SWF Loader with variable loading?
nikolaig Oct 3, 2012 1:08 PMI have my flash website composed from different labeled sections.
One section (A) has SWF loader inside which different SWF's can be loaded depending on what image is clicked from a thumbnail image scroller.
Here is the code for it:
var xmlLoader:XMLLoader = new XMLLoader("loadingAssets/appThumbnails/slideshow_image scroller greenSock_mine/assets/data.xml", {onComplete:_xmlCompleteHandler});
xmlLoader.load();
function _xmlCompleteHandler(event:LoaderEvent):void {
_slides = [];
var xml:XML = event.target.content; //the XMLLoader's "content" is the XML that was loaded.
var imageList:XMLList = xml.image; //In the XML, we have <image /> nodes with all the info we need.
//loop through each <image /> node and create a Slide object for each.
for each (var image:XML in imageList) {
_slides.push( new Slide(image.@name,
image.@description,
new ImageLoader("loadingAssets/appThumbnails/slideshow_image scroller greenSock_mine/assets/thumbnails/appThmb_imgs/" + image.@name + ".jpg",
name:image.@na me + "Thumb",
width:_THUMB_W IDTH,
height:_THUMB_ HEIGHT,
//centerRegist ration:true,
//x:260, y:320,//doesn't work here but works in line 69
scaleMode:"pro portionalInside",
bgColor:0x0000 00,
estimatedBytes :13000,
onFail:_imageF ailHandler}),
new SWFLoader("loadingAssets/appThumbnails/slideshow_image scroller greenSock_mine/assets/images/" + image.@name + ".swf",
name:image.@name + "Image",
width:_IMAGE_WIDTH,
height:_IMAGE_HEIGHT,
//centerRegistration:true,
x:-420, y:-260,
scaleMode:"proportionalInside",
bgColor:0x000000,
estimatedBytes:820000,
onFail:_imageFailHandler})
Is it possible to call up a specific SWF inside this SWFLoader from another section (B)
For now all I can do is to make a link and bring a user to section (A) which always opens with the default (first in order) SWF.
I want to have a number of image buttons in section (B) and each button would open a different SWF inside SWF loader in section (A)
Is it possible to resolve?
the code above also can be viewed at http://pastebin.com/JHNWvS6q
