20 Replies Latest reply on Oct 5, 2012 1:15 PM by pixxxel schubser
    choose folder default location
    restless_mind Level 1
      I've been searching the forum to try and a way to allow a user to choose a folder from a default location. I thought I had found the solution but it's not quite working as I wanted:
      #target illustrator
      //Example 1
      var output_folder = Folder.selectDialog ('Choose PDF output folder.');
      //Example 2
      var myFolder=Folder(app.activeDocument.path).selectDlg("Choose PDF output folder:");
      If I use the code in example 1 the choose folder dialog appears and the 'Open' button is available and when I press the button the location is chosen as expected. However if I use the code in example 2, although the choose window opens in the path of the active documents location the 'Open' button is not able to be pressed until I select a folder., which means that the chosen location is not correct. I should indicate that I'm running this code on a Mac.
      Does anybody know a way to have a choose folder dialog window specify a location and be able to select that.
      Nik
