1. Re: I have turned highlighting CSS settings from the code off and can't figure how to get it back?
Jon Fritz II Oct 4, 2012 11:11 AM (in response to Eirehotspur)Are you talking about the CSS Styles tab under Window > CSS Styles?
If so, you might need to switch the tab from All to Current.
Or are you talking about Code Hinting under Edit > Preferences > Code Hints (check the Enable code hints box)?
2. Re: I have turned highlighting CSS settings from the code off and can't figure how to get it back?
Eirehotspur Oct 4, 2012 11:21 AM (in response to Jon Fritz II)Thanks for that reply Jon...that was fast.
I have the CSS Properties set to current.
When I used to select each div the properties would show for each one....I found that a fast way of working.
When I select a different Div in the code it doesn't change the values to that div.
See how I have the div activemainnavigation selected in the code and yet the summary for selection still shows the CSS properties of the footercredits div.
3. Re: I have turned highlighting CSS settings from the code off and can't figure how to get it back?
Jon Fritz II Oct 4, 2012 11:29 AM (in response to Eirehotspur)I see what you're saying.
If this just started, and wasn't after an update (the recent Cloud update has people fuming), I would try clearing the DW cache file http://forums.adobe.com/thread/494811
If it was after the Cloud update, Adobe may have another undocumented "deprecated feature" on their hands
4. Re: I have turned highlighting CSS settings from the code off and can't figure how to get it back?
Eirehotspur Oct 4, 2012 12:27 PM (in response to Jon Fritz II)Brilliant...that done the trick Jon.....never thought of doing that.
At least I will be able to fix it when it occurs again as I am sure it will.
You just get used to working a certain way you know?
Thanks again.
