8 Replies Latest reply on Oct 5, 2012 7:40 AM by CarlosCanto
    Create a rectangle around object?
    martin_Cahill
      Can this be done in illustrator scripting??
      http://coreldraw.com/forums/t/35280.aspx
      creating a rectangle around selected object or objects and set margins...
      Regards
      Martin
        • 1. Re: Create a rectangle around object?
          CarlosCanto Adobe Community Professional & MVP
          yes, it can be done
          • 2. Re: Create a rectangle around object?
            martin_Cahill Level 1
            Great news.
            I have this script that does what I want, it draws the rectangle around the obect with a distance margin of 0.05cm then groups the objects togeather.
            can you help me to convert this script to work in illustrator?
            this works in coral draw its VBA
            Sub makeRect()
                Dim s As Shape, sRect As Shape
                Dim x As Double, y#, h#, w#
                Dim dMarg#
                Dim sr As New ShapeRange
                dMarg = 0.05
                ActiveDocument.Unit = cdrCentimeter
                Set s = ActiveShape
                If s Is Nothing Then Exit Sub
                s.GetBoundingBox x, y, w, h
                Set sRect = ActiveLayer.CreateRectangle2(x - dMarg, y - dMarg, w + (dMarg * 2), h + (dMarg * 2))
                sRect.Outline.Width = 0.001
                sRect.CreateSelection
                sr.Add sRect
                sr.Add s
                sr.Group
            End Sub
            • 3. Re: Create a rectangle around object?
              pixxxel schubser MVP & Adobe Community Professional
              Hallo martin_Cahill,
              My English is not the best, because of that in German.
              Grundsätzlich sind sich VBA und Javascript sehr ähnlich. Versuche die folgende Funktion mit den VBA-Äquivalenten zu vergleichen. Learning by doing
              function makeRect() {
              if (selection.length == 0) {
                  alert("Kein Objekt …");
                  return;
              }else{
                  if (selection.length > 1) {
                      alert("Zu viele Objekte …");
                      return;
                  }else{
                      var Sel = myDoc.selection
                      var SelVB = Sel[0].visibleBounds;
                      var dMarg = 28.3464567;
                      var Links = SelVB[0];
                      var Oben = SelVB[1];
                      var SelBreite = (SelVB[2] - SelVB[0]);
                      var SelHoehe = (SelVB[1] - SelVB[3]);
                      var newCMYK = new CMYKColor();
                      newCMYK.cyan = 100;
                      newCMYK.magenta = 0;
                      newCMYK.yellow = 0;
                      newCMYK.black = 0;
                      var myGroup =myDoc.groupItems.add();
                      Sel[0].move(myGroup, ElementPlacement.PLACEATBEGINNING);
                      var MargBox = myDoc.pathItems.rectangle(Oben+dMarg, Links-dMarg, SelBreite+2*dMarg, SelHoehe+2*dMarg);
                      MargBox.stroked = true;
                      MargBox.strokeWidth = 10;
                      //MargBox.filled = false;
                      MargBox.fillColor = newCMYK;
                      MargBox.move(myGroup, ElementPlacement.PLACEATEND);
              Hilft dir das weiter?
              Viel Spass noch.
              • 4. Re: Create a rectangle around object?
                Hallo Vielen Dank für die Hilfe
                I have copied the code into a text file and saved it as .jsx in the preset folder of illustrator
                I run the script no errors but nothing happens??
                Martin
                • 5. Re: Create a rectangle around object?
                  Add this at as the very first line:
                  makeRect() ;
                  -- schubser defined a new function but forgot to call it
                  • 6. Re: Create a rectangle around object?
                    yes it works!
                    Only thing last thin I would  like no fill colour atall?
                    I have comented MargBox.fillColor = newCMYK; but didnt work
                    Regards
                    Martin
                    • 7. Re: Create a rectangle around object?
                      Ive fixed it now!
                      Thanks everyone for the help great forum!
                      thanks pixxxel schubser great job!!
                      Martin
                      • 8. Re: Create a rectangle around object?
                        please get into the habit of marking your posts as "Answered" if you get satisfactory answers.
                        thanks
