2 Replies Latest reply on Oct 5, 2012 2:44 AM by CaraShop
    how to rename a file based on XMP values?
    CaraShop
      I have a files with multiple IDs in the keyword field of information tab.
      I want to rename the file with the values I have in the fields.
      For example, with file1.psd:
      in keywords I have: 36607675; 36607675; 20999012; 20999013;
      I want to have 5 files at the end :
      36607675.psd
      36607675.psd
      20999012.psd
      20999013.psd
      file1.psd
      I tried to create a script by using ScriptingListener plugin, but it didn't works and the code generated is a little be hard to understand. He doesn't take care of the metadata of the other files...
      After that i tried to find some tutorials but evryone try to add XMP data, not retrieve it for use them.
      Thanks in advance for your help and best regards
        • 1. Re: how to rename a file based on XMP values?
          Paul Riggott Level 6
          This should do a folder of PSD's....
          It requires Photoshop CS4 or newer!
          #target photoshop
          app.bringToFront();
          main();
          function main(){
          var selectedFolder = Folder.selectDialog( "Please select source folder");
          if(selectedFolder == null ) return;
          var fileList = selectedFolder.getFiles("*.psd");
          for(var a in fileList){
          var Keys = getKeys( fileList[a]);
          for(var k in Keys){
              var copyName = Keys[k] + ".psd";
              fileList[a].copy(File(selectedFolder + "/" + copyName));
          function getKeys( file){
          if ( !ExternalObject.AdobeXMPScript ) ExternalObject.AdobeXMPScript = new ExternalObject('lib:AdobeXMPScript');
                  var xmpf = new XMPFile( File(file).fsName, XMPConst.UNKNOWN, XMPConst.OPEN_FOR_READ );
                  var xmp = xmpf.getXMP();
                  var arrItem=[];
              var items =  xmp.countArrayItems(XMPConst.NS_DC, "subject");
              for(var i = 1;i <= items;i++){
                  arrItem.push(xmp.getArrayItem(XMPConst.NS_DC, "subject", i));
           return arrItem;
          • 2. Re: how to rename a file based on XMP values?
            CaraShop Level 1
            Hi Paul,
            It works great thanks a lot!
            I add some condition in order to know which files are correctly processed and which are not.
            #target photoshop
            app.bringToFront();
            main();
            function main(){
                var i = 0;
            var fileList = selectedFolder.getFiles("*.eps");
            var name=fileList[a].name;
            for(var k in Keys){
                var test=Keys[k];
                var copyName = Keys[k] + ".eps";
                if (isNaN(test) == false){
                    fileList[a].copy(File(selectedFolder + "/Processed/" + copyName));
                    i=i+1;
                if (isNaN(test) == true){
                    fileList[a].copy(File(selectedFolder + "/Processed/" + name));
                    i=i+1;
                if (i>0) {
                    fileList[a].copy(File(selectedFolder + "/OK/" + name));
                if (i==0){
                    fileList[a].copy(File(selectedFolder + "/NOK/" + name));
                    var arrItem=[];
            return arrItem;
