1 Reply Latest reply on Oct 9, 2012 2:32 PM by ggaarde2
    Adjust Y pos of Flash video control strip (skin)
    ggaarde2
      Hi
      I am in need to move the video control strip upwards so it clears my caption in the video shown below.
      The skin is a swf, and normally if I import a swf to to another fla as an outside source I can adjust xpos and ypos with action script.
      I am using AS2 and would think this can be controlled in the flv playback component. But I can not find out how.
      Can you help?
      Thank you on beforehand!
      ggaarde2
        • 1. Re: Adjust Y pos of Flash video control strip (skin)
          ggaarde2 Level 1
          Hi Again!
          Is there anybody out there?
          Meanwhile I have looked into creating a dublicate skin and tried to edit that.
          There is not much code for the fla. Here it is:
          // a lot of the code below is commented out.  This is because the
          // we are just setting those values to the default values anyways.
          // This gives you an idea of how little code you might have to write
          // if you did your own skin!  But we leave the commented code in
          // to give you an idea of what you would need to do if you wanted
          // to customize the skin.
          // Defaults:
          // * layout_mc.foo_mc.mc defaults to foo_mc
          // * for seek bar, layout_mc.foo_mc.handle_mc defaults to handle_mc
          // * layout_mc.foo_mc.anchorLeft defaults to true, unless anchorRight
          //   is explicitly set to true and then it defaults to false
          // * layout_mc.foo_mc.anchorRight defaults to false
          // * layout_mc.foo_mc.anchorTop defaults to false
          // * layout_mc.foo_mc.anchorBottom defaults to true, unless anchorTop
          // minimum width and height of video recommended to use this skin,
          // leave as undefined or <= 0 if there is no minimum
          layout_mc.minWidth = 155;
          layout_mc.minHeight = 60;
          // background for controls, some commented out because are defaults
          layout_mc.bg1_mc.mc = chrome_mc;
          layout_mc.bg1_mc.anchorLeft = true;
          layout_mc.bg1_mc.anchorRight = true;
          //layout_mc.bg1_mc.anchorBottom = true;
          // playpause_mc just using all defaults, so no code needed
          //layout_mc.playpause_mc.mc = playpause_mc;
          //layout_mc.playpause_mc.anchorLeft = true;
          //layout_mc.playpause_mc.anchorBottom = true;
          // volumeMute_mc just using all defaults, so no code needed
          //layout_mc.volumeMute_mc.mc = volumeMute_mc;
          layout_mc.volumeMute_mc.anchorRight = true;
          //layout_mc.volumeMute_mc.anchorBottom = true;
          // seekBar_mc using mostly defaults, but setting
          // anchorRight to true
          //layout_mc.seekBar_mc.mc = seekBar_mc;
          layout_mc.seekBar_mc.anchorLeft = true;
          layout_mc.seekBar_mc.anchorRight = true;
          //layout_mc.seekBar_mc.handle_mc = seekBarHandle_mc;
          //layout_mc.seekBar_mc.progress_mc = _parent.seekBarProgress_mc;
          // bufferingBar_mc using mostly defaults, but setting both anchorLeft
          // and anchorRight to true and setting fill_mc
          //layout_mc.bufferingBar_mc.mc = bufferingBar_mc;
          layout_mc.bufferingBar_mc.anchorLeft = true;
          layout_mc.bufferingBar_mc.anchorRight = true;
          //layout_mc.bufferingBar_mc.fill_mc = _parent.bufferingBarFill_mc;
          I have tried to add:
          layout_mc.ypos = -100;   and layout_mc._y = -100;
          to my ClearOverPlaySeekMute_GG_1.fla
          Did not work.
          Also tried inside Fla with the flv playback component to add
          _y=-100
          That moved the whole component up.
          Then I tried to address the swf from there:
          Did not work.
          ClearOverPlaySeekMute_GG_1.swf._y = -100;
          Also did not work.
          What is it that decides the default position of the componet?
          I am out of ideas.
          ANYONE?
          kglad or Ned Murphy?
          Thanks on beforehand
          ggaarde2
