2 Replies Latest reply on Oct 2, 2012 4:40 PM by thor2112
    Checking last character
    thor2112
      What would you consider being the best way to check the last character of a string?
      var folderPath = '~/Desktop/Test';
      if (folderPath[folderPath.length - 1] !== '/') { folderPath += '/'; }
        or
      if (folderPath.slice(-1) !== '/') { folderPath += '/'; }
      I see that changePath() can also be used to keep track of this path separator.
      Thanks.
        • 1. Re: Checking last character
          -hans- Level 4
          well,
          coercing class folder to string will never include the slash ...
          Folder('~/Desktop/test/').toString() + '/' //~/Desktop/test/
          Folder('~/Desktop/test').toString() + '/' //~/Desktop/test/
          How's the path created¿ why should you test it?
          • 2. Re: Checking last character
            thor2112 Level 1
            Hi Hans,
            I was trying to come up with a function to move a folder and it's contents, or a file... similar to how the OS X Finder would do it.  However, I just noticed when the files are copied over, they're not the same file size as the original which makes me think it's stripping resource forks, etc.  :-(
            I'm looking now at using doScript and running ditto from the command-line with applescript.  Here's the code I was working with earlier though:
            function moveItem(oldPath, newPath) {
                newPath = newPath.toString();
                //if (newPath[newPath.length - 1] !== '/') { newPath += '/'; }
                if (newPath.slice(-1) !== '/') { newPath += '/'; }
                var oldPathType = oldPath.constructor.name;
                if (oldPathType === 'Folder') {
                    newPath += (oldPath.name + '/');
                    with (Folder(newPath)) {
                        if (! exists) { create(); }
                    for each (var i in oldPath.getFiles()) {
                        if (i.constructor.name === 'Folder') {
                            moveItem(i, newPath);
                        } else {
                            i.copy(newPath + i.name);
                            i.remove();
                    oldPath.remove();
                } else if (oldPathType === 'File') {
                    oldPath.copy(newPath + oldPath.name);
                    oldPath.remove();
                } else {
                    throw 'Problem moving file/folder!';
