11 Replies Latest reply on Jul 17, 2013 2:02 PM by pixelnickel
    Premiere Pro CS6 freezes during loading
    Mikel24fps
      Having used thsi programm several times successfully all of the sudden since today, after a few seconds of loading process of Premiere Pro CS6, loading process always starts freezzing at loading stage : "loading ExporterQuickTimeHost.bundle" (Mac OS). Deinstallation and reinstallation didn't help.
      Can someone help me?
        • 1. Re: Premiere Pro CS6 freezes during loading
          Bruce Bullis Adobe Employee
          Did you change something in your sysetm (or QuickTime) configuration; new device, new video board, new codec?
          • 2. Re: Premiere Pro CS6 freezes during loading
            Mikel24fps Level 1
            No I didn't change anything. In the meantime i have uninstalled all items and reinstalled again. Same problem: It freezes at loading status "ExporterQuickTimeHost.bundle. I have to shut down manually the program.
            • 3. Re: Premiere Pro CS6 freezes during loading
              Mikel24fps Level 1
              The following is the crash report (extract) of Adobe Premiere Pro CS6. Maybe some of new has some system knowledge.
              Process:         Adobe Premiere Pro CS6
              Path:            /Applications/Adobe Premiere Pro CS6/Adobe Premiere Pro CS6.app/Contents/MacOS/Adobe Premiere Pro CS6
              Identifier:      com.adobe.AdobePremierePro
              Version:         6.0.0 (6.0.0)
              Code Type:       X86-64 (Native)
              Parent Process:  launchd
              Date/Time:       2012-10-03 22:54:32.002 +0200
              OS Version:      Mac OS X 10.6.8 (10K549)
              Report Version:  6
              Interval Since Last Report:          -6877 sec
              Per-App Interval Since Last Report:  457 sec
              Per-App Crashes Since Last Report:   3
              Anonymous UUID:                      C1440D44-6720-4316-9D5B-DA9C509698E4
              Exception Type:  EXC_BAD_ACCESS (SIGSEGV)
              Exception Codes: KERN_INVALID_ADDRESS at 0x0000000000000000
              Crashed Thread:  0  Dispatch queue: com.apple.main-thread
              Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
              0   com.adobe.premiere.frontend       0x000000010c6c8e38 FE::Application::AttemptPanicProjectSave() + 18
              1   com.adobe.premiere.frontend       0x000000010c7207cc UnixInterruptSignal(int) + 44
              2   libSystem.B.dylib                 0x00007fff83bf01ba _sigtramp + 26
              3   libSystem.B.dylib                 0x00007fff83b8fdc2 semaphore_wait_signal_trap + 10
              4   libSystem.B.dylib                 0x00007fff83b9540d pthread_mutex_lock + 469
              5   com.adobe.QT32Client.framework    0x000000010d0895d6 ASL::SingletonSupport<ASL::InterfaceRef<QT32Client::QT32Client, QT32Client::IQT32Client> >::CreateClassRef() + 54
              6   com.adobe.QT32Client.framework    0x000000010d05f747 QT32Client::Create() + 23
              7   ...rterQuickTimeHost.framework    0x0000000133e1b01e ExporterQuickTimeHost::OnStartup(exportStdParms, exExporterInfoRec) + 28
              8   ...rterQuickTimeHost.framework    0x0000000133e1e6fe PrExporterModule::ExportEntry(int, exportStdParms, void, void*) + 68
              9   ...rterQuickTimeHost.framework    0x0000000133e1e4e1 xSDKExport + 81
              10  ...dobe.ExporterHost.framework    0x00000001047f71b3 ML::CallExporterModuleGuarded(int ()(int, exportStdParms, void, void), int, exportStdParms, void, void*, std::basic_string const&) + 131
              11  ...dobe.ExporterHost.framework    0x00000001047f7483 ML::ExporterPluginModule::CallExportModule(int, void, void) + 405
              12  ...dobe.ExporterHost.framework    0x00000001047f6fe3 ML::ExporterPluginModule::StartupFromDisk(unsigned int, bool) + 353
              13  ...dobe.ExporterHost.framework    0x00000001047c162c ML::ExporterModuleFactory::CreateUnknown(ASL::InterfaceRef&) + 308
              • 4. Re: Premiere Pro CS6 freezes during loading
                That helps!
                During OnStartup(), the QuickTime exporter enumerates the available video and audio codecs on the system.
                One of them is hanging.
                • 5. Re: Premiere Pro CS6 freezes during loading
                  Mikel24fps Level 1
                  But what do I have to do?
                  • 6. Re: Premiere Pro CS6 freezes during loading
                    Remove codecs until PPro launches successfully. Then put back the other codecs.
                    This may help:
                    http://aeroquartet.com/movierepair/quicktime-codecs-install
                    • 7. Re: Premiere Pro CS6 freezes during loading
                      Mikel24fps Level 1
                      I don't know what happened but for some reasons my Premiere Pro now works. Ok I deleted some files but anyways thanks to all who tried to help me
                      • 8. Re: Premiere Pro CS6 freezes during loading
                        Rallymax-forum Level 3
                        glad you worked it out.
                        this
                        that stack trace showed that while ExporterQuickTimeHost.prm was loading it tried to make a C++ class for each QuickTime codec it could find and failed to get memory for it (thus the 0x0 access violation).
                        Looks like you had a wobby system and it finally righted itself. Do you overclock your ram? I'm assuming since it's Mac you do not since it's hard to do.
                        • 9. Re: Premiere Pro CS6 freezes during loading
                          tententwenty
                          Hey folks, I tried doing all this stuff, but a closer look at my stack indicated that I needed to kill my QT32Server process, which I did by going to Activity Monitor & simply stopping the process from there. Starting up premiere restarted that process and now all is working. Thank goodness!
                          • 10. Re: Premiere Pro CS6 freezes during loading
                            the_wine_snob Level 9
                            Great news, and thank you for reporting your steps to get things running.
                            • 11. Re: Premiere Pro CS6 freezes during loading
                              pixelnickel Level 1
                              Did as tententwenty said.
                              As Premiere was hanging on ExporterQuickTimeHost.bundle, I killed the QT32Server process in Activity Monitor.
                              Premiere proceeded with launch.
