1 Reply Latest reply on Oct 5, 2012 5:49 AM by Jump_Over
    Split Column
    Pooja_IDDev Level 1
      I have text frame with one column count, split column is applied to the paragraph as paragraph layout with sub- columns equal to 2, how would i know that the paragraph is in first split column or second split column. Is there any property to check that paragraph's split column.
      Thanks in advance
      Pooja
        • 1. Re: Split Column
          Jump_Over Level 5
          Var1 = textFrame.textColumns;     gives you array with textFrame columns
          Var2 = story.paragraphs[2].textColumns[0];           gives you textColumn (begin) of 3rd paragraph of your story
          if Var2 == Var1[0]  ==> your paragraph is in 1st column
          rgds
