2 Replies Latest reply on Oct 5, 2012 4:29 AM by jason@micrographix.co.uk
    Select ungrouped items, change opacity and save
      Hi, I am a javascript beginner trying to create a script to do the following to several . ai files, one at a time:
      1. open document
      2. select all items
      3. change opacity to 40%
      4. select all grouped items
      5. change opacity to 100%
      6. save and close
      This is what I have so far which I know only affects the opacity of one layer, but if anybody has any tips for what I can do next, it would be greatly appreciated.
      for ( i = 0; i < app.documents.length; i++ ) {
          var targetDocument = app.documents[i];
          var layerCount = targetDocument.layers.length;
              for (var ii = layerCount - 1; ii >= 0; ii-- ) {
                  targetLayer = targetDocument.layers[ii];
                  var layerName = new String( targetLayer.name );
                      if ( layerName.indexOf("TEST") == 0 ) {
                          targetDocument.layers[ii].opacity=40.0;
      targetDocument.close;
      targetDocument = null;
        • 1. Re: Select ungrouped items, change opacity and save
          Muppet Mark Level 5
          You don't select in script but does this do what you meant?
          #target illustrator
          setObjectOpacity()
          function setObjectOpacity() {
              var doc = app.activeDocument;
              for ( var i = 0; i < doc.pageItems.length; i++ ) {
                  doc.pageItems[i].opacity = 40; // This will do everything
              for ( var i = 0; i < doc.groupItems.length; i++ ) {
                  doc.groupItems[i].opacity = 100; // Put this back
                  for ( var j = 0; j < doc.groupItems[i].pageItems.length; j++ ) {
                      doc.groupItems[i].pageItems[j].opacity = 100; // Put these back too
          • 2. Re: Select ungrouped items, change opacity and save
            jason@micrographix.co.uk Level 1
            That is perfect Muppet Mark, thanks very much. I will enclose it in a script to open and close the documents.
            Cheers
