2 Replies Latest reply on Oct 5, 2012 2:36 AM by subtlefly72
    How can I get a loading animation to play while fly playback component loads a file?
    subtlefly72 Level 1
      Hi team,
      Two part question here..
      So I have a FLV playback component and a number of .flv files that it loads   ------>  using video1.source="film/whatever.flv";
      There is a slight delay while the file loads and so I would like to
      A) make this pause a bit longer (it would be so fast at the moment that any loading animation would be subliminal, but with nothing at all you get a second of blank which is not good either- so if I can get it to be a bit longer, like say 2 seconds..
      B) have an animation play while this happens..
      It does not need to show progress or anything, just like a spinning wheel or whatever.
      I have been playing around with bufferTime but not really getting anywhere..
      Can anyone help me out?
      sub
        • 1. Re: How can I get a loading animation to play while fly playback component loads a file?
          subtlefly72 Level 1
          Here is a test with one flv player (video1) and two buttons (butt and butt1)
          Ok so I have some code that kind of works using the countdown timer... but I obviosuly dont know why it works because if I change the seconds count down from 1 to 2 it only works once.
          I get "working"
                   "working"  trace twice and it works
          After that I get the "working" trace but nothing happens    ...    I am close but would really like to understand a bit more what I am doing!
          Any help greatly appreciated.
          Cheers
          Sub
          import flash.events.MouseEvent;
          var fl_SecondsToCountDown:Number = 1;
          var fl_CountDownTimerInstance:Timer = new Timer(1000, fl_SecondsToCountDown);
          video1.visible=false;
          video1.load("film/film1.flv");
          video1.stop();
          butt.addEventListener(MouseEvent.CLICK, go);
          function go(e:MouseEvent){
                    fl_SecondsToCountDown = 1;
          fl_CountDownTimerInstance.addEventListener(TimerEvent.TIMER, fl_CountDownTimerHandler);
          fl_CountDownTimerInstance.start();
          butt1.addEventListener(MouseEvent.CLICK, go1);
          function go1(e:MouseEvent){
                    video1.load("film/film2.flv");
          function fl_CountDownTimerHandler(event:TimerEvent):void
          {trace("working");
                    fl_SecondsToCountDown--;
                    if(fl_SecondsToCountDown==0){
                              trace("done");
                              playmovie();
                              fl_CountDownTimerInstance.removeEventListener(TimerEvent.TIMER, fl_CountDownTimerHandler);
          function playmovie(){
                    video1.visible=true;
                    video1.play();
          • 2. Re: How can I get a loading animation to play while fly playback component loads a file?
            subtlefly72 Level 1
            Hi team I think I worked out my code here...
            I needed to use the "new" for each timer event to reset a new one each time..
            BUT even though this workaround kind of works, if anyone can actually give me some code that would hide a loading animation once a FLV player knows the film it is playing is loaded .. that would be golden.
            Cheers
            sub
