2 Replies Latest reply on Oct 1, 2012 8:22 PM by pwillener
    installing of Flash Player on Windows 7 !!!
    antonella Italy
      hello, this is the system final comment of above installation,
      to be submitted to Adobe:
      quote
      PLATFORM VERSION INFO
      Windows: 6.1.7601.65536 (Win32NT)
      Common Language Runtime: 4.0.30319.269
      System.Deployment.dll: 4.0.30319.1 (RTMRel.030319-0100)
      clr.dll: 4.0.30319.269 (RTMGDR.030319-2600)
      dfdll.dll: 4.0.30319.1 (RTMRel.030319-0100)
      dfshim.dll: 4.0.31106.0 (Main.031106-0000)
      ORIGINS
      Distribution URL: file :/ / / C :/ Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat
      ERROR SUMMARY
      The following is a summary of the errors. Detailed information about these errors are listed later in the log.
      * Activation of C: \ Users \ ANTON \ AppData \ Local \ Temp \ install_flashplayer11x32ax_gtba_chra_dy_aih.bat caused an exception. Were detected the following error messages:
      + Exception reading manifest from file :/ / / C :/ Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat: manifest is not valid or can not open the file.
      + Detected invalid data at the root level. Line 1, position 1.
      COMPONENT STORE TRANSACTION FAILURE SUMMARY
      No transaction error was detected.
      NOTICES
      No warnings during this operation.
      OPERATION PROGRESS STATUS
      * [01/10/2012 23:52:47]: Activation of C: \ Users \ ANTON \ AppData \ Local \ Temp \ install_flashplayer11x32ax_gtba_chra_dy_aih.bat started.
      ERROR DETAILS
      During the operation, the following errors were detected.
      * [01/10/2012 23:52:51] System.Deployment.Application.InvalidDeploymentException (ManifestParse)
      - Exception reading manifest from file :/ / / C :/ Users/ANTON/AppData/Local/Temp/install_flashplayer11x32ax_gtba_chra_dy_aih.bat: manifest is not valid or can not open the file.
      - Origin: System.Deployment
      - Stack Trace:
      in System.Deployment.Application.ManifestReader.FromDocument (String localPath, ManifestType manifestType, Uri SourceUri)
      in subStore, Uri & SourceUri, & tempfile tempfile, & SubscriptionState substate, IDownloadNotification notification, DownloadOptions options, ServerInformation & serverInformation)
      in System.Deployment.Application.DownloadManager.DownloadDeploymentManifestBypass (SubscriptionStore subStore, Uri & SourceUri, & tempfile tempfile, & SubscriptionState substate, IDownloadNotification notification, DownloadOptions options)
      in System.Deployment.Application.ApplicationActivator.PerformDeploymentActivation (activationUri Uri, Boolean IsShortcut, textualSubId String, String deploymentProviderUrlFromExtension, BrowserSettings browserSettings, String & errorPageUrl)
      in System.Deployment.Application.ApplicationActivator.ActivateDeploymentWorker (Object state)
      --- Inner Exception ---
      System.Xml.XmlException
      - Invalid data was detected at the root level. Line 1, position 1.
      - Source: System.Xml
      - Stack Trace:
      in System.Xml.XmlTextReaderImpl.Throw (String res, String arg)
      in System.Xml.XmlTextReaderImpl.ParseRootLevelWhitespace ()
      in System.Xml.XmlTextReaderImpl.ParseDocumentContent ()
      in System.Deployment.Application.ManifestValidatingReader.XmlFilteredReader.Read ()
      in System.Xml.XmlCharCheckingReader.Read ()
      in System.Xml.XsdValidatingReader.Read ()
      COMPONENT STORE TRANSACTION DETAILS
      No transaction information is available
      unquote
      please kindly comment and give related fix instructions, thanks and regards,
      Antonella
