1 Reply Latest reply on Oct 10, 2012 4:18 AM by Timothy Brand-Spencer
    Multipart/form-data using HTTPService, sending a binary file and some text in the same request.
    arifali_007
      Hi There,
               I am new to FLEX and also new to writing a client for a web service.
      My question is more about flex (Flash builder 4.5) APIs, what APIs to use.
      I want to access a web service, that's published here.
      https://build.phonegap.com/docs/write_api
      here is the description of webservice
      1) I have to do a post on POST https://build.phonegap.com/api/v1/apps
      2) content type has to be "multipart/form-data"
      3) JSON bodies of requests are expected to have the name 'data'
        data will be someting like this
      'data={"title":"API V1 App","package":"com.alunny.apiv1","version":"0.1.0","create_method":"file"}'
      4) include a zip file in the multipart body of your post, with the parameter name 'file'.
      I want to make a 'multipart/form-data' Post and send
      one string and one zip file.
      My first question to self was If i send both string + binary data in the body ...
      how will server understand where string end and where zip file starts?
      Then read on W3.org( http://www.w3.org/TR/html401/interact/forms.html#h-17.13.4.2 )
      How is text + binary data can be sent through "multipart/form-data" post requst.
      there has to be some boundries.
      After this I read and example in flex and  tried following it.
      http://codeio.wordpress.com/2010/04/03/5-minutes-on-adobe-flex-mimic-file-upload-for-in-me mory-contents/
      but it doesn't seems to be working for me.
                          public function createNewApp(cb:Function , appFile : File):void
                                    var service:HTTPService = new HTTPService();
                                    service.url = ROOT+"apps";
                                    service.showBusyCursor = true;
                                    service.addEventListener(ResultEvent.RESULT, function(e:ResultEvent):void {
                                              //translate JSON
                                              trace(e.result);
                                              var result:String = e.result.toString();
                                              var data:Object = JSON.parse(result);
                                              cb(data.link);
                                    service.addEventListener(FaultEvent.FAULT, defaultFaultHandler); //todo : allow user to add his own as well
                                    authAndUploadNewApp(service,appFile);
                          private function authAndUploadNewApp(service:HTTPService,appFile : File):void {
                                    var encoder:Base64Encoder = new Base64Encoder();
                                    encoder.encode(username + ":"+password);
                                    service.headers = {Accept:"application/json", Authorization:"Basic " + encoder.toString()};
                                    service.method ="POST";
                                    var boundary:String = UIDUtil.createUID();
                                    service.contentType = "multipart/form-data; boundary=—————————" + boundary;
                                    var stream:FileStream = new FileStream();
                                    stream.open(appFile, FileMode.READ);
                                    var binaryData:ByteArray = new ByteArray();
                                    var fileData : String = new String();
                                    stream.readBytes(binaryData);
                                    stream.close();
                                    fileData = binaryData.readUTFBytes(binaryData.bytesAvailable); // I think this is where I have problem.... how do
                             //how do i converrt this bytearray/stream of data to string and send it in my post request's body - i guess if this step work rest should work..
                                    var params: String = new String();
                                    var content:String = "—————————" + boundary + "nr";
                                    content += 'Content-Disposition: form-data; name="data";' + '{"title":"ELS test app 2","package":"com.elsapp.captivate","version":"12.3.09","create_method":"file"}' + "nr";
                                    content += "—————————" + boundary + "nr";
                                    content += 'Content-Disposition: form-data; name="file";' + fileData  + "nr";
                                    content += "—————————–" + boundary + "–nr";
                                    service.request = content;
                                    service.send();
