2 Replies Latest reply on Oct 4, 2012 5:34 AM by TLL...
    Import CR xml into PS?
    TLL... Level 3
      Hello
      Can I import or otherwise interpret adjustments made in Camera Raw and saved as .xml and use them in Photoshop? The reason I need to use PS for the adjustment step is that the imagery I'm trying to correct contains more than RGB data. While a CR adjusted and exported image looks great the 4th alpha channel gets deleted in the process. In PS I apply the same settings created for the RGB channels to the 4th one. Camera Raw seems to provide a quicker way to even out color and the 'fill light' setting lightens without destroying highlights. In production I typically avoid using overly complicated correction processes and the CR/ xml seems like it might work.
