Hello Adobe -
I would love to be able to have an integrated coloring application in the CS6 suite, and feel that Speedgrade is a great "skeleton" for what it can one day be.
The two biggest things I'm running into are:
1. Lots of crashes.
2. Transitions between scenes that have been rendered in Premiere should be easily understood by Speegrade and it should have an option to default to "transition between looks" which have been applied to either end of the transition. For example:
Look A ------> Look B
Scene A -----> Scene B
That should be default.
NOT:
Look A | Look C | Look B
Scene A --------> Scene B
This is creating chaos in my workflow since needing to create a top layer look that uses keyframes to transition smoothly from scene to scene is causing constant crashing.
Is there any way to make this simple in the current version, 6.0.4?
Thanks!
Brian Nunes
Final Cut 7 Convert
