [0x102a0436b]
                            Thread 0x6e648    priority 97         cpu time   0.023s
                                41 ??? (coreaudiod + 30821) [0x1029a8865]
                                  41 ??? (coreaudiod + 146267) [0x1029c4b5b]
                                    41 ??? (coreaudiod + 146407) [0x1029c4be7]
                                      41 ??? (coreaudiod + 154157) [0x1029c6a2d]
                                        41 ??? (coreaudiod + 49674) [0x1029ad20a]
                            Thread 0x723f3    priority 31         cpu time   0.013s
                            Thread 0x723f8    priority 31
                            Thread 0x723f9    priority 31
                            Thread 0x723fa    priority 31
                            Thread 0x723fb    priority 31
                            34 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              34 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                34 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *34 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x1029a1000 -        0x102a70ff7  coreaudiod <30CC89D4-54A4-3A58-8776-C258CC17E448> /usr/sbin/coreaudiod
                          Process:         coreservicesd [61]
                          Path:            /System/Library/CoreServices/coreservicesd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       14457 pages
                          CPU Time:        0.004s
                            Thread 0x1e9      DispatchQueue 1          priority 31         cpu time   0.004s
                              41 _CoreServicesServerMain + 691 (CarbonCore) [0x7fff95423085]
                            Thread 0x1f0      DispatchQueue 2          priority 33
                            Thread 0x24d      priority 31
                                41 fmodWatchConsumer + 581 (CarbonCore) [0x7fff95428c87]
                            Thread 0x24e      priority 31
                                41 read + 10 (libsystem_kernel.dylib) [0x7fff8ffd9ffa]
                                     *41 read_nocancel + 130 (mach_kernel) [0xffffff80005768e2]
                                       *41 ??? (mach_kernel + 3631806) [0xffffff8000576abe]
                                         *41 ??? (mach_kernel + 1168729) [0xffffff800031d559]
                                           *41 tsleep + 88 (mach_kernel) [0xffffff800056a3d8]
                                             *41 ??? (mach_kernel + 3580128) [0xffffff800056a0e0]
                            Binary Images:
                                   0x1022b7000 -        0x1022b7fff  coreservicesd <2F52FCB5-6C20-3437-AB0F-6950D61F672E> /System/Library/CoreServices/coreservicesd
                          Process:         coresymbolicationd [2668]
                          Path:            /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       14178 pages
                            Thread 0x7079c    DispatchQueue 7          priority 31
                            Thread 0x7079d    DispatchQueue 2          priority 33
                            Binary Images:
                                   0x1059b8000 -        0x1059c3fff  coresymbolicationd <7EB12B92-6A43-3678-AEF7-F38DE2AD1626> /System/Library/PrivateFrameworks/CoreSymbolication.framework/coresymbolicationd
                          Process:         CS6ServiceManager [2789]
                          Path:            /Library/Application Support/Adobe/*/CS6ServiceManager.app/Contents/MacOS/CS6ServiceManager
                          Architecture:    i386
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       1306 pages (-3)
                          Process:         CVMCompiler [2764]
                          Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
                          UID:             501
                          Sudden Term:     Dirty
                          Task size:       7279 pages
                            Thread 0x71e24    DispatchQueue 7          priority 31
                            Thread 0x71e26    DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10ed28000 -        0x10ed2cfff  CVMCompiler <C2EBBD52-1FB3-3690-8BAD-9C6B538AE29A> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMCompiler
                          Process:         CVMServer [122]
                          Path:            /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Dirty
                          Task size:       441 pages
                            Thread 0x413      DispatchQueue 7          priority 31
                            Thread 0x416      DispatchQueue 2          priority 33
                            Thread 0x723f2    priority 31
                            Thread 0x723f5    priority 31
                            Binary Images:
                                   0x103be6000 -        0x103bf0fff  CVMServer <1CE1774E-6B8C-3E72-B3D0-5A2C0EEE3433> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/CVMServer
                          Process:         dbfseventsd [317]
                          Path:            /Library/DropboxHelperTools/*/dbfseventsd
                          Architecture:    i386
                          Parent:          Dropbox [263]
                          UID:             0
                          Task size:       94 pages
                          Process:         dbfseventsd [318]
                          Architecture:    i386
                          Parent:          dbfseventsd [317]
                          UID:             0
                          Task size:       1087 pages
                          Process:         dbfseventsd [319]
                          Architecture:    i386
                          Parent:          dbfseventsd [318]
                          UID:             501
                          Task size:       43 pages
                          Process:         DictationIM [270]
                          Path:            /System/Library/Input Methods/DictationIM.app/Contents/MacOS/DictationIM
                          UID:             501
                          Task size:       3884 pages
                          CPU Time:        0.001s
                            Thread 0x784      DispatchQueue 1          priority 47         cpu time   0.001s
                              41 ??? (DictationIM + 51162) [0x10957b7da]
                            Thread 0x7a0      DispatchQueue 2          priority 49
                            Thread 0x841      priority 47
                                  41 ??? (DictationIM + 44006) [0x109579be6]
                            Binary Images:
                                   0x10956f000 -        0x109589fff  com.apple.inputmethod.ironwood 1.1.1 (1.1.1) <0E3D80A6-0D22-31E5-A0CC-2E780576013E> /System/Library/Input Methods/DictationIM.app/Contents/MacOS/DictationIM
                          Process:         diskarbitrationd [16]
                          Path:            /usr/sbin/diskarbitrationd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Dirty
                          Task size:       568 pages
                            Thread 0x163      DispatchQueue 1          priority 31
                              41 ??? (diskarbitrationd + 33664) [0x106fa2380]
                            Thread 0x168      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x106f9a000 -        0x106fb4fff  diskarbitrationd <17948715-612A-309D-8891-2B6B9596EF0D> /usr/sbin/diskarbitrationd
                          Process:         diskimages-helper [790]
                          Path:            /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       1851 pages
                          CPU Time:        0.004s
                            Thread 0xab06     DispatchQueue 1          priority 31
                              41 ??? (diskimages-helper + 17286) [0x106e1c386]
                            Thread 0xab08     DispatchQueue 2          priority 33
                            Thread 0xab2d     priority 31         cpu time   0.004s
                                  41 ??? (diskimages-helper + 41341) [0x106e2217d]
                                    41 ??? (diskimages-helper + 44418) [0x106e22d82]
                                      41 ??? (diskimages-helper + 45936) [0x106e23370]
                                        41 CBundleBackingStore::handlePowerChange(unsigned int) + 108 (DiskImages) [0x7fff8efff132]
                                          41 CBundleBackingStore::flushBands(unsigned int) + 193 (DiskImages) [0x7fff8ef7d659]
                                            41 CBundleBackingStore::flushBand(BandEntry*, unsigned int) + 249 (DiskImages) [0x7fff8ef7d7d9]
                                              41 fsync + 10 (libsystem_kernel.dylib) [0x7fff8ffd9ae6]
                                                   *41 ??? (mach_kernel + 1048209) [0xffffff80002ffe91]
                                                     *41 VNOP_FSYNC + 47 (mach_kernel) [0xffffff80003120af]
                                                       *41 afpfs_vnop_fsync + 171 (afpfs) [0xffffff7f823fda11]
                                                         *41 afpfs_fsync + 215 (afpfs) [0xffffff7f823f8680]
                                                           *41 cluster_push_ext + 576 (mach_kernel) [0xffffff80002e8030]
                                                             *41 ??? (mach_kernel + 951722) [0xffffff80002e85aa]
                                                               *41 ??? (mach_kernel + 953477) [0xffffff80002e8c85]
        *41 ??? (mach_kernel + 927743) [0xffffff80002e27ff]
        *41 VNOP_STRATEGY + 46 (mach_kernel) [0xffffff8000313a5e]
        *41 afpfs_vnop_strategy + 952 (afpfs) [0xffffff7f823e1666]
        *41 afpfs_DoWrite + 658 (afpfs) [0xffffff7f823dfc95]
        *41 WriteFork + 1224 (afpfs) [0xffffff7f823e7a50]
        *41 UserReply + 185 (afpfs) [0xffffff7f823e4d45]
        *41 ??? (mach_kernel + 3654989) [0xffffff800057c54d]
        *41 asp_tcp_usr_control + 500 (asp_tcp) [0xffffff7f823bcde1]
        *41 Reply + 284 (asp_tcp) [0xffffff7f823bfdfa]
        *41 msleep + 116 (mach_kernel) [0xffffff800056a344]
        *41 ??? (mach_kernel + 3579718) [0xffffff8000569f46]
        *41 lck_mtx_sleep_deadline + 87 (mach_kernel) [0xffffff8000226697]
        *30 thread_block_reason + 300 (mach_kernel) [0xffffff800022da0c]
        *30 ??? (mach_kernel + 190273) [0xffffff800022e741]
        *30 machine_switch_context + 366 (mach_kernel) [0xffffff80002b3d7e]
        *11 thread_block_reason + 275 (mach_kernel) [0xffffff800022d9f3]
        *11 ??? (mach_kernel + 187521) [0xffffff800022dc81]
        *11 processor_idle + 227 (mach_kernel) [0xffffff800022f1c3]
        *11 machine_idle + 282 (mach_kernel) [0xffffff80002b8c5a]
                            Thread 0x6bebb    priority 31
                                  41 ??? (diskimages-helper + 68765) [0x106e28c9d]
                                    41 CSparseBundleDiskImage::handleIdle() + 147 (DiskImages) [0x7fff8efff53f]
                                      41 CBundleBackingStore::handleIdle() + 90 (DiskImages) [0x7fff8efff0a4]
                                        41 CBundleBackingStore::flushBands(unsigned int) + 63 (DiskImages) [0x7fff8ef7d5d7]
                                          41 __psynch_mutexwait + 10 (libsystem_kernel.dylib) [0x7fff8ffd9122]
                                           *41 psynch_mtxcontinue + 0 (mach_kernel) [0xffffff80005b46d0]
                            Binary Images:
                                   0x106e18000 -        0x106e69ff7  diskimages-helper <07667AD4-7FCD-390C-85BA-C3B9B3AE0CFB> /System/Library/PrivateFrameworks/DiskImages.framework/Resources/diskimages-helper
                                0x7fff8ef6f000 -     0x7fff8f05fff7  com.apple.DiskImagesFramework 10.8 (344) <AC72B2EF-7307-3B20-B561-5ECF30E83627> /System/Library/PrivateFrameworks/DiskImages.framework/Versions/A/DiskImages
                          *0xffffff7f823bb000 - 0xffffff7f823c6ffe  com.apple.nke.asp_tcp 7.0.0 (7.0.0) <78FAA01C-ABC4-3AD3-8D9A-6187F7911E1A> /System/Library/Filesystems/AppleShare/asp_tcp.kext/Contents/MacOS/asp_tcp
                          *0xffffff7f823d9000 - 0xffffff7f82423ff3  com.apple.filesystems.afpfs 10.0 (10.0) <B0A45DB0-315A-34C2-B9D2-4BBAEDF8775C> /System/Library/Filesystems/AppleShare/afpfs.kext/Contents/MacOS/afpfs
                          Process:         distnoted [59]
                          Path:            /usr/sbin/distnoted
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       614 pages
                          CPU Time:        0.018s
                            Thread 0x19b      DispatchQueue 1          priority 31
                              41 ??? (distnoted + 14743) [0x10a2a4997]
                            Thread 0x1af      DispatchQueue 2          priority 33
                            Thread 0x711b3    priority 31         cpu time   0.003s
                            40 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              40 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                40 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *40 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            1  __pthread_set_self + 16 (libsystem_c.dylib) [0x7fff98bbe164]
                             *1  ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x711b4    priority 31         cpu time   0.003s
                            Thread 0x711b7    priority 31         cpu time   0.001s
                            Thread 0x711c5    priority 31
                            Thread 0x711ca    priority 31
                            Thread 0x711b2    priority 31         cpu time   0.009s
                            Thread 0x724f1    priority 31
                          *23 ??? (mach_kernel + 3911792) [0xffffff80005bb070]
                            Thread 0x711b2    DispatchQueue 6          priority 31
                                      1 __block_global_0 + 27 (CoreFoundation) [0x7fff97e5e51b]
                                        1 ??? (distnoted + 15302) [0x10a2a4bc6]
                                          1 ??? (distnoted + 11495) [0x10a2a3ce7]
                                            1 _xpc_dictionary_copy + 56 (libxpc.dylib) [0x7fff8dacd329]
                                              1 _xpc_dictionary_apply_node_f + 117 (libxpc.dylib) [0x7fff8dad48ba]
                                                1 _xpc_dictionary_copy_apply + 62 (libxpc.dylib) [0x7fff8dacd36f]
                                                  1 _xpc_dictionary_insert + 225 (libxpc.dylib) [0x7fff8dad02f6]
                                                    1 _xpc_malloc + 69 (libxpc.dylib) [0x7fff8dad04b6]
                                                      1 malloc + 41 (libsystem_c.dylib) [0x7fff98beaba7]
                                                        1 malloc_zone_malloc + 71 (libsystem_c.dylib) [0x7fff98bea153]
                                                          1 szone_malloc_should_clear + 971 (libsystem_c.dylib) [0x7fff98bf7ad8]
                                                            1 tiny_malloc_from_free_list + 853 (libsystem_c.dylib) [0x7fff98bf746d]
                                                              1 <executing in user space>
                            Binary Images:
                                   0x10a2a1000 -        0x10a2a6ff7  distnoted <063BC349-9A91-3D19-BFF4-692ADD5F35C1> /usr/sbin/distnoted
                          Process:         distnoted [208]
                          UID:             501
                          Task size:       1368 pages (-3)
                          CPU Time:        0.057s
                            Thread 0x5e2      DispatchQueue 1          priority 31
                              41 ??? (distnoted + 14743) [0x10d220997]
                            Thread 0x5e9      DispatchQueue 2          priority 33         cpu time   0.001s
                            Thread 0x711bb    priority 31         cpu time   0.004s
                            Thread 0x711bc    priority 31         cpu time   0.002s
                            Thread 0x711bd    priority 31         cpu time   0.001s
                            Thread 0x711c6    priority 31
                            Thread 0x71918    priority 31         cpu time   0.001s
                            Thread 0x71171    priority 31         cpu time   0.012s
                                     *1  workq_kernreturn + 478 (mach_kernel) [0xffffff80005ba7ae]
                                       *1  ??? (mach_kernel + 3907428) [0xffffff80005b9f64]
                                         *1  thread_block_reason + 275 (mach_kernel) [0xffffff800022d9f3]
                                           *1  ??? (mach_kernel + 187521) [0xffffff800022dc81]
                                             *1  processor_idle + 227 (mach_kernel) [0xffffff800022f1c3]
                                               *1  machine_idle + 282 (mach_kernel) [0xffffff80002b8c5a]
                            Thread 0x71d45    priority 31         cpu time   0.012s
                            Thread 0x72363    priority 31         cpu time   0.009s
                            Thread 0x723ef    priority 31         cpu time   0.011s
                            Thread 0x72362    priority 31
                            20 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              20 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                20 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *20 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x71d45    DispatchQueue 6          priority 31
                                        1 ??? (distnoted + 15302) [0x10d220bc6]
                                          1 ??? (distnoted + 11520) [0x10d21fd00]
                                            1 xpc_dictionary_set_string + 24 (libxpc.dylib) [0x7fff8dad01a0]
                                              1 xpc_string_create + 52 (libxpc.dylib) [0x7fff8dad01f7]
                                                1 _xpc_base_create + 21 (libxpc.dylib) [0x7fff8dad0105]
                                                  1 _os_object_alloc + 71 (libdispatch.dylib) [0x7fff9315cfc2]
                                                    1 class_createInstance + 102 (libobjc.A.dylib) [0x7fff95c5cbc8]
                                                      1 calloc + 48 (libsystem_c.dylib) [0x7fff98beabf4]
                                                        1 malloc_zone_calloc + 79 (libsystem_c.dylib) [0x7fff98bea44e]
                                                          1 _spin_lock$VARIANT$mp + 30 (libsystem_c.dylib) [0x7fff98bbff4e]
                            Thread 0x723ef    DispatchQueue 59         priority 31
                                    1 _dispatch_queue_drain + 235 (libdispatch.dylib) [0x7fff9315e47f]
                                        1 _Block_release + 202 (libsystem_blocks.dylib) [0x7fff9056a6a3]
                                          1 ??? (distnoted + 13719) [0x10d220597]
                                            1 -[OS_xpc_object _xref_dispose] + 51 (libxpc.dylib) [0x7fff8dad0852]
                                              1 _xpc_dispose + 33 (libxpc.dylib) [0x7fff8dad2c4d]
                                                1 _xpc_dictionary_dispose + 34 (libxpc.dylib) [0x7fff8dad2f36]
                                                  1 _xpc_dictionary_node_free + 52 (libxpc.dylib) [0x7fff8dad2ffa]
                                                        1 free + 199 (libsystem_c.dylib) [0x7fff98bea898]
                                                          1 _spin_lock$VARIANT$mp + 25 (libsystem_c.dylib) [0x7fff98bbff49]
                            Thread 0x71171    DispatchQueue 65         priority 31
                                                      1 object_dispose + 54 (libobjc.A.dylib) [0x7fff95c5dfc0]
                                                          1 szone_free_definite_size + 2013 (libsystem_c.dylib) [0x7fff98bf07d6]
                                                            1 tiny_free_list_add_ptr + 390 (libsystem_c.dylib) [0x7fff98bf3ef7]
                            Thread 0x72363    DispatchQueue 77         priority 31
                                          1 ??? (distnoted + 11859) [0x10d21fe53]
                                            1 xpc_array_apply + 50 (libxpc.dylib) [0x7fff8dad8db8]
                                              1 ??? (distnoted + 11958) [0x10d21feb6]
                                                1 xpc_dictionary_get_string + 38 (libxpc.dylib) [0x7fff8dad7a8c]
                                                  1 _xpc_dictionary_look_up_fast + 24 (libxpc.dylib) [0x7fff8dad2cf9]
                                                    1 _xpc_dictionary_look_up + 40 (libxpc.dylib) [0x7fff8dad2d60]
                                                      1 _xpc_dictionary_look_up_table + 37 (libxpc.dylib) [0x7fff8dad2eef]
                            Binary Images:
                                   0x10d21d000 -        0x10d222ff7  distnoted <063BC349-9A91-3D19-BFF4-692ADD5F35C1> /usr/sbin/distnoted
                                0x7fff90569000 -     0x7fff9056afff  libsystem_blocks.dylib <D92DCBC3-541C-37BD-AADE-ACC75A0C59C8> /usr/lib/system/libsystem_blocks.dylib
                                0x7fff95c54000 -     0x7fff95d6c92f  libobjc.A.dylib <90D31928-F48D-3E37-874F-220A51FD9E37> /usr/lib/libobjc.A.dylib
                          Process:         distnoted [349]
                          UID:             89
                          Task size:       455 pages (+3)
                          CPU Time:        0.001s
                            Thread 0xb7f      DispatchQueue 1          priority 31
                              41 ??? (distnoted + 14743) [0x10e66a997]
                            Thread 0xb80      DispatchQueue 2          priority 33
                            Thread 0x71a84    priority 31
                            Thread 0x71bd0    priority 31
                            Thread 0x71db6    priority 31         cpu time   0.001s
                            Thread 0x724f5    priority 31
                            18 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              18 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                18 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *18 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x10e667000 -        0x10e66cff7  distnoted <063BC349-9A91-3D19-BFF4-692ADD5F35C1> /usr/sbin/distnoted
                          Process:         Dock [217]
                          Path:            /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                          UID:             501
                          Task size:       21349 pages (-37)
                          CPU Time:        0.380s
                            Thread 0x619      DispatchQueue 1          priority 47         cpu time   0.161s
                              41 ??? (Dock + 844286) [0x10b4e61fe]
                                  27 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                    27 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                      27 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                       *26 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                       *1  hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002ced53]
                                         *1  ??? (mach_kernel + 678678) [0xffffff80002a5b16]
                                           *1  mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                                             *1  ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
                                  14 __CFRunLoopRun + 1775 (CoreFoundation) [0x7fff97d2f19f]
                                    14 __CFRunLoopDoSource1 + 153 (CoreFoundation) [0x7fff97cfc019]
                                      14 __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff97cfc2d9]
                                        13 mshPerform + 11 (HIServices) [0x7fff92eb233e]
                                          11 ??? (Dock + 134538) [0x10b438d8a]
                                            11 ??? (Dock + 231148) [0x10b4506ec]
                                              11 ??? (Dock + 419310) [0x10b47e5ee]
                                                11 ??? (Dock + 428652) [0x10b480a6c]
                                                  11 ??? (Dock + 430873) [0x10b481319]
                                                    11 _HandlePopUpMenuSelection7 + 629 (HIToolbox) [0x7fff99221924]
                                                      9  PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1556 (HIToolbox) [0x7fff99221f94]
                                                        7  TrackMenuCommon(MenuSelectData&, unsigned char*) + 307 (HIToolbox) [0x7fff9908ba8a]
                                                          7  IsUserStillTracking(MenuSelectData*, unsigned char*) + 194 (HIToolbox) [0x7fff990a2234]
                                                            7  ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff990e1e42]
                                                              7  RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff990e20a4]
        7  CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff97d2e6b2]
        *7  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                                        2  TrackMenuCommon(MenuSelectData&, unsigned char*) + 1770 (HIToolbox) [0x7fff9908c041]
                                                          1  SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 487 (HIToolbox) [0x7fff990a96c7]
                                                            1  FlashFeedback(MenuSelectData*) + 127 (HIToolbox) [0x7fff990a98e6]
                                                              1  HIView::SimulateClick(unsigned int, short, unsigned int, short*) + 171 (HIToolbox) [0x7fff990a99e5]
        1  SendEventToEventTargetWithOptions + 43 (HIToolbox) [0x7fff990ba236]
        1  SendEventToEventTargetInternal(OpaqueEventRef*, OpaqueEventTargetRef*, HandlerCallRec*) + 410 (HIToolbox) [0x7fff990ba3d9]
        1  DispatchEventToHandlers(EventTargetRec*, OpaqueEventRef*, HandlerCallRec*) + 1206 (HIToolbox) [0x7fff990baf0a]
        1  HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1751 (HIToolbox) [0x7fff990c5947]
        1  HIView::SimulateClickSelf(short, unsigned int, short*) + 75 (HIToolbox) [0x7fff990a9ac7]
        1  SendControlSimulateHit(HIView*, short, unsigned int, short*) + 153 (HIToolbox) [0x7fff990a9c04]
        1  HIView::EventHandler(OpaqueEventHandlerCallRef*, OpaqueEventRef*, void*) + 1930 (HIToolbox) [0x7fff990c59fa]
        1  HIStandardMenuView::SimulateHitSelf(short, unsigned int, short*) + 188 (HIToolbox) [0x7fff990a9d02]
        1  HIMenuView::SimulateHitSelf(short, unsigned int, short*) + 144 (HIToolbox) [0x7fff990a9dd8]
        1  RunCurrentEventLoopInMode + 262 (HIToolbox) [0x7fff990e20d9]
        *1  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                                          1  SelectItemAndRestoreAllMenuBits(MenuSelectData&) + 853 (HIToolbox) [0x7fff990a9835]
                                                      1  PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1241 (HIToolbox) [0x7fff99221e59]
                                                        1  ShowAndCacheMenu(MenuData*, Rect const*, __CFArray*, unsigned char) + 54 (HIToolbox) [0x7fff990a0be0]
                                                          1  ShowMenuWindow + 363 (HIToolbox) [0x7fff990a0dc7]
                                                            1  HIWindowFlush + 27 (HIToolbox) [0x7fff990e021e]
                                                              1  _FlushWindow + 74 (HIToolbox) [0x7fff990e0270]
        1  FlushWindowObject(WindowData*, void**, unsigned char) + 1000 (HIToolbox) [0x7fff990e0671]
        1  CGSReenableUpdate + 25 (CoreGraphics) [0x7fff9216498a]
        1  CGSReenableUpdateForConnections + 395 (CoreGraphics) [0x7fff92164b1b]
        1  _CGSReenableUpdateForConnections + 175 (CoreGraphics) [0x7fff92164c64]
                                                      1  PopUpMenuSelectCore(MenuData*, Point, double, Point, unsigned short, unsigned int, Rect const*, unsigned short, unsigned int, Rect const*, Rect const*, __CFString const*, OpaqueMenuRef**, unsigned short*) + 1673 (HIToolbox) [0x7fff99222009]
                                                        1  FinishMenuSelection(SelectionData*, MenuResult*, MenuResult*) + 94 (HIToolbox) [0x7fff990aba4f]
                                                          1  SendMenuItemSelectedEvent + 254 (HIToolbox) [0x7fff990abbc3]
                                                            1  SendMenuCommandWithContextAndModifiers + 59 (HIToolbox) [0x7fff990abc11]
                                                              1  SendHICommandEvent(unsigned int, HICommand const*, unsigned int, unsigned int, unsigned char, void const*, OpaqueEventTargetRef*, OpaqueEventTargetRef*, OpaqueEventRef**) + 443 (HIToolbox) [0x7fff99106e89]
        1  SendEventToEventTarget + 40 (HIToolbox) [0x7fff990d01bd]
        1  ??? (Dock + 645588) [0x10b4b59d4]
        1  ??? (Dock + 666824) [0x10b4bacc8]
        1  ??? (Dock + 643758) [0x10b4b52ae]
        1  LQForceQuit + 97 (libquit.dylib) [0x7fff9103d7d5]
        1  _CRProcessWillBeForceQuit + 90 (CrashReporterSupport) [0x7fff93e6327e]
        1  _CRCopyCrashHistoryForProcess + 62 (CrashReporterSupport) [0x7fff93e62c00]
        1  _CRCreatePropertyListWithPath + 54 (CrashReporterSupport) [0x7fff93e5f48f]
        1  CreatePropertyListWithURL + 57 (CrashReporterSupport) [0x7fff93e5f4df]
        1  CFReadStreamOpen + 86 (CoreFoundation) [0x7fff97d4d466]
        1  _CFStreamOpen + 137 (CoreFoundation) [0x7fff97d2b9a9]
        1  __open + 10 (libsystem_kernel.dylib) [0x7fff8ffd8fee]
        *1  open + 260 (mach_kernel) [0xffffff80002fc314]
        *1  ??? (mach_kernel + 1030985) [0xffffff80002fbb49]
        *1  vn_open_auth + 1632 (mach_kernel) [0xffffff8000309190]
        *1  namei + 1454 (mach_kernel) [0xffffff80002eb18e]
        *1  lookup + 556 (mach_kernel) [0xffffff80002eb79c]
        *1  VNOP_LOOKUP + 52 (mach_kernel) [0xffffff8000311674]
        *1  hfs_vnop_lookup + 1144 (mach_kernel) [0xffffff80004f9098]
        *1  cat_lookup + 152 (mach_kernel) [0xffffff80004e9368]
        *1  ??? (mach_kernel + 3053157) [0xffffff80004e9665]
        *1  BTSearchRecord + 304 (mach_kernel) [0xffffff800051d2a0]
        *1  SearchTree + 276 (mach_kernel) [0xffffff8000521314]
        *1  GetNode + 44 (mach_kernel) [0xffffff800052024c]
        *1  GetBTreeBlock + 182 (mach_kernel) [0xffffff80004e7766]
        *1  buf_biowait + 121 (mach_kernel) [0xffffff80002dd759]
                                          2  ??? (Dock + 432994) [0x10b481b62]
                                            2  CGSGetNextEventRecord + 25 (CoreGraphics) [0x7fff92516f70]
                                        1  mshMIGPerform + 443 (HIServices) [0x7fff92e81f4e]
                                          1  ??? (Dock + 416843) [0x10b47dc4b]
                                            1  ??? (Dock + 417078) [0x10b47dd36]
                                              1  ??? (Dock + 417372) [0x10b47de5c]
                                                1  ??? (Dock + 417745) [0x10b47dfd1]
                                                  1  ??? (Dock + 81873) [0x10b42bfd1]
                                                    1  CGContextDrawImage + 460 (CoreGraphics) [0x7fff9216534b]
                                                      1  ripc_DrawImage + 1045 (libRIP.A.dylib) [0x7fff92edc709]
                                                        1  ripc_AcquireImage + 2468 (libRIP.A.dylib) [0x7fff92eddba9]
                                                          1  CGSImageDataLock + 193 (CoreGraphics) [0x7fff92165816]
                                                            1  img_data_lock + 1121 (CoreGraphics) [0x7fff92166b05]
                                                              1  CGColorTransformConvertNeedsCMS + 9 (CoreGraphics) [0x7fff92168bf3]
        1  getConversionType + 308 (CoreGraphics) [0x7fff92168d39]
        1  CGCMSInterfaceTransformConvertRequired + 20 (CoreGraphics) [0x7fff92184d0e]
        1  CMSTransformConvertRequired + 16 (libCSync.A.dylib) [0x7fff952be381]
        1  acquireColorWorld + 135 (libCSync.A.dylib) [0x7fff952bcf57]
        1  aquireColorWorldByAttributes + 193 (libCSync.A.dylib) [0x7fff952bd0a0]
        1  create + 1164 (libCSync.A.dylib) [0x7fff952c1e89]
        1  ColorSyncTransformCreate + 788 (ColorSync) [0x7fff976f714e]
        1  ColorSyncCMMInitializeTransform + 113 (ColorSync) [0x7fff97742057]
        1  AppleCMMInitializeTransform + 281 (ColorSync) [0x7fff97708ebb]
        1  DoInitializeTransform + 920 (ColorSync) [0x7fff977072dc]
        1  ConversionManager::MakeConversionSequence(CMMProfileInfoContainer*, CMMColorConversionInfo*) + 1377 (ColorSync) [0x7fff97709c15]
        1  ConversionManager::AddInvGrayConv(CMMProfile*) + 358 (ColorSync) [0x7fff9770b8ca]
        1  CMMCurveTag::MakeInvLutTable(CMMFloatLutInfo*, CMMMemMgr&, CMMTable**) + 670 (ColorSync) [0x7fff977159dc]
        1  InvertLUT(int*, int*) + 203 (ColorSync) [0x7fff97700e88]
                            Thread 0x62c      DispatchQueue 2          priority 49
                            Thread 0x8c1      priority 47         cpu time   0.013s
                                38 ??? (Dock + 101992) [0x10b430e68]
                                  38 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8ffd90fa]
                                   *38 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5d30]
                                2  ??? (Dock + 102214) [0x10b430f46]
                                  2  ??? (Dock + 106463) [0x10b431fdf]
                                    1  ??? (Dock + 122320) [0x10b435dd0]
                                      1  ??? (Dock + 903229) [0x10b4f483d]
                                        1  CGSSetMagicMirror + 274 (CoreGraphics) [0x7fff9250e9a0]
                                          1  _CGSSetMagicMirror + 141 (CoreGraphics) [0x7fff922fabad]
                                    1  ??? (Dock + 121184) [0x10b435960]
                                      1  ??? (Dock + 122621) [0x10b435efd]
                                        1  CGSSetBackgroundEventMaskAndShape + 213 (CoreGraphics) [0x7fff92517552]
                                          1  _CGSSetBackgroundEventMaskAndShape + 126 (CoreGraphics) [0x7fff921a7c9f]
                                1  clock_sleep_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7776]
                                     *1  clock_sleep_trap + 434 (mach_kernel) [0xffffff800021d452]
                            Thread 0x7016e    priority <multiple> cpu time   0.024s
                            Thread 0x7020e    priority <multiple> cpu time   0.016s
                            Thread 0x7020f    priority <multiple>
                            Thread 0x71a1e    priority <multiple> cpu time   0.022s
                            Thread 0x71c5c    priority <multiple> cpu time   0.015s
                            Thread 0x71d43    priority <multiple> cpu time   0.024s
                            Thread 0x71fdb    priority <multiple> cpu time   0.028s
                            Thread 0x72060    priority <multiple> cpu time   0.030s
                            Thread 0x723af    priority <multiple> cpu time   0.041s
                            Binary Images:
                                   0x10b418000 -        0x10b672fff  com.apple.dock 1.8 (1168.6) <E04E5714-DD1C-3F3E-8BF7-52D3086AB241> /System/Library/CoreServices/Dock.app/Contents/MacOS/Dock
                                0x7fff9103c000 -     0x7fff9103dfff  libquit.dylib <FD30E6D6-B4F9-3E14-8376-7036271100D1> /usr/lib/libquit.dylib
                                0x7fff92e78000 -     0x7fff92ecefff  com.apple.HIServices 1.20 <A1129272-FEC8-350B-BA26-5A97F23C413D> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
                                0x7fff92ecf000 -     0x7fff92efbff7  libRIP.A.dylib <5A7EB5C2-BA60-36D7-BF41-9853F37837AA> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
                                0x7fff93e5e000 -     0x7fff93e6afff  com.apple.CrashReporterSupport 10.8.2 (414.3) <B1A904D2-1944-39AD-9F43-F589CEE3FCC3> /System/Library/PrivateFrameworks/CrashReporterSupport.framework/Versions/A/CrashReporter Support
                                0x7fff952b9000 -     0x7fff952c5fff  libCSync.A.dylib <2033247A-CABC-3E20-8498-7367A8F44A08> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
                                0x7fff976ee000 -     0x7fff977abff7  com.apple.ColorSync 4.8.0 (4.8.0) <6CE333AE-EDDB-3768-9598-9DB38041DC55> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
                          Process:         Dropbox [263]
                          Path:            /Applications/Dropbox.app/Contents/MacOS/Dropbox
                          Architecture:    i386
                          Parent:          launchd [204]
                          UID:             501
                          Task size:       13007 pages
                          CPU Time:        0.005s
                          Process:         dynamic_pager [46]
                          Path:            /sbin/dynamic_pager
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       168 pages
                            Thread 0x186      priority 63
                            41 ??? [0x7fff980747e1]
                              41 ??? [0x107bf74c8]
                                41 ??? [0x107bf6d8f]
                                  41 ??? [0x107bf6b80]
                                    41 ??? [0x107bf6613]
                                      41 ??? [0x7fff8ffd7686]
                            Binary Images:
                          Process:         filecoordinationd [252]
                          Path:            /usr/sbin/filecoordinationd
                          Architecture:    x86_64
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       704 pages
                            Thread 0x6df      DispatchQueue 7          priority 31
                            Thread 0x6e2      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10fb8a000 -        0x10fb8aff7  filecoordinationd <3550B2C5-526B-3B56-9912-D144BBC64937> /usr/sbin/filecoordinationd
                          Process:         Finder [219]
                          Path:            /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                          UID:             501
                          Task size:       21627 pages (-170)
                          CPU Time:        0.070s
                            Thread 0x61c      DispatchQueue 1          priority 46         cpu time   0.066s
                              41 ??? (Finder + 23366) [0x1048a4b46]
                                                38 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                                  38 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                                    38 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                                     *37 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                                1  __CFRunLoopRun + 1513 (CoreFoundation) [0x7fff97d2f099]
                                                  1  __CFRunLoopDoTimer + 557 (CoreFoundation) [0x7fff97d498bd]
                                                    1  __CFRUNLOOP_IS_CALLING_OUT_TO_A_TIMER_CALLBACK_FUNCTION__ + 20 (CoreFoundation) [0x7fff97d49da4]
                                                      1  __NSFireTimer + 96 (Foundation) [0x7fff900b0513]
                                                        1  ??? (Finder + 854477) [0x10496f9cd]
                                                          1  ??? (Finder + 2157128) [0x104aada48]
                            Thread 0x632      DispatchQueue 2          priority 48         cpu time   0.001s
                            Thread 0x7016a    DispatchQueue 23802      priority 46
                                    41 _dispatch_queue_drain + 235 (libdispatch.dylib) [0x7fff9315e47f]
                                          41 __PostNodeTaskRequest_block_invoke_0 + 91 (DesktopServicesPriv) [0x7fff96912fe1]
                                            41 ExceptionSafeBlock(void ()() block_pointer) + 12 (DesktopServicesPriv) [0x7fff96913040]
                                              41 __block_global_1 + 82 (DesktopServicesPriv) [0x7fff969864e7]
                                                41 TNode::HandleNodeRequest(TCountedPtr<TNodeTask> const&, TCountedPtr<TVolumeSyncThread> const&) + 1058 (DesktopServicesPriv) [0x7fff969134b8]
                                                  41 TNode::RemoveVolume(short, unsigned char) + 139 (DesktopServicesPriv) [0x7fff9695a417]
                                                    41 TNode::HandleSync(unsigned int) + 2629 (DesktopServicesPriv) [0x7fff969235cd]
                                                      41 TNode::SynchronizeChildren(unsigned int, TNodeEventPtrSet&) + 318 (DesktopServicesPriv) [0x7fff9692636a]
                                                        41 TFSInfoSynchronizer::FetchChildren() + 242 (DesktopServicesPriv) [0x7fff9692a398]
                                                          41 TFSIterator::Next(TCountedPtr<TFSInfo>&) + 41 (DesktopServicesPriv) [0x7fff9693890d]
                                                            41 TFSIterator::NextRaw(TCountedPtr<TFSInfo>&) + 44 (DesktopServicesPriv) [0x7fff96938a14]
                                                              41 _URLEnumeratorGetNextURL + 114 (CoreServicesInternal) [0x7fff8ddafbb1]
        41 _GetDirectoryURLs(_CFURLEnumerator*) + 894 (CoreServicesInternal) [0x7fff8ddb0a54]
        41 ftsattr_read$INODE64 + 556 (CoreServicesInternal) [0x7fff8ddb37f2]
        41 ftsattr_build + 1023 (CoreServicesInternal) [0x7fff8ddb42af]
        41 ftsattr_getattrlist + 425 (CoreServicesInternal) [0x7fff8ddb3d71]
        41 __getattrlist + 10 (libsystem_kernel.dylib) [0x7fff8ffd8bd2]
        *41 hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ced33]
        *41 unix_syscall64 + 522 (mach_kernel) [0xffffff80005e182a]
        *41 getattrlist + 188 (mach_kernel) [0xffffff80002d9dfc]
        *41 ??? (mach_kernel + 885205) [0xffffff80002d81d5]
        *41 vnode_getattr + 105 (mach_kernel) [0xffffff8000310669]
        *41 hfs_vnop_getattr + 548 (mach_kernel) [0xffffff8000512d64]
        *41 hfs_lock + 85 (mach_kernel) [0xffffff80004ef835]
        *41 lck_rw_lock_shared_gen + 128 (mach_kernel) [0xffffff80002b0c10]
        *41 thread_block_reason + 300 (mach_kernel) [0xffffff800022da0c]
        *41 ??? (mach_kernel + 190273) [0xffffff800022e741]
        *41 machine_switch_context + 366 (mach_kernel) [0xffffff80002b3d7e]
                            Thread 0xb5f      priority 46
                            41 thread_start + 13 (libsystem_c.dylib) [0x7fff98bbe181]
                              41 _pthread_start + 327 (libsystem_c.dylib) [0x7fff98bd1742]
                            Thread 0x717fe    priority 46
                                41 TNodeOperationTask::OperationTaskProc(void*) + 23 (DesktopServicesPriv) [0x7fff96977997]
                                  41 TSuboperationTask::OperationTaskProcedure() + 245 (DesktopServicesPriv) [0x7fff96997253]
                                      41 TSWaitOnConditionTimedRelative + 132 (CarbonCore) [0x7fff954cf3eb]
                                        41 TSWaitOnCondition + 108 (CarbonCore) [0x7fff954cf214]
                                          41 __psynch_cvwait + 10 (libsystem_kernel.dylib) [0x7fff8ffd90fa]
                                           *41 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5d30]
                            Thread 0x72007    priority 46
                            Thread 0x722b8    priority 46
                            Thread 0x7232c    priority <multiple> cpu time   0.002s
                            Binary Images:
                                   0x10489f000 -        0x104d59ff7  com.apple.finder 10.8.1 (10.8.1) <E66EA62C-F929-30B3-BB53-5D8685451059> /System/Library/CoreServices/Finder.app/Contents/MacOS/Finder
                                0x7fff8dd90000 -     0x7fff8ddbefff  com.apple.CoreServicesInternal 154.2 (154.2) <3E6196E6-F3B4-316F-9E1F-13B6B9694C7E> /System/Library/PrivateFrameworks/CoreServicesInternal.framework/Versions/A/CoreServicesI nternal
                                0x7fff8ffc7000 -     0x7fff8ffe2ff7  libsystem_kernel.dylib <C0535565-35D1-31A7-A744-63D9F10F12A4> /usr/lib/system/libsystem_kernel.dylib
                                0x7fff9315b000 -     0x7fff93170ff7  libdispatch.dylib <D26996BF-FC57-39EB-8829-F63585561E09> /usr/lib/system/libdispatch.dylib
                                0x7fff95422000 -     0x7fff95739ff7  com.apple.CoreServices.CarbonCore 1037.3 (1037.3) <DF7CABCA-F2CB-345B-8EFF-F0F4E937B7FF> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
                                0x7fff98bbd000 -     0x7fff98c89fe7  libsystem_c.dylib <8CBCF9B9-EBB7-365E-A3FF-2F3850763C6B> /usr/lib/system/libsystem_c.dylib
                          *0xffffff8000200000 - 0xffffff800074033c  mach_kernel <69A5853F-375A-3EF4-9247-478FD0247333> /mach_kernel
                          Process:         FMCore [2672]
                          Path:            /Applications/Suitcase Fusion 4.app/Contents/Resources/FMCore
                          Architecture:    i386
                          Parent:          Suitcase Fusion 4 [2670]
                          UID:             501
                          Task size:       10429 pages
                          CPU Time:        0.006s
                          Process:         fontd [146]
                          Path:            /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                          Parent:          launchd [1]
                          UID:             97
                          Sudden Term:     Clean
                          Task size:       1184 pages
                            Thread 0x4b0      DispatchQueue 1          priority 31
                            41 start + 1 (libdyld.dylib) [0x7fff980747e1]
                              41 main_handler + 4757 (libATSServer.dylib) [0x7fff8d531ff7]
                                  41 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff97d2e6b2]
                                    41 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                      41 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                        41 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                         *41 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                            Thread 0x4b5      DispatchQueue 2          priority 33
                            41 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9315f9ee]
                              41 kevent + 10 (libsystem_kernel.dylib) [0x7fff8ffd9d16]
                               *41 ??? (mach_kernel + 3471600) [0xffffff800054f8f0]
                            Binary Images:
                                   0x105f96000 -        0x105f99fff  fontd <8EE3DBFC-B8F0-3A32-9ED8-29E195EF9269> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                                0x7fff8d4b3000 -     0x7fff8d55afff  libATSServer.dylib <2EC4C098-9FB5-3505-AB9D-23E578BCF8FB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libATSServer.dylib
                                0x7fff97cfa000 -     0x7fff97ee3fff  com.apple.CoreFoundation 6.8 (744.12) <EF002794-DAEF-31C6-866C-E3E3AC387A9F> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
                                0x7fff98072000 -     0x7fff98075ff7  libdyld.dylib <F59367C9-C110-382B-A695-9035A6DD387E> /usr/lib/system/libdyld.dylib
                          Process:         fontd [254]
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       3214 pages (-7)
                            Thread 0x6f3      DispatchQueue 1          priority 31
                            Thread 0x6fd      DispatchQueue 2          priority 33
                            Thread 0x72335    priority 38
                                41 AsyncFileThread(void*) + 257 (CarbonCore) [0x7fff95492b97]
                                  41 TSWaitOnSemaphoreCommon + 265 (CarbonCore) [0x7fff954cef71]
                            Thread 0x723f0    priority 31
                            23 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              23 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                23 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *23 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x10d558000 -        0x10d55bfff  fontd <8EE3DBFC-B8F0-3A32-9ED8-29E195EF9269> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ATS.framework/Support /fontd
                          Process:         fseventsd [44]
                          Path:            /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       1493 pages
                            Thread 0x184      DispatchQueue 1          priority 31
                              41 ??? (fseventsd + 5593) [0x109ceb5d9]
                                41 mach_msg_server + 335 (libsystem_kernel.dylib) [0x7fff8ffd7433]
                                  41 mach_msg_overwrite_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7692]
                            Thread 0x22b      DispatchQueue 2          priority 33
                            Thread 0x1aa      priority 49
                                41 ??? (fseventsd + 43270) [0x109cf4906]
                                  41 ??? (fseventsd + 42498) [0x109cf4602]
                            Thread 0x1ab      priority 31
                                41 ??? (fseventsd + 12969) [0x109ced2a9]
                            Thread 0x1ac      priority 50
                            Thread 0x1ad      priority 31
                                41 ??? (fseventsd + 29444) [0x109cf1304]
                            Thread 0x3e0      priority 31
                            Thread 0x3e2      priority 31
                            Thread 0x3e3      priority 31
                            Thread 0x3e4      priority 31
                            Thread 0x3e5      priority 31
                            Thread 0x3e6      priority 31
                            Thread 0x3e7      priority 31
                            Thread 0x3e9      priority 31
                            Thread 0x3ea      priority 31
                            Thread 0x3eb      priority 31
                            Thread 0x3ec      priority 31
                            Thread 0x3ee      priority 31
                            Thread 0x3ef      priority 31
                            Thread 0x3f0      priority 31
                            Thread 0x3f1      priority 31
                            Thread 0x3f2      priority 31
                            Thread 0x3f3      priority 31
                            Thread 0x3f4      priority 31
                            Thread 0x3f5      priority 31
                            Thread 0x3f7      priority 31
                            Thread 0x3f8      priority 31
                            Thread 0x3f9      priority 31
                            Thread 0x3fa      priority 31
                            Thread 0x3fb      priority 31
                            Thread 0x3fc      priority 31
                            Thread 0x3ff      priority 31
                            Thread 0x400      priority 31
                            Thread 0x4be      priority 31
                            Thread 0x4c0      priority 31
                            Thread 0x4d0      priority 31
                            Thread 0x6c5      priority 31
                            Thread 0x728      priority 31
                            Thread 0x730      priority 31
                            Thread 0x736      priority 31
                            Thread 0x750      priority 31
                            Thread 0x753      priority 31
                            Thread 0x816      priority 31
                            Thread 0x81a      priority 31
                            Thread 0x81d      priority 31
                            Thread 0x81e      priority 31
                            Thread 0x821      priority 31
                            Thread 0x822      priority 31
                            Thread 0x823      priority 31
                            Thread 0x824      priority 31
                            Thread 0x826      priority 31
                            Thread 0x827      priority 31
                            Thread 0x828      priority 31
                            Thread 0x834      priority 31
                            Thread 0x869      priority 31
                            Thread 0x86a      priority 31
                            Thread 0x86f      priority 31
                            Thread 0x8c8      priority 31
                            Thread 0x8cb      priority 31
                            Thread 0x8cc      priority 31
                            Thread 0x8cd      priority 31
                            Thread 0x8ce      priority 31
                            Thread 0x950      priority 31
                            Thread 0xab9      priority 31
                            Thread 0x134a     priority 31
                            Thread 0x1392     priority 31
                            Thread 0x148b     priority 31
                            Thread 0xb6f1     priority 31
                            Thread 0xc2d7     priority 31
                            Thread 0x18cc8    priority 31
                            Thread 0x68caf    priority 31
                            Thread 0x6ebbd    priority 31
                            Thread 0x6f338    priority 31
                            Thread 0x6fc97    priority 31
                            Thread 0x70bd8    priority 31
                            Thread 0x71869    priority 31
                            Thread 0x71e44    priority 31
                            Binary Images:
                                   0x109cea000 -        0x109cfffff  fseventsd <1FDDBDE1-2670-3E68-A162-FA0E264718C8> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/Support/fseventsd
                          Process:         Google Drive [262]
                          Path:            /Applications/Google Drive.app/Contents/MacOS/Google Drive
                          Architecture:    i386
                          UID:             501
                          Task size:       18570 pages
                          CPU Time:        0.002s
                          Process:         hdiejectd [787]
                          Path:            /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Dirty
                          Task size:       371 pages
                            Thread 0xaaf5     DispatchQueue 1          priority 31
                              41 ??? (hdiejectd + 5704) [0x103fa4648]
                                41 ??? (hdiejectd + 6545) [0x103fa4991]
                                  41 ??? (hdiejectd + 7596) [0x103fa4dac]
                            Thread 0xaaf6     DispatchQueue 2          priority 33
                            Binary Images:
                                   0x103fa3000 -        0x103fabfff  hdiejectd <C519E4D6-1295-318F-A1CD-4F587B93D770> /System/Library/PrivateFrameworks/DiskImages.framework/Resources/hdiejectd
                          Process:         helpd [2491]
                          Path:            /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       401 pages
                            Thread 0x6f269    DispatchQueue 1          priority 31
                              41 ??? (helpd + 41173) [0x10a7f70d5]
                                41 CFRunLoopRun + 97 (CoreFoundation) [0x7fff97d3d371]
                            Thread 0x6f272    DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10a7ed000 -        0x10a7fcfff  helpd <18369DE6-2FD3-3D31-8E69-F1CE023B0B8F> /System/Library/PrivateFrameworks/HelpData.framework/Versions/A/Resources/helpd
                          Process:         hidd [43]
                          Path:            /usr/libexec/hidd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       213 pages
                            Thread 0x183      DispatchQueue 1          priority 31
                              41 ??? (hidd + 3863) [0x10af52f17]
                            Thread 0x1cb      DispatchQueue 2          priority 33
                            Thread 0x1cf      priority 63
                                41 __IOHIDSessionStartOnThread + 402 (IOKit) [0x7fff953cf28a]
                            Binary Images:
                                   0x10af52000 -        0x10af52fff  hidd <4CDFE963-F75C-3BFF-8B10-484CD9E95081> /usr/libexec/hidd
                                0x7fff953a0000 -     0x7fff9540dff7  com.apple.framework.IOKit 2.0 <142E19DD-1C8D-3D61-ABC8-83994A73279F> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
                          Process:         Image Capture Extension [296]
                          Path:            /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       3066 pages
                            Thread 0x855      DispatchQueue 1          priority 46
                            Thread 0x861      DispatchQueue 2          priority 48
                            Binary Images:
                                   0x10c155000 -        0x10c1bcfff  com.apple.ImageCaptureExtension2 8.0.1 (8.0.1) <67E77621-8363-37E6-9080-D5D96C5FB3E3> /System/Library/Image Capture/Support/Image Capture Extension.app/Contents/MacOS/Image Capture Extension
                          Process:         imagent [230]
                          Path:            /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
                          UID:             501
                          Task size:       1783 pages
                            Thread 0x650      DispatchQueue 1          priority 31
                              41 ??? (imagent + 32939) [0x10885e0ab]
                            Thread 0x6b3      DispatchQueue 2          priority 33
                            Thread 0x6bc      priority 31
                                41 __NSThread__main__ + 1345 (Foundation) [0x7fff900d2612]
                                  41 ??? (IMDPersistence + 6074) [0x7fff996ff7ba]
                            Thread 0x72413    priority 33
                            Thread 0x72416    priority 33
                            Thread 0x72508    priority 33
                            Thread 0x7250c    priority 33
                            Binary Images:
                                   0x108856000 -        0x10887dfff  com.apple.imagent 8.0 (900) <EA8F8437-AD21-36A7-9738-DB04F6C60162> /System/Library/PrivateFrameworks/IMCore.framework/imagent.app/Contents/MacOS/imagent
                                0x7fff9003d000 -     0x7fff90399fff  com.apple.Foundation 6.8 (945.11) <A5D41956-A354-3ACC-9355-BE200072223B> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
                                0x7fff996fe000 -     0x7fff99744ff7  com.apple.IMDPersistence 8.0 (900) <96EEA554-9DD3-3B2C-99E0-9266F8F5B6C9> /System/Library/PrivateFrameworks/IMDPersistence.framework/Versions/A/IMDPersistence
                          Process:         imklaunchagent [266]
                          Path:            /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       727 pages
                            Thread 0x75b      DispatchQueue 1          priority 31
                              41 ??? (imklaunchagent + 3596) [0x10aa92e0c]
                            Thread 0x75e      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10aa92000 -        0x10aa93fff  imklaunchagent <F8E45501-FDB9-38F1-AF87-24718DC36458> /System/Library/Frameworks/InputMethodKit.framework/Resources/imklaunchagent
                          Process:         iTunes [305]
                          Path:            /Applications/iTunes.app/Contents/MacOS/iTunes
                          UID:             501
                          Task size:       37898 pages
                          CPU Time:        0.103s
                            Thread 0x8ec      DispatchQueue 1          priority 46         cpu time   0.078s
                            41 ??? (iTunes + 11392) [0x10907ac80]
                              41 ??? (iTunes + 11839) [0x10907ae3f]
                                                   *34 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                                   *5  hndl_mach_scall64 + 19 (mach_kernel) [0xffffff80002ced53]
                                                     *5  ??? (mach_kernel + 678678) [0xffffff80002a5b16]
                                                       *5  mach_msg_overwrite_trap + 427 (mach_kernel) [0xffffff800021970b]
                                                         *5  ipc_mqueue_receive + 59 (mach_kernel) [0xffffff800021310b]
                                                           *5  thread_block_reason + 275 (mach_kernel) [0xffffff800022d9f3]
                                                             *5  ??? (mach_kernel + 187521) [0xffffff800022dc81]
                                                               *5  processor_idle + 227 (mach_kernel) [0xffffff800022f1c3]
        *5  machine_idle + 282 (mach_kernel) [0xffffff80002b8c5a]
                            Thread 0x996      DispatchQueue 2          priority 48
                            Thread 0x9e0      priority 46
                                41 ??? (iTunes + 8991126) [0x10990b196]
                                  41 ??? (iTunes + 36167) [0x109080d47]
                            Thread 0xa22      priority 55         cpu time   0.006s
                                  41 ??? (iTunes + 106727) [0x1090920e7]
                                    41 ??? (iTunes + 36662) [0x109080f36]
                                       *36 psynch_cvcontinue + 0 (mach_kernel) [0xffffff80005b5d30]
                                       *5  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ced33]
                                         *5  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e182a]
                                           *5  psynch_cvwait + 1340 (mach_kernel) [0xffffff80005b5c6c]
                            Thread 0xa65      priority 46
                                  41 ??? (iTunes + 140206) [0x10909a3ae]
                            Thread 0xaba      priority 46
                                  41 ??? (iTunes + 10198197) [0x109a31cb5]
                                    41 ??? (iTunes + 10198160) [0x109a31c90]
                                      41 ??? (iTunes + 36400) [0x109080e30]
                                        41 ??? (iTunes + 36596) [0x109080ef4]
                            Thread 0xabb      priority 46
                                41 ??? (iTunes + 983755) [0x1091682cb]
                            Thread 0xabc      priority 46
                                  41 ??? (iTunes + 8427556) [0x109881824]
                                    41 ??? (iTunes + 8427137) [0x109881681]
                                      41 __accept + 10 (libsystem_kernel.dylib) [0x7fff8ffd8996]
                                           *41 accept_nocancel + 442 (mach_kernel) [0xffffff800059faea]
                                               *41 ??? (mach_kernel + 3579734) [0xffffff8000569f56]
                                                 *41 lck_mtx_sleep + 78 (mach_kernel) [0xffffff80002265fe]
                            Thread 0xabd      priority 46
                            Thread 0xabe      priority 46
                                41 __select + 10 (libsystem_kernel.dylib) [0x7fff8ffd9322]
                                 *41 ??? (mach_kernel + 3581216) [0xffffff800056a520]
                            Thread 0xac1      priority 46
                            Thread 0xac8      priority 46
                                  41 ??? (iTunes + 175170) [0x1090a2c42]
                                    41 ??? (iTunes + 8796065) [0x1098db7a1]
                                      41 ??? (iTunes + 8795895) [0x1098db6f7]
                                        41 ??? (iTunes + 8796271) [0x1098db86f]
                            Thread 0xaca      priority 46
                            Thread 0xb11      priority 46
                            Thread 0xb2a      priority 46
                            Thread 0xcb1      priority 46
                            Thread 0x63df3    priority 53
                            Thread 0x63e3c    priority 46
                                  41 ??? (iTunes + 1791314) [0x10922d552]
                                    41 ATHostConnectionReadMessage + 607 (AirTrafficHost) [0x114fcc8e2]
                                      41 ATProcessLinkCopyMessageFromChild + 162 (AirTrafficHost) [0x114fcd917]
                            Thread 0x6e642    priority 97         cpu time   0.007s
                                41 HALB_IOThread::Entry(void*) + 75 (CoreAudio) [0x7fff93fee24b]
                                  41 HALC_ProxyIOContext::IOThreadEntry(void*) + 83 (CoreAudio) [0x7fff93fee391]
                                    41 HALC_ProxyIOContext::IOWorkLoop() + 1209 (CoreAudio) [0x7fff93fee8db]
                                      41 HALB_MachPort::SendSimpleMessageWithSimpleReply(unsigned int, unsigned int, int, int&, bool, unsigned int) + 42 (CoreAudio) [0x7fff93ff0108]
                                        41 HALB_MachPort::SendMessageWithReply(unsigned int, unsigned int, unsigned int, unsigned int, mach_msg_header_t*, bool, unsigned int) + 98 (CoreAudio) [0x7fff93ff017a]
                            Thread 0x7201a    priority 53
                            Thread 0x7201b    priority 54         cpu time   0.010s
                            Thread 0x7240d    priority 48
                            Thread 0x72404    priority 48
                            Thread 0x724fc    priority 48
                            Thread 0x72501    priority 48
                            Binary Images:
                                   0x109078000 -        0x10a218fff  com.apple.iTunes 10.7 (10.7) <0CC47E12-134F-A9E1-7E4F-3EAC797C3050> /Applications/iTunes.app/Contents/MacOS/iTunes
                                   0x114fca000 -        0x11514bff7  com.apple.AirTrafficHost 282 (282) <8BB16E44-91BB-3124-A1FA-040D4638B748> /System/Library/PrivateFrameworks/AirTrafficHost.framework/AirTrafficHost
                                0x7fff93fc3000 -     0x7fff94020fff  com.apple.audio.CoreAudio 4.1.0 (4.1.0) <B3198BD6-EA1D-3E5E-ADD4-37D8E6B72678> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
                          Process:         iTunesHelper [257]
                          Path:            /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
                          UID:             501
                          Task size:       2759 pages
                          Note:            Throttled by external source
                            Thread 0x702      DispatchQueue 1          priority 4
                            41 ??? (iTunesHelper + 4820) [0x1000012d4]
                              41 ??? (iTunesHelper + 9654) [0x1000025b6]
                                            2  ??? (iTunesHelper + 9740) [0x10000260c]
                            Thread 0x706      DispatchQueue 2          priority 4
                            Thread 0x70c      priority 4
                            Binary Images:
                                   0x100000000 -        0x100025ff7  com.apple.iTunesHelper 10.7 (10.7) <E32A3512-0956-4757-A6BE-2E29D01E9F2D> /Applications/iTunes.app/Contents/MacOS/iTunesHelper.app/Contents/MacOS/iTunesHelper
                          Process:         KernelEventAgent [41]
                          Path:            /usr/sbin/KernelEventAgent
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       259 pages
                            Thread 0x181      DispatchQueue 1          priority 31
                              41 main + 908 (KernelEventAgent) [0x10043a6ec]
                            Thread 0x198      DispatchQueue 2          priority 33
                            Thread 0x197      priority 31
                            Binary Images:
                                   0x100439000 -        0x10043ffff  KernelEventAgent <F160063A-1452-388A-AF35-18892F224ADC> /usr/sbin/KernelEventAgent
                          Process:         kextd [12]
                          Path:            /usr/libexec/kextd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       1737 pages
                            Thread 0x159      DispatchQueue 1          priority 31
                              41 ??? (kextd + 6436) [0x10324e924]
                            Thread 0x161      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x10324d000 -        0x10326aff7  kextd <195CC1FA-DEE9-3BEE-85B0-EB5E2F8B2086> /usr/libexec/kextd
                          Process:         launchd [1]
                          Path:            /sbin/launchd
                          Parent:          kernel_task [0]
                          UID:             0
                          Task size:       673 pages (-1)
                          CPU Time:        0.007s
                            Thread 0x137      DispatchQueue 1          priority 31         cpu time   0.007s
                              41 ??? (launchd + 15472) [0x1077dec70]
                                41 ??? (launchd + 24092) [0x1077e0e1c]
                                  40 xpc_pipe_try_receive + 89 (libxpc.dylib) [0x7fff8dacdbbd]
                                    40 _xpc_pipe_receive + 116 (libxpc.dylib) [0x7fff8dacddb0]
                                      40 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                       *40 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                  1  xpc_pipe_try_receive + 258 (libxpc.dylib) [0x7fff8dacdc66]
                                    1  ??? (launchd + 28819) [0x1077e2093]
                                      1  ??? (launchd + 4031) [0x1077dbfbf]
                                        1  ??? (launchd + 23864) [0x1077e0d38]
                                          1  ??? (launchd + 29218) [0x1077e2222]
                                            1  ??? (launchd + 87775) [0x1077f06df]
                                              1  ??? (launchd + 32417) [0x1077e2ea1]
                                                1  ??? (launchd + 43506) [0x1077e59f2]
                                                  1  ??? (launchd + 24907) [0x1077e114b]
                                                    1  __fork + 11 (libsystem_kernel.dylib) [0x7fff8ffd8b4f]
                                                     *1  hndl_unix_scall64 + 19 (mach_kernel) [0xffffff80002ced33]
                                                       *1  unix_syscall64 + 522 (mach_kernel) [0xffffff80005e182a]
                                                         *1  fork + 60 (mach_kernel) [0xffffff800055a6cc]
                                                           *1  fork1 + 665 (mach_kernel) [0xffffff8000559be9]
                                                             *1  cloneproc + 77 (mach_kernel) [0xffffff800055a3ed]
                                                               *1  fork_create_child + 39 (mach_kernel) [0xffffff800055a5c7]
        *1  task_create_internal + 131 (mach_kernel) [0xffffff80002351c3]
        *1  vm_map_fork + 942 (mach_kernel) [0xffffff800026e36e]
        *1  lck_rw_done + 2 (mach_kernel) [0xffffff80002ac892]
                            Thread 0x149      priority 31
                                40 __select + 10 (libsystem_kernel.dylib) [0x7fff8ffd9322]
                                 *40 ??? (mach_kernel + 3581216) [0xffffff800056a520]
                                1  ??? (launchd + 19362) [0x1077dfba2]
                                  1  ??? (launchd + 3716) [0x1077dbe84]
                            Thread 0x14a      priority 31
                            41 sync + 10 (libsystem_kernel.dylib) [0x7fff8ffda3e2]
                                 *41 sync + 25 (mach_kernel) [0xffffff80002fa339]
                                   *41 vfs_iterate + 375 (mach_kernel) [0xffffff80002f3af7]
                                     *41 ??? (mach_kernel + 1024959) [0xffffff80002fa3bf]
                                       *41 hfs_sync + 187 (mach_kernel) [0xffffff8000505e4b]
                                         *41 vnode_iterate + 535 (mach_kernel) [0xffffff80002ee797]
                                           *41 ??? (mach_kernel + 3170373) [0xffffff8000506045]
                                             *41 hfs_lock + 101 (mach_kernel) [0xffffff80004ef845]
                                               *41 lck_rw_lock_exclusive_gen + 128 (mach_kernel) [0xffffff80002b0690]
                            Binary Images:
                                   0x1077db000 -        0x107801ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
                                0x7fff8dacb000 -     0x7fff8daedff7  libxpc.dylib <FAC04D8B-680E-325F-8F0C-DD69859D0E01> /usr/lib/system/libxpc.dylib
                          Process:         launchd [204]
                          Path:            /sbin/launchd
                          Parent:          launchd [1]
                          UID:             501
                          Sudden Term:     Dirty
                          Task size:       450 pages
                          CPU Time:        0.001s
                            Thread 0x5ca      DispatchQueue 1          priority 31         cpu time   0.001s
                              41 ??? (launchd + 15472) [0x107918c70]
                                41 ??? (launchd + 24092) [0x10791ae1c]
                                  41 xpc_pipe_try_receive + 89 (libxpc.dylib) [0x7fff8dacdbbd]
                                    41 _xpc_pipe_receive + 116 (libxpc.dylib) [0x7fff8dacddb0]
                            Thread 0x5cb      priority 31
                            Binary Images:
                                   0x107915000 -        0x10793bff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
                          Process:         launchd [245]
                          Path:            /sbin/launchd
                          Parent:          launchd [1]
                          UID:             88
                          Sudden Term:     Dirty
                          Task size:       247 pages
                            Thread 0x669      DispatchQueue 1          priority 31
                              41 ??? (launchd + 15472) [0x104081c70]
                                41 ??? (launchd + 24092) [0x104083e1c]
                            Thread 0x689      priority 31
                            Binary Images:
                                   0x10407e000 -        0x1040a4ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
                          Process:         launchd [346]
                          Path:            /sbin/launchd
                          Parent:          launchd [1]
                          UID:             89
                          Sudden Term:     Dirty
                          Task size:       260 pages
                            Thread 0xb6e      DispatchQueue 1          priority 31
                              41 ??? (launchd + 15472) [0x10ffeec70]
                                41 ??? (launchd + 24092) [0x10fff0e1c]
                            Thread 0xb72      priority 31
                            Binary Images:
                                   0x10ffeb000 -        0x110011ff7  launchd <7DCC9489-2DF5-3807-83FA-EF5666EE8078> /sbin/launchd
                          Process:         launchdadd [2811]
                          Path:            /usr/libexec/launchdadd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       451 pages
                            Thread 0x7244a    DispatchQueue 1          priority 31
                            40 start + 1 (libdyld.dylib) [0x7fff980747e1]
                              40 main + 281 (launchdadd) [0x10f2c4577]
                                40 CFRunLoopRun + 97 (CoreFoundation) [0x7fff97d3d371]
                                  40 CFRunLoopRunSpecific + 290 (CoreFoundation) [0x7fff97d2e6b2]
                                    40 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                      40 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                            Thread 0x724c3    DispatchQueue 2          priority 33
                            40 _dispatch_mgr_thread + 54 (libdispatch.dylib) [0x7fff9315f9ee]
                              40 kevent + 10 (libsystem_kernel.dylib) [0x7fff8ffd9d16]
                               *40 ??? (mach_kernel + 3471600) [0xffffff800054f8f0]
                            Thread 0x724c5    priority 31
                            Binary Images:
                                   0x10f2bd000 -        0x10f2c9fff  launchdadd <635F6227-0868-3C28-94C5-7BFD7464BC9E> /usr/libexec/launchdadd
                          Process:         librariand [392]
                          Path:            /usr/libexec/librariand
                          UID:             501
                          Task size:       2170 pages
                            Thread 0x123f     DispatchQueue 1          priority 31
                              41 ??? (librariand + 9300) [0x1070cd454]
                            Thread 0x1244     DispatchQueue 2          priority 33
                            Binary Images:
                                   0x1070cb000 -        0x1070dbff7  librariand <8F24D2CC-4A2F-3D3F-AFAF-D7C7F37B582C> /usr/libexec/librariand
                          Process:         logind [135]
                          Path:            /System/Library/CoreServices/logind
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       329 pages
                            Thread 0x476      DispatchQueue 1          priority 31
                              41 ??? (logind + 3087) [0x105ec8c0f]
                            Thread 0x477      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x105ec8000 -        0x105ecafff  logind <A9CB95FF-33BE-3EF8-AF0E-C5FD4A747C7E> /System/Library/CoreServices/logind
                          Process:         loginwindow [39]
                          Path:            /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       6760 pages (+6)
                          CPU Time:        0.001s
                            Thread 0x17f      DispatchQueue 1          priority 48         cpu time   0.001s
                              41 ??? (loginwindow + 20616) [0x109182088]
                                                      2  __NSFireMachPort + 257 (Foundation) [0x7fff900ecbb5]
                                                        2  ??? (BezelServices + 19067) [0x10a7b7a7b]
                            Thread 0x39a      DispatchQueue 2          priority 50
                            Thread 0x724f6    priority 48
                            17 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              17 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                17 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *17 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x724f7    priority 48
                            Binary Images:
                                   0x10917d000 -        0x10920cff7  com.apple.loginwindow 8.2 (8.2) <0121C127-87FD-3A20-8D11-693BEAC18449> /System/Library/CoreServices/loginwindow.app/Contents/MacOS/loginwindow
                                   0x10a7b3000 -        0x10a7e0ff7  com.apple.BezelServices 235.55 (235.55) <8B18DBFB-D571-3A74-B85E-C5474BA0209F> /System/Library/LoginPlugins/BezelServices.loginPlugin/Contents/MacOS/BezelServices
                          Process:         lsboxd [273]
                          Path:            /usr/libexec/lsboxd
                          UID:             501
                          Task size:       718 pages
                            Thread 0x7b7      DispatchQueue 7          priority 31
                            41 _dispatch_sig_thread + 45 (libdispatch.dylib) [0x7fff9315cd85]
                              41 __sigsuspend_nocancel + 10 (libsystem_kernel.dylib) [0x7fff8ffd9566]
                            Thread 0x7b9      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x100fa2000 -        0x100fa5ff7  lsboxd <E6B74B49-27EA-3B2A-84E1-26B22BF512F1> /usr/libexec/lsboxd
                          Process:         lsof [2770]
                          Path:            /usr/sbin/lsof
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       47 pages
                            Thread 0x71f86    priority 31
                            41 ??? (lsof + 45483) [0x10fa3e1ab]
                              41 stat$INODE64 + 10 (libsystem_kernel.dylib) [0x7fff8ffda37e]
                                   *41 stat64 + 140 (mach_kernel) [0xffffff80002fe40c]
                                     *41 ??? (mach_kernel + 1071760) [0xffffff8000305a90]
                                       *41 vn_stat_noauth + 151 (mach_kernel) [0xffffff8000309887]
                            Binary Images:
                                   0x10fa33000 -        0x10fa49fff  lsof <D022AC51-6648-385F-BE2D-1D8C7FAB1553> /usr/sbin/lsof
                          Process:         lsof [2772]
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       47 pages
                            Thread 0x71f92    priority 31
                            41 ??? (lsof + 45483) [0x10953c1ab]
                            Binary Images:
                                   0x109531000 -        0x109547fff  lsof <D022AC51-6648-385F-BE2D-1D8C7FAB1553> /usr/sbin/lsof
                          Process:         lsof [2778]
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       47 pages
                            Thread 0x7208e    priority 31
                            41 ??? (lsof + 45483) [0x10b9121ab]
                            Binary Images:
                                   0x10b907000 -        0x10b91dfff  lsof <D022AC51-6648-385F-BE2D-1D8C7FAB1553> /usr/sbin/lsof
                          Process:         lsof [2781]
                          Parent:          launchd [1]
                          UID:             501
                          Task size:       47 pages
                            Thread 0x72095    priority 31
                            41 ??? (lsof + 45483) [0x102aaf1ab]
                            Binary Images:
                                   0x102aa4000 -        0x102abafff  lsof <D022AC51-6648-385F-BE2D-1D8C7FAB1553> /usr/sbin/lsof
                          Process:         Mail [390]
                          Path:            /Applications/Mail.app/Contents/MacOS/Mail
                          UID:             501
                          Sudden Term:     Dirty
                          Task size:       39967 pages
                          CPU Time:        0.001s
                            Thread 0x122a     DispatchQueue 1          priority 46         cpu time   0.001s
                              41 NSApplicationMain + 869 (AppKit) [0x7fff96b1ecb6]
                                41 -[NSApplication run] + 517 (AppKit) [0x7fff96b7a283]
                                  41 -[NSApplication nextEventMatchingMask:untilDate:inMode:dequeue:] + 128 (AppKit) [0x7fff96b82ed2]
                                    41 _DPSNextEvent + 685 (AppKit) [0x7fff96b83613]
                                      41 BlockUntilNextEventMatchingListInMode + 62 (HIToolbox) [0x7fff990e1cd3]
                                        41 ReceiveNextEventCommon + 356 (HIToolbox) [0x7fff990e1e42]
                                          41 RunCurrentEventLoopInMode + 209 (HIToolbox) [0x7fff990e20a4]
                                              39 __CFRunLoopRun + 1078 (CoreFoundation) [0x7fff97d2eee6]
                                                39 __CFRunLoopServiceMachPort + 195 (CoreFoundation) [0x7fff97d29803]
                                                  39 mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
                                                   *39 ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                                              2  __CFRunLoopRun + 1775 (CoreFoundation) [0x7fff97d2f19f]
                                                2  __CFRunLoopDoSource1 + 153 (CoreFoundation) [0x7fff97cfc019]
                                                  2  __CFRUNLOOP_IS_CALLING_OUT_TO_A_SOURCE1_PERFORM_FUNCTION__ + 41 (CoreFoundation) [0x7fff97cfc2d9]
                                                    2  __CFMachPortPerform + 288 (CoreFoundation) [0x7fff97cfc410]
                                                      2  PullEventsFromWindowServerOnConnection(unsigned int, unsigned char) + 71 (HIToolbox) [0x7fff990e87d7]
                                                        2  CGEventCreateNextEvent + 31 (CoreGraphics) [0x7fff92170904]
                                                          2  CGSGetNextEventRecordInternal + 122 (CoreGraphics) [0x7fff921709c7]
                                                            2  snarf_events + 184 (CoreGraphics) [0x7fff92170b8b]
                                                              2  _CGSGetPortStreamInline + 99 (CoreGraphics) [0x7fff92170d2e]
        2  mach_msg_trap + 10 (libsystem_kernel.dylib) [0x7fff8ffd7686]
        *2  ipc_mqueue_receive_continue + 0 (mach_kernel) [0xffffff8000213030]
                            Thread 0x1237     DispatchQueue 2          priority 48
                            Thread 0x136f     priority 46
                                  41 +[_NSSocket _runIOThread] + 77 (CoreMessage) [0x7fff92daa167]
                                    41 -[NSRunLoop(NSRunLoop) run] + 74 (Foundation) [0x7fff9007018a]
                                      41 -[NSRunLoop(NSRunLoop) runMode:beforeDate:] + 268 (Foundation) [0x7fff900d789e]
                            Thread 0x1377     priority 46
                            Thread 0x1393     priority 62
                                  41 +[NSURLConnection(Loader) _resourceLoadLoop:] + 356 (Foundation) [0x7fff90074586]
                            Thread 0x13cf     priority 46
                                41 WTF::wtfThreadEntryPoint(void*) + 15 (JavaScriptCore) [0x7fff99a6d36f]
                                  41 JSC::BlockAllocator::blockFreeingThreadMain() + 90 (JavaScriptCore) [0x7fff99a57d0a]
                                    41 WTF::ThreadCondition::timedWait(WTF::Mutex&, double) + 118 (JavaScriptCore) [0x7fff99835d96]
                            Thread 0x13d0     priority 46
                                  41 JSC::MarkStackThreadSharedData::markingThreadMain() + 214 (JavaScriptCore) [0x7fff999ba606]
                                    41 JSC::SlotVisitor::drainFromShared(JSC::SlotVisitor::SharedDrainMode) + 212 (JavaScriptCore) [0x7fff999ba724]
                            Thread 0x13d1     priority 46
                            Thread 0x13d2     priority 46
                            Thread 0x4be7     priority 62
                                41 thread_fun + 25 (QuartzCore) [0x7fff930b4e76]
                                  41 CA::Render::Server::server_thread(void*) + 403 (QuartzCore) [0x7fff9303035b]
                            Thread 0x7240b    priority 48
                            28 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              28 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                28 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *28 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x7240f    priority 48
                            27 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              27 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                27 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *27 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x72505    priority 48
                            13 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              13 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                13 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *13 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x7250a    priority 48
                            Binary Images:
                                   0x10ab45000 -        0x10aee4fff  com.apple.mail 6.1 (1498) <AEF8CE03-7543-3379-8993-157A5F6214E1> /Applications/Mail.app/Contents/MacOS/Mail
                                0x7fff9210c000 -     0x7fff92a9cc67  com.apple.CoreGraphics 1.600.0 <DCC70C6E-AB6D-3457-A823-7569CB29B107> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
                                0x7fff92da7000 -     0x7fff92e5fff7  com.apple.CoreMessage 1.0 (1498) <3E2D1B0C-D0D5-3097-AD70-D9EA978D6E9C> /System/Library/PrivateFrameworks/CoreMessage.framework/Versions/A/CoreMessage
                                0x7fff92f73000 -     0x7fff93121fff  com.apple.QuartzCore 1.8 (304.0) <BDC66714-F60C-386D-A773-F897D1E87AB6> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
                                0x7fff96a2e000 -     0x7fff9765bff7  com.apple.AppKit 6.8 (1187.34) <1FF64844-EB62-3F96-AED7-6525B7CCEC23> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
                                0x7fff99082000 -     0x7fff993b2ff7  com.apple.HIToolbox 2.0 <317F75F7-4B0F-35F5-89A7-F20BA60AC944> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
                                0x7fff9982f000 -     0x7fff99ac9ff7  com.apple.JavaScriptCore 8536 (8536.26.7) <ADAD1276-675A-3000-B746-560A2EB596A2> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
                          Process:         mDNSResponder [36]
                          Path:            /usr/sbin/mDNSResponder
                          Parent:          launchd [1]
                          UID:             65
                          Sudden Term:     Clean
                          Task size:       1069 pages
                            Thread 0x17c      DispatchQueue 1          priority 31
                            41 start + 52 (mDNSResponder) [0x102889920]
                              41 main + 3362 (mDNSResponder) [0x102856e14]
                            Thread 0x220      DispatchQueue 2          priority 33
                            Thread 0x377      priority 31
                            Thread 0x72407    priority 33
                            Thread 0x72412    priority 33
                            Thread 0x724fe    priority 33
                            Thread 0x72500    priority 33
                            Binary Images:
                                   0x102855000 -        0x1028e4fff  mDNSResponder <94425E3C-0029-3A3F-B147-7504EE1E9FF1> /usr/sbin/mDNSResponder
                          Process:         mds [35]
                          Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       98250 pages (+5)
                          CPU Time:        0.006s
                            Thread 0x17b      DispatchQueue 1          priority 31
                              41 ??? (mds + 59988) [0x102779a54]
                            Thread 0x325      DispatchQueue 2          priority 33
                            Thread 0x1f032    DispatchQueue 1531       priority 0
                            41 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              41 _pthread_wqthread + 404 (libsystem_c.dylib) [0x7fff98bd3cab]
                                41 _dispatch_worker_thread2 + 249 (libdispatch.dylib) [0x7fff9315e1c3]
                                  41 _dispatch_queue_invoke + 52 (libdispatch.dylib) [0x7fff9315e2f1]
                                    41 _dispatch_queue_drain + 180 (libdispatch.dylib) [0x7fff9315e448]
                                              41 _dispatch_client_callout + 8 (libdispatch.dylib) [0x7fff9315d0b6]
                                                41 work_fun + 662 (SpotlightIndex) [0x10291d691]
                                                  41 runLoop + 51 (SpotlightIndex) [0x1028f5063]
                                                    41 si_index_inactive + 455 (SpotlightIndex) [0x10290490d]
                                                      41 close + 10 (libsystem_kernel.dylib) [0x7fff8ffd98b6]
                                                           *41 close_nocancel + 160 (mach_kernel) [0xffffff800054af60]
                                                             *41 ??? (mach_kernel + 3443567) [0xffffff8000548b6f]
                                                               *41 closef_locked + 316 (mach_kernel) [0xffffff800054c56c]
        *41 ??? (mach_kernel + 1082959) [0xffffff800030864f]
        *41 vnode_put + 25 (mach_kernel) [0xffffff80002ee949]
        *41 vnode_put_locked + 103 (mach_kernel) [0xffffff80002f2057]
        *41 VNOP_INACTIVE + 50 (mach_kernel) [0xffffff8000313432]
        *41 hfs_vnop_inactive + 240 (mach_kernel) [0xffffff80004efb00]
        *41 ??? (mach_kernel + 3079479) [0xffffff80004efd37]
        *41 hfs_filedone + 170 (mach_kernel) [0xffffff80004f037a]
        *41 ??? (mach_kernel + 928085) [0xffffff80002e2955]
        *41 VNOP_BLOCKMAP + 129 (mach_kernel) [0xffffff8000313a01]
        *41 hfs_vnop_blockmap + 405 (mach_kernel) [0xffffff80004fd8e5]
        *41 hfs_start_transaction + 163 (mach_kernel) [0xffffff80005105d3]
        *41 journal_start_transaction + 392 (mach_kernel) [0xffffff8000317888]
        *41 lck_mtx_lock + 653 (mach_kernel) [0xffffff80002acdcd]
        *41 lck_mtx_lock_wait_x86 + 391 (mach_kernel) [0xffffff80002b1917]
                            Thread 0x1ea21    DispatchQueue 1539       priority 0
                                                    41 setAttributes + 3482 (SpotlightIndex) [0x10290943b]
                                                      41 __syscall + 10 (libsystem_kernel.dylib) [0x7fff8ffd95de]
                                                           *41 ??? (mach_kernel + 1068624) [0xffffff8000304e50]
                                                             *41 build_path + 1416 (mach_kernel) [0xffffff80002dfa78]
                                                               *41 vnode_authorize + 91 (mach_kernel) [0xffffff80002f54cb]
        *41 kauth_authorize_action + 90 (mach_kernel) [0xffffff8000540d3a]
        *41 ??? (mach_kernel + 1001500) [0xffffff80002f481c]
        *41 vnode_getattr + 240 (mach_kernel) [0xffffff80003106f0]
        *41 ??? (mach_kernel + 1117133) [0xffffff8000310bcd]
        *41 vn_getxattr + 353 (mach_kernel) [0xffffff8000309fe1]
        *41 VNOP_GETXATTR + 63 (mach_kernel) [0xffffff80003137df]
        *41 hfs_vnop_getxattr + 874 (mach_kernel) [0xffffff800051936a]
        *41 hfs_getxattr_internal + 466 (mach_kernel) [0xffffff8000519582]
        *41 hfs_systemfile_lock + 143 (mach_kernel) [0xffffff800051019f]
                            Thread 0x346      priority 50
                            Thread 0x72045    priority <multiple>
                              41 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                41 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *41 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x7213d    priority 31         cpu time   0.001s
                            Thread 0x721be    priority 0
                            Thread 0x7226c    priority <multiple> cpu time   0.004s
                            Thread 0x7226d    priority <multiple> cpu time   0.001s
                            Thread 0x722e0    priority <multiple>
                            Binary Images:
                                   0x10276b000 -        0x10288aff7  mds <1448C11E-D2EC-305E-88C9-C6DAF1FEB535> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Support/m ds
                                   0x1028dd000 -        0x102aacfff  com.apple.spotlight.index 10.7.0 (707.3) <DB706194-BC57-3853-9993-95DC58D3A07C> /System/Library/PrivateFrameworks/SpotlightIndex.framework/Versions/A/SpotlightIndex
                          Process:         mdworker [2330]
                          Path:            /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       11058 pages
                          CPU Time:        0.002s
                          Note:            Self-throttled
                            Thread 0x6dfa1    DispatchQueue 1          priority 0
                              41 ??? (mdworker + 35753) [0x106f8dba9]
                            Thread 0x6dfa4    DispatchQueue 2          priority 4
                            Thread 0x6dfad    priority 4          cpu time   0.002s
                                41 ??? (mdworker + 47970) [0x106f90b62]
                                  41 ??? (mdworker + 50378) [0x106f914ca]
                            Thread 0x6dfae    priority 4
                                41 ??? (mdworker + 118265) [0x106fa1df9]
                            Thread 0x72393    priority 4
                            Binary Images:
                                   0x106f85000 -        0x106fdeff7  mdworker <105316D8-F5DF-3079-96EF-0EF0986EB053> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
                          Process:         mdworker [2765]
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       1438 pages
                            Thread 0x71e59    DispatchQueue 1          priority 0
                              41 ??? (mdworker + 35753) [0x100b4fba9]
                            Thread 0x71e5a    DispatchQueue 2          priority 4
                            Thread 0x71e5e    priority 4
                                41 ??? (mdworker + 47970) [0x100b52b62]
                                  41 ??? (mdworker + 50378) [0x100b534ca]
                            Binary Images:
                                   0x100b47000 -        0x100ba0ff7  mdworker <105316D8-F5DF-3079-96EF-0EF0986EB053> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
                          Process:         mdworker [2766]
                          Parent:          launchd [346]
                          UID:             89
                          Sudden Term:     Clean
                          Task size:       2116 pages (+142)
                          CPU Time:        0.027s
                            Thread 0x71e5f    DispatchQueue 1          priority 0
                              41 ??? (mdworker + 35753) [0x106240ba9]
                            Thread 0x71e60    DispatchQueue 2          priority 4
                            Thread 0x71e67    priority 4          cpu time   0.027s
                                41 ??? (mdworker + 47970) [0x106243b62]
                                  41 ??? (mdworker + 50378) [0x1062444ca]
                            Binary Images:
                                   0x106238000 -        0x106291ff7  mdworker <105316D8-F5DF-3079-96EF-0EF0986EB053> /System/Library/Frameworks/CoreServices.framework/Frameworks/Metadata.framework/Versions/ A/Support/mdworker
                          Process:         MicrosoftMouseHelper [259]
                          Path:            /Library/PreferencePanes/Microsoft Mouse.prefPane/Contents/Resources/MicrosoftMouseHelper.app/Contents/MacOS/MicrosoftMouseH elper
                          UID:             501
                          Task size:       1678 pages
                          CPU Time:        0.001s
                          Process:         netbiosd [90]
                          Path:            /usr/sbin/netbiosd
                          Parent:          launchd [1]
                          UID:             222
                          Sudden Term:     Clean
                          Task size:       733 pages (+3)
                            Thread 0x396      DispatchQueue 2          priority 4
                            Thread 0x397      DispatchQueue 7          priority 4
                            Thread 0x724f9    priority 4
                            15 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              15 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                15 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *15 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x1005f9000 -        0x10064aff7  netbiosd <7B46D5AD-B51A-3F27-8E1E-C0B1BD6926C1> /usr/sbin/netbiosd
                          Process:         netsession_mac [243]
                          Path:            /Users/USER/*/netsession_mac
                          Architecture:    i386
                          UID:             501
                          Task size:       3501 pages
                          CPU Time:        0.002s
                          Process:         NetworkBrowserAgent [253]
                          Path:            /System/Library/CoreServices/NetworkBrowserAgent
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       770 pages
                            Thread 0x6ea      DispatchQueue 1          priority 31
                              41 main + 120 (NetworkBrowserAgent) [0x10115d869]
                            Thread 0x6f6      DispatchQueue 2          priority 33
                            Thread 0x71c      priority 31
                            Binary Images:
                                   0x10112d000 -        0x101175ff7  NetworkBrowserAgent <E593F29F-3D39-3431-A38E-86F6906DE2CB> /System/Library/CoreServices/NetworkBrowserAgent
                          Process:         networkd [109]
                          Path:            /usr/libexec/networkd
                          Parent:          launchd [1]
                          UID:             24
                          Sudden Term:     Dirty (allows idle exit)
                          Task size:       352 pages (-7)
                            Thread 0x3a7      DispatchQueue 2          priority 33
                            Thread 0x3aa      DispatchQueue 7          priority 31
                            Thread 0x723bd    priority 31
                            Thread 0x723be    priority 31
                            35 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              35 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                35 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *35 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Thread 0x723bf    priority 31
                            34 start_wqthread + 13 (libsystem_c.dylib) [0x7fff98bbe171]
                              34 _pthread_wqthread + 412 (libsystem_c.dylib) [0x7fff98bd3cb3]
                                34 __workq_kernreturn + 10 (libsystem_kernel.dylib) [0x7fff8ffd96d6]
                                 *34 ??? (mach_kernel + 3911280) [0xffffff80005bae70]
                            Binary Images:
                                   0x1071ee000 -        0x1071f4ff7  networkd <5612B489-6A6B-39A2-9AAC-834F5409D9CA> /usr/libexec/networkd
                          Process:         NotificationCenter [227]
                          Path:            /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
                          UID:             501
                          Task size:       4080 pages
                            Thread 0x64d      DispatchQueue 1          priority 31
                              41 ??? (NotificationCenter + 6112) [0x10ad787e0]
                            Thread 0x6aa      DispatchQueue 2          priority 33
                            Thread 0x751      priority 38
                                41 startIOThread(void*) + 148 (CoreVideo) [0x7fff92ce7013]
                                  41 CVDisplayLink::runIOThread() + 680 (CoreVideo) [0x7fff92ce72d4]
                            Binary Images:
                                   0x10ad77000 -        0x10adb7fff  com.apple.notificationcenterui 1.0 (111.4) <2DC861FD-01E7-361B-BC61-E0B26F799AE3> /System/Library/CoreServices/NotificationCenter.app/Contents/MacOS/NotificationCenter
                                0x7fff92ce5000 -     0x7fff92d0fff7  com.apple.CoreVideo 1.8 (99.3) <C424838A-889C-39E5-8108-FD05C93D26A0> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
                          Process:         notifyd [15]
                          Path:            /usr/sbin/notifyd
                          Architecture:    unknown
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       525 pages
                          CPU Time:        0.001s
                            Thread 0x15e      DispatchQueue 2          priority 33
                            41 ??? [0x7fff9315f9ee]
                              41 ??? [0x7fff8ffd9d16]
                            Thread 0x15f      DispatchQueue 7          priority 31
                            41 ??? [0x7fff9315cd85]
                              41 ??? [0x7fff8ffd9566]
                            Thread 0x7219c    priority 31         cpu time   0.001s
                            41 ??? [0x7fff98bbe171]
                              41 ??? [0x7fff98bd3cb3]
                                41 ??? [0x7fff8ffd96d6]
                            Thread 0x723fd    priority 31
                            Thread 0x723fe    priority 31
                            Binary Images:
                          Process:         ntpd [114]
                          Path:            /usr/sbin/ntpd
                          Parent:          launchd [1]
                          UID:             0
                          Task size:       367 pages
                            Thread 0x3e1      DispatchQueue 1          priority 31
                              41 ??? (ntpd + 143653) [0x10626a125]
                                41 ??? (ntpd + 144853) [0x10626a5d5]
                                  41 __sigsuspend + 10 (libsystem_kernel.dylib) [0x7fff8ffd9552]
                            Thread 0x89f      DispatchQueue 2          priority 33
                            Binary Images:
                                   0x106247000 -        0x10629dff7  ntpd <620BA025-EBF8-3704-8229-A17D4B371F9F> /usr/sbin/ntpd
                          Process:         ocspd [160]
                          Path:            /usr/sbin/ocspd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       1804 pages
                            Thread 0x51a      DispatchQueue 1          priority 31
                              41 ??? (ocspd + 17983) [0x1053bc63f]
                                41 ??? (ocspd + 58188) [0x1053c634c]
                                  41 ??? (ocspd + 58845) [0x1053c65dd]
                            Thread 0x6e8      DispatchQueue 2          priority 33
                            Thread 0x6ee      priority 31
                            Thread 0x71d52    priority 31
                                41 ??? (ocspd + 63859) [0x1053c7973]
                                  41 ??? (ocspd + 60287) [0x1053c6b7f]
                            Binary Images:
                                   0x1053b8000 -        0x1053d5ff7  ocspd <92D8A30F-DB72-37D3-94FE-C941A6206397> /usr/sbin/ocspd
                          Process:         opendirectoryd [32]
                          Path:            /usr/libexec/opendirectoryd
                          Parent:          launchd [1]
                          UID:             0
                          Sudden Term:     Clean
                          Task size:       2907 pages (-3)
                            Thread 0x1ba      DispatchQueue 2          priority 33
                            Thread 0x1bb      DispatchQueue 6          priority 31
                                41 _dispatch_worker_thread2 + 304 (libdispatch.dylib) [0x7fff9315e1fa]
                                    41 _dispatch_call_block_and_release + 15 (libdispatch.dylib) [0x7fff93160f01]
                                      41 __systemcache_mig_initialize_block_invoke_0 + 39 (SystemCache) [0x108da16cb]
                                        41 mach_msg_server + 289 (libsystem_kernel.dylib) [0x7fff8ffd7405]
                            Thread 0x1c1      DispatchQueue 6          priority 31
                                      41 ??? (opendirectoryd + 110174) [0x1087f9e5e]
                                        41 sleep + 61 (libsystem_c.dylib) [0x7fff98c5b68a]
                                          41 __semwait_signal + 10 (libsystem_kernel.dylib) [0x7fff8ffd9386]
                                           *41 semaphore_wait_continue + 0 (mach_kernel) [0xffffff8000233ec0]
                            Thread 0x1d8      DispatchQueue 6          priority 31
                                      41 __systemcache_mig_initialize_block_invoke_026 + 39 (SystemCache) [0x108da17a5]
                            Thread 0x1be      DispatchQueue 7          priority 31
                            Thread 0x202      DispatchQueue 364        priority 31
                                    41 _dispatch_async_f_redirect_invoke + 117 (libdispatch.dylib) [0x7fff93162317]
                            Thread 0x72217    priority 31
                            Thread 0x72330    priority 31
                            Thread 0x723b6    priority 31
                            Thread 0x723b7    priority 31
                            Thread 0x723b8    priority 31
                            Binary Images:
                                   0x1087df000 -        0x108840fff  opendirectoryd <E76065E0-8023-3CE8-AE52-D34623A94D22> /usr/libexec/opendirectoryd
                                   0x108d82000 -        0x108db2fff  com.apple.opendirectoryd.module.SystemCache 10.8 (197.14.6) <42594DFB-FCF9-3D6C-B6D1-CC4912D7A3E7> /System/Library/OpenDirectory/Modules/SystemCache.bundle/Contents/MacOS/SystemCache
                          Process:         pboard [220]
                          Path:            /usr/sbin/pboard
                          UID:             501
                          Sudden Term:     Clean
                          Task size:       214 pages
                            Thread 0x62b      DispatchQueue 1          priority 31
                              41 ??? (pboard + 2225) [0x10ed498b1]
                                41 mach_msg_server + 552 (libsystem_kernel.dylib) [0x7fff8ffd750c]
                            Binary Images:
                                   0x10ed49000 -        0x10ed49ff7  pboard <6E03CB0C-E68D-354C-B04C-D8663887269C> /usr/sbin/pboard
                          Process:         pbs [308]
                          Path:            /System/Library/CoreServices/pbs
                          UID:             501
                          Sudden Term:     Clean (allows idle exit)
                          Task size:       1987 pages
                            Thread 0x90b      DispatchQueue 2          priority 33
                            Thread 0x90d      DispatchQueue 7          priority 31
                            Binary Images:
                                   0x108c40000 -        0x108c54fff  pbs <E2DF274A-B49F-383E-AF90-F87DDA6CA47D> /System/Library/CoreServices/pbs
                          Process:         PhotoStreamAgent [256]
                          Path:            /Applications/iPhoto.app/Contents/Library/LoginItems/PhotoStreamAgent.app/Contents/MacOS/ PhotoStreamAgent
                          UID:             501
                          Sudden Term:     Dirty
                          Task size:       4623 pages
                            Thread 0x6f9      DispatchQueue 1          priority 47
                            41 ??? (PhotoStreamAgent + 9092) [0x10ed35384]
                              41 ??? (PhotoStreamAgent + 9167) [0x10ed353cf]
