6 Replies Latest reply on Oct 7, 2012 11:22 PM by Steve_BDL
    Script required for styling
    Steve_BDL
      Hi All,
      I am currently type-setting a dictionary and need to character style the keyword used in the example which follows the definition. of the entry. Following is an example of such:
      bukkett (buk-kett) n.m.
      pl.s. bukketti
      Ħafna fjuri marbutin flimkien b’xi żigarella. • F’Jum l-Omm Toni xtara bukkett fjuri lil ommu.
      Line 1: Paragraph style: Headwords using a nested style to give a character style (Headword) to the first word
      Line 2: Paragraph style: terms
      Line 3: Definition followed by example, seperated by a space, bullet and non-breaking space. Paragraph style: Text entry with a grep style styling the example with a character style (keyowrd in example).
      The above is all done.
      I need a script to find in the example the preceeding entry styled as Headword (in this case bukkett). I am very poor in Javascript and VBscript.
      I hope I was clear enough. If required I can make available for download a sample of the document including the current styles I'm using.
      Thank in advance
      Stephen
        • 1. Re: Script required for styling
          Please do. It's ever so easy to find out with *actual* data. What version of InDesign are you using, by the way?
          • 3. Re: Script required for styling
            -hans- Level 4
            was grumbling for a clever solution, but didn't find one ;-)
            No errorhandling applied ...
            var allStories =  myDoc.stories;
            s = allStories.length;
            for(var i = 0; i < s;i ++){
            currStory =     allStories[i];
            var storyParagraphs = currStory.paragraphs;
            p = storyParagraphs.length;
            for(var j = 0; j < p;j++){
            var currPara = storyParagraphs[j];
            var paraName = currPara.appliedParagraphStyle.name
            switch(paraName){
            case  'Headwords'  :
            app.findTextPreferences = NothingEnum.nothing;
            app.findTextPreferences.appliedCharacterStyle = 'Headword';
            var Res = currPara.findText();
            var resCont = Res[0].texts[0].contents; break;
            case 'Text entry' :
            app.changeTextPreferences = NothingEnum.nothing;
            app.findTextPreferences.findWhat = resCont;
            app.changeTextPreferences.appliedCharacterStyle = 'keyword in example';
            currPara.changeText(); break;
            default : break;
            Hans-Gerd Claßen
            • 4. Re: Script required for styling
              Steve_BDL Level 1
              Many thanks for your script.
              I have re-uploaded the file here, this time in idml format.
              http://www.bdlbooks.com/files/Dictionary_sample.idml
              I need to trim the findText from spaces for it to work better.
              • 5. Re: Script required for styling
                -hans- Level 4
                your nested style in Headwords = 'headword over 1 words' includes the space behind the first word. Guess it should be till 1 words.
                As I work on a German version it's called 'über' und 'bis'
                Hans-Gerd Claßen
                • 6. Re: Script required for styling
                  Steve_BDL Level 1
                  Thank you to all of you who helped me out in this. Really impressed with the high qaulity assistance available. It took quite a while to complete, over 4 hours, then I left and let the computer on. I'm here today and everything looks good.
                  This saved me alot of manual formatting.
                  Thank you once more.
                  Regards
                  Stephen
